# REST Client
> Use the REST client to manage SignalWire resources programmatically.
[ref-agentbase]: /docs/server-sdks/reference/python/agents/agent-base
[ref-datasphere]: /docs/server-sdks/reference/python/rest/datasphere
### What Is the REST Client?
The `SignalWireClient` provides a synchronous Python interface to all SignalWire REST APIs. It organizes the platform's HTTP endpoints into namespaced resource objects with standard CRUD operations.
#### When to Use REST vs Relay vs Agents
| Approach                              | Best For                                                    |
| **[AgentBase][ref-agentbase]** (SWML) | AI-driven voice agents                                      |
| **Relay Client**                      | Real-time call control over WebSocket                       |
| **REST Client**                       | Resource management, provisioning, log queries, admin tasks |
Use the REST client for tasks like purchasing phone numbers, managing fabric resources, querying call logs, or any operation that doesn't require real-time event handling.
### Quick Start
#### Python
#!/usr/bin/env python3
"""REST client quick start."""
from signalwire.rest import SignalWireClient
client = SignalWireClient(
    project="your-project-id",
    token="your-api-token",
    host="your-space.signalwire.com",
# List AI agents in your fabric
agents = client.fabric.ai_agents.list()
print(agents)
# Search for available phone numbers
available = client.phone_numbers.search(area_code="512")
print(available)
#### TypeScript
```typescript
import { RestClient } from '@signalwire/sdk';
  project: 'your-project-id',
  token: 'your-api-token',
  host: 'your-space.signalwire.com',
// List AI agents
const agents = await client.fabric.aiAgents.list();
console.log(agents);
// Search for available phone numbers
const available = await client.phoneNumbers.search({ areaCode: '512' });
console.log(available);
### Authentication
#### Constructor Arguments
| Language   | Syntax                                                          |
| Python     | `SignalWireClient(project="...", token="...", host="...")`      |
| TypeScript | `new RestClient({ project: '...', token: '...', host: '...' })` |
#### Environment Variables
All credentials can be provided via environment variables:
| Variable                | Purpose        |
| `SIGNALWIRE_PROJECT_ID` | Project ID     |
| `SIGNALWIRE_API_TOKEN`  | API token      |
| `SIGNALWIRE_SPACE`      | Space hostname |
# With env vars set, no arguments needed
client = SignalWireClient()
### Namespaced Resources
The client exposes all SignalWire APIs through typed namespace properties:
client.fabric          # AI agents, SWML scripts, subscribers, call flows
client.calling         # REST-based call control (37 commands)
client.phone_numbers   # Search, purchase, manage numbers
client.video           # Rooms, sessions, recordings, conferences
client.datasphere      # Document management and semantic search
client.compat          # Twilio-compatible LAML API
client.logs            # Message, voice, fax, conference logs
client.registry        # 10DLC brand/campaign management
client.queues          # Call queue management
client.recordings      # Recording management
client.project         # Project-level token management
client.mfa             # Multi-factor authentication
client.lookup          # Phone number carrier/CNAM lookup
client.pubsub          # PubSub token management
client.chat            # Chat token management
### CRUD Pattern
Most resources follow a standard CRUD pattern:
| Operation | Python                                           |
| List      | `client.phone_numbers.list()`                    |
| Create    | `client.fabric.ai_agents.create(name="x")`       |
| Get       | `client.fabric.ai_agents.get("id")`              |
| Update    | `client.fabric.ai_agents.update("id", name="y")` |
| Delete    | `client.fabric.ai_agents.delete("id")`           |
# List resources
result = client.phone_numbers.list(page_size=10)
# Create a resource
new = client.fabric.ai_agents.create(name="my-agent", type="ai_agent")
# Get a single resource
agent = client.fabric.ai_agents.get("resource-id")
# Update a resource
client.fabric.ai_agents.update("resource-id", name="updated-name")
# Delete a resource
client.fabric.ai_agents.delete("resource-id")
### Fabric Namespace
Manage SignalWire Fabric resources -- AI agents, SWML scripts, [subscribers](/docs/platform/subscribers), and call flows:
# AI agents
agent = client.fabric.ai_agents.create(name="support-bot", type="ai_agent")
# SWML scripts
scripts = client.fabric.swml_scripts.list()
# SWML webhooks
webhooks = client.fabric.swml_webhooks.list()
# Subscribers
subs = client.fabric.subscribers.list()
# Subscriber SIP endpoints
endpoints = client.fabric.subscribers.list_sip_endpoints("subscriber-id")
client.fabric.subscribers.create_sip_endpoint("subscriber-id", username="ext100")
# Call flows with versioning
flows = client.fabric.call_flows.list()
versions = client.fabric.call_flows.list_versions("flow-id")
client.fabric.call_flows.deploy_version("flow-id", version_id="v2")
# Tokens (subscriber, guest, invite, embed)
token = client.fabric.tokens.create_subscriber_token(subscriber_id="sub-id")
guest = client.fabric.tokens.create_guest_token(name="Guest User")
### Phone Numbers
Search, purchase, and manage phone numbers:
# Search for available numbers
    area_code="512",
    quantity=5,
# List your numbers
numbers = client.phone_numbers.list()
# Get a specific number
number = client.phone_numbers.get("number-id")
# Update number configuration
client.phone_numbers.update("number-id", name="Support Line")
### Calling Namespace
REST-based call control with 37+ commands. All commands are dispatched via POST:
# Initiate a call
result = client.calling.dial(
    call_id="call-id",
    devices=[[{"type": "phone", "params": {"to_number": "+15559876543"}}]],
# Play audio on a call
client.calling.play(call_id="call-id", play=[
    {"type": "tts", "text": "Hello from REST!"}
# Record a call
client.calling.record(call_id="call-id", record={"audio": {}})
# Control playback
client.calling.play_pause(call_id="call-id", control_id="ctrl-id")
client.calling.play_resume(call_id="call-id", control_id="ctrl-id")
client.calling.play_stop(call_id="call-id", control_id="ctrl-id")
# AI commands
client.calling.ai_message(call_id="call-id", message_text="New instruction")
client.calling.ai_hold(call_id="call-id")
client.calling.ai_unhold(call_id="call-id")
# End a call
client.calling.end(call_id="call-id", reason="hangup")
### Video Namespace
Manage video rooms, conferences, sessions, and recordings:
# Create a video room
room = client.video.rooms.create(name="standup", max_participants=10)
# List room sessions
sessions = client.video.room_sessions.list()
# Get session members
members = client.video.room_sessions.list_members("session-id")
# Manage conferences
conf = client.video.conferences.create(name="team-conf")
client.video.conferences.list_streams("conference-id")
### [Datasphere][ref-datasphere] Namespace
Manage documents and run semantic search:
# List documents
docs = client.datasphere.documents.list()
# Upload a document
doc = client.datasphere.documents.create(
    name="FAQ",
    content="Your FAQ content here...",
# Semantic search
results = client.datasphere.documents.search(
    query_string="How do I reset my password?",
    count=5,
# Manage chunks
chunks = client.datasphere.documents.list_chunks("document-id")
client.datasphere.documents.delete_chunk("document-id", "chunk-id")
### Logs Namespace
Query message, voice, fax, and conference logs:
# Voice call logs
calls = client.logs.voice.list(page_size=20)
call = client.logs.voice.get("log-id")
events = client.logs.voice.list_events("log-id")
# Message logs
messages = client.logs.messages.list()
# Fax logs
faxes = client.logs.fax.list()
# Conference logs
confs = client.logs.conferences.list()
### Registry Namespace (10DLC)
Manage 10DLC brands and campaigns for A2P messaging compliance:
# List brands
brands = client.registry.brands.list()
# Create a brand
brand = client.registry.brands.create(
    entity_type="PRIVATE_PROFIT",
    display_name="My Company",
# Create a campaign under a brand
campaign = client.registry.brands.create_campaign(
    "brand-id",
    description="Customer notifications",
    usecase="MIXED",
# Assign numbers to campaigns
order = client.registry.campaigns.create_order(
    "campaign-id",
    phone_number_ids=["number-id-1"],
### Compatibility (LAML) Namespace
Twilio-compatible REST API for migrating existing applications:
# List calls
calls = client.compat.calls.list()
# Send an SMS
msg = client.compat.messages.create(
    To="+15559876543",
    From="+15551234567",
    Body="Hello from SignalWire!",
# Manage phone numbers
numbers = client.compat.phone_numbers.list()
# Start call recording
client.compat.calls.start_recording("call-sid")
### Other Resources
# Queue management
queues = client.queues.list()
members = client.queues.list_members("queue-id")
next_member = client.queues.get_next_member("queue-id")
# Recordings
recordings = client.recordings.list()
# Phone number lookup
info = client.lookup.phone_number("+15551234567")
client.mfa.sms(to="+15551234567", from_="+15550000000", message="Your code: {code}")
client.mfa.verify(request_id="req-id", token="123456")
# SIP profile
profile = client.sip_profile.get()
client.sip_profile.update(username="my-sip-user")
# Verified caller IDs
callers = client.verified_callers.list()
### Pagination
For endpoints that return paginated results, use `PaginatedIterator`:
from signalwire.rest._pagination import PaginatedIterator
# Iterate all phone numbers across pages
for number in PaginatedIterator(
    client._http,
    "/api/relay/rest/phone_numbers",
    data_key="data",
    print(number["name"], number["number"])
The iterator automatically follows `links.next` URLs to fetch subsequent pages.
### Error Handling
REST errors raise `SignalWireRestError`:
from signalwire.rest import SignalWireClient, SignalWireRestError
try:
    client.phone_numbers.get("nonexistent-id")
except SignalWireRestError as e:
    print(f"HTTP {e.status_code}: {e.body}")
    print(f"URL: {e.method} {e.url}")
### Practical Example: Provision and Configure
"""Provision a phone number and assign it to an AI agent."""
# Search for a local number
available = client.phone_numbers.search(area_code="512", quantity=1)
numbers = available.get("data", [])
if not numbers:
    print("No numbers available")
    exit(1)
# Purchase the first available number
number_id = numbers[0]["id"]
print(f"Purchasing: {numbers[0].get('number', number_id)}")
# List AI agents
agent_list = agents.get("data", [])
if agent_list:
    agent_id = agent_list[0]["id"]
    print(f"Found agent: {agent_list[0].get('name', agent_id)}")
# Query recent call logs
logs = client.logs.voice.list(page_size=5)
for log in logs.get("data", []):
    print(f"  Call: {log.get('from')} -> {log.get('to')} ({log.get('status')})")
