# Native Functions
> Native functions are built-in SignalWire capabilities that can be enabled without writing code, providing common operations like web search and debugging.
[skills]: /docs/server-sdks/guides/understanding-skills
### What Are Native Functions?
Native functions run directly on SignalWire's platform. Enable them to give the AI access to built-in capabilities without creating handlers.
| Handler Function    | Native Function     |
| You define handler  | SignalWire provides |
| Runs on your server | Runs on SignalWire  |
| Custom logic        | Pre-built behavior  |
**Available Native Functions:**
* `web_search` - Search the web
* `debug` - Debug mode for testing
### Enabling Native Functions
Enable native functions in the constructor. The syntax varies by language:
| Language   | Syntax        |
| Python     | `AgentBase(name="my-agent", native_functions=["web_search"])`          |
| TypeScript | `new AgentBase({ name: 'my-agent', nativeFunctions: ['web_search'] })` |
class MyAgent(AgentBase):
        super().__init__(
            name="my-agent",
            native_functions=["web_search"]  # Enable web search
### Web Search Function
Enable web search to let the AI autonomously search the web during conversations:
class ResearchAgent(AgentBase):
        super().__init__(
            name="research-agent",
        self.prompt_add_section(
            "Role",
            "You are a research assistant. Search the web to answer questions."
#### How Web Search Works
When enabled, the AI can decide to search the web when it needs information to answer a question. The process is:
1. **AI decides to search**: Based on the conversation, the AI determines a search is needed
2. **Query formulation**: The AI creates a search query from the conversation context
3. **Search execution**: SignalWire executes the search on the AI's behalf
4. **Results processing**: Search results are returned to the AI as context
5. **Response generation**: The AI synthesizes the results into a spoken response
The caller doesn't interact with search directly -- the AI handles everything automatically.
#### What Web Search Returns
The AI receives search results including:
* Page titles and snippets
* URLs of matching pages
* Relevant text excerpts
The AI then summarizes and presents this information conversationally. It doesn't read URLs or raw HTML to the caller.
#### Web Search Limitations
**No control over search behavior:**
* Cannot specify search engine (Google, Bing, etc.)
* Cannot filter by domain or site
* Cannot control result count
* Cannot exclude specific sources
**Content limitations:**
* Results may be outdated (search index lag)
* Cannot access paywalled or login-required content
* Cannot search private/internal sites
* May not find very recent information
**No result logging:**
* Search queries aren't logged to your server
* Cannot audit what was searched
* Cannot cache results for reuse
**Rate and cost:**
* Subject to SignalWire's rate limits
* May incur additional usage costs
* Multiple searches per call add latency
#### When to Use Native web\_search
**Good use cases:**
* General knowledge questions ("What year was the Eiffel Tower built?")
* Current events (with freshness caveats)
* Quick fact lookups during calls
* Agents that need broad knowledge access
**When to use alternatives instead:**
| Need                     | Alternative                             |
| Specific search engine   | `web_search` skill with Google API      |
| Domain-restricted search | Custom handler with filtered API        |
| Result logging/auditing  | Custom handler with logging             |
| Cached results           | Custom handler with caching layer       |
| Internal/private content | Custom handler with your search backend |
#### Prompting for Web Search
Guide the AI on when and how to use web search:
    "Search Guidelines",
    Use web search when:
    - Asked about current events or recent information
    - Need to verify facts you're uncertain about
    - Question is outside your core knowledge
    Don't search for:
    - Information already in your prompt
    - Customer-specific data (use account functions instead)
    - Simple calculations or conversions
### Debug Function
Enable debug mode for development and testing:
class DebugAgent(AgentBase):
        super().__init__(
            name="debug-agent",
            native_functions=["debug"]
#### What Debug Provides
The debug function exposes diagnostic information during calls:
* Current conversation state
* Function call history
* Configuration details
* Timing information
#### When to Use Debug
**Use during development:**
* Testing conversation flows
* Verifying function registration
* Checking prompt configuration
* Troubleshooting unexpected behavior
**Don't use in production:**
* Exposes internal details to callers
* May reveal sensitive configuration
* Adds unnecessary function to AI's options
* Remove before deploying to production
### Call Transfers
For call transfers, use `FunctionResult.connect()` in a custom handler function - there is no native transfer function:
class TransferAgent(AgentBase):
    DEPARTMENTS = {
        "sales": "+15551111111",
        "support": "+15552222222",
        "billing": "+15553333333"
        super().__init__(name="transfer-agent")
            "Role",
            "You are a receptionist. Transfer callers to the appropriate department."
        self.define_tool(
            name="transfer_call",
            description="Transfer the call to a department",
            parameters={
                "type": "object",
                "properties": {
                    "department": {
                        "type": "string",
                        "description": "Department to transfer to",
                        "enum": ["sales", "support", "billing"]
                "required": ["department"]
            handler=self.transfer_call
    def transfer_call(self, args, raw_data):
        department = args.get("department")
        number = self.DEPARTMENTS.get(department)
        if not number:
            return FunctionResult("Invalid department")
        return (
            FunctionResult(f"Transferring you to {department}")
            .connect(number, final=True)
### Combining Native and Custom Functions
The examples below use Python. The pattern of passing `native_functions` in the constructor and adding `define_tool()` calls works identically in all SDK languages using the syntax shown in the table above.
Use native functions alongside your custom handlers:
class HybridAgent(AgentBase):
        super().__init__(
            name="hybrid-agent",
            native_functions=["web_search"]  # Native
        # Custom function alongside native ones
        self.define_tool(
            name="check_account",
            description="Look up customer account information",
            parameters={
                "type": "object",
                "properties": {
                    "account_id": {
                        "type": "string",
                        "description": "Account ID"
                "required": ["account_id"]
            handler=self.check_account
            "Role",
            "You are a customer service agent. "
            "You can check accounts and search the web for information."
    def check_account(self, args, raw_data):
        account_id = args.get("account_id")
        return FunctionResult(f"Account {account_id} is active")
### When to Use Native vs Custom Functions
| Scenario                 | Recommendation                                 |
| Web search capability    | Use `web_search` native function               |
| Development testing      | Use `debug` native function                    |
| Transfer to phone number | Use FunctionResult.connect() in custom handler |
| Transfer to SIP address  | Use FunctionResult.connect() in custom handler |
| Custom business logic    | Use define\_tool() with handler                |
| Database lookups         | Use define\_tool() with handler                |
### Native Functions Reference
| Function     | Description       | Use Case                 |
| `web_search` | Search the web    | Answer general questions |
| `debug`      | Debug information | Development/testing      |
### Next Steps
You've now learned all about SWAIG functions. Next, explore [Skills][skills] to add pre-built capabilities to your agents.
