# Multi-Agent Servers
> Run multiple agents on a single server using AgentServer with path-based routing and SIP username mapping.
[ref-agentserver]: /docs/server-sdks/reference/python/agents/agent-server
Multi-agent servers let you run several specialized agents from a single process. This simplifies deployment, reduces resource overhead, and provides unified management. Instead of running separate processes for sales, support, and billing agents, you run one server that routes requests to the appropriate agent.
This architecture is especially useful when you have related agents that share infrastructure but have different personas and capabilities.
### Single Agent vs Multi-Agent: Decision Guide
Choosing between `agent.run()` and [`AgentServer`][ref-agentserver] depends on your deployment needs.
**Use single agent (`agent.run()`) when:**
* You have one agent with a single purpose
* You want the simplest possible deployment
* Each agent needs isolated resources (memory, CPU)
* Agents have very different scaling requirements
* You're using container orchestration that handles multi-instance deployment
**Use AgentServer when:**
* You have multiple related agents (sales, support, billing)
* Agents share the same deployment environment
* You want unified health monitoring
* SIP routing determines which agent handles a call
* You want to reduce operational overhead of managing multiple processes
* Agents share common code or resources
| Single Agent (`agent.run()`) | AgentServer                  |
| One agent per process        | Multiple agents per process  |
| Simple deployment            | Shared resources             |
| Separate ports per agent     | Single port, multiple routes |
| Independent scaling          | Shared scaling               |
| Isolated failures            | Unified monitoring           |
|                              | SIP username routing         |
|                              | Unified health checks        |
### Basic AgentServer
#### Python
from signalwire import AgentBase, AgentServer
class SalesAgent(AgentBase):
        super().__init__(name="sales-agent")
        self.prompt_add_section("Role", "You are a sales representative.")
        super().__init__(name="support-agent")
        self.prompt_add_section("Role", "You are a support specialist.")
    server = AgentServer(host="0.0.0.0", port=3000)
    server.register(SupportAgent(), "/support")
    server.run()
#### TypeScript
```typescript
import { AgentBase, AgentServer } from '@signalwire/sdk';
const sales = new AgentBase({ name: 'sales-agent' });
sales.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
sales.promptAddSection('Role', { body: 'You are a sales representative.' });
const support = new AgentBase({ name: 'support-agent' });
support.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
support.promptAddSection('Role', { body: 'You are a support specialist.' });
const server = new AgentServer({ port: 3000 });
server.register(sales, '/sales');
server.register(support, '/support');
server.run();
Agents are available at:
| Endpoint                        | Description           |
| `http://localhost:3000/sales`   | Sales agent           |
| `http://localhost:3000/support` | Support agent         |
| `http://localhost:3000/health`  | Built-in health check |
### AgentServer Configuration
    host="0.0.0.0",     # Bind address
    port=3000,          # Listen port
    log_level="info"    # debug, info, warning, error, critical
### Registering Agents
#### With Explicit Route
#### Using Agent's Default Route
class BillingAgent(AgentBase):
        super().__init__(
            name="billing-agent",
            route="/billing"  # Default route
server.register(BillingAgent())  # Uses "/billing"
### Server Architecture
```mermaid
flowchart TD
    server["AgentServer<br />FastAPI application"] --> sales["/sales<br />Sales Agent"]
    server --> support["/support<br />Support Agent"]
    server --> billing["/billing<br />Billing Agent"]
    sales & support & billing --> routes["Each agent exposes:<br />GET or POST /route for SWML<br />POST /route/swaig for functions<br />POST /route/post_prompt for post-prompt handling"]
### Managing Agents
#### Get All Agents
agents = server.get_agents()
for route, agent in agents:
    print(f"{route}: {agent.get_name()}")
#### Get Specific Agent
sales_agent = server.get_agent("/sales")
#### Unregister Agent
server.unregister("/sales")
### SIP Routing
Route SIP calls to specific agents based on username:
    server = AgentServer()
    # Enable SIP routing
    server.setup_sip_routing("/sip", auto_map=True)
    # Manual SIP username mapping
    server.register_sip_username("sales-team", "/sales")
    server.register_sip_username("help-desk", "/support")
    server.run()
When `auto_map=True`, the server automatically creates mappings:
* Agent name to route (e.g., "salesagent" to "/sales")
* Route path to route (e.g., "sales" to "/sales")
### SIP Routing Flow
```mermaid
flowchart TD
    call["SIP call to sip:sales-team@example.com"] --> endpoint["POST /sip routing endpoint"]
    endpoint --> username["Extract username: sales-team"]
    username --> route["Look up route: /sales"]
    route --> swml["Return SWML from Sales Agent"]
### Health Check Endpoint
AgentServer provides a built-in health check:
```bash
curl http://localhost:3000/health
Response:
```json
    "status": "ok",
    "agents": 2,
    "routes": ["/sales", "/support"]
### Serverless Deployment
AgentServer supports serverless environments automatically:
class MyAgent(AgentBase):
server.register(MyAgent(), "/agent")
## AWS Lambda handler
def lambda_handler(event, context):
    return server.run(event, context)
## CGI mode (auto-detected)
    server.run()
### Complete Example
#!/usr/bin/env python3
## multi_agent_server.py - Server with multiple specialized agents
            "Role",
            "You are a sales representative for Acme Corp."
        self.define_tool(
            name="get_pricing",
            description="Get product pricing",
            parameters={
                "type": "object",
                "properties": {
                    "product": {"type": "string", "description": "Product name"}
                "required": ["product"]
            handler=self.get_pricing
    def get_pricing(self, args, raw_data):
        product = args.get("product", "")
        return FunctionResult(f"The price for {product} is $99.99")
            "Role",
            "You are a technical support specialist."
        self.define_tool(
            name="create_ticket",
            description="Create a support ticket",
            parameters={
                "type": "object",
                "properties": {
                    "issue": {"type": "string", "description": "Issue description"}
                "required": ["issue"]
            handler=self.create_ticket
    def create_ticket(self, args, raw_data):
        issue = args.get("issue", "")
        return FunctionResult(f"Created ticket #12345 for: {issue}")
        super().__init__(name="billing-agent")
            "Role",
            "You help customers with billing questions."
    # Create server
    # Register agents
    server.register(BillingAgent(), "/billing")
    # Custom SIP mappings
    server.register_sip_username("sales", "/sales")
    server.register_sip_username("help", "/support")
    server.register_sip_username("accounts", "/billing")
    print("Agents available:")
    for route, agent in server.get_agents():
        print(f"  {route}: {agent.get_name()}")
    server.run()
### AgentServer Methods Summary
| Method                                   | Purpose                      |
| `register(agent, route)`                 | Register an agent at a route |
| `unregister(route)`                      | Remove an agent              |
| `get_agents()`                           | Get all registered agents    |
| `get_agent(route)`                       | Get agent by route           |
| `setup_sip_routing(route, auto_map)`     | Enable SIP-based routing     |
| `register_sip_username(username, route)` | Map SIP username to route    |
| `run()`                                  | Start the server             |
### Performance Considerations
Running multiple agents in a single process has implications:
**Memory**: Each agent maintains its own state, but they share the Python interpreter. For most deployments, this reduces overall memory compared to separate processes.
**CPU**: Agents share CPU resources. A heavy-load agent can affect others. Monitor and adjust if needed.
**Startup time**: All agents initialize when the server starts. More agents = longer startup.
**Isolation**: A crash in one agent's handler can affect the entire server. Implement proper error handling in your handlers.
**Scaling**: You scale the entire server, not individual agents. If one agent needs more capacity, you scale everything. For very different scaling needs, consider separate deployments.
### Shared State Between Agents
Agents in an AgentServer are independent instances -- they don't share state by default. Each agent has its own prompts, functions, and configuration.
**If you need shared state:**
Use external storage (Redis, database) rather than Python globals:
import redis
class SharedStateAgent(AgentBase):
    def __init__(self, redis_client):
        super().__init__(name="shared-state-agent")
        self.redis = redis_client
        # ... setup
    def some_handler(self, args, raw_data):
        # Read shared state
        shared_value = self.redis.get("shared_key")
        # Update shared state
        self.redis.set("shared_key", "new_value")
        return FunctionResult("Done")
# In main
redis_client = redis.Redis(host='localhost', port=6379)
server.register(SharedStateAgent(redis_client), "/agent1")
server.register(AnotherAgent(redis_client), "/agent2")
**Sharing configuration:**
For shared configuration like API keys or business rules, use a shared module:
# config.py
SHARED_CONFIG = {
    "company_name": "Acme Corp",
    "support_hours": "9 AM - 5 PM",
    "api_key": os.environ.get("API_KEY")
# agents.py
from config import SHARED_CONFIG
            "Company",
            f"You work for {SHARED_CONFIG['company_name']}"
### Routing Logic
AgentServer routes requests based on URL path and SIP username. Understanding this routing helps you design your agent structure.
**Path-based routing** is straightforward:
* Request to `/sales` routes to the Sales agent
* Request to `/support` routes to the Support agent
**SIP routing** extracts the username from the SIP address:
* `sip:sales@example.com` looks up "sales" and routes to `/sales`
* `sip:help-desk@example.com` looks up "help-desk" and routes based on mapping
**Auto-mapping** creates automatic mappings from agent names and route paths:
# Creates mappings like:
# "salesagent" -> "/sales" (from agent name, normalized)
# "sales" -> "/sales" (from route path without leading /)
**Manual mapping** gives explicit control:
server.register_sip_username("tech-support", "/support")
### Common Patterns
#### Department-Based Routing
server.register(ReceptionistAgent(), "/main")  # Default/main line
#### Time-Based Routing
class TimeSensitiveServer:
        self.server = AgentServer()
        self.server.register(LiveAgent(), "/live")
        self.server.register(AfterHoursAgent(), "/afterhours")
    def get_current_agent_route(self):
        from datetime import datetime
        hour = datetime.now().hour
        if 9 <= hour < 17:  # Business hours
            return "/live"
        return "/afterhours"
#### Feature-Based Agents
server.register(GeneralAgent(), "/general")        # Basic Q&A
server.register(OrderAgent(), "/orders")           # Order management
server.register(TechnicalAgent(), "/technical")    # Technical support
server.register(EscalationAgent(), "/escalation")  # Human escalation
### Best Practices
**DO:**
* Use meaningful route names (/sales, /support, /billing)
* Enable SIP routing for SIP-based deployments
* Monitor /health endpoint for availability
* Use consistent naming between routes and SIP usernames
* Implement proper error handling in all agent handlers
* Use external storage for shared state
* Log which agent handles each request for debugging
**DON'T:**
* Register duplicate routes
* Forget to handle routing conflicts
* Mix agent.run() and AgentServer for the same agent
* Store shared state in Python globals (use external storage)
* Put agents with very different scaling needs in the same server
