# Local Development
> Run and test SignalWire SDK agents locally during development with hot reloading, tunneling, and debug tools.
[ref-agentserver]: /docs/server-sdks/reference/python/agents/agent-server
## Server configuration
### Custom host and port
| Language   | Custom Host and Port                         |
| Python     | `agent.run(host="0.0.0.0", port=8080)`       |
| TypeScript | `agent.run({ host: "0.0.0.0", port: 8080 })` |
### Using serve() directly (Python)
For more control, use `serve()` instead of `run()`:
# Development server
agent.serve(host="127.0.0.1", port=3000)
# Listen on all interfaces
agent.serve(host="0.0.0.0", port=3000)
## Development endpoints
| Endpoint        | Method   | Purpose                                                         |
| `/`             | GET/POST | SWML document                                                   |
| `/swaig`        | POST     | SWAIG function calls                                            |
| `/post_prompt`  | POST     | Post-prompt handling                                            |
| `/debug`        | GET/POST | Debug information                                               |
| `/debug_events` | POST     | Real-time debug events (when `enable_debug_events()` is active) |
| `/health`       | GET      | Health check ([AgentServer][ref-agentserver] only)              |
## Testing your agent
### View SWML output
```bash
# Get the SWML document (use credentials from agent startup output or env vars)
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" http://localhost:3000/
# Pretty print with jq
curl -u "$SWML_BASIC_AUTH_USER:$SWML_BASIC_AUTH_PASSWORD" http://localhost:3000/ | jq .
### Using swaig-test CLI
```bash
# List available functions
swaig-test my_agent.py --list-tools
# Test a specific function
swaig-test my_agent.py --exec get_weather --city "Seattle"
# Dump SWML output
## Exposing local server
SignalWire needs to reach your agent via a public URL. Use ngrok or similar:
**Connection Flow:** SignalWire Cloud --> ngrok tunnel --> localhost:3000
**Steps:**
1. Start your agent (see run command table above)
2. Start ngrok: `ngrok http 3000`
3. Use ngrok URL in SignalWire: `https://abc123.ngrok.io`
### Using ngrok
```bash
# Start your agent (example with Python; substitute your language's run command)
python my_agent.py
# In another terminal, start ngrok
ngrok http 3000
ngrok provides a public URL like `https://abc123.ngrok.io` that forwards to your local server.
### Using localtunnel
```bash
# Install
npm install -g localtunnel
# Start tunnel
lt --port 3000
## Environment variables for development
These environment variables work across all SDK languages:
| Variable                   | Purpose                   | Default        |
| `SWML_BASIC_AUTH_PASSWORD` | Auth password             | Auto-generated |
| `SWML_BASIC_AUTH_USER`     | Auth username             | `signalwire`   |
| `SWML_PROXY_URL_BASE`      | Public URL (behind proxy) | Auto-detected  |
| `SWML_ALLOW_PRIVATE_URLS`  | Allow private IP requests | `false`        |
```bash
# Authentication (username defaults to 'signalwire' when not set)
# Only the password is required; omit both to disable auth for local testing
export SWML_BASIC_AUTH_PASSWORD="test123"
# Or disable authentication entirely for local testing
export SWML_BASIC_AUTH_USER=""
export SWML_BASIC_AUTH_PASSWORD=""
# Override proxy URL if behind ngrok
export SWML_PROXY_URL_BASE="https://abc123.ngrok.io"
# APP_URL is also accepted as a fallback (useful for Dokku deployments)
# Allow DataMap/skill requests to private IPs (e.g., local backend services)
export SWML_ALLOW_PRIVATE_URLS=true
## Proxy URL configuration
When behind ngrok or another proxy, the SDK needs to know the public URL:
import os
# Option 1: Environment variable
os.environ['SWML_PROXY_URL_BASE'] = 'https://abc123.ngrok.io'
# Option 2: Auto-detection from X-Forwarded headers
# The SDK automatically detects proxy from request headers
## Development workflow
**1. Code**
Write/modify your agent code.
**2. Test Locally**
* `swaig-test my_agent.py --dump-swml`
* `swaig-test my_agent.py --exec function_name --param value`
**3. Run Server**
`python my_agent.py` (or your language's equivalent run command)
**4. Expose Publicly**
`ngrok http 3000`
**5. Test with SignalWire**
Point phone number to ngrok URL and make test call.
## Debug mode
Enable debug logging:
import logging
logging.basicConfig(level=logging.DEBUG)
agent = MyAgent()
Or via environment variable:
```bash
export SIGNALWIRE_LOG_MODE=default
python my_agent.py
## Hot reloading
For automatic reloading during development, use uvicorn directly:
```bash
# Install uvicorn with reload support
pip install "uvicorn[standard]"
# Run with auto-reload
uvicorn my_agent:agent._app --reload --host 0.0.0.0 --port 3000
Or create a development script:
# dev.py
from my_agent import MyAgent
agent = MyAgent()
app = agent._app  # Expose the ASGI app for uvicorn
Then run:
```bash
uvicorn dev:app --reload --port 3000
## Serving static files
Use `AgentServer.serve_static_files()` to serve static files alongside your agents. This is useful for web dashboards, documentation, or any static content:
from signalwire import AgentServer
from pathlib import Path
# Create your agents
from my_agents import SupportAgent, SalesAgent
HOST = "0.0.0.0"
PORT = 3000
server = AgentServer(host=HOST, port=PORT)
server.register(SupportAgent(), "/support")
# Serve static files from web directory
web_dir = Path(__file__).parent / "web"
if web_dir.exists():
    server.serve_static_files(str(web_dir))
server.run()
**Directory Structure:**
```text
my_project/
├── server.py
├── my_agents.py
└── web/
    ├── index.html
    ├── styles.css
    └── app.js
**Key Points:**
* Use `server.serve_static_files(directory)` to serve static files
* Agent routes always take priority over static files
* Requests to `/` serve `index.html` from the static directory
* Both `/support` and `/support/` work correctly with agents
**Route Priority:**
| Route      | Handler                  |
| `/support` | SupportAgent             |
| `/sales`   | SalesAgent               |
| `/health`  | AgentServer health check |
| `/*`       | Static files (fallback)  |
## Common development issues
| Issue                  | Solution                                     |
| Port already in use    | Use different port: `agent.run(port=8080)`   |
| 401 Unauthorized       | Check `SWML_BASIC_AUTH_*` env vars           |
| Functions not found    | Verify function registration                 |
| SWML URL wrong         | Set `SWML_PROXY_URL_BASE` for ngrok          |
| Connection refused     | Ensure agent is running on correct port      |
| Static files not found | Check `web_dir.exists()` and path is correct |
