# Docker & Kubernetes
> Containerize your agents with Docker and deploy to Kubernetes for scalable, manageable production deployments.
## Dockerfile
Each language has a different Dockerfile. Choose the one matching your SDK language.
#### Python
```dockerfile
FROM python:3.11-slim
WORKDIR /app
## Install dependencies
COPY requirements.txt .
RUN pip install --no-cache-dir -r requirements.txt
## Copy application
COPY . .
## Create non-root user
RUN useradd -m appuser && chown -R appuser:appuser /app
USER appuser
## Expose port
EXPOSE 3000
## Run with uvicorn
CMD ["uvicorn", "app:app", "--host", "0.0.0.0", "--port", "3000", "--workers", "4"]
#### TypeScript
```dockerfile
FROM node:20-slim
WORKDIR /app
## Install dependencies (package.json must include "type": "module" — @signalwire/sdk is ESM-only)
COPY package*.json ./
RUN npm ci --only=production
## Copy application
COPY . .
## Build TypeScript to dist/
RUN npm run build
RUN groupadd -r appuser && useradd -r -g appuser appuser && chown -R appuser:appuser /app
USER appuser
EXPOSE 3000
CMD ["node", "dist/app.js"]
## Application entry point (Python)
## app.py
class MyAgent(AgentBase):
agent = MyAgent()
app = agent._app
## Building and running
```bash
## Build image
docker build -t signalwire-agent .
## Run container
docker run -d \
  -p 3000:3000 \
  -e SWML_BASIC_AUTH_USER=myuser \
  -e SWML_BASIC_AUTH_PASSWORD=mypassword \
  --name agent \
  signalwire-agent
## View logs
docker logs -f agent
## Stop container
docker stop agent
## Docker Compose
```yaml
## docker-compose.yml
version: '3.8'
services:
  agent:
    build: .
    ports:
      - "3000:3000"
    environment:
      - SWML_BASIC_AUTH_USER=${SWML_BASIC_AUTH_USER}
      - SWML_BASIC_AUTH_PASSWORD=${SWML_BASIC_AUTH_PASSWORD}
      - SWML_PROXY_URL_BASE=${SWML_PROXY_URL_BASE}
    restart: unless-stopped
    healthcheck:
      test: ["CMD", "curl", "-f", "http://localhost:3000/health"]
      interval: 30s
      timeout: 10s
      retries: 3
  nginx:
    image: nginx:alpine
    ports:
      - "443:443"
      - "80:80"
    volumes:
      - ./nginx.conf:/etc/nginx/nginx.conf:ro
      - ./certs:/etc/ssl/certs:ro
    depends_on:
      - agent
Run with:
```bash
docker-compose up -d
## Kubernetes deployment
Kubernetes manifests are language-agnostic. The only difference is the Docker image referenced and any build steps. Use the appropriate Dockerfile from the section above to build your image, then deploy with the same manifests regardless of language.
| Language   | Image Build Command                                                 |
| Python     | `docker build -f Dockerfile.python -t your-registry/agent:latest .` |
| TypeScript | `docker build -f Dockerfile.ts -t your-registry/agent:latest .`     |
### Deployment manifest
```yaml
## deployment.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: signalwire-agent
spec:
  replicas: 3
  selector:
    matchLabels:
  template:
    metadata:
      labels:
    spec:
      containers:
      - name: agent
        image: your-registry/signalwire-agent:latest
        ports:
        - containerPort: 3000
        env:
        - name: SWML_BASIC_AUTH_USER
          valueFrom:
            secretKeyRef:
              key: auth-user
        - name: SWML_BASIC_AUTH_PASSWORD
          valueFrom:
            secretKeyRef:
              key: auth-password
        resources:
          requests:
            memory: "256Mi"
            cpu: "250m"
          limits:
            memory: "512Mi"
            cpu: "500m"
        livenessProbe:
          httpGet:
            path: /health
            port: 3000
          initialDelaySeconds: 10
          periodSeconds: 30
        readinessProbe:
          httpGet:
            path: /health
            port: 3000
          initialDelaySeconds: 5
          periodSeconds: 10
### Service manifest
```yaml
## service.yaml
apiVersion: v1
kind: Service
metadata:
spec:
  selector:
  ports:
  - protocol: TCP
    port: 80
    targetPort: 3000
  type: ClusterIP
### Ingress manifest
```yaml
## ingress.yaml
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  annotations:
    nginx.ingress.kubernetes.io/ssl-redirect: "true"
    cert-manager.io/cluster-issuer: "letsencrypt-prod"
spec:
  ingressClassName: nginx
  tls:
  - hosts:
    - agent.example.com
    secretName: agent-tls
  rules:
  - host: agent.example.com
    http:
      paths:
      - path: /
        pathType: Prefix
        backend:
          service:
            port:
              number: 80
### Secrets
```yaml
## secrets.yaml
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
  auth-user: your-username
  auth-password: your-secure-password
## Kubernetes architecture
```mermaid
flowchart TD
    internet["Internet"] --> ingress["Ingress: nginx or Traefik<br />SSL termination and routing"]
    ingress --> service["ClusterIP Service<br />load balancing across pods"]
    service --> pod1["Agent pod 1"]
    service --> pod2["Agent pod 2"]
    service --> pod3["Agent pod 3"]
## Deploying to Kubernetes
```bash
## Create secrets
kubectl apply -f secrets.yaml
## Deploy application
kubectl apply -f deployment.yaml
kubectl apply -f service.yaml
kubectl apply -f ingress.yaml
## Check status
kubectl get pods -l app=signalwire-agent
kubectl get svc signalwire-agent
kubectl get ingress signalwire-agent
## View logs
kubectl logs -f -l app=signalwire-agent
## Scale deployment
kubectl scale deployment signalwire-agent --replicas=5
## Horizontal Pod Autoscaler
```yaml
## hpa.yaml
apiVersion: autoscaling/v2
kind: HorizontalPodAutoscaler
metadata:
spec:
  scaleTargetRef:
    apiVersion: apps/v1
    kind: Deployment
  minReplicas: 2
  maxReplicas: 10
  metrics:
  - type: Resource
    resource:
      target:
        type: Utilization
        averageUtilization: 70
## Multi-architecture builds
```dockerfile
## Build for multiple architectures
FROM --platform=$TARGETPLATFORM python:3.11-slim
## ... rest of Dockerfile
Build with:
```bash
docker buildx build --platform linux/amd64,linux/arm64 -t your-registry/agent:latest --push .
## Container best practices
### Security
* Run as non-root user
* Use minimal base images (slim, alpine)
* Scan images for vulnerabilities
* Don't store secrets in images
### Performance
* Use multi-stage builds to reduce image size
* Layer dependencies efficiently
* Set appropriate resource limits
### Reliability
* Add health checks
* Use restart policies
* Configure proper logging
* Set graceful shutdown handling
