# Development Environment Setup
> Configure a professional development environment for building SignalWire agents with proper project structure, environment variables, and debugging tools.
### Recommended Project Structure
The project layout varies by language. Here are the recommended structures:
#### Python
```text
my-agent-project/
├── venv/                       # Virtual environment
├── agents/                     # Your agent modules
│   ├── __init__.py
│   ├── customer_service.py
│   └── support_agent.py
├── skills/                     # Custom skills (optional)
│   └── my_custom_skill/
│       ├── __init__.py
│       └── skill.py
├── tests/                      # Test files
│   ├── __init__.py
│   └── test_agents.py
├── .env                        # Environment variables (not in git)
├── .env.example                # Example env file (in git)
├── .gitignore
├── requirements.txt
└── main.py                     # Entry point
#### TypeScript
```text
my-agent-project/
├── node_modules/
├── src/
│   ├── agents/
│   │   ├── customer_service.ts
│   │   └── support_agent.ts
│   └── index.ts                # Entry point
├── .env
├── .gitignore
├── package.json
└── tsconfig.json
### Create the Project
```bash
## Create project directory
mkdir my-agent-project
cd my-agent-project
## Create virtual environment
python -m venv venv
source venv/bin/activate  # Windows: venv\Scripts\activate
## Install dependencies
pip install signalwire-sdk
## Create directory structure
mkdir -p agents skills tests
## Create initial files
touch agents/__init__.py
touch tests/__init__.py
touch .env .env.example .gitignore requirements.txt main.py
### Environment Variables
Create a `.env` file for configuration:
```bash
## .env - DO NOT COMMIT THIS FILE
## Authentication
## These set your agent's basic auth credentials.
## If not set, SDK uses username "signalwire" with an auto-generated
## password that changes on every invocation (printed to console).
SWML_BASIC_AUTH_USER=my_username
SWML_BASIC_AUTH_PASSWORD=my_secure_password_here
## Server Configuration
SWML_PROXY_URL_BASE=https://my-agent.ngrok.io
## SSL (optional, for production)
SWML_SSL_ENABLED=false
SWML_SSL_CERT_PATH=
SWML_SSL_KEY_PATH=
## Skill API Keys (as needed)
GOOGLE_API_KEY=your_google_api_key
GOOGLE_CX_ID=your_custom_search_id
WEATHER_API_KEY=your_weather_api_key
## Logging
SIGNALWIRE_LOG_MODE=default
**Important**: The `SWML_BASIC_AUTH_USER` and `SWML_BASIC_AUTH_PASSWORD` environment variables let you set stable credentials for your agent. Without these:
* Username defaults to `signalwire`
* Password is randomly generated on each startup
* The generated password is printed to the console
For development, you can leave these unset and use the printed credentials. For production, always set explicit values.
Create `.env.example` as a template (safe to commit):
```bash
## .env.example - Template for environment variables
## Authentication (optional - SDK generates credentials if not set)
## Skill API Keys
GOOGLE_API_KEY=
WEATHER_API_KEY=
### Loading Environment Variables
Install python-dotenv:
```bash
pip install python-dotenv
Load in your agent:
#!/usr/bin/env python3
## main.py - Main entry point with environment loading
"""Main entry point with environment loading."""
import os
from dotenv import load_dotenv
## Load environment variables from .env file
load_dotenv()
from agents.customer_service import CustomerServiceAgent
def main():
    agent = CustomerServiceAgent()
    # Use environment variables
    host = os.getenv("AGENT_HOST", "0.0.0.0")
    port = int(os.getenv("AGENT_PORT", "3000"))
    print(f"Starting agent on {host}:{port}")
    agent.run(host=host, port=port)
    main()
### The .gitignore File
```gitignore
## Virtual environment
venv/
.venv/
env/
## Environment variables
.env
.env.local
.env.*.local
## Python
__pycache__/
*.py[cod]
*$py.class
*.so
.Python
build/
dist/
*.egg-info/
## IDE
.idea/
.vscode/
*.swp
*.swo
## Testing
.pytest_cache/
.coverage
htmlcov/
## Logs
*.log
## OS
.DS_Store
Thumbs.db
### Requirements File
Create `requirements.txt`:
```text
signalwire-sdk>=1.0.15
python-dotenv>=1.0.0
Or generate from current environment:
```bash
pip freeze > requirements.txt
### IDE Configuration
#### VS Code
Create `.vscode/settings.json`:
```json
    "python.defaultInterpreterPath": "${workspaceFolder}/venv/bin/python",
    "python.envFile": "${workspaceFolder}/.env",
    "python.testing.pytestEnabled": true,
    "python.testing.pytestArgs": ["tests"],
    "editor.formatOnSave": true,
    "python.formatting.provider": "black"
Create `.vscode/launch.json` for debugging:
```json
    "version": "0.2.0",
    "configurations": [
            "name": "Run Agent",
            "type": "python",
            "request": "launch",
            "program": "${workspaceFolder}/main.py",
            "console": "integratedTerminal",
            "envFile": "${workspaceFolder}/.env"
            "name": "Run Current File",
            "type": "python",
            "program": "${file}",
            "name": "Test Agent with swaig-test",
            "type": "python",
            "module": "signalwire.cli.test_swaig",
            "args": ["${file}", "--dump-swml"],
#### PyCharm
1. Open Settings -> Project -> Python Interpreter
2. Select your virtual environment
3. Go to Run -> Edit Configurations
4. Create a Python configuration:
   * Script path: `main.py`
   * Working directory: Project root
   * Environment variables: Load from `.env`
### Using swaig-test for Development
The `swaig-test` CLI is essential for development:
```bash
## View SWML output (formatted)
swaig-test agents/customer_service.py --dump-swml
## View raw SWML JSON
swaig-test agents/customer_service.py --dump-swml --raw
## List all registered functions
swaig-test agents/customer_service.py --list-tools
## Execute a specific function
swaig-test agents/customer_service.py --exec get_customer --customer_id 12345
## Simulate serverless environment
swaig-test agents/customer_service.py --simulate-serverless lambda --dump-swml
### Development Workflow
**1. Edit Code**
Modify your agent in `agents/`.
**2. Quick Test**
* `swaig-test agents/my_agent.py --dump-swml`
* Verify SWML looks correct
**3. Function Test**
* `swaig-test agents/my_agent.py --exec my_function --param_name value`
* Verify function returns expected result
**4. Run Server**
* `python main.py`
* `curl http://localhost:3000/`
**5. Integration Test**
* Start ngrok (see next section)
* Configure SignalWire webhook
* Make test call
### Sample Agent Module
## customer_service.py - Customer service agent
Customer Service Agent
A production-ready customer service agent template.
import os
class CustomerServiceAgent(AgentBase):
    """Customer service voice AI agent."""
        super().__init__(
            name="customer-service",
            route="/",
            host="0.0.0.0",
            port=int(os.getenv("AGENT_PORT", "3000"))
        self._configure_voice()
        self._configure_prompts()
        self._configure_functions()
    def _configure_voice(self):
        """Set up voice and language."""
        self.set_params({
            "end_of_speech_timeout": 500,
            "attention_timeout": 15000,
        self.add_hints([
            "account",
            "billing",
            "support",
            "representative"
    def _configure_prompts(self):
        """Set up AI prompts."""
        self.prompt_add_section(
            "Role",
            "You are a helpful customer service representative for Acme Corp. "
            "Help customers with their questions about accounts, billing, and products."
            "Guidelines",
            body="Follow these guidelines:",
            bullets=[
                "Be professional and courteous",
                "Ask clarifying questions when needed",
                "Offer to transfer to a human if you cannot help",
                "Keep responses concise"
    def _configure_functions(self):
        """Register SWAIG functions."""
        self.define_tool(
            name="lookup_account",
            description="Look up a customer account by phone number or account ID",
            parameters={
                "type": "object",
                "properties": {
                    "identifier": {
                        "type": "string",
                        "description": "Phone number or account ID"
                "required": ["identifier"]
            handler=self.lookup_account
        self.define_tool(
            name="transfer_to_human",
            description="Transfer the call to a human representative",
            handler=self.transfer_to_human
    def lookup_account(self, args, raw_data):
        """Look up account information."""
        identifier = args.get("identifier", "")
        # In production, query your database here
        return FunctionResult(
            f"Found account for {identifier}: Status is Active, Balance is $0.00"
    def transfer_to_human(self, args, raw_data):
        """Transfer to human support."""
            "Transferring you to a human representative now."
        ).connect("+15551234567", final=True, from_addr="+15559876543")
## Allow running directly for testing
### Testing Your Agent
## test_agents.py - Tests for agents
"""Tests for agents."""
import pytest
class TestCustomerServiceAgent:
    """Test customer service agent."""
    def setup_method(self):
        """Set up test fixtures."""
        self.agent = CustomerServiceAgent()
    def test_agent_name(self):
        """Test agent has correct name."""
        assert self.agent.name == "customer-service"
    def test_lookup_account(self):
        """Test account lookup function."""
        result = self.agent.lookup_account(
            {"identifier": "12345"},
        assert "Found account" in result
    def test_has_functions(self):
        """Test agent has expected functions."""
        functions = self.agent._tool_registry.get_function_names()
        assert "lookup_account" in functions
        assert "transfer_to_human" in functions
Run tests:
```bash
pytest tests/ -v
### Next Steps
Your development environment is ready. Now let's expose your agent to the internet so SignalWire can reach it.
