title: SWAIG Functions
description: SWAIG (SignalWire AI Gateway) functions let your AI agent call custom code to look up data, make API calls, and take actions during conversations.
slug: /guides/defining-functions
max-toc-depth: 3
[defining-functions]: /docs/server-sdks/guides/defining-functions
[parameters]: /docs/server-sdks/guides/parameters
[results-actions]: /docs/server-sdks/guides/result-actions
[datamap]: /docs/server-sdks/guides/data-map
[native-functions]: /docs/server-sdks/guides/native-functions
[ref-functionresult]: /docs/server-sdks/reference/python/agents/function-result
## What You'll Learn
This chapter covers everything about SWAIG functions:
1. **Defining Functions** - Creating functions the AI can call
2. **Parameters** - Accepting arguments from the AI
3. **Results & Actions** - Returning data and triggering actions
4. **DataMap** - Serverless API integration without webhooks
5. **Native Functions** - Built-in SignalWire functions
## How SWAIG Functions Work
<Frame caption="SWAIG Function Flow">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/2c6a3f3206b615c8c519b37dcd4f40f8e2374f770fbee1d1c0e4b021f5dd5ac2/assets/images/sdks/diagrams/04_01_defining-functions_diagram1.webp" alt="SWAIG function flow diagram." />
</Frame>
## Quick Start Example
Here's a complete agent with a SWAIG function:
<Tabs>
  <Tab title="Python">
    class OrderAgent(AgentBase):
            super().__init__(name="order-agent")
            self.prompt_add_section(
                "Role",
                "You are an order status assistant. Help customers check their orders."
            # Define a function the AI can call
            self.define_tool(
                name="check_order",
                description="Look up order status by order number",
                parameters={
                    "type": "object",
                    "properties": {
                        "order_number": {
                            "type": "string",
                            "description": "The order number to look up"
                    "required": ["order_number"]
                handler=self.check_order
        def check_order(self, args, raw_data):
            order_number = args.get("order_number")
            # Your business logic here - database lookup, API call, etc.
            orders = {
                "12345": "Shipped Monday, arriving Thursday",
                "67890": "Processing, ships tomorrow"
            status = orders.get(order_number, "Order not found")
            return FunctionResult(f"Order {order_number}: {status}")
        agent = OrderAgent()
  </Tab>
  <Tab title="TypeScript">
    ```typescript
    import { AgentBase, FunctionResult } from 'signalwire-agents';
    const agent = new AgentBase({ name: 'order-agent' });
    agent.addLanguage('English', 'en-US', 'rime.spore');
    agent.promptAddSection('Role', 'You are an order status assistant. Help customers check their orders.');
    agent.defineTool({
      description: 'Look up order status by order number',
      parameters: {
        type: 'object',
        properties: {
          order_number: { type: 'string', description: 'The order number to look up' }
        required: ['order_number']
      handler: (args) => {
        const orders: Record<string, string> = {
          '12345': 'Shipped Monday, arriving Thursday',
          '67890': 'Processing, ships tomorrow'
        const status = orders[args.order_number] || 'Order not found';
        return new FunctionResult(`Order ${args.order_number}: ${status}`);
    agent.run();
  </Tab>
</Tabs>
## Function Types
| Type                  | Description        |
| **Handler Functions** | Defined with `define_tool()`. Your handler runs on your server with full control over logic, database access, and API calls. |
| **DataMap Functions** | Serverless API integration that runs on SignalWire's servers. No webhook endpoint needed - direct REST API calls.            |
| **Native Functions**  | Built into SignalWire. No custom code required - handles transfer, recording, etc.                                           |
## Chapter Contents
| Section                                  | Description                                  |
| [Defining Functions][defining-functions] | Creating SWAIG functions with define\_tool() |
| [Parameters][parameters]                 | Defining and validating function parameters  |
| [Results & Actions][results-actions]     | Returning results and triggering actions     |
| [DataMap][datamap]                       | Serverless API integration                   |
| [Native Functions][native-functions]     | Built-in SignalWire functions                |
## When to Use SWAIG Functions
| Use Case                | Approach                                    |
| Database lookups        | Handler function                            |
| Complex business logic  | Handler function                            |
| Simple REST API calls   | DataMap                                     |
| Pattern-based responses | DataMap expressions                         |
| Call transfers          | Native function or FunctionResult.connect() |
| SMS sending             | FunctionResult.send\_sms()                  |
## Key Concepts
**Handler Functions**: Python code that runs on your server when the AI decides to call a function. You have full access to databases, APIs, and any Python library.
**FunctionResult**: The return type for all SWAIG functions. Contains the response text the AI will speak and optional actions to execute.
**Parameters**: JSON Schema definitions that tell the AI what arguments your function accepts. The AI will extract these from the conversation.
**Actions**: Side effects like call transfers, SMS sending, or context changes that execute after the function completes.
**DataMap**: A way to define functions that call REST APIs without running any code on your server - the API calls happen directly on SignalWire's infrastructure.
Let's start by learning how to define functions.
## Basic Function Definition
class MyAgent(AgentBase):
        # Define a function
        self.define_tool(
            name="get_weather",
            description="Get current weather for a city",
            parameters={
                "type": "object",
                "properties": {
                    "city": {
                        "type": "string",
                        "description": "City name"
                "required": ["city"]
            handler=self.get_weather
    def get_weather(self, args, raw_data):
        city = args.get("city")
        # Your logic here
        return FunctionResult(f"The weather in {city} is sunny, 72 degrees")
### define\_tool() Across Languages
The `define_tool()` method is available in all SDK languages. The parameters JSON Schema is identical everywhere; only the calling syntax differs:
| Language   | Syntax        |
| Python     | `agent.define_tool(name="x", description="d", parameters={...}, handler=self.fn)`                |
| TypeScript | `agent.defineTool({ name: 'x', description: 'd', parameters: {...}, handler: (args) => {...} })` |
## The define\_tool() Method
**Required Parameters:**
| Parameter     | Description                                          |
| `name`        | Unique function name (lowercase, underscores)        |
| `description` | What the function does (helps AI decide when to use) |
| `parameters`  | JSON Schema defining accepted arguments              |
| `handler`     | Python function to call                              |
**Optional Parameters:**
| `secure`      | Require token validation (default: True)       |
| `fillers`     | Language-specific filler phrases               |
| `webhook_url` | External webhook URL (overrides local handler) |
| `required`    | List of required parameter names               |
## Handler Function Signature
All handlers receive two arguments: the parsed function arguments and the full request data. The handler returns a [`FunctionResult`][ref-functionresult] with response text and optional actions.
    Args:
        args: Dictionary of parsed function arguments
              {"city": "New York", "units": "fahrenheit"}
        raw_data: Full request data including:
              - call_id: Unique call identifier
              - caller_id_num: Caller's phone number
              - caller_id_name: Caller's name
              - called_id_num: Number that was called
              - And more...
    Returns:
        FunctionResult with response text and optional actions
    return FunctionResult("Response text")
The handler signature across languages:
| Language   | Signature        |
| Python     | `def handler(self, args, raw_data):` returns `FunctionResult`                        |
| TypeScript | `(args: Record<string, any>, raw?: Record<string, any>) =>` returns `FunctionResult` |
## Accessing Call Data
def check_account(self, args, raw_data):
    # Get caller information
    caller_number = raw_data.get("caller_id_num", "")
    call_id = raw_data.get("call_id", "")
    # Get function arguments
    account_id = args.get("account_id")
    # Use both for your logic
        f"Account {account_id} for caller {caller_number} is active"
## Multiple Functions
Register as many functions as your agent needs:
class CustomerServiceAgent(AgentBase):
        super().__init__(name="customer-service")
        # Order lookup
        self.define_tool(
            name="check_order",
            parameters={
                "type": "object",
                "properties": {
                    "order_number": {
                        "type": "string",
                        "description": "The order number"
        # Account balance
        self.define_tool(
            name="get_balance",
            description="Get account balance for a customer",
            parameters={
                "type": "object",
                "properties": {
                    "account_id": {
                        "type": "string",
                        "description": "Customer account ID"
                "required": ["account_id"]
            handler=self.get_balance
        # Store hours
        self.define_tool(
            name="get_store_hours",
            description="Get store hours for a location",
            parameters={
                "type": "object",
                "properties": {
                    "location": {
                        "type": "string",
                        "description": "Store location or city"
                "required": ["location"]
            handler=self.get_store_hours
        return FunctionResult(f"Order {order_number} is in transit")
    def get_balance(self, args, raw_data):
        return FunctionResult(f"Account {account_id} balance: $150.00")
    def get_store_hours(self, args, raw_data):
        location = args.get("location")
        return FunctionResult(f"{location} store: Mon-Fri 9AM-9PM, Sat-Sun 10AM-6PM")
## Function Fillers
Add per-function filler phrases for when the function is executing:
self.define_tool(
    name="search_inventory",
    description="Search product inventory",
    parameters={
        "type": "object",
        "properties": {
            "product": {"type": "string", "description": "Product to search"}
        "required": ["product"]
    handler=self.search_inventory,
    fillers={
        "en-US": [
            "Let me check our inventory...",
            "Searching our stock now...",
            "One moment while I look that up..."
        "es-MX": [
            "Dejame revisar nuestro inventario...",
            "Buscando en nuestro stock..."
## The @tool Decorator
<Note>
  The `@tool` decorator is a Python-specific convenience. Other languages achieve the same result using `define_tool()` / `defineTool()` as shown in the examples above.
</Note>
Alternative syntax using decorators:
    @AgentBase.tool(
        name="get_time",
        description="Get the current time",
        parameters={
            "type": "object",
            "properties": {
                "timezone": {
                    "type": "string",
                    "description": "Timezone (e.g., 'EST', 'PST')"
    def get_time(self, args, raw_data):
        timezone = args.get("timezone", "UTC")
        return FunctionResult(f"The current time in {timezone} is 3:45 PM")
## define\_tool() vs @tool: Choosing an Approach
Both methods register SWAIG functions with the same result. Choose based on your coding style and requirements.
### Comparison
| Aspect                    | define\_tool()                   | @tool Decorator         |
| **Where defined**         | Inside `__init__`                | At method definition    |
| **Dynamic registration**  | Easy                             | Requires workarounds    |
| **Conditional functions** | Straightforward                  | More complex            |
| **Code organization**     | Definition separate from handler | Self-documenting        |
| **Inheritance**           | Easier to override               | Works but less flexible |
### When to Use define\_tool()
**Conditional function registration:**
def __init__(self, enable_admin=False):
    # Always available
    self.define_tool(name="get_info", ...)
    # Only for admin mode
    if enable_admin:
        self.define_tool(name="admin_reset", ...)
**Dynamic functions from configuration:**
def __init__(self, functions_config):
    for func in functions_config:
        self.define_tool(
            name=func["name"],
            description=func["description"],
            parameters=func["params"],
            handler=getattr(self, func["handler_name"])
**Handlers defined outside the class:**
def external_handler(agent, args, raw_data):
    return FunctionResult("Handled externally")
        self.define_tool(
            name="external_func",
            description="Uses external handler",
            parameters={...},
            handler=lambda args, raw: external_handler(self, args, raw)
### When to Use @tool Decorator
**Static, self-documenting functions:**
    @AgentBase.tool(
        name="check_order",
        description="Look up order status",
        parameters={...}
        # Handler right here with its definition
        return FunctionResult("...")
    @AgentBase.tool(
        name="get_balance",
        description="Get account balance",
        parameters={...}
The decorator keeps the function metadata with the implementation, making it easier to see what a function does at a glance.
### Type-Inferred Functions
<Note>
  Type inference from function signatures is a Python-specific feature. Other languages require explicit JSON Schema parameter definitions via `define_tool()` / `defineTool()`.
</Note>
When using the `@tool` decorator (or `define_tool()`) **without** explicit `parameters`, the SDK automatically infers the JSON Schema from Python type hints. This eliminates boilerplate for straightforward functions.
from typing import Optional, Literal
class TypedAgent(AgentBase):
        super().__init__(name="typed-agent")
    @AgentBase.tool(name="check_order")
    def check_order(self, order_number: str, include_tracking: bool = False):
        """Look up order status by order number.
        Args:
            order_number: The order number to look up
            include_tracking: Include tracking URL in the response
        status = "Shipped Monday, arriving Thursday"
        result = f"Order {order_number}: {status}"
        if include_tracking:
            result += " Tracking: https://track.example.com/12345"
        return FunctionResult(result)
    @AgentBase.tool(name="set_priority")
    def set_priority(self, ticket_id: str, level: Literal["low", "medium", "high"]):
        """Set the priority level for a support ticket.
        Args:
            ticket_id: The support ticket ID
            level: Priority level to set
        return FunctionResult(f"Ticket {ticket_id} set to {level} priority")
**How type inference works:**
| Python Type          | JSON Schema Type        |
| `str`                | `"string"`              |
| `int`                | `"integer"`             |
| `float`              | `"number"`              |
| `bool`               | `"boolean"`             |
| `list` / `List[str]` | `"array"` (with items)  |
| `dict`               | `"object"`              |
| `Optional[X]`        | Type of X, not required |
| `Literal["a", "b"]`  | `"string"` with `enum`  |
**Rules:**
* Parameters without defaults and not `Optional` are marked as **required**
* The function's docstring summary becomes the tool **description**
* Google-style `Args:` docstring sections provide per-parameter **descriptions**
* A `raw_data` parameter is recognized and passed through (not included in schema)
* If no type hints are present, the SDK falls back to the traditional `(args, raw_data)` convention
**Accessing raw\_data with typed functions:**
@AgentBase.tool(name="caller_info")
def caller_info(self, raw_data: dict):
    """Get information about the current caller."""
    caller = raw_data.get("caller_id_num", "unknown")
    return FunctionResult(f"Your number is {caller}")
**When to use type inference vs explicit parameters:**
| Scenario                          | Recommendation             |
| Simple string/int/bool params     | Type inference             |
| Nested objects or complex schemas | Explicit parameters        |
| Enum constraints                  | `Literal` type or explicit |
| Shared parameter schemas          | Explicit parameters        |
### Mixing Both Approaches
You can use both in the same agent:
class HybridAgent(AgentBase):
    def __init__(self, extra_functions=None):
        super().__init__(name="hybrid")
        # Dynamic functions via define_tool
        if extra_functions:
            for func in extra_functions:
                self.define_tool(**func)
    # Static function via decorator
    @AgentBase.tool(
        name="get_help",
        description="Get help information",
        parameters={"type": "object", "properties": {}}
    def get_help(self, args, raw_data):
        return FunctionResult("How can I help you?")
## Registering Pre-Built SWAIG Functions
The `register_swaig_function()` method registers a function definition object directly (used with DataMap and external definitions). This is a lower-level method than `define_tool()`:
| Language   | Syntax                                                  |
| Python     | `agent.register_swaig_function(dm.to_swaig_function())` |
| TypeScript | `agent.registerSwaigFunction(dm.toSwaigFunction())`     |
## External Webhook Functions
Route function calls to an external webhook:
self.define_tool(
    name="external_lookup",
    description="Look up data from external service",
    parameters={
        "type": "object",
        "properties": {
            "query": {"type": "string", "description": "Search query"}
        "required": ["query"]
    handler=None,  # No local handler
    webhook_url="https://external-service.com/api/lookup"
## Function Security
By default, functions require token validation. Disable for testing:
# Secure function (default)
self.define_tool(
    name="secure_function",
    description="Requires token validation",
    handler=self.secure_handler,
    secure=True  # Default
# Insecure function (testing only)
self.define_tool(
    name="test_function",
    description="No token validation (testing only)",
    handler=self.test_handler,
    secure=False  # Disable for testing
## Writing Good Descriptions
The description helps the AI decide when to use your function:
# Good - specific and clear
description="Look up order status by order number. Returns shipping status and estimated delivery date."
# Bad - too vague
description="Get order info"
# Good - mentions what triggers it
description="Check if a product is in stock. Use when customer asks about availability."
# Good - explains constraints
description="Transfer call to human support. Only use if customer explicitly requests to speak with a person."
## Testing Functions
Use swaig-test to test your functions:
```bash
# List all functions
swaig-test my_agent.py --list-tools
# Test a specific function
swaig-test my_agent.py --exec check_order --order_number 12345
# See the generated SWML
## Complete Example
<Note>
  The following example is shown in Python. All concepts demonstrated (multiple `define_tool()` calls, fillers, handlers) work identically in other SDK languages using the syntax shown in the Quick Start and define\_tool() tables above.
</Note>
#!/usr/bin/env python3
# restaurant_agent.py - Restaurant order assistant
class RestaurantAgent(AgentBase):
    MENU = {
        "burger": {"price": 12.99, "description": "Angus beef burger with fries"},
        "pizza": {"price": 14.99, "description": "12-inch cheese pizza"},
        "salad": {"price": 9.99, "description": "Garden salad with dressing"}
        super().__init__(name="restaurant-agent")
            "Role",
            "You are a friendly restaurant order assistant."
        self.define_tool(
            name="get_menu_item",
            description="Get details about a menu item including price and description",
            parameters={
                "type": "object",
                "properties": {
                    "item_name": {
                        "type": "string",
                        "description": "Name of the menu item"
                "required": ["item_name"]
            handler=self.get_menu_item,
            fillers={
                "en-US": ["Let me check the menu..."]
        self.define_tool(
            name="place_order",
            description="Place an order for menu items",
            parameters={
                "type": "object",
                "properties": {
                    "items": {
                        "type": "array",
                        "items": {"type": "string"},
                        "description": "List of menu items to order"
                    "special_requests": {
                        "type": "string",
                        "description": "Any special requests or modifications"
                "required": ["items"]
            handler=self.place_order,
            fillers={
                "en-US": ["Placing your order now..."]
    def get_menu_item(self, args, raw_data):
        item_name = args.get("item_name", "").lower()
        item = self.MENU.get(item_name)
        if item:
                f"{item_name.title()}: {item['description']}. Price: ${item['price']}"
        return FunctionResult(f"Sorry, {item_name} is not on our menu.")
    def place_order(self, args, raw_data):
        items = args.get("items", [])
        special = args.get("special_requests", "")
        total = sum(
            self.MENU.get(item.lower(), {}).get("price", 0)
            for item in items
        if total > 0:
            msg = f"Order placed: {', '.join(items)}. Total: ${total:.2f}"
            if special:
                msg += f" Special requests: {special}"
            return FunctionResult(msg)
        return FunctionResult("Could not place order. Please check item names.")
    agent = RestaurantAgent()
