# CGI Mode
> Deploy agents as CGI scripts on traditional web servers like Apache or nginx with automatic environment detection.
## CGI overview
CGI (Common Gateway Interface) allows web servers to execute scripts and return their output as HTTP responses.
CGI mode is primarily supported by the **Python** and **Perl** SDKs. Compiled languages (Go, C++, Java) are better served by their built-in HTTP servers. TypeScript and Ruby can use CGI via their respective interpreters but this is uncommon.
| Language | CGI Support | Notes                                       |
| Python   | Full        | Automatic detection via `GATEWAY_INTERFACE` |
**Benefits:**
* Works with shared hosting
* Simple deployment - just upload files
* No separate process management
* Compatible with Apache, nginx
**Drawbacks:**
* New process per request (slower)
* No persistent connections
* Limited scalability
## CGI detection
The SDK detects CGI mode via the `GATEWAY_INTERFACE` environment variable:
## Automatic detection
if os.getenv('GATEWAY_INTERFACE'):
    # CGI mode detected
    mode = 'cgi'
## Basic CGI script
#### Python
## agent.py - Basic CGI agent script (add #!/usr/bin/env python3 shebang)
class MyAgent(AgentBase):
    agent = MyAgent()
    agent.run()  # Automatically detects CGI mode
Make scripts executable:
```bash
chmod +x agent.py agent.pl
## CGI request flow
```mermaid
flowchart TD
    cloud["SignalWire"] --> server["Apache or nginx web server"]
    server -->|"Set CGI environment: GATEWAY_INTERFACE, PATH_INFO, CONTENT_LENGTH"| script["Python CGI script: agent.py"]
    script -->|PATH_INFO empty| swml["Return SWML document"]
    script -->|PATH_INFO=/swaig| function["Execute SWAIG function"]
    swml & function --> stdout["Write JSON response to stdout<br />for the web server"]
## Apache configuration
### Enable CGI
```apache
## Enable CGI module
LoadModule cgi_module modules/mod_cgi.so
## Configure CGI directory
<Directory "/var/www/cgi-bin">
    Options +ExecCGI
    AddHandler cgi-script .py
    Require all granted
</Directory>
### Virtual host configuration
```apache
<VirtualHost *:443>
    ServerName agent.example.com
    SSLEngine on
    SSLCertificateFile /etc/ssl/certs/agent.crt
    SSLCertificateKeyFile /etc/ssl/private/agent.key
    ScriptAlias / /var/www/cgi-bin/agent.py
        Options +ExecCGI
        SetHandler cgi-script
        Require all granted
    </Directory>
    # Set environment variables
    SetEnv SWML_BASIC_AUTH_USER "myuser"
    SetEnv SWML_BASIC_AUTH_PASSWORD "mypassword"
</VirtualHost>
## nginx configuration
nginx doesn't natively support CGI, but you can use FastCGI with `fcgiwrap`:
```nginx
server {
    listen 443 ssl;
    server_name agent.example.com;
    ssl_certificate /etc/ssl/certs/agent.crt;
    ssl_certificate_key /etc/ssl/private/agent.key;
    location / {
        fastcgi_pass unix:/var/run/fcgiwrap.socket;
        fastcgi_param SCRIPT_FILENAME /var/www/cgi-bin/agent.py;
        fastcgi_param GATEWAY_INTERFACE CGI/1.1;
        fastcgi_param PATH_INFO $uri;
        fastcgi_param SWML_BASIC_AUTH_USER "myuser";
        fastcgi_param SWML_BASIC_AUTH_PASSWORD "mypassword";
        include fastcgi_params;
## CGI host configuration
In CGI mode, the SDK needs to know the external hostname for generating URLs:
```bash
## Using swaig-test to simulate CGI mode
swaig-test my_agent.py --simulate-serverless cgi --cgi-host agent.example.com
Or set environment variable:
```apache
SetEnv SWML_PROXY_URL_BASE "https://agent.example.com"
## Testing CGI locally
Use `swaig-test` to simulate CGI environment:
```bash
## Test SWML generation in CGI mode
swaig-test my_agent.py --simulate-serverless cgi --dump-swml
## With custom host
swaig-test my_agent.py --simulate-serverless cgi --cgi-host mysite.com --dump-swml
## Test a function
swaig-test my_agent.py --simulate-serverless cgi --exec function_name --param value
## Authentication in CGI mode
The SDK checks basic auth in CGI mode:
## Authentication is automatic when these are set
## SWML_BASIC_AUTH_USER
## SWML_BASIC_AUTH_PASSWORD
## The SDK reads Authorization header and validates
If authentication fails, returns 401 with WWW-Authenticate header.
## Directory structure
```text
/var/www/cgi-bin/
├── agent.py              # Main CGI script
├── requirements.txt      # Dependencies
└── venv/                 # Virtual environment (optional)
## Shared hosting deployment
For shared hosting where you can't install system packages:
## agent_shared.py - CGI agent for shared hosting (add #!/usr/bin/env python3 shebang)
import sys
import os
## Add local packages directory
sys.path.insert(0, os.path.join(os.path.dirname(__file__), 'packages'))
    agent = MyAgent()
Install packages locally:
```bash
pip install --target=./packages signalwire-sdk
## CGI best practices
### Performance
* Keep imports minimal - each request starts fresh
* Consider FastCGI for better performance
* Cache what you can (but remember process dies)
### Security
* Set proper file permissions (750 or 755)
* Don't expose .py files directly if possible
* Use HTTPS always
* Set auth credentials as environment variables
### Debugging
* Check web server error logs
* Verify shebang line (#!/usr/bin/env python3)
* Test script from command line first
* Ensure proper line endings (LF, not CRLF)
## Common CGI issues
| Issue                     | Solution                               |
| 500 Internal Server Error | Check error logs, verify permissions   |
| Permission denied         | `chmod +x agent.py`                    |
| Module not found          | Check `sys.path`, install dependencies |
| Wrong Python version      | Update shebang to correct Python       |
| Malformed headers         | Ensure proper Content-Type output      |
| Timeout                   | Optimize code, increase server timeout |
## Migration from CGI
### CGI to FastCGI
Keep same code, use fcgiwrap or gunicorn. Better performance, persistent processes.
### CGI to server mode
Same code works - just run differently (`python agent.py` instead of CGI). Add systemd service, nginx reverse proxy.
### CGI to serverless
Same code works with minor changes. Add Lambda handler wrapper. Deploy to AWS/GCP/Azure.
