title: AgentBase
description: Learn how to build voice AI agents using AgentBase, from basic configuration to advanced prompt engineering and voice customization.
slug: /guides/agent-base
max-toc-depth: 3
[swml]: /docs/server-sdks/guides/swml
[swaig]: /docs/server-sdks/guides/swaig
[lifecycle]: /docs/server-sdks/guides/lifecycle
[agentbase]: /docs/server-sdks/guides/agent-base
[static-vs-dynamic]: /docs/server-sdks/guides/static-vs-dynamic
[prompts-pom]: /docs/server-sdks/guides/prompts-pom
[voice-language]: /docs/server-sdks/guides/voice-language
[ai-parameters]: /docs/server-sdks/guides/ai-parameters
[hints]: /docs/server-sdks/guides/hints
[call-flow]: /docs/server-sdks/guides/call-flow
## What You'll Learn
This chapter covers everything you need to build production-quality agents:
1. **AgentBase** - The foundation class and its capabilities
2. **Static vs Dynamic** - Choosing the right pattern for your use case
3. **Prompts & POM** - Crafting effective prompts with the Prompt Object Model
4. **Voice & Language** - Configuring voices and multi-language support
5. **AI Parameters** - Tuning conversation behavior
6. **Hints** - Improving speech recognition accuracy
7. **Call Flow** - Customizing when and how calls are answered
## Prerequisites
Before building agents, you should understand:
* Core concepts from Chapter 2 ([SWML][swml], [SWAIG][swaig], [Lifecycle][lifecycle])
* Basic Python class structure
* How SignalWire processes calls
## Agent Architecture Overview
<Frame caption="Agent Components">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/64082d344e54d82c9dcf007dfa98b49c2c5a8c50763fc586d475fb8d8676805b/assets/images/sdks/diagrams/03_01_agent-base_diagram1.webp" alt="Agent components overview." />
</Frame>
## A Complete Agent Example
Here's what a production agent looks like across all supported languages:
<Tabs>
  <Tab title="Python">
    class CustomerSupportAgent(AgentBase):
        """Production customer support agent."""
            super().__init__(
                name="customer-support",
                route="/support"
            # Voice configuration
            # AI behavior
            self.set_params({
                "end_of_speech_timeout": 500,
                "attention_timeout": 15000,
                "inactivity_timeout": 30000
            # Prompts
            self.prompt_add_section(
                "Role",
                "You are Alex, a friendly customer support agent for Acme Inc."
                "Guidelines",
                body="Follow these guidelines:",
                bullets=[
                    "Be helpful and professional",
                    "Ask clarifying questions when needed",
                    "Keep responses concise for voice",
                    "Offer to transfer if you cannot help"
            # Speech recognition hints
            self.add_hints([
                "Acme", "account number", "order status",
                "refund", "billing", "representative"
            # Functions
            self.define_tool(
                name="check_order",
                description="Look up an order by order number",
                parameters={
                    "type": "object",
                    "properties": {
                        "order_number": {
                            "type": "string",
                            "description": "The order number to look up"
                    "required": ["order_number"]
                handler=self.check_order
            # Skills
            self.add_skill("datetime")
            # Post-call summary
            self.set_post_prompt(
                "Summarize: issue type, resolution, customer satisfaction"
        def check_order(self, args, raw_data):
            order_number = args.get("order_number")
            return FunctionResult(
                f"Order {order_number}: Shipped on Monday, arriving Thursday"
        agent = CustomerSupportAgent()
        agent.run(host="0.0.0.0", port=3000)
  </Tab>
  <Tab title="TypeScript">
    ```typescript
    import { AgentBase, FunctionResult } from 'signalwire-agents';
    const agent = new AgentBase({
      route: "/support"
    agent.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
    agent.setParams({ end_of_speech_timeout: 500, attention_timeout: 15000, inactivity_timeout: 30000 });
    agent.promptAddSection('Role', 'You are Alex, a friendly customer support agent for Acme Inc.');
    agent.promptAddSection('Guidelines', { body: 'Follow these guidelines:', bullets: ['Be helpful and professional', 'Ask clarifying questions when needed', 'Keep responses concise for voice', 'Offer to transfer if you cannot help'] });
    agent.addHints(['Acme', 'account number', 'order status', 'refund', 'billing', 'representative']);
    agent.defineTool({ name: 'check_order', description: 'Look up an order by order number', parameters: { type: 'object', properties: { order_number: { type: 'string', description: 'The order number to look up' } }, required: ['order_number'] }, handler: async (args) => new FunctionResult(`Order ${args.order_number}: Shipped on Monday, arriving Thursday`) });
    agent.addSkill('datetime');
    agent.setPostPrompt('Summarize: issue type, resolution, customer satisfaction');
    agent.run({ host: '0.0.0.0', port: 3000 });
  </Tab>
</Tabs>
## Chapter Contents
| Section                                | Description                        |
| [AgentBase][agentbase]                 | Core class and constructor options |
| [Static vs Dynamic][static-vs-dynamic] | Choosing the right pattern         |
| [Prompts & POM][prompts-pom]           | Prompt engineering for voice AI    |
| [Voice & Language][voice-language]     | Voice selection and multi-language |
| [AI Parameters][ai-parameters]         | Behavior tuning                    |
| [Hints][hints]                         | Speech recognition improvement     |
| [Call Flow][call-flow]                 | Customizing call answer behavior   |
## Key Patterns
### Pattern 1: Class-Based Agent
Best for complex agents with multiple functions:
class MyAgent(AgentBase):
        self.configure()
    def configure(self):
        # All configuration here
        pass
### Pattern 2: Functional Agent
Quick agents for simple use cases:
| Language   | Functional Agent                                        |
| Python     | `agent = AgentBase(name="simple-agent")`                |
| TypeScript | `const agent = new AgentBase({ name: "simple-agent" })` |
agent.prompt_add_section("Role", "You are a helpful assistant.")
### Pattern 3: Multi-Agent Server
Multiple agents on one server:
from signalwire import AgentServer
server = AgentServer()
server.register(SupportAgent(), "/support")
server.register(BillingAgent(), "/billing")
server.run(port=3000)
## Testing Your Agent
Always test before deploying:
```bash
# View SWML output
# List registered functions
swaig-test my_agent.py --list-tools
# Test a function
swaig-test my_agent.py --exec check_order --order_number 12345
## Class Overview
<Frame caption="AgentBase Inheritance">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/c6dba2a7393a713ec6b6adbcd4970eb5d6f37c681b426154a88e046ac2d3ffd0/assets/images/sdks/diagrams/03_01_agent-base_diagram2.webp" alt="AgentBase inheritance diagram." />
</Frame>
## Constructor Parameters
The constructor accepts the agent name plus optional configuration:
| Language   | Constructor Syntax                                            |
| Python     | `AgentBase(name="my-agent", route="/", port=3000)`            |
| TypeScript | `new AgentBase({ name: "my-agent", route: "/", port: 3000 })` |
Full Python constructor with all options:
agent = AgentBase(
    # Required
    name="my-agent",                    # Unique agent identifier
    # Server Configuration
    route="/",                          # HTTP route path (default: "/")
    host="0.0.0.0",                     # Bind address (default: "0.0.0.0")
    port=3000,                          # Server port (default: 3000)
    # Authentication
    basic_auth=("user", "pass"),        # Override env var credentials
    # Behavior
    auto_answer=True,                   # Answer calls automatically
    use_pom=True,                       # Use Prompt Object Model
    # Recording
    record_call=False,                  # Enable call recording
    record_format="mp4",                # Recording format
    record_stereo=True,                 # Stereo recording
    # Tokens and Security
    token_expiry_secs=3600,             # Function token expiration
    # Advanced
    default_webhook_url=None,           # Override webhook URL
    agent_id=None,                      # Custom agent ID (auto-generated)
    native_functions=None,              # Built-in SignalWire functions
    schema_path=None,                   # Custom SWML schema path
    suppress_logs=False,                # Disable logging
    config_file=None                    # Load from config file
## Parameter Reference
| Parameter           | Type  | Default   | Description                          |
| `name`              | str   | Required  | Unique identifier for the agent      |
| `route`             | str   | "/"       | HTTP route where agent is accessible |
| `host`              | str   | "0.0.0.0" | IP address to bind server            |
| `port`              | int   | 3000      | Port number for server               |
| `basic_auth`        | tuple | None      | (username, password) for auth        |
| `use_pom`           | bool  | True      | Enable Prompt Object Model           |
| `auto_answer`       | bool  | True      | Auto-answer incoming calls           |
| `record_call`       | bool  | False     | Enable call recording                |
| `record_format`     | str   | "mp4"     | Recording file format                |
| `record_stereo`     | bool  | True      | Record in stereo                     |
| `token_expiry_secs` | int   | 3600      | Token validity period                |
| `native_functions`  | list  | None      | SignalWire native functions          |
| `suppress_logs`     | bool  | False     | Disable agent logs                   |
## Creating an Agent
### Method 1: Class-Based (Recommended)
        self._setup()
    def _setup(self):
        self.define_tool(name="greet", description="Greet the user", parameters={}, handler=self.greet)
    def greet(self, args, raw_data):
        return FunctionResult("Hello! How can I help you today?")
    agent = MyAgent()
### Method 2: Instance-Based
agent = AgentBase(name="quick-agent")
### Method 3: Declarative (PROMPT\_SECTIONS)
class DeclarativeAgent(AgentBase):
    PROMPT_SECTIONS = {
        "Role": "You are a helpful customer service agent.",
        "Guidelines": [
            "Be professional and courteous",
            "Keep responses concise"
        "Rules": {
            "body": "Always follow these rules:",
            "bullets": [
                "Never share customer data",
                "Escalate complex issues"
        super().__init__(name="declarative-agent")
## Key Methods
### Configuration Methods
| Method       | Python                              |
| Add language | `add_language(name, code, voice)`   |
| Add prompt   | `prompt_add_section(title, body)`   |
| Set params   | `set_params(dict)`                  |
| Add hints    | `add_hints(list)`                   |
| Define tool  | `define_tool(name=..., handler=fn)` |
| Post-prompt  | `set_post_prompt(text)`             |
# Voice and Language
agent.add_language(name, code, voice)       # Add language support
agent.set_languages(languages)               # Set all languages at once
# Prompts
agent.prompt_add_section(title, body)        # Add prompt section
agent.prompt_add_subsection(parent, title)   # Add subsection
agent.set_post_prompt(text)                  # Set post-call summary prompt
# AI Parameters
agent.set_params(params_dict)                # Set AI behavior parameters
agent.set_param_value(key, value)            # Set single parameter
# Speech Recognition
agent.add_hints(hints_list)                  # Add speech hints
agent.add_hint(hint_string)                  # Add single hint
# Functions
agent.define_tool(name, description, ...)   # Define SWAIG function
agent.add_skill(skill_name)                 # Add a skill
# Pronunciation
agent.add_pronunciation(replace, with_text)  # Add pronunciation rule
### Runtime Methods
# Start server
# Get SWML document
swml = agent.get_swml()
# Access components
agent.pom              # Prompt Object Model
agent.data_map         # DataMap builder
## Agent Lifecycle
<Frame caption="Agent Lifecycle">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/1060c7a8c99abc6edaa73788d8f4333998fbf86c14e641e126f4fe84c96623fc/assets/images/sdks/diagrams/03_01_agent-base_diagram3.webp" alt="Agent lifecycle." />
</Frame>
## Configuration File
Load configuration from a YAML/JSON file:
agent = AgentBase(
    name="my-agent",
    config_file="config/agent.yaml"
```yaml
# config/agent.yaml
route: /support
host: 0.0.0.0
port: 3000
## Environment Variables
AgentBase respects these environment variables:
| Variable                   | Purpose                            |
| `SWML_BASIC_AUTH_USER`     | Basic auth username                |
| `SWML_BASIC_AUTH_PASSWORD` | Basic auth password                |
| `SWML_PROXY_URL_BASE`      | Base URL for webhooks behind proxy |
| `SWML_SSL_ENABLED`         | Enable SSL                         |
| `SWML_SSL_CERT_PATH`       | SSL certificate path               |
| `SWML_SSL_KEY_PATH`        | SSL key path                       |
| `SWML_DOMAIN`              | Domain for SSL                     |
## Multi-Agent Server
Run multiple agents on one server:
        super().__init__(name="support", route="/support")
class SalesAgent(AgentBase):
        super().__init__(name="sales", route="/sales")
server.register(SupportAgent())
server.register(SalesAgent())
server.run(host="0.0.0.0", port=3000)
Access agents at:
* `http://localhost:3000/support`
* `http://localhost:3000/sales`
## Best Practices
1. **Use class-based agents** for anything beyond simple prototypes
2. **Organize configuration** into logical private methods
3. **Set explicit credentials** in production via environment variables
4. **Use meaningful agent names** for logging and debugging
5. **Test with swaig-test** before deploying
class WellOrganizedAgent(AgentBase):
        super().__init__(name="organized-agent")
        self._configure_voice()
        self._configure_prompts()
        self._configure_functions()
        self._configure_skills()
    def _configure_voice(self):
        self.set_params({"end_of_speech_timeout": 500, "attention_timeout": 15000})
    def _configure_prompts(self):
    def _configure_functions(self):
        self.define_tool(name="help", description="Get help", parameters={}, handler=self.get_help)
    def _configure_skills(self):
    def get_help(self, args, raw_data):
        return FunctionResult("I can help you with...")
