# Adding Skills
> Add skills to your agents with add_skill() and pass configuration parameters to customize behavior.
[built-in-skills]: /docs/server-sdks/guides/builtin-skills
### Basic Usage
Add a skill with no configuration:
| Language   | Syntax                                      |
| Python     | `self.add_skill("datetime")`                |
| TypeScript | `await agent.addSkill(new DateTimeSkill())` |
class MyAgent(AgentBase):
        # Add skill with default settings
### With Configuration
Pass parameters as a dictionary (or map/hash depending on language):
| Language   | Syntax        |
| Python     | `self.add_skill("web_search", {"api_key": "KEY", "num_results": 5})`           |
| TypeScript | `await agent.addSkill(new WebSearchSkill({ api_key: 'KEY', num_results: 5 }))` |
        # Add skill with configuration
            "api_key": "YOUR_API_KEY",
            "search_engine_id": "YOUR_ENGINE_ID",
            "num_results": 5
### Method Chaining
`add_skill()` returns `self` for chaining (in languages that support it):
| Language   | Chaining syntax        |
| Python     | `self.add_skill("datetime").add_skill("math").add_skill("joke")`                                                           |
| TypeScript | `await agent.addSkill(new DateTimeSkill()); await agent.addSkill(new MathSkill()); await agent.addSkill(new JokeSkill());` |
        # Chain multiple skills
        (self
            .add_skill("math")
            .add_skill("joke"))
### Multiple Skills
Add as many skills as needed:
class AssistantAgent(AgentBase):
        super().__init__(name="assistant")
        # Add multiple capabilities
        self.add_skill("math")
        self.add_skill("wikipedia_search")
        self.prompt_add_section(
            "Role",
            "You are a helpful assistant."
            "Capabilities",
            body="You can help with:",
            bullets=[
                "Date and time information",
                "Math calculations",
                "Wikipedia lookups"
### Checking Loaded Skills
## Check if skill is loaded
if agent.has_skill("datetime"):
    print("Datetime skill is active")
## List all loaded skills
skills = agent.list_skills()
print(f"Loaded skills: {skills}")
### Removing Skills
## Remove a skill
agent.remove_skill("datetime")
### Multi-Instance Skills
Some skills support multiple instances. Give each instance a unique `tool_name`:
| Language   | Two instances of web\_search                                                  |
| Python     | `self.add_skill("web_search", {"tool_name": "search_news", ...})`             |
| TypeScript | `await agent.addSkill(new WebSearchSkill({ tool_name: 'search_news', ... }))` |
class MultiSearchAgent(AgentBase):
        super().__init__(name="multi-search")
        # First search instance for news
            "search_engine_id": "NEWS_ENGINE_ID"
        # Second search instance for documentation
            "tool_name": "search_docs",
            "search_engine_id": "DOCS_ENGINE_ID"
            "Role",
            "You can search news and documentation separately."
### SWAIG Fields
Add extra SWAIG metadata to skill functions:
self.add_skill("datetime", {
    "swaig_fields": {
        "fillers": {
            "en-US": ["Let me check the time..."]
### Error Handling
Skills may fail to load:
try:
    agent.add_skill("web_search", {
        "api_key": "invalid"
except ValueError as e:
    print(f"Skill failed to load: {e}")
Common errors:
| Error                 | Cause                         | Solution            |
| Skill not found       | Invalid skill name            | Check spelling      |
| Missing parameters    | Required config not provided  | Add required params |
| Package not installed | Missing Python dependency     | Install with pip    |
| Env var missing       | Required environment variable | Set the variable    |
### Skills with Environment Variables
Some skills read from environment variables:
import os
## Set API key via environment
os.environ["GOOGLE_SEARCH_API_KEY"] = "your-key"
## Skill can read from env
    "api_key": os.environ["GOOGLE_SEARCH_API_KEY"],
    "search_engine_id": "your-engine-id"
### Complete Example
#### Python
#!/usr/bin/env python3
## full_featured_agent.py - Agent with multiple configured skills
class FullFeaturedAgent(AgentBase):
        super().__init__(name="full-featured")
        # Simple skills (no config needed)
            "Role",
            "You are a versatile assistant named Alex."
            "Capabilities",
            bullets=[
                "Current date and time",
                "Math calculations"
    agent = FullFeaturedAgent()
#### TypeScript
```typescript
import { AgentBase, DateTimeSkill, MathSkill } from '@signalwire/sdk';
const agent = new AgentBase({ name: 'full-featured' });
agent.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
// Simple skills (no config needed)
agent.promptAddSection('Role', { body: 'You are a versatile assistant named Alex.' });
agent.promptAddSection('Capabilities', {
  body: 'You can help with:',
  bullets: ['Current date and time', 'Math calculations'],
await agent.run();
Skills like `web_search` and `joke` require additional configuration or API keys. See the [Built-in Skills][built-in-skills] section for details on each skill's requirements.
### Best Practices
**DO:**
* Add skills in **init** before prompt configuration
* Use environment variables for API keys
* Check skill availability with has\_skill() if conditional
* Update prompts to mention skill capabilities
**DON'T:**
* Hardcode API keys in source code
* Add duplicate skills (unless multi-instance)
* Assume skills are available without checking
* Forget to handle skill loading errors
