Rate limits
Platform basics
The below throughput limits apply to Voice and Messaging. These are account-level limits that count activity from all Projects within your Space. Contact Support to increase Voice and Messaging throughput.
Rate limits and backlogs for Messaging and Voice are separate. For example, exceeding the Voice rate limit does not cause outbound messages to queue.
Voice
View pricing and contact Support to increase calling throughput.
Because faxes are sent via phone calls, the below rate limits apply to faxes as well.
ValueDefault limit
Calls1 call per second (CPS)
Backlog10,000 queued calls
Messaging
View pricing and contact Support to increase messaging throughput for toll-free or short code numbers.
Number typeDefault limit
Toll-free3 messages per second (MPS)
US long code (10DLC)4 MPS
Actual throughput may be lower or higher depending on carrier and TCR limits
Canadian long code1 MPS
Short code10 MPS
Backlog10,000 queued messages
Larger messages are automatically split into smaller “segments” which are sent as individual messages. Each of these segments counts towards the messages per second (MPS) limit. Consult the guide to Messaging Character Limits for more information.
API
The below limits apply to all API requests across the SignalWire platform. Every HTTP request includes the user’s current limit and remaining requests in its X-Header.
HTTP verbLimit
GET DELETEEffectively unlimited
POST PUT PATCH13800 requests per 10 seconds
Space
These limits apply to SignalWire Spaces not in Trial mode. New accounts remain in Trial mode until at least $5 USD of credit is added.
Space limitDefault
Number of ProjectsUnlimited
Phone numbers per Project1000
Verified IDs1000
Call backlog10,000
Message backlog10,000
Queue and backlog system
When an application sends calls or messages to SignalWire at a rate exceeding the applicable rate limit, SignalWire queues these messages or calls in the order received. The backlog is the limit to the number of queued (pending) calls or messages. The Voice backlog and Messaging backlog are both 10,000 by default.
When the backlog for calls is full, SignalWire will stop adding additional calls to the Voice queue. Similarly, when the backlog for messages is full, SignalWire will stop adding to the Messaging queue. The platform will process queued calls or messages at the maximum applicable rate, and add new calls or messages to the queue as long as the backlog has not been reached.
The Voice and Messaging backlogs are entirely separate.
If you would like to raise your Voice or Messaging backlog, fill out the Space Increase Request Form.
Request increased limits
Request an increase to your Space’s default limits by filling out the SignalWire Space Increase Request Form and submitting the required documentation to start the account verification process. SignalWire’s Space Compliance team reviews submissions and will notify you of the results.
Phone number limits
Requests for more than 1000 phone numbers require additional verification. Please be prepared to share detailed information about your use case.
If approved, you MUST set up auto top up on your project to the total cost of the numbers monthly before the limit will be raised. This requirement prevents the suspension of services due to insufficient balance. Pricing for phone numbers can be found on the SignalWire pricing page. See Auto Top-Up for how it is charged and what enabling it commits you to.
