API credentials
The API credentials found on this page are your key to accessing SignalWire’s APIs and SDKs.
The API Credentials page on the SignalWire Dashboard.
Most SignalWire API endpoints require authentication using HTTP Basic Auth. HTTP Basic Authentication requires you to send an Authorization header with your Project ID and API Token.
Each Project has its own Project ID and API Authentication Tokens you will need to use when making a request to the API. Some methods will also require you to pass your Space URL. Subprojects work the same way: each one has its own Project ID and tokens, and a root Project can issue a token for one of its Subprojects with Create API token.
  • Project ID: Use this UUID to specify your Project to the API.
  • Space URL: Use this URL to access SignalWire APIs. For example: https://{Your_Space_Name}.signalwire.com/api/calling/calls
  • API Tokens: Authentication tokens to access the API. You can have multiple tokens for each Project.
An API token acts for one Project. To administer the Space itself over the API, such as managing members, the balance, or billing, or to create a root Project, use a Personal access token instead. It is created from your user menu in the Dashboard rather than on this page, and it carries your owner or admin role instead of a Project’s scopes.
API tokens are protected and used server-side to access the API. The tokens we refer to when using Video, Chat, or Fabric products in the browser are not the same tokens we generate and store here. Instead, you use your API token to call an endpoint that generates a client-side token:
For more details on authentication methods, see the REST API Authorization guide.
Generate a new API token
To generate a new API token, click the blue ”+ New” button. A “New API Token” form will open. Give your token a descriptive name to help differentiate it in logs and for debugging.
You can edit the token name and allowed scopes later by clicking the ⋯ button and selecting “Edit.” You may also delete a token from the same dropdown menu or the Edit page.
To replace a token’s value over the API without changing its name or scopes, use Regenerate API token. The previous value stops working immediately, so update everything that uses it with the new value from the response. List API tokens returns each token’s ID and when it last authenticated a request, but never its value.
Token format
New API tokens begin with swapi_ and are 42 characters long. Tokens created earlier begin with PT and are 50 characters long. Both formats authenticate the same way, and a Project can hold tokens in both formats at the same time.
Existing PT tokens are not deprecated and have no end date, so there is nothing to migrate.
Treat a token as an opaque string. Don’t parse it, match it against a pattern, or assume a fixed length, in either format.
Token scopes
API tokens can be configured with specific scopes that limit which APIs the token can access. When creating or editing an API token in the Dashboard, you can select which scopes to enable under the “Permissions” section.
For security best practices, only enable the scopes your application actually needs. This limits the potential impact if a token is compromised.
If your API request returns a 401 Unauthorized error, verify that your API token has the required scope enabled for that endpoint in the Dashboard.
Use an API token
All API requests must be made with proper authentication over HTTPS. Calls made over plain HTTP or without auth will fail.
Find the correct credentials structure for each specific call in the SDK Reference, REST API Reference, or in a specific Guide you may wish to follow.
For example, list video rooms with the REST client in the Server SDKs, or call the REST API directly:
client = RestClient(
project="<Project ID>",
token="<API token>",
host="<space-name>.signalwire.com",
rooms = client.video.rooms.list()
for room in rooms.get("data", []):
print(f"{room['name']}: {room['id']}")
