> This page is for Platform.
# API credentials
> Learn how to access your SignalWire API Space.
The API credentials found on this page are your key to accessing SignalWire's APIs and SDKs.
Open **API Credentials** in the Dashboard to find the current Project's **Project ID** and **Space URL**. Reveal and copy an existing API token or select **+ New** to create one.
Most SignalWire API endpoints require authentication using
[HTTP Basic Auth](https://en.wikipedia.org/wiki/Basic_access_authentication).
HTTP Basic Authentication requires you to send an Authorization header with your Project ID and API Token.
Each Project has its own Project ID and API Authentication Tokens you will need to use when making a request to the API.
Some methods will also require you to pass your Space URL.
[Subprojects](/docs/platform/projects#subprojects) work the same way: each one has its own Project ID and tokens,
and a root Project can issue a token for one of its Subprojects with
[Create API token](/docs/apis/rest/project-tokens/create-token).
* **Project ID:** Use this UUID to specify your Project to the API.
* **Space URL:** Use this URL to access SignalWire APIs.
  For example: `https://{Your_Space_Name}.signalwire.com/api/calling/calls`
* **API Tokens:** Authentication tokens to access the API.
  You can have multiple tokens for each Project.
An API token acts for one Project. To administer the Space itself over the API, such as managing members, the balance,
or billing, or to create a root Project, use a [Personal access token](/docs/apis/authorization#personal-access-tokens)
instead. It is created from your user menu in the Dashboard rather than on this page, and it carries your owner or admin
role instead of a Project's scopes.
> **Info**
> API tokens are protected and used server-side to access the API.
> The tokens we refer to when using Video, Chat, or Fabric products in the browser are not the same tokens we generate and store here.
> Instead, you use your API token to call an endpoint that generates a client-side token:
> * **Video Room Tokens**: Generated via the
>   [Create Room Token](/docs/apis/rest/video/room-tokens/create-room-token) endpoint.
> * **Chat Tokens**: Generated for chat applications via the
>   [Create Chat Token](/docs/apis/rest/chat-tokens/create-chat-token) endpoint.
> * **[Subscriber](/docs/platform/subscribers) Access Tokens (SAT)**: Generated via the
>   [Create Subscriber Token](/docs/apis/rest/subscribers/tokens/create-subscriber-token) endpoint for Fabric applications.
> For more details on authentication methods, see the [REST API Authorization guide](/docs/apis/authorization).
## Generate a new API token
To generate a new API token, click the blue "+ New" button. A "New API Token" form will open.
Give your token a descriptive name to help differentiate it in logs and for debugging.
You can edit the token name and allowed scopes later by clicking the **⋯** button and selecting "Edit."
You may also delete a token from the same dropdown menu or the Edit page.
To replace a token's value over the API without changing its name or scopes, use
[Regenerate API token](/docs/apis/rest/project-tokens/regenerate-token). The previous value stops
working immediately, so update everything that uses it with the new value from the response.
[List API tokens](/docs/apis/rest/project-tokens/list-tokens) returns each token's ID and when it
last authenticated a request, but never its value.
### Token format
New API tokens begin with `swapi_` and are 42 characters long. Tokens created earlier begin
with `PT` and are 50 characters long. Both formats authenticate the same way, and a Project
can hold tokens in both formats at the same time.
Existing `PT` tokens are not deprecated and have no end date, so there is nothing to migrate.
Treat a token as an opaque string. Don't parse it, match it against a pattern, or assume a
fixed length, in either format.
### Token scopes
API tokens can be configured with specific scopes that limit which APIs the token can access.
When creating or editing an API token in the Dashboard,
you can select which scopes to enable under the "Permissions" section.
> **Tip**
> For security best practices, only enable the scopes your application actually needs. This limits the potential impact if a token is compromised.
If your API request returns a `401 Unauthorized` error,
verify that your API token has the required scope enabled for that endpoint
in the Dashboard.
## Use an API token
All API requests must be made with proper authentication over HTTPS.
Calls made over plain HTTP or without auth will fail.
Find the correct credentials structure for each specific call in the [SDK Reference](/docs/server-sdks/reference),
[REST API Reference](/docs/apis),
or in a specific [Guide](/docs/browser-sdk/guides/overview) you may wish to follow.
For example, list video rooms with the REST client in the [Server SDKs](/docs/server-sdks), or call the **REST API** directly:
#### Server SDKs
#### Python — REST client
client = RestClient(
    project="<Project ID>",
    token="<API token>",
    host="<space-name>.signalwire.com",
rooms = client.video.rooms.list()
for room in rooms.get("data", []):
    print(f"{room['name']}: {room['id']}")
#### TypeScript — REST client
```typescript
  project: "<Project ID>",
  token: "<API token>",
  host: "<space-name>.signalwire.com",
const rooms = await client.video.rooms.list();
for (const room of rooms.data ?? []) {
  console.log(`${room.name}: ${room.id}`);
#### cURL
This example uses curl with the `-u` flag to make a request with Basic Auth.
```shell
curl https://<space-name>.signalwire.com/api/video/rooms \
  -u '<Project ID>:<API token>'
#### Node.js
This example uses [Axios](https://axios-http.com/), so install it before you run the script.
```javascript
// npm install axios
import axios from "axios";
await axios
  .get("https://<space-name>.signalwire.com/api/video/rooms", {
    auth: { username: "<Project ID>", password: "<API token>" },
  .then((response) => {
    console.log(JSON.stringify(response.data));
  .catch((error) => {
    console.log(error);
## Signing key
The **Signing Key** on this page is the secret SignalWire uses to sign the requests it sends to
your webhooks. It appears once the Project has at least one API token. Select **Show** to reveal
and copy it, then use it to [verify webhook signatures](/docs/platform/webhooks#verify-webhook-signature).
New signing keys begin with `swpsk_` and are 42 characters long. Keys created earlier begin with
`PSK_` and are 28 characters long. Both formats sign and verify webhooks the same way, and existing
`PSK_` keys keep working with nothing to reset or migrate.
After you select **Show**, **Reset** replaces the current key with the next key, which the
confirmation dialog shows before you proceed. [Rotate signing key](/docs/apis/rest/projects/rotate-signing-key)
promotes the same next key through the API. Either way, the new key takes a minute or two to become
active, and until then requests can still arrive signed with the old key. Update your verification
code to accept a signature that verifies with either key during that window, then remove the old key.
Because that next key already exists, a Project created before the `swpsk_` format can receive a
`PSK_` key from its first reset or API rotation.
Treat a signing key as an opaque string. Signature verification uses the whole key, so don't
parse it, match it against a pattern, or assume a fixed length.
