Play Audio or TTS
This node allows you to play an audio file, play silence, play a ringtone, or play text-to-speech.
Node Settings
Text to Speech
object
Text to Speech node options. See Text to Speech Settings.
Play Audio File
object
Play Audio file node options. See Play Audio File Settings.
Node options for Text to Speech.
Language
string
The language to use for the text-to-speech.
Gender
string
The gender of the voice to use for the text-to-speech.
Voice
string
The voice to use for the text-to-speech.
Please note that any voices that show (premium) next to the name will be billed at the Premium TTS rate.
Text
string
The text to convert to speech. SSML can be used to customize the speech. The text can also include variables to be replaced with the variable value.
SSML Example: <speak>Here is a <say-as interpret-as="characters">SSML</say-as> example</speak>
Variables Example: Hello, you got a call from %{call.from}
Node options for Play Audio File.
Audio File
string
A URL of a audio file to play.
Additionally a ringtone or silence can be played over the call.
Ringtone Format: silence:<time in seconds> (ex: silence:5)
Silence Format: ring:<time in seconds><ringtone code> (ex: ring:5:jp)
Example
Text to Speech node example with variable.
