Hang Up Call
The Hang Up Call node will disconnect a call and end the flow.
This node is not strictly required, as calls will automatically end when the call reaches the end of a flow.
The Reason parameter is used for logging purposes and does not change the behavior of the Hang Up Call node.
The Hangup Call node.
Node Settings
Reason
string
The reason for hanging up the call.
Possible Values: Busy, Decline, Hang up
Default Value: Busy
