Translate calls
Let two people talk across languages on one call
Live translation lets two people who speak different languages talk on one call. SignalWire recognizes what each person says, translates it, and speaks the translation to the other person in a synthesized voice. Start by translating a call to your number, with a small server that prints each translated utterance, then start translation from code, read the translated conversation on your webhook, choose voices and tone filters, get AI summaries, and stop translating.
Pick the right product for call translation
Translation is available across these products, but not every function is available on each.
FunctionSWMLWebSocket (Relay)RESTBrowser SDKCall Flow Builder
Translate both sides of a call as it happens
Get each translated utterance on your webhook as it’s spoken
Get an AI summary of the conversation, during or after the call
Stop translating before the call ends
  • SWML is the document that describes how the call should flow. The Server SDKs’ SWML builder writes it, or you can write it by hand.
  • WebSocket (Relay), a Server SDK namespace, holds a live WebSocket connection to a call in progress and controls it from code.
  • The REST Calling API sends the same commands as Relay to a call in progress over HTTP, by call ID, from any process.
  • The Browser SDK places and answers calls in a web page. Translation is started by the server-side products above.
  • Call Flow Builder draws call flows on a canvas, with a node for each step of the call. Translation is started by the products above.
Prepare for call translation
This guide answers and forwards calls the way Make and receive calls and Forward calls do. Have these values ready:
  • Your Space URL, such as <YOUR_SPACE>.signalwire.com.
  • Your Project ID and an API token with the Voice permission.
  • A phone number in your Space.
  • Two phones you can answer: one to call your number from, and one that receives the translated call. Ask a second person to answer it, or put both phones in front of you.
  • A machine that can run a small server, and a tunnel such as ngrok that gives it a public HTTPS URL.
Trial projects only call and receive calls from verified numbers
A trial project only places calls to and receives calls from numbers you’ve purchased or verified, and can’t call internationally. Verify both phones you’ll test with, as Prepare for your first call shows.
Translating a call can require consent
Translation captures what people say on the call and sends the text to your webhook. Many jurisdictions require you to tell callers before you record or transcribe them. Check the rules that apply to your callers before you translate a real conversation.
If you only need the text of a call in one language, see Transcribe calls instead.
ValueReplace with
<YOUR_API_TOKEN>Your API token with the Voice permission, used only in server code
<YOUR_PUBLIC_HOST>The public hostname of your server’s tunnel
<YOUR_BASIC_AUTH_PASSWORD>A password you choose for the SWML your server serves
<YOUR_TRANSLATION_WEBHOOK_URL>Your server’s translation webhook, https://<YOUR_PUBLIC_HOST>/translations
<YOUR_DESTINATION>The phone that receives the translated call, in E.164 format, such as +12025550123
<YOUR_CALLER_ID>Your SignalWire phone number, or a verified caller ID, in E.164 format, when Relay connects the call
<YOUR_CALL_ID>The ID of a live call, when you send a command over REST
How call translation works
The live_translate SWML method and the calling.live_translate command, sent over Relay or REST, all take the same action: start a session, summarize it, or stop it. start names two languages, from_lang and to_lang, and lists the sides of the call to translate in direction:
  • remote-caller is the audio SignalWire receives from the call: the person who called your number, or the person your app dialed.
  • local-caller is the audio SignalWire sends into the call, such as the other party of a connect.
For each side you list, SignalWire mutes that person’s own voice and plays the translation in its place, so the listener hears only the translated speech. With both sides listed, each person hears only the other’s translation. A side you leave out passes through untouched.
Bayview Taxi uses this for riders who call in Spanish. Their calls are connected to Ada, a dispatcher who speaks English. Every sample in this guide starts translation with the same values:
"from_lang": "es-ES",
"to_lang": "en-US",
"direction": ["local-caller", "remote-caller"]
With those values, each person speaks and hears one language:
PersonSide of the callSpeaksHears the other person in
The rider, who calls your numberremote-callerSpanish, the from_langSpanish, in the from_voice voice
Ada, whom the call connects tolocal-callerEnglish, the to_langEnglish, in the to_voice voice
The order of direction decides which side speaks which language. With local-caller listed first, as here, the caller speaks from_lang and the connected party speaks to_lang. Listing remote-caller first swaps the two, so keep this order and change the languages to fit your callers. from_voice always speaks from_lang, and to_voice always speaks to_lang. When you list one side only, that side speaks to_lang, and the other person hears it in from_lang.
The local-caller side carries a voice only once another party is on the call, so the samples start translation, then connect the caller to Ada. Translation runs in the background: after start, the call moves on to its next step at once.
When the session has a webhook, SignalWire sends it HTTP POST requests: one for each translated utterance when live_events is true, one when you ask for a summary, and one with the whole conversation when the session ends.
Translate a call
Every sample in this guide sends translation events to one small server that prints them. Run it first, then start translation from the product your app uses.
Translate a call via SWML
When someone calls your number, SignalWire fetches the call’s SWML from your server and runs it. The server below serves that document and receives the translation events, so one tunnel covers both.
1
Run the translation server
This server answers calls with a SWML document that starts translation and connects the caller to your second phone. It prints each translated utterance that arrives at /translations. The document is served only to requests that carry the username signalwire and the password you set.
# Install: python -m pip install signalwire-sdk fastapi "uvicorn[standard]"
# Save as translate_app.py and run: python translate_app.py
import uvicorn
from fastapi import FastAPI, Request
service = SWMLService(
name="translate-call",
swml = SWMLBuilder(service)
swml.answer().live_translate(action={
"start": {
"to_lang": "en-US",
"direction": ["local-caller", "remote-caller"],
"webhook": "<YOUR_TRANSLATION_WEBHOOK_URL>",
"live_events": True,
}).connect(to="<YOUR_DESTINATION>")
app = FastAPI()
# SignalWire fetches the call's SWML from the server's root URL.
app.include_router(service.as_router())
# Translation events arrive at /translations.
@app.post("/translations")
async def translations(request: Request):
event = await request.json()
kind = event["channel_data"]["content_disposition"]
if kind == "translate.translate_utterance":
for key in ("primary_utterance", "secondary_utterance"):
utterance = event.get(key)
if utterance:
print(f"{utterance['role']} [{utterance['lang']}]: {utterance['content']}")
elif kind == "translate.live_summary":
for key in ("primary_conversation_summary", "secondary_conversation_summary"):
if event.get(key):
print(f"Summary so far: {event[key]}")
elif kind == "translate.conversation_log":
print(f"Translation ended after {len(event['primary_conversation_log'])} utterances")
if event.get(key):
print(f"Summary: {event[key]}")
return {}
uvicorn.run(app, host="0.0.0.0", port=8080)
Start a tunnel to port 8080, such as ngrok http 8080, and use its hostname as <YOUR_PUBLIC_HOST> in the webhook URL before you start the server. Check that the document is reachable through the tunnel:
curl -u "signalwire:<YOUR_BASIC_AUTH_PASSWORD>" "https://<YOUR_PUBLIC_HOST>/"
The response is the SWML document, starting with {"version": "1.0.0". A 401 means the password doesn’t match the one in your server.
Point your phone number at the server
Create a SWML Script that fetches the document from your server:
  1. Open My Resources, select + Add, then Script, then SWML Script.
  2. Name it Translate call and leave Used For set to Calling.
  3. Under Handle Calls Using, choose External URL and enter https://signalwire:<YOUR_BASIC_AUTH_PASSWORD>@<YOUR_PUBLIC_HOST>/ in Primary Script URL.
  4. Select Create.
Then assign the script, a Resource, to your phone number:
Open Phone Numbers, select the number, and select Edit Settings. Under Inbound Call Settings, select Assign Resource, choose the Resource, and save. To assign from the Resource instead, open its Addresses & Phone Numbers tab, select + Add, then Phone Number, and pick a number you own.
A phone number's Edit page in the Dashboard showing the Assign Resource button under Inbound Call Settings
Assigning a Resource under a phone number's Inbound Call Settings
To do both in code, see Answer a call via SWML.
Call your number and speak Spanish
Call your SignalWire number from your first phone, and answer your second phone when it rings. Say something in Spanish on the first phone, such as “Necesito un taxi al aeropuerto.” The second phone hears it in English, in a synthesized voice, and never hears the Spanish. Answer in English on the second phone, and the first phone hears Spanish.
The server prints each utterance in both languages, with the side of the call that spoke:
remote-caller [es-ES]: Necesito un taxi al aeropuerto.
remote-caller [en-US]: I need a taxi to the airport.
local-caller [es-ES]: Claro. ¿Cuál es la dirección de recogida?
local-caller [en-US]: Sure. What's the pickup address?
Your wording and the translations will differ. When either phone hangs up, the server prints Translation ended after with the number of utterances. If it doesn’t work, see Troubleshoot call translation.
The same document in YAML and JSON, to paste into a hosted SWML Script instead:
version: 1.0.0
sections:
main:
- answer: {}
- live_translate:
action:
start:
from_lang: es-ES
to_lang: en-US
direction:
- local-caller
- remote-caller
webhook: <YOUR_TRANSLATION_WEBHOOK_URL>
live_events: true
- connect:
to: <YOUR_DESTINATION>
Start translation on a live call via WebSocket (Relay)
Send the live translate command to an answered call, passing the same action the SWML method takes. Translation events still go to your webhook, so keep the translation server and its tunnel running.
This handler subscribes to the translate-calls topic. When a call arrives, it answers, starts translation, and connects the caller to your second phone. It hangs up when the connected call ends.
# Save as translate_call_relay.py and run: python translate_call_relay.py
from signalwire.relay import ConnectEvent, RelayClient
client = RelayClient(
project="<YOUR_PROJECT_ID>",
token="<YOUR_API_TOKEN>",
contexts=["translate-calls"],
@client.on_call
async def handle_call(call):
print(f"Connect: {event.connect_state}")
if event.connect_state in ("disconnected", "failed") and call.state != "ended":
await call.hangup()
await call.answer()
await call.live_translate({
"start": {
"to_lang": "en-US",
await call.connect(
devices=[[{
"type": "phone",
"params": {
"timeout": 30,
await call.wait_for_ended()
client.run()
The Server SDKs send the action keys as written, so they stay in snake_case in every language. Run the handler, then create a Relay Application with translate-calls as its Topic and assign it to your phone number in place of the SWML Script, as Answer a call via WebSocket (Relay) shows. Call your number and speak Spanish: the handler prints Connect: connected when your second phone answers, and the translation server prints each utterance as in the SWML walkthrough.
To start translation on a call your process doesn’t hold, send the calling.live_translate command with the answered call’s ID and a start action. The call ID is the id from a dial response, or the call_id delivered to your SWML endpoint or webhook. The Server SDKs wrap the command:
# Save as translate_rest.py and run: python translate_rest.py
client = RestClient(
client.calling.live_translate(
"<YOUR_CALL_ID>",
action={
"start": {
"to_lang": "en-US",
print("Translation started")
To try it, run the program while a forwarded call from Forward calls is up and both phones are talking. The translation server starts printing utterances as soon as the command succeeds. The cURL request goes to Call commands.
Sending start again with the same languages while a session runs changes nothing. With different languages, it restarts translation in the new ones.
Read translation events on your webhook
Each request is a JSON POST. Read channel_data.content_disposition first, then the fields for that event:
content_dispositionSentFields to read
translate.translate_utteranceOnce per translated utterance, when live_events is trueprimary_utterance, secondary_utterance
translate.live_summaryWhen you send summarizeprimary_conversation_summary, secondary_conversation_summary
translate.conversation_logOnce, when the session endsprimary_conversation_log, secondary_conversation_log, and their summaries when ai_summary is true
Every event carries the conversation in both languages. The primary_ fields hold it in from_lang, and the secondary_ fields hold it in to_lang. role says which side of the call spoke, using the values you passed in direction. Every event also carries channel_data.call_id, so one server can follow several calls at once.
An utterance event looks like this, shortened to the fields the translation server reads:
"channel_data": {
"content_type": "text/json",
"content_disposition": "translate.translate_utterance",
"call_id": "76ac3c36-56da-4a3e-a0d6-b5f8df6da9ad"
"primary_utterance": {
"role": "remote-caller",
"lang": "es-ES",
"content": "Necesito un taxi al aeropuerto.",
"utterance_id": "0b6f3c1e-8a52-4a8f-9a8e-2f1d7c9e4b10"
"secondary_utterance": {
"lang": "en-US",
"content": "I need a taxi to the airport.",
Each utterance can also carry confidence, the recognizer’s confidence in the text, and filter_type and filter_value when a tone filter rewrote it.
The event sent when the session ends carries the whole conversation in order, in each language. It also carries translate_data, which lists each translated side with the language it was spoken in and the language it was translated to. With ai_summary set to true, translate_data is instead a flat object for the first-listed side only, with from_language, to_language, to_voice, role, and position. Log entries name their language in language:
"channel_data": {
"content_disposition": "translate.conversation_log",
"translate_data": {
"remote-caller": { "role": "remote-caller", "from_language": "es-ES", "to_language": "en-US" },
"local-caller": { "role": "local-caller", "from_language": "en-US", "to_language": "es-ES" }
"primary_conversation_log": [
{ "role": "remote-caller", "language": "es-ES", "content": "Necesito un taxi al aeropuerto." },
{ "role": "local-caller", "language": "es-ES", "content": "Claro. ¿Cuál es la dirección de recogida?" }
"secondary_conversation_log": [
{ "role": "remote-caller", "language": "en-US", "content": "I need a taxi to the airport." },
{ "role": "local-caller", "language": "en-US", "content": "Sure. What's the pickup address?" }
SignalWire sends this event whenever the session has a webhook, whether the session ended because you stopped it or because the call ended. A summary you request mid-call carries primary_conversation_summary and secondary_conversation_summary, one summary for each conversation log.
Answer each request with a 2xx status, and do slow work after you respond. SignalWire retries an utterance event that fails to connect or gets a 5xx status, so a slow handler can receive the same utterance more than once. Use utterance_id to ignore repeats.
Protect your webhooks
Requests carry an X-SignalWire-Signature header, so your server can confirm they came from SignalWire, as Verify webhook signature shows. You can also put a username and password in the webhook URL, as in https://<USERNAME>:<PASSWORD>@<YOUR_PUBLIC_HOST>/translations, and SignalWire sends them as HTTP Basic authentication. If you reject unsigned requests, keep live_events set to true: with it off, the end-of-session event can arrive without a signature.
Translation options: voices, tone filters, and speech detection
start takes more options alongside the languages. The same options work in SWML, Relay, and REST. The live_translate reference lists every option.
Choose the voices for each language
from_voice speaks the from_lang translations, and to_voice speaks the to_lang translations. Without them, both use azure.en-US-RyanMultilingualNeural. A voice is the engine name in lowercase, a dot, and the voice ID, such as azure.es-ES-ElviraNeural or elevenlabs.josh. The engine prefix is case-sensitive: a voice whose engine prefix SignalWire doesn’t recognize, such as a capitalized one, falls back to the default voice. The text-to-speech voices pages list each engine’s voices and languages, such as Azure and ElevenLabs.
Change the tone of the translation with filters
A filter rewrites the translation in a tone you choose before it’s spoken. filter_from applies to speech in from_lang, here what the rider says, and filter_to applies to speech in to_lang, here what Ada says. Use a preset or your own instruction:
ValueThe translation is
politeStripped of insults, keeping the speaker’s sentiment
rudeGiven insults, keeping the speaker’s sentiment
professionalStripped of slang
shakespeareRewritten in iambic pentameter
gen-zRewritten in Gen Z slang
prompt:<instruction>Rewritten as your instruction says, such as prompt:Use formal business language
Set from_lang and to_lang to the same language and add a filter to rewrite the tone of a call without translating it. Without a filter, a same-language session repeats each person’s words in the synthesized voice.
This change to the first run’s start action has the rider hear Ada in an Azure Spanish voice and Ada hear the rider in an ElevenLabs voice, and keeps the rider’s words polite for Ada:
"start": {
"to_lang": "en-US",
"from_voice": "azure.es-ES-ElviraNeural",
"to_voice": "elevenlabs.josh",
"filter_from": "polite",
Tune speech detection for your callers
speech_engine picks the speech recognizer: deepgram, the default, or google. When the recognizer splits utterances too early or too late for your callers, tune vad_silence_ms, the silence in milliseconds that ends an utterance, 700 by default with Deepgram and 500 with Google. vad_thresh, 400 by default, sets how loud audio must be to count as speech.
Get AI summaries of the translated conversation
Live translation can hand the conversation to an AI model and send you a summary of each conversation log, either once when the session ends or whenever you ask while the call is up.
Summarize the call when translation ends
Add ai_summary: true to start, and optionally ai_summary_prompt to say what the summary should contain. The event sent when the session ends then includes primary_conversation_summary and secondary_conversation_summary. This change to the first run’s start action works the same way in Relay and REST:
"start": {
"to_lang": "en-US",
"ai_summary": True,
"ai_summary_prompt": "List the pickup address, the destination, and the pickup time.",
After the call ends, the translation server prints each summary on a Summary: line.
Summarize a call in progress via WebSocket (Relay)
Send the summarize action while translation is running to get a summary of the conversation so far, and keep translating. Its prompt and webhook are optional. An empty summarize object sends the summary to the webhook from start and uses the default summary prompt. In the Relay handler, add it wherever your app needs a summary. The REST client sends the same action to a call by ID:
"summarize": {"prompt": "Summarize the ride request in one sentence."}
When the summaries arrive, the translation server prints each one on a Summary so far: line. The cURL request goes to Call commands. A SWML document can send the same action as a live_translate step.
Stop call translation
A session stops by itself when the call ends. Stop it earlier with the stop action, which stops both sides at once. SignalWire then sends the event for the end of the session with everything translated until that point.
Stop call translation via SWML
Set action to the string stop:
swml.live_translate(action="stop")
Stop call translation via WebSocket (Relay)
The Relay samples send stop as a key with an empty object, and the REST samples send the string stop. The platform accepts either form:
await call.live_translate({"stop": {}})
To translate again, send a new start action.
Find the symptom you see:
  • Each phone hears the other’s own voice, untranslated. Translation didn’t start. Check that start has from_lang, to_lang, and direction. A SWML document carries on with the call when start is missing one of them, so the call connects without translation.
  • The translations make no sense, or come out in the wrong language. Each person is speaking the other’s language. Check the order of direction against How call translation works: with local-caller first, the caller speaks from_lang.
  • You hear a different voice from the one you set. SignalWire didn’t recognize the voice and used the default. Check that the engine name is lowercase, as in azure.es-ES-ElviraNeural.
  • The call connects and translates, but your server prints nothing. SignalWire couldn’t reach your webhook. Check that the URL begins with https:// and ends with /translations, and that the tunnel is running and points at port 8080.
  • The server prints the end of the session, but no utterances. live_events isn’t true on start. Without it, the conversation arrives only when the session ends.
  • You hear an error or silence when you call your number. SignalWire couldn’t fetch your SWML. Rerun the curl check with the exact URL in the SWML Script, and confirm that the server and the tunnel are still running. A 401 means the password in the URL doesn’t match the server’s.
  • You hear your number’s old behavior. The number still points at another Resource. Open it under Phone Numbers and check Inbound Call Settings.
  • The second phone never rings. Check that <YOUR_DESTINATION> is in E.164 format, and in a trial project, that it’s a verified number.
Next steps
