Transfer calls with SIP REFER
SIP REFER lets your app ask a SIP device or PBX to transfer a call to another destination. Start by transferring a call to another SIP address and handling the result, with a bridged transfer as the fallback, then track the transfer as it progresses.
Choose an approach
Each approach sends the REFER and receives its result in its own way, so pick the one that matches how your app controls the call and follow only its section. The sections don’t build on each other, and code from one doesn’t carry over to another.
  • SWML: add sip_refer to your call document and branch on the result. The document waits for the transfer to finish. Optionally send events to a webhook.
  • WebSocket (Relay): send the REFER on an answered call from a Relay client and handle events in your code. No public URL is needed.
  • REST: send the REFER by call ID from any process and receive results at a webhook.
Prepare for SIP REFER
Start with working call setup from Make and receive calls. You also need a SIP device or PBX that SignalWire can call, and a second SIP address the device can transfer the call to. Use a device and a target you can answer to test both stages of the transfer. The device must:
  • Accept a REFER during an established call and reply 202 Accepted. A device that doesn’t support REFER, or that refuses transfers, replies with an error such as 403, 405, or 501.
  • Place a call to the Refer-To URI. The device’s network and dial plan must allow calls to the target.
  • Report the new call’s progress in NOTIFY requests. Without them, SignalWire can’t tell whether the target answered: it waits about 32 seconds for the first NOTIFY, then reports success.
  • Accept authentication credentials if it challenges the REFER. Supply username and password with the transfer request when required.
Check your device or PBX documentation for how it handles an incoming REFER, sometimes listed as blind or unattended transfer. The SIP overview covers registering a softphone with SignalWire for testing, and SIP trunking covers connecting a PBX.
SIP REFER only works on SIP calls
REFER is a SIP request, so the call must be a SIP call, such as one SignalWire places to a SIP URI. For phone and browser call legs, Relay and REST reject the command, and SWML sets sip_refer_result to error. Use a bridged transfer, such as SWML connect, for those call legs.
ValueReplace with
<YOUR_API_TOKEN>Your API token, used only in server code
<YOUR_CALLER_ID>The caller ID SignalWire presents to your device, such as your SignalWire phone number in E.164 format
<YOUR_SIP_DEVICE>The SIP URI of the device or PBX that answers the call and receives the REFER, such as sip:1001@pbx.example.com
<YOUR_TRANSFER_TARGET>The SIP URI the device should call, starting with sip: or sips:, such as sip:1002@pbx.example.com
<YOUR_STATUS_WEBHOOK_URL>A public URL that receives calling.call.refer events
<YOUR_CALL_ID>The ID of an answered SIP call
How SIP REFER works
SignalWire sends a REFER request on an answered SIP call, with the transfer target in the Refer-To header. The SIP device or PBX accepts with 202 Accepted, places a new call to the target, and reports its progress to SignalWire in NOTIFY requests. When the target answers, your app ends SignalWire’s leg. The device and target continue their call directly.
This is a blind, or unattended, transfer: the device calls the destination without your app speaking to the recipient first.
Transfer with SIP REFER REFER (Refer-To: target) 202 Accepted inProgress INVITE NOTIFY (100 Trying) 200 OK NOTIFY (200 OK) success Hang up BYE Your app SignalWire SIP device or PBX Transfer target
SignalWire waits about 32 seconds for the device to accept the REFER, about 32 seconds for its first NOTIFY, and up to two minutes for the target to answer. Only one REFER can run on a call at a time. Your app must hang up SignalWire’s leg after a successful transfer.
When to use SIP REFER instead of a bridged transfer
Use SIP REFER when a SIP device or PBX can reach the destination directly and your app no longer needs to control the call. The device places the new call from its own network, and your app ends SignalWire’s leg after the transfer succeeds.
For a bridged transfer, such as SWML connect, SignalWire calls the target and joins the two call legs. Both legs remain active and carry audio through SignalWire for the rest of the conversation. This keeps your app in control of the call and requires the target to be reachable from SignalWire.
SIP REFERBridged transfer
Who calls the targetThe SIP device or PBXSignalWire
SignalWire’s leg after the transferYour app ends it; the device and target continue directlyRemains active for the rest of the call
Calls it works onSIP calls to a device that supports REFERPhone, SIP, and browser calls
The target must be reachable fromThe device or PBXSignalWire
Your app after the transferCan’t play, record, or control the transferred callKeeps controlling the call
Common uses include:
  • Return a call to your PBX. A PBX sends a call to a SignalWire SIP address so an app can answer it, and the app then decides which extension, queue, or group should take the call. REFER lets the PBX connect the caller there directly.
  • Reach a destination only the device can dial, such as an internal extension or a SIP URI on a private network.
  • Remove SignalWire from the audio path after the transfer, so the rest of the conversation no longer uses two SignalWire call legs.
Use a bridged transfer instead when the call isn’t a SIP call, when you need to keep recording or controlling the call after the transfer, or when the device doesn’t support REFER.
SIP REFER results and response codes
Every approach reports the same final result: SWML sets it in sip_refer_result, and Relay and webhooks carry it as the event’s state.
ResultMeaningTypical action
successThe target answered. Also reported when the device accepted the REFER but sent no NOTIFY within about 32 seconds, when the call ended before the first NOTIFY, and when the target was still ringing after two minutesHang up SignalWire’s leg
busyThe target was busy or declined the call (486, 600, or 603)Tell the caller, or try another target
noAnswerThe target didn’t answer or wasn’t found (404, 487, or 604)Tell the caller, or try another target
cancelThe call ended while the target was ringing, after the device reported progress in a NOTIFYNone; the call is over
errorThe device rejected the REFER, didn’t reply within about 32 seconds, or the call ended before it replied; or the target’s call failed with another response codeBridge the call through SignalWire
A success result doesn’t always mean the target answered. If your app needs to know, check the target’s response code before it hangs up: a 2xx code means the target answered.
Response codeHolds
The device’s reply to the REFERThe reply, such as 202 or 403. 0 when the device didn’t reply. -1 when the device replied 503 to three attempts in a row
The target’s responseThe target’s final response from NOTIFY, such as 200 or 486. The latest provisional response, such as 180, when the target was still ringing after two minutes or the call ended while it rang. 0 when the device accepted the REFER but sent no NOTIFY. -1 when the device didn’t accept the REFER
SWML reads the codes from variables, and Relay and webhooks from event fields:
CodeSWML variableEvent field
The device’s reply to the REFERsip_refer_response_codesip_refer_response_code
The target’s responsesip_refer_to_response_codesip_notify_response_code
Event fields are strings, and an event omits a code that is 0 or -1. The target’s response appears only on the final event.
Transfer calls via SWML
sip_refer waits for the transfer to finish, then sets the result and response code variables, plus sip_refer_to with the target URI. It answers the call first if it hasn’t been answered. Use switch on sip_refer_result to choose the next action. When the call isn’t a SIP call or a REFER is already in progress, sip_refer_result is error and both response code variables are unset.
Transfer a SIP call via SWML
Transfer the call to the target, then branch on the result. On success, the document hangs up SignalWire’s leg. On error, it uses connect to bridge the call to the same target. The default branch plays a failure message and hangs up for other results.
The bridged fallback requires the target to be reachable from SignalWire.
The SDK programs place the call to your SIP device as in Place a call via SWML. Each branch is built with the SDK’s SWML builder. The YAML and JSON tabs contain the equivalent complete document.
# Save as sip_refer.py and run: python sip_refer.py
client = RestClient(
project="<YOUR_PROJECT_ID>",
token="<YOUR_API_TOKEN>",
transferred = (
SWMLBuilder(SWMLService(name="transferred"))
.hangup()
.build()["sections"]["main"]
bridge = (
SWMLBuilder(SWMLService(name="bridge"))
.connect(to="<YOUR_TRANSFER_TARGET>")
failed = (
SWMLBuilder(SWMLService(name="failed"))
.say("The transfer couldn't be completed.")
swml = (
SWMLBuilder(SWMLService(name="sip-refer"))
.say("Transferring your call.")
.sip_refer(to_uri="<YOUR_TRANSFER_TARGET>")
.switch(
variable="sip_refer_result",
case={
"success": transferred,
"error": bridge,
default=failed,
.hangup()
.build()
call = client.calling.dial(
from_="<YOUR_CALLER_ID>",
to="<YOUR_SIP_DEVICE>",
swml=swml,
print(call["id"])
Run the example and answer on your SIP device. You hear “Transferring your call,” then the device calls the target. Answer at the target to complete the transfer and end SignalWire’s leg. Test again with the target busy or unanswered to hear the failure message.
If the device challenges the REFER, add username and password to sip_refer.
Track REFER results via SWML
Add status_url to sip_refer to receive JSON webhooks as the transfer progresses. The document still waits for the final result and branches on sip_refer_result.
Webhook fieldValue
event_typecalling.call.refer
params.call_idThe call ID
params.stateinProgress, then the final result
params.sip_refer_toThe SIP URI you transferred the call to
params.sip_refer_response_codeThe device’s reply to the REFER, such as "202"
params.sip_notify_response_codeThe target’s response reported in NOTIFY, such as "200"; only on the final event
OutcomeCallbacks, in order
The device accepts the REFERinProgress, then the final result
The device rejects the REFER or doesn’t replyerror
Only the first REFER the device accepts on a call sends inProgress. If you try another target on the same call, expect the final result only. See the webhooks guide for endpoint setup and testing.
Transfer calls via WebSocket (Relay)
Send the REFER on an answered SIP call with refer() and a sip device whose to is the target. The method returns as soon as SignalWire starts the REFER, so register a calling.call.refer handler first and read the event’s state for the result. If the call isn’t a SIP call or a REFER is already in progress, refer() raises an error instead of sending events.
Transfer a SIP call via WebSocket (Relay)
Dial your SIP device, then refer the call to the target. The handler hangs up on success, bridges the call to the target with connect() on error, and plays a message before hanging up on busy or noAnswer. If the device challenges the REFER, add username and password to the device’s params.
Call setup follows Place a call via WebSocket (Relay), with a sip device instead of a phone device.
# Save as sip_refer_relay.py and run: python sip_refer_relay.py
import asyncio
from signalwire.relay.event import ReferEvent
client = RelayClient(
contexts=["default"],
async def main():
async with client:
call = await client.dial(
devices=[[{
"type": "sip",
"params": {
"from": "<YOUR_CALLER_ID>",
"to": "<YOUR_SIP_DEVICE>",
"timeout": 30,
if call.state != "ended":
await call.hangup()
async def on_refer(event: ReferEvent):
print(f"REFER {event.state}: {event.sip_refer_response_code} {event.sip_notify_response_code}")
if call.state == "ended":
return
if event.state == "success":
# The device has connected to the target.
await call.hangup()
elif event.state == "error":
# The device couldn't complete the REFER: bridge through SignalWire instead.
await call.connect([[{
"type": "sip",
"params": {
"to": "<YOUR_TRANSFER_TARGET>",
"timeout": 30,
elif event.state in ("busy", "noAnswer"):
await call.play(
[{"type": "tts", "params": {"text": "The transfer couldn't be completed."}}],
call.on("calling.call.refer", on_refer)
await call.refer({"type": "sip", "params": {"to": "<YOUR_TRANSFER_TARGET>"}})
await call.wait_for_ended()
asyncio.run(main())
Answer on your SIP device. The program prints inProgress with the device’s 202, then success with the target’s 200 once the target answers, and hangs up SignalWire’s leg. To transfer an incoming SIP call, answer it first, then send the REFER.
Track REFER results via WebSocket (Relay)
The calling.call.refer handler is how Relay tracks the transfer. Each event carries state (inProgress, then the final result), the target URI, the device’s reply to the REFER, and the target’s response from NOTIFY, the same values as the SWML webhook fields. As in SWML, only the first REFER the device accepts on a call sends inProgress. To send the same events to a webhook as well, pass a status URL to refer().
Transfer calls via REST
Send calling.refer with an answered SIP call’s ID from any process, such as one that didn’t place the call. The command returns immediately, and the result arrives at your webhook.
Transfer a SIP call via REST
Send the command with a sip device whose to is the target, and status_url. Add username and password to the device’s params if the device challenges the REFER. Use the Server SDKs REST client’s calling.refer() to send the command:
# Save as refer_call.py and run: python refer_call.py
client.calling.refer(
"<YOUR_CALL_ID>",
device={"type": "sip", "params": {"to": "<YOUR_TRANSFER_TARGET>"}},
To call the REST API directly, see Call commands.
Track REFER results via REST
Your webhook receives the calling.call.refer events described in Track REFER results via SWML. Have the handler send the next call command, such as calling.end on success, or calling.transfer to a document that uses connect on error.
Next steps
