title: Hang Up Call
description: Call Flow Builder node to hang up a call.
slug: /reference/hangup-call
max-toc-depth: 3
The Hang Up Call node will disconnect a call and end the flow.
This node is not strictly required, as calls will automatically end when the call reaches the end of a flow.
The **Reason** parameter is used for logging purposes and does not change the behavior of the Hang Up Call node.
## Node Settings
The reason for hanging up the call.
**Possible Values:** `Busy`, `Decline`, `Hang up`
**Default Value:** `Busy`
