Interactive live streaming
In case of large events, scalability is key. If you need to broadcast your live video event to a large audience, we have a couple of solutions.
As a first option, you can use RTMP Streaming. With RTMP Streaming, you can stream the audio and video of the video room to an external service such as YouTube, from where your audience can watch.
Streaming with RTMP works fine in many cases, but sometimes you may need more flexibility. What if you want to temporarily bring a member from the audience on stage, for example to ask or answer a question? What if you want your own custom UI? To address these advanced use cases, we support Interactive Live Streaming.
What is Interactive Live Streaming
You can use Interactive Live Streaming with any of your video rooms. When streaming, a room can have two different kinds of participants: audience and members.
An audience participant can only watch and listen: their own media is not going to be shared. On the other hand, a member is the typical videoconference room member: they can watch and listen, but their own media is also shared with all other participants in the room. Depending on their permissions, members can also perform other actions, such as changing the layout of the room or playing videos.
When streaming, audience participants can be promoted to members and, vice-versa, members can be demoted to audience participants.
Joining a room
When using the Browser SDK, the kind of Video Room Token that you get determines whether you join the room as audience or as a member.
Joining as audience
To join as audience, specify "join_as": "audience" when creating a token.
POST
/api/video/room_tokens
1curl -X POST https://{your_space_name}.signalwire.com/api/video/room_tokens \
2 -H "Content-Type: application/json" \
3 -u "<project_id>:<api_token>" \
4 -d '{
5 "room_name": "my_room"
6}'
$curl -L -X POST "https://$SPACE_URL/api/video/room_tokens" \
> -H 'Content-Type: application/json' \
> -H 'Accept: application/json' \
> -u "$PROJECT_ID:$API_TOKEN" \
> --data-raw '{
> "room_name": "my_room",
> "user_name": "John Smith",
Then use the returned token to initialize a RoomSession.
Joining as a member
To join as an audience member, specify "join_as": "member" when creating a token.
> --data-raw '{
> "join_as": "member"
Then use the returned token to initialize a RoomSession:
1import * as SignalWire from "@signalwire/js";
3const roomSession = new SignalWire.Video.RoomSession({
4 token: "<YourRoomToken>",
5 rootElement: document.getElementById("yourVideoElement"),
6});
7
8roomSession.join();
For more information about using tokens to join a video room, please refer to our build a video application guide. Follow that guide to learn the basics about instantiating custom video rooms using the SDKs.
Promoting and demoting
Using the SDKs, you can programmatically promote and demote participants, to allow the audience participants to interact with the room and vice-versa.
To promote a member, use the promote method:
1await roomSession.promote({
2 memberId: "de550c0c-3fac-4efd-b06f-b5b8614b8966",
3 mediaAllowed: "all",
4 permissions: [
5 "room.self.audio_mute",
6 "room.self.audio_unmute",
7 "room.self.video_mute",
8 "room.self.video_unmute",
9 "room.list_available_layouts",
10 ],
11});
Only members can promote other participants. As you can observe from the code snippet above, you can specify a set of permissions to assign to the new member.
The memberId value identifies the id of the audience participant that you want to promote.
Demoting a member back to the audience, instead, is performed by the demote method:
1await roomSession.demote({
4});
Wrap up
We have seen how to use Interactive Live Streaming to easily build next generation communication platforms. Make sure to check out our technical documentation. If, instead, you are just starting out, then we suggest reading our guide on how to get started with the Video APIs.
