author: danieleds
x-custom:
tags:
* 'product:video'
* 'language:javascript'
* 'sdk:relaybrowser'
repo: >-
[https://github.com/signalwire/examples/tree/main/Video/Interactive-Live-Streaming](https://github.com/signalwire/examples/tree/main/Video/Interactive-Live-Streaming)
sidebar\_custom\_props:
github: >-
platform: javascript
slug: /js/guides/interactive-live-streaming
title: Interactive live streaming
max-toc-depth: 3
In case of large events, scalability is key. If you need to broadcast your live
video event to a large audience, we have a couple of solutions.
As a first option, you can use [RTMP Streaming](/docs/browser-sdk/v3/js/guides/stream-to-platforms).
With RTMP Streaming, you can stream the audio and video of the video room to an
external service such as YouTube, from where your audience can watch.
Streaming with RTMP works fine in many cases, but sometimes you may need more
flexibility. What if you want to temporarily bring a member from the audience on
stage, for example to ask or answer a question? What if you want your own custom
UI? To address these advanced use cases, we support *Interactive Live Streaming*.
## What is Interactive Live Streaming
You can use Interactive Live Streaming with any of your video rooms. When
streaming, a room can have two different kinds of participants: audience and
members.
An *audience participant* can only watch and listen: their own media is not
going to be shared. On the other hand, a *member* is the typical videoconference
room member: they can watch and listen, but their own media is also shared with
all other participants in the room. Depending on their permissions, members can
also perform other actions, such as changing the layout of the room or playing
videos.
When streaming, audience participants can be *promoted* to members and,
vice-versa, members can be *demoted* to audience participants.
The source code for this application is available on GitHub.
## Joining a room
When using the [Browser SDK](/docs/browser-sdk), the kind of
[Video Room Token](/docs/apis/video/room-tokens/create-room-token) that you
get determines whether you join the room as audience or as a member.
### Joining as audience
To join as audience, specify `"join_as": "audience"` when creating a token.
{/* TODO: create examples to join as audience and member */}
```bash
curl -L -X POST "https://$SPACE_URL/api/video/room_tokens" \
-H 'Content-Type: application/json' \
-H 'Accept: application/json' \
-u "$PROJECT_ID:$API_TOKEN" \
--data-raw '{
"room_name": "my_room",
"user_name": "John Smith",
Then use the returned token to initialize a
[RoomSession](/docs/browser-sdk/v3/js/reference/video/room-session).
### Joining as a member
To join as an audience member, specify `"join_as": "member"` when creating a token.
```bash
--data-raw '{
"join_as": "member"
[RoomSession](/docs/browser-sdk/v3/js/reference/video/room-session):
```js
import * as SignalWire from "@signalwire/js";
token: "",
rootElement: document.getElementById("yourVideoElement"),
roomSession.join();
For more information about using tokens to join a video room, please refer to
our [build a video application](/docs/browser-sdk/v3/js/guides/build-a-video-app) guide.
Follow that guide to learn the basics about instantiating custom video rooms
using the SDKs.
## Promoting and demoting
Using the SDKs, you can programmatically promote and demote participants,
to allow the audience participants to interact with the room and vice-versa.
To promote a member, use the
[promote](/docs/browser-sdk/v3/js/reference/video/room-session/promote)
method:
```js
await roomSession.promote({
memberId: "de550c0c-3fac-4efd-b06f-b5b8614b8966",
mediaAllowed: "all",
permissions: [
"room.self.audio_mute",
"room.self.audio_unmute",
"room.self.video_mute",
"room.self.video_unmute",
"room.list_available_layouts",
Only members can promote other participants. As you can observe from the code
snippet above, you can specify a set of permissions to assign to the new member.
The `memberId` value identifies the id of the audience participant that you want to promote.
Demoting a member back to the audience, instead, is performed by the
[demote](/docs/browser-sdk/v3/js/reference/video/room-session/demote)
method:
```js
await roomSession.demote({
## Wrap up
We have seen how to use Interactive Live Streaming to easily build next
generation communication platforms. Make sure to check out our [technical documentation](/docs/browser-sdk/v3/js/reference/video/room-session/promote).
If, instead, you are just starting out, then we suggest reading our guide on
[how to get started with the Video APIs](/docs/browser-sdk/v3/js/guides/build-a-video-app).
