Handle incoming calls from code
In the Quickstart guide, we learned how to use SWML Scripts in the Dashboard to handle incoming calls serverlessly.
Handling calls from code gives us more flexibility. Instead of serving a static SWML Script, we can use a custom web server to decide the content of the YAML/JSON depending on the incoming call.
In this guide, we will show how to set up a remote server to serve SWML dynamically.
Setting up the environment
If your preferred language allows you to write YAML/JSON (it probably does), then all you really need is to use your preferred library to spin up a web server:
Serving SWML
We’d like to set up an endpoint (our own “dynamic” SWML Script) which emits a valid SWML document, like this one:
We prefer YAML for its readability, so we’re going to use it instead of JSON in this example. The YAML will be sent back to the client as a response to their request. Let’s see how to set up a web server to serve valid SWML.
Setting up a web server
How you set up the web server is mostly specific to the language and framework of your choosing. A basic skeleton might be the following:
Try running the application, which will listen on port 3000:
Since you are likely behind a NAT, to test this application on your local machine you need a public IP address that SignalWire can reach. We suggest using ngrok.
In short, while the application is up and listening on port 3000, run ngrok from a new terminal like this:
You’ll get a public random URL (such as https://983f-93-41-16-193.ngrok.io/) that you can use to access your local application.
Configuring the number
Now that the code is ready and the HTTP endpoint is reachable from the web, we need to configure our SignalWire number to access it.
If you don’t have a phone number yet, make sure to buy one from the SignalWire Dashboard. You will need at least one number to receive calls.
Next, create a new Resource by navigating to the Resources section in the SignalWire Dashboard. Select a Script, and choose type as SWML. For the primary script, make sure it’s set to “External URL” and not “Hosted Script”. Input the URL you’ve hosted your application on. As a quick test, you can use ngrok to tunnel your local application to a public URL.
If you’re using the exact express web server application we’ve provided above, make sure the SWML External URL points to the /start endpoint of your application. Your path
might look like this: https://<UUID>.ngrok.io/start.
Try calling the phone number: SignalWire will ask your server for the instructions to run and say “Hello from SignalWire!”, but you can make SignalWire say/do whatever you like.
Accessing call information from the server
SignalWire will send certain information to your server in the POST request every time it is requesting a SWML script.
This gives your server a chance to customize the SWML script it sends based on the call information or the supplied parameters.
Case 1: SWML is being requested to service a phone call
In cases when you have configured a number to automatically invoke a SWML script (as we have done above),
a Call JSON object will be passed.
Case 2: SWML is being executed from another SWML script
You can execute or transfer the control flow out of one SWML to another. In such case, in addition to the Call object,
extra context from the calling SWML is sent to the new SWML being invoked.
This includes the variables that were set in the executing SWML script (vars), and the
parameters deliberately passed to the new SWML (params).
Verifying that the request came from SignalWire
Anyone who learns your endpoint URL can POST to it and read back the SWML document you return, so a public endpoint should check who is calling it before it answers.
SignalWire signs every request for a SWML document with an HMAC signature in the
X-Signalwire-Signature header, which you can verify against your project’s signing key.
Conclusion
We have shown how to handle incoming calls from code, by emitting SWML instructions that say something on a call, but it can do so much more! For more advanced applications, you’ll want to check out SWML’s Technical Reference.
