Call whisper
Call Whisper is a feature that allows you to play a message to the recipient of a call before connecting them to the caller. This feature is useful for informing the recipient about the nature of the call before they answer it. This guide shows you how to perform a Call Whisper using SWML to inform the recipient the number of the caller.
Setting up the SWML scripts
To perform a Call Whisper using SWML, you need to create two SWML script resources. One will utilize the connect method to connect the caller to the recipient, while the other will use the play method to play the Call Whisper message.
SWML Play Example
This will be the SWML script that is fetched when a call is successfully connected. In this example, we will play a message that says “You got a call from [Caller ID]”, where [Caller ID] is the phone number of the caller.This is done by using the say: command inside the play method and using the ${call.from} variable to get the caller’s phone number.
Example
version: 1.0.0
sections:
main:
- play:
url: 'say:You got a call from ${call.from}'
SWML Connect Example
Inside the connect method, you can use the confirm parameter to specify the URL that will return the SWML script to play the Call Whisper message. The from parameter is used to specify the caller’s phone number, which will be used in the Call Whisper message. Here we are using the ${call.from} variable to get the caller’s phone number from the initial call. The to parameter is used to specify the recipient’s phone number. Please replace +1XXXXXXXXXX with the recipient’s phone number and the confirm parameter with the URL of the SWML script that plays the Call Whisper message.
version: 1.0.0
sections:
main:
- connect:
confirm: "https://your-space.signalwire.com/relay-bins/your-first-bin-url-goes-here"
to: "+1XXXXXXXXXX"
Conclusion
After setting up your SWML script resources, you can now use them to perform a Call Whisper. First assign the connect example script to a SignalWire phone number. Now, when a call is made to that phone number, the Call Whisper message will be played to the recipient before connecting them to the caller.
