Messaging & Chat
Text messaging in the Browser SDK lives on the Address entity, not on the Call. Every Address — whether a User (Subscriber), room, or external contact — has a conversation associated with it: an append-only log of chat messages and call history. You can send a text to an Address with or without an active call.
The same conversation is shared across all clients of the same User. Sending a message from your phone client and your laptop client puts both into the same thread.
Sending a message
import { firstValueFrom } from "rxjs";
const directory = await firstValueFrom(client.directory$);
const id = await directory.findAddressIdByURI("/private/alice");
const address = directory.get(id);
await address.sendText("Heading over to the call now");
findAddressIdByURI checks the local cache and falls back to the server, so it works even before directory.loadMore() has populated directory.addresses. See Address Book & Directory for the directory-lookup patterns.
sendText resolves once the message is accepted by the server. There’s no separate “delivered” / “read” signal in v4 — if you need those, store delivery state in your own backend.
You can’t message your own address. The platform rejects a join request whose destination is the same fabric address as the caller with a 422. If your UI lists the directory, filter client.user.addresses[0].id out before rendering.
Testing two sides of a conversation requires two different Subscriber Access Tokens — one per user. Reusing the same SAT in two tabs will work for the most recently connected tab, while the other tab logs Discarding stale event: conversation.message as the platform rotates the session’s event channel.
Reading the conversation
address.textMessages$ lazy-loads the conversation on first subscribe and emits a TextMessageCollection. The collection itself is reactive — its values$ re-emits as new messages arrive or older ones are paginated in.
address.textMessages$.subscribe((collection) => {
if (!collection) return;
collection.values$.subscribe((messages) => {
chatList.innerHTML = "";
for (const m of messages) {
const li = document.createElement("li");
li.textContent = `${m.text} — ${new Date(m.created).toLocaleTimeString()}`;
chatList.appendChild(li);
Each entry is a TextMessage with id, text, created and a fromAddress$ observable — the sender is itself a resolved [Address], so you can render an avatar / name from the same SDK data without an extra fetch.
Paging older messages
textMessages$ initially loads the most recent page. To pull older messages, watch hasMore$ and call loadMore():
collection.hasMore$.subscribe((hasMore) => {
if (!hasMore) return;
chatList.onscroll = () => {
if (chatList.scrollTop < 50) collection.loadMore();
The “scroll near the top → loadMore” pattern is what the kitchen-sink demo uses; the same shape works for any direction.
In-call chat
When you have an active call, the call’s address is reachable as call.address. Use that to send chat messages within the call’s conversation:
const sendButton = document.querySelector("#send-chat");
const input = document.querySelector("#chat-input");
sendButton.onclick = async () => {
const text = input.value.trim();
if (!text || !call.address) return;
await call.address.sendText(text);
input.value = "";
call.address?.textMessages$.subscribe((collection) => {
collection?.values$.subscribe(renderMessages);
Even after the call ends, the conversation persists — you can scroll back through messages from previous calls and send asynchronous messages between calls.
Call history
The same conversation log also carries call history — same shape, same pagination, filtered to call entries instead of chat. Each entry (AddressHistory) has kind, status, started, ended.
address.history$.subscribe((collection) => {
collection?.values$.subscribe((entries) => renderCallLog(entries));
textMessages$ and history$ are two filtered views of the same underlying conversation, so loading one populates both.
Both observables shareReplay(1) — late subscribers get the existing collection without re-fetching.
Group chat in a room
In a room call, call.address is the room’s address — sending a chat message there delivers it to everyone in the room’s conversation. Each room thus has one chat thread, persisted across sessions:
const call = await client.dial("/public/team-standup", { audio: true });
collection?.values$.subscribe((messages) => renderChat(messages));
sendButton.onclick = () => call.address?.sendText(input.value);
For private side-channels within a room (a DM between two participants), use each participant’s Address directly — look it up from directory.get$(addressId) using the Participant.addressId field.
Realtime delivery without a call
Conversations are reactive whether or not a call is active. To run a chat-only experience (e.g. a support inbox), subscribe to multiple addresses’ textMessages$ streams and update your UI as messages land:
directory.addresses$.subscribe((addresses) => {
for (const address of addresses) {
collection?.values$.subscribe((messages) => {
const unread = messages.filter((m) => !isRead(m.id));
updateUnreadBadge(address.id, unread.length);
directory.loadMore();
Subscribing to addresses$ (rather than reading the addresses snapshot) means new entries that arrive on later pages or via background updates get watched automatically. Track which address.ids you’ve already wired up if you want to avoid double-subscribing on re-emit.
The platform pushes new messages over the same WebSocket the SDK uses for signaling — no polling required.
Try it: a tiny chat client
The page below stitches together everything above into one runnable file. Paste a Subscriber Access Token, hit Connect, pick a conversation from the dropdown, and you can read history, paginate older pages, send a text, and toggle the call log for the same address — all from one Address entity.
The demo touches: client.directory$ (to list addresses), address.textMessages$ and the collection’s values$ / hasMore$ / loadMore() (to render and paginate the thread), address.sendText() (to post), and address.history$ (to surface the call log for the same conversation).
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8" />
<title>SignalWire SDK messaging & chat demo</title>
<style>
body { font: 14px/1.5 system-ui, sans-serif; max-width: 720px; margin: 2rem auto; padding: 0 1rem; }
label { display: block; margin: 0.75rem 0 0.25rem; font-weight: 600; }
input, select { width: 100%; padding: 0.5rem; font: 13px ui-monospace, monospace; box-sizing: border-box; }
button { margin: 0.5rem 0.5rem 0 0; padding: 0.5rem 1rem; font: 14px system-ui; cursor: pointer; }
button[disabled] { opacity: 0.5; cursor: not-allowed; }
#thread { margin-top: 1rem; padding: 0.5rem; border: 1px solid #ddd; border-radius: 4px; height: 18rem; overflow-y: auto; background: #fafafa; }
#thread li { list-style: none; padding: 0.25rem 0; border-bottom: 1px solid #eee; }
#thread li:last-child { border-bottom: none; }
.meta { color: #666; font-size: 12px; }
#history { margin-top: 0.5rem; padding: 0.5rem; border: 1px solid #ddd; border-radius: 4px; max-height: 10rem; overflow-y: auto; background: #fafafa; display: none; font-size: 13px; }
#log { margin-top: 1rem; padding: 1rem; background: #111; color: #0f0; font: 13px ui-monospace, monospace; min-height: 4rem; white-space: pre-wrap; border-radius: 4px; }
.row { display: flex; gap: 0.5rem; align-items: stretch; }
.row input { flex: 1; }
</style>
</head>
<body>
<h1>SignalWire SDK messaging & chat demo</h1>
<label for="token">Subscriber Access Token</label>
<input id="token" type="password" placeholder="Paste your SAT here" />
<button id="connect">Connect</button>
<label for="address">Conversation</label>
<select id="address" disabled>
<option>— connect first —</option>
</select>
<button id="loadOlder" disabled>Load older</button>
<button id="toggleHistory" disabled>Show call history</button>
<ul id="thread"></ul>
<div id="history"></div>
<div class="row" style="margin-top: 0.75rem;">
<input id="text" placeholder="Type a message…" disabled />
<button id="send" disabled>Send</button>
</div>
<pre id="log"></pre>
<script type="module">
import { SignalWire, StaticCredentialProvider } from "https://esm.sh/@signalwire/js@dev?bundle-deps";
import { firstValueFrom, filter } from "https://esm.sh/rxjs@7.8.2?bundle-deps";
const $ = (id) => document.getElementById(id);
const log = (msg) => ($("log").textContent += msg + "\n");
let client, currentAddress, threadSub, valuesSub, hasMoreSub, historySub, currentCollection;
$("connect").addEventListener("click", async () => {
const token = $("token").value.trim();
if (!token) return log("Paste a token first.");
$("connect").disabled = true;
log("Connecting…");
client = new SignalWire(new StaticCredentialProvider({ token }));
await firstValueFrom(client.ready$.pipe(filter((r) => r)));
} catch (err) {
log("Failed: " + (err.message || err));
$("connect").disabled = false;
return;
// `directory.addresses` starts empty — subscribing to `addresses$`
// and calling `loadMore()` triggers the initial fetch and keeps
// the UI in sync as pages stream in.
// The directory includes the current user's own address —
// filter it out, since you can't open a conversation with yourself
// (the server rejects join with a 422).
const selfAddressId = client.user?.addresses?.[0]?.id;
const select = $("address");
let addresses = [];
let pickedFirst = false;
directory.addresses$.subscribe((next) => {
addresses = next.filter((a) => a.id !== selfAddressId);
select.innerHTML = "";
if (!addresses.length) {
const opt = document.createElement("option");
opt.textContent = "— no addresses in directory —";
select.appendChild(opt);
return;
for (const a of addresses) {
opt.value = a.id;
opt.textContent = a.name + " (" + a.type + ")";
select.disabled = false;
if (!pickedFirst) {
pickedFirst = true;
log("Connected. Pick a conversation above.");
selectAddress(addresses[0]);
select.addEventListener("change", () => {
const a = addresses.find((x) => x.id === select.value);
if (a) selectAddress(a);
function selectAddress(address) {
currentAddress = address;
$("thread").innerHTML = "";
$("history").innerHTML = "";
$("history").style.display = "none";
$("toggleHistory").textContent = "Show call history";
$("text").disabled = false;
$("send").disabled = false;
$("toggleHistory").disabled = false;
threadSub?.unsubscribe();
valuesSub?.unsubscribe();
hasMoreSub?.unsubscribe();
historySub?.unsubscribe();
log("Loading conversation with " + address.name + "…");
threadSub = address.textMessages$.subscribe((collection) => {
currentCollection = collection;
valuesSub = collection.values$.subscribe((messages) => {
const time = new Date(m.created).toLocaleTimeString();
li.innerHTML =
"<div>" + escapeHtml(m.text) + "</div>" +
"<div class='meta'>" + time + "</div>";
$("thread").appendChild(li);
$("thread").scrollTop = $("thread").scrollHeight;
hasMoreSub = collection.hasMore$.subscribe((hasMore) => {
$("loadOlder").disabled = !hasMore;
$("loadOlder").addEventListener("click", () => {
if (!currentCollection) return;
log("Loading older messages…");
currentCollection.loadMore();
$("send").addEventListener("click", async () => {
const text = $("text").value.trim();
if (!text || !currentAddress) return;
$("send").disabled = true;
await currentAddress.sendText(text);
$("text").value = "";
} catch (err) {
log("Send failed: " + (err.message || err));
} finally {
$("text").addEventListener("keydown", (e) => {
if (e.key === "Enter") $("send").click();
$("toggleHistory").addEventListener("click", () => {
if (!currentAddress) return;
const panel = $("history");
if (panel.style.display === "block") {
panel.style.display = "none";
return;
panel.style.display = "block";
$("toggleHistory").textContent = "Hide call history";
historySub = currentAddress.history$.subscribe((collection) => {
collection?.values$.subscribe((entries) => {
panel.innerHTML = "";
if (!entries.length) {
panel.textContent = "(no call history)";
return;
for (const e of entries) {
const div = document.createElement("div");
div.textContent =
e.kind + " · " + e.status + " · " +
new Date(e.started).toLocaleString();
panel.appendChild(div);
function escapeHtml(s) {
return s.replace(/[&<>"']/g, (c) => ({
"&": "&amp;", "<": "&lt;", ">": "&gt;", '"': "&quot;", "'": "&#39;",
})[c]);
</script>
</body>
</html>
Reference
