Screen Sharing
Screen sharing is a method on the SelfParticipant. Call startScreenShare() to add a screen-share track to the active call; call stopScreenShare() to remove it. The SDK calls getDisplayMedia() under the hood, negotiates the additional track, and pushes status changes through an observable.
There’s no separate “screen share call” — the share is added to the existing call alongside the camera, as a second video stream.
You’ll need an active call. Screen share attaches to an existing Call — start one of these first.
Start / stop
call.self$.subscribe(async (self) => {
if (!self) return;
shareButton.onclick = async () => {
if (self.screenShareStatus === "started") {
await self.stopScreenShare();
} else {
await self.startScreenShare();
} catch (err) {
handleShareError(err);
startScreenShare() triggers the browser’s screen-picker. The promise rejects on cancel and on permission denial — you need to tell them apart to avoid showing a scary error toast for what was a deliberate user choice.
A call carries at most one screen share. Starting a second one throws ScreenShareAlreadyActiveError and leaves the live share untouched — stop the first one before replacing it. Read screenShareStatus before calling and treat 'starting' and 'stopping' as busy.
A screen-share failure is never fatal: whatever goes wrong with the share, the call itself keeps running. The picker is human time and sits outside the SDK’s connect budget, so a user who takes a minute to choose a window is not timed out; only the 15 seconds of negotiation that follow are bounded, with AuxiliaryLegTimeoutError if they run out.
Handling permission and cancel
The browser surfaces both outcomes as a DOMException from getDisplayMedia(). Use err.name to distinguish:
err.nameWhat happenedUX
NotAllowedErrorUser clicked Cancel in the picker, or the OS / browser denied the permission entirelySilent — no toast on cancel
NotFoundErrorNo source was available to share (rare — usually a misconfigured kiosk environment)Tell the user “no shareable screen”
NotReadableErrorOS-level capture failure (another app holds the screen, hardware error)Suggest retry / closing other apps
AbortErrorThe session ended before capture startedSilent
NotSupportedErrorgetDisplayMedia() isn’t available (iOS Safari, some embedded WebViews)Hide the share button entirely
NotAllowedError is the one to watch — its message contains "Permission denied" when the OS or browser blocked the prompt, vs "Permission denied by user" (Chromium) or an empty message (Firefox / Safari) when the user clicked Cancel. The distinction is fuzzy across browsers, so the safest UX is: silent on NotAllowedError and rely on the user re-trying, since they just made an explicit choice.
import {
AuxiliaryLegCancelledError,
ScreenShareAlreadyActiveError,
} from "@signalwire/js";
function handleShareError(err) {
if (err instanceof AuxiliaryLegCancelledError) {
// Your own stopScreenShare() beat the leg to the finish — nothing to report.
return;
if (err instanceof ScreenShareAlreadyActiveError) {
showToast("Already sharing. Stop the current share first.");
return;
if (err?.name === "NotAllowedError") {
// Cancel or denied — don't surface a toast either way.
return;
if (err?.name === "NotFoundError" || err?.name === "NotReadableError") {
showToast("Couldn't start screen share. Close other capture apps and try again.");
return;
if (err?.name === "NotSupportedError") {
showToast("Screen sharing isn't supported in this browser.");
return;
console.error("Unexpected screen share error:", err);
Detect support before showing the button
getDisplayMedia() is unavailable on iOS Safari and some embedded WebViews. Gate the button on the capability and the API existence so the user never sees a control that can’t work:
const supported =
typeof navigator.mediaDevices?.getDisplayMedia === "function";
call.self?.capabilities.screenshare$.subscribe((canShare) => {
shareButton.hidden = !(supported && canShare);
Observing share state
screenShareStatus$ is the reactive form. Use it instead of polling screenShareStatus so your UI reflects auto-stop (user clicked “Stop sharing” in the browser bar, OS revoked permission, etc.):
type ScreenShareStatus = 'none' | 'starting' | 'started' | 'stopping';
self.screenShareStatus$.subscribe((status) => {
shareButton.classList.toggle("active", status === "started");
shareButton.disabled = status === "starting" || status === "stopping";
How the share appears to other participants
The screen-share track is delivered as a separate participant entry in call.participants$ — usually with a name like Screen or the sharer’s name suffixed with (Screen). The local participant doesn’t need to render their own share to see it; the SDK doesn’t mirror the local capture into remoteStream$.
To detect which participants are screen shares specifically, check the participant’s metadata or type. In the kitchen-sink demo, the share state is read from self.screenShareStatus directly:
const isSharing = call.self?.screenShareStatus === "started";
Audio with the share
Pass { audio: true } to also request the shared surface’s audio. The default is video only — the share never carries the local microphone, which stays on the main connection:
await self.startScreenShare({ audio: true });
Whether audio is actually captured depends on the browser, the OS, and the surface the user picks. A share the user grants without audio yields a video-only stream, and the share still starts normally — so treat surface audio as best-effort, not a guarantee.
In practice:
  • Chrome / Edge: offered for tabs and windows; system audio depends on the OS and version.
  • Firefox: video only.
  • Safari: video only (and screen sharing requires explicit user-initiated permission per session).
Browser quirks
  • User gesture required. startScreenShare() must originate from a click or keyboard event — calling it on a timer or after an async chain that didn’t start from a gesture will fail.
  • iOS Safari. Tab screen sharing isn’t supported. iOS has its own system-wide screen-broadcast flow which is outside the browser’s reach.
  • Multiple displays. The picker lists each display separately; selecting “Entire screen” on a multi-monitor setup shares only the picked display.
Stopping from outside the page
The user can stop sharing from the browser’s “Stop sharing” toolbar. When they do, the underlying track ends and the SDK transitions screenShareStatus$ to 'none' automatically — no action required on your side. Subscribe to screenShareStatus$ and your UI will update without polling.
Reference
