# Screen Sharing
Screen sharing is a method on the `SelfParticipant`. Call
`startScreenShare()` to add a screen-share track to the active call;
call `stopScreenShare()` to remove it. The SDK calls
`getDisplayMedia()` under the hood, negotiates the additional track,
and pushes status changes through an observable.
There's no separate "screen share call" — the share is added to the
*existing* call alongside the camera, as a second video stream.
**You'll need an active call.** Screen share attaches to an existing
`Call` — start one of these first.
Install the SDK and create a `SignalWire` client with a credential provider.
Dial a destination with `client.dial()` to get a `Call` instance.
Subscribe to `client.session.incomingCalls$` and `call.answer()`.
## Start / stop
```js
call.self$.subscribe(async (self) => {
  if (!self) return;
  shareButton.onclick = async () => {
      if (self.screenShareStatus === "started") {
        await self.stopScreenShare();
      } else {
        await self.startScreenShare();
    } catch (err) {
      handleShareError(err);
`startScreenShare()` triggers the browser's screen-picker. The
promise rejects on cancel *and* on permission denial — you need to
tell them apart to avoid showing a scary error toast for what was a
deliberate user choice.
## Handling permission and cancel
The browser surfaces both outcomes as a `DOMException` from
`getDisplayMedia()`. Use `err.name` to distinguish:
| `err.name`          | What happened        | UX                                  |
| `NotAllowedError`   | User clicked Cancel in the picker, **or** the OS / browser denied the permission entirely | Silent — no toast on cancel         |
| `NotFoundError`     | No source was available to share (rare — usually a misconfigured kiosk environment)       | Tell the user "no shareable screen" |
| `NotReadableError`  | OS-level capture failure (another app holds the screen, hardware error)                   | Suggest retry / closing other apps  |
| `AbortError`        | The session ended before capture started                                                  | Silent                              |
| `NotSupportedError` | `getDisplayMedia()` isn't available (iOS Safari, some embedded WebViews)                  | Hide the share button entirely      |
`NotAllowedError` is the one to watch — its message contains
`"Permission denied"` when the OS or browser blocked the prompt, vs
`"Permission denied by user"` (Chromium) or an empty message
(Firefox / Safari) when the user clicked Cancel. The distinction is
fuzzy across browsers, so the safest UX is: **silent on
`NotAllowedError`** and rely on the user re-trying, since they just
made an explicit choice.
```js
function handleShareError(err) {
  if (err?.name === "NotAllowedError") {
    // Cancel or denied — don't surface a toast either way.
    return;
  if (err?.name === "NotFoundError" || err?.name === "NotReadableError") {
    showToast("Couldn't start screen share. Close other capture apps and try again.");
    return;
  if (err?.name === "NotSupportedError") {
    showToast("Screen sharing isn't supported in this browser.");
    return;
  console.error("Unexpected screen share error:", err);
### Detect support before showing the button
`getDisplayMedia()` is unavailable on iOS Safari and some embedded
WebViews. Gate the button on the capability and the API existence
so the user never sees a control that can't work:
```js
const supported =
  typeof navigator.mediaDevices?.getDisplayMedia === "function";
call.self?.capabilities.screenshare$.subscribe((canShare) => {
  shareButton.hidden = !(supported && canShare);
## Observing share state
`screenShareStatus$` is the reactive form. Use it instead of polling
[`screenShareStatus`] so your UI reflects auto-stop (user clicked
"Stop sharing" in the browser bar, OS revoked permission, etc.):
```ts
type ScreenShareStatus = 'idle' | 'starting' | 'started' | 'stopping';
```js
self.screenShareStatus$.subscribe((status) => {
  shareButton.classList.toggle("active", status === "started");
  shareButton.disabled = status === "starting" || status === "stopping";
## How the share appears to other participants
The screen-share track is delivered as a separate participant entry
in `call.participants$` — usually with a name like `Screen` or the
sharer's name suffixed with `(Screen)`. The local participant
doesn't need to render their own share to see it; the SDK doesn't
mirror the local capture into `remoteStream$`.
To detect which participants are screen shares specifically, check
the participant's metadata or `type`. In the kitchen-sink demo, the
share state is read from `self.screenShareStatus` directly:
```js
const isSharing = call.self?.screenShareStatus === "started";
## Audio with the share
`getDisplayMedia()` can capture system / tab audio on some platforms
(Chromium-based browsers on macOS / Windows). The SDK forwards
whatever the browser provides — there's no separate "share audio"
toggle. If the user's browser doesn't support display audio, only
the video is shared.
In practice:
* Chrome / Edge on macOS or Windows: works for tab audio, may work
  for system audio depending on OS version.
* Firefox: video only.
* Safari: video only (and screen sharing requires explicit
  user-initiated permission per session).
## Browser quirks
* **User gesture required.** `startScreenShare()` must originate from
  a click or keyboard event — calling it on a timer or after an
  async chain that didn't start from a gesture will fail.
* **iOS Safari.** Tab screen sharing isn't supported. iOS has its own
  system-wide screen-broadcast flow which is outside the browser's
  reach.
* **Multiple displays.** The picker lists each display separately;
  selecting "Entire screen" on a multi-monitor setup shares only the
  picked display.
## Stopping from outside the page
The user can stop sharing from the browser's "Stop sharing" toolbar.
When they do, the underlying track ends and the SDK transitions
`screenShareStatus$` to `'idle'` automatically — no action required
on your side. Subscribe to `screenShareStatus$` and your UI will
update without polling.
## Reference
* [`SelfParticipant.startScreenShare()`] — open picker, add the share track
* [`SelfParticipant.stopScreenShare()`] — remove the share track
* [`SelfParticipant.screenShareStatus$`] / [`screenShareStatus`] — reactive status (`'idle' | 'starting' | 'started' | 'stopping'`)
* [`SelfCapabilities.screenshare$`] — capability gate
[`SelfParticipant.startScreenShare()`]: /docs/browser-sdk/v4/reference/self-participant/start-screen-share
[`SelfParticipant.stopScreenShare()`]: /docs/browser-sdk/v4/reference/self-participant/stop-screen-share
[`SelfParticipant.screenShareStatus$`]: /docs/browser-sdk/v4/reference/self-participant/screen-share-status$
[`screenShareStatus`]: /docs/browser-sdk/v4/reference/self-participant/screen-share-status$
[`SelfCapabilities.screenshare$`]: /docs/browser-sdk/v4/reference/self-capabilities/screenshare$
