REST (Representational State Transfer) has become rather prolific, with more than 70% of all public APIs being REST. The popularity comes from the fact that REST builds upon existing systems and features of HTTP, making it familiar to web developers everywhere. REST was chosen over alternatives like SOAP, for its close coupling with JSON and web-friendly format, which web developers preferred when rapidly iterating web applications. That said, there are limitations to REST.
REST-based applications by nature are stateless. The state is managed by the client. Similarly, since HTTP doesn't have a mechanism to push notifications from the server to the client, it is difficult to implement any type of service where the server updates the client in real-time. At least not without the use of polling, web sockets, or another type of webhook.
At SignalWire, we felt like we needed something a bit more modern - something where web microservices are intrinsic in the design from the start.
Introducing RELAY
RELAY is the next evolution in real-time communication APIs. It's a new real-time web service protocol that provides for persistent, asynchronous connections to the SignalWire network.
RELAY brings advanced real-time capabilities like real-time event monitoring functionality to the developer, without the need for markup language interpretation or latent REST responses. This is a game-changer for developers.
System and billing events can be monitored and acted upon in real time. In the past, doing something simple like intercepting call events for a voice call that shows the destination endpoint as offline, and then re-routing those calls automagically, was clunky and didn’t produce elegant results. Many times the call would fail or the delays in call setup would drive the user to hang up themselves.
Enabling RELAY Call Control via NodeJS
The first set of RELAY functions that can be consumed via our Relay JavaScript library is Call Control. This will allow developers to programmatically manage voice calls in real-time using NodeJS. It’s the first step towards completing SignalWire’s real-time web services API and libraries. Check our developer website for a current list of supported programming languages and our developer documentation for RELAY Voice Clients.
Before getting started, be sure you have created your SignalWire account.
Create an outbound call using RELAY and NodeJS
1. Install the package using NPM:
npm install @signalwire/realtime-api
2. In order to use the NodeJS client, you must get your project and API token from your SignalWire dashboard:
const project = "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX"
const token = "PTXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
3. Use the SignalWire project, token, and a context of your choice to set up a Voice Client:
import { Voice } from '@signalwire/realtime-api";
const client = new Voice.Client({
project: "<project-id>",
token: "<api-token>",
contexts: ["office"],
4. You can then use the client to place a call and play a message:
const call = await client.dialPhone({
to: "+XXXXXXXXXX",
await call.playTTS({ text: "Welcome to SignalWire!" });5. Now, let's process an inbound call:
// Attach a listener to listen for incoming calls.
client.on("call.received", async (call) => {
console.log("Got call", call.from, call.to);
await call.answer();
await call.playTTS({ text: "Thank you for calling SignalWire!" });
} catch (error) {
});Using the Dashboard
In the SignalWire dashboard, you will have the opportunity to see your RELAY activity. Here we can see a few SIP calls and some that also touch the PSTN:
If we click on the call thread we can see more details on the conversation, including a summary, segments and events:
We can expand the segments and see the detail in each segment:
Let's have a look at the events. In this first example we see a Call Creation event:
Next is the Call Connection event:
Disruptive Pricing
Our fee structure is simple. We meter per minute / per call leg, we don’t charge for setting up calls programmatically, nor do we charge for securing your calls, because security is a good thing.
For all pricing check here.
We want to see what you build with SignalWire! If you have any questions while getting started, stop by our Community Slack or our Forum to connect with our team. You can also reach out to sales@signalwire.com with questions about pricing or specific products.
