Use Cases
— AI Agents
AI Voice agents you can actually put in production
Define the agent in Python. Scope its tools and data per step. Deploy on real telephony, with your code governing every turn.
The hard part
Voice AI demos pass. Production is where they break.
Every voice AI failure traces to one problem: the call is stateful and real-time, but traditional platforms treat it as stateless transactions. So your app becomes the state machine, and everything hard about voice AI breaks from there.
The model acts on stale context and drifts out of bounds. Every decision crosses a network hop, so the conversation lags. And the record is scattered across services, so you're debugging blind. When the platform owns the call's state, these problems go with it: your code governs the agent against the call's real-time state, the AI runs in the media path for low latency, and every step lands on one record you can inspect.
A program that uses a model, not a model that uses tools.
The model makes it natural. The software makes it correct.
Try it now
Sigmond Runs on SignalWire
A voice and video AI agent built on the SignalWire SDK, wired to a live knowledge base, able to see what you show him. Build the same thing on voice, phone, WhatsApp, or SIP, or an entire white-label platform with SignalWire as the network underneath.
Sigmond
Try it now
Sigmond
Try it now
Sigmond
The event stream
Every step, tool call, and decision, on one record
A live call, mid-conversation: speech detected with confidence scores, the response timed at every stage, a tool result from your code, and the step change it triggered. This is what debugging voice AI looks like when the platform owns the record.
A live call's event stream with latencies
How it works
A look inside an AI agent, mid-turn
Foundation models are brilliant at conversation and unreliable at everything else. Mid-turn, five things work at once: the model brings the language, your code brings the process.
01
AI runs in the media engine
The AI kernel runs inside the same media engine as the call, not as a separate service across the network. Speech, model, and voice are orchestrated from inside the audio path, which is what keeps latency low.
AI kernel → in the media path, not over a hop
02
Your code governs the model
You define the agent as steps, and at each step the model sees only the tools and data you scope to it, so it can't act outside what you allowed.
steps → a defined state machine, not one big prompt
03
The model calls your tools
The model reads the conversation and decides which of your tools to call. Your function runs, works with data the model never sees, and returns a prompt carrying the answer or the instructions the model needs.
SWAIG function → your handler returns the result
04
Real telephony under the agent
The agent can transfer to a human, pull someone into a conference, and start a recording, all as native call control on a real telephony platform.
05
Every step is observable
Every step, tool call, and decision lands on one structured event stream, so you can see exactly what the agent did and why.
01
02
03
04
05
01
02
03
04
05
Build it
Build a voice agent in one Python file
From idea to phone number in an afternoon: define the agent, scope each step, and deploy with telephony built in. Your code stays in control the whole way.
AI.PY
copy
01
02
03
04
05
06
07
08
09
def lookup_order(order_id):  # swap for your real backend
    return {"id": order_id, "status": "shipped, arriving Tuesday"}
        super().__init__(name="support-agent")
        self.prompt_add_section("Role", body="You help callers with order issues.")
        # A context is a state machine. Each step whitelists the tools that
        # exist while it's active — the agent can't escalate before it looks up.
        steps = self.define_contexts().add_context("default")
        steps.add_step("triage") \
            .set_text("Greet the caller and ask for their 8-digit order number.") \
            .set_functions(["check_order"])
        steps.add_step("resolve") \
            .set_text("Their order is ${global_data.order_status}. Share it, "
                      "and offer a specialist if they're unhappy.") \
            .set_functions(["escalate_to_human"])
    # Type hints + docstring generate the schema — no JSON to hand-write.
    # The model decides WHEN to call it; your code decides WHAT it does.
    @AgentBase.tool(name="check_order")
    def check_order(self, order_id: str):
        """Look up an order by ID. Call before quoting any status."""
        order = lookup_order(order_id)
        # One result that SPEAKS, saves state for the next step, and advances
        # the state machine from your code — not the model's discretion.
        return FunctionResult(f"Order {order['id']} is {order['status']}.") \
            .update_global_data({"order_status": order["status"]}) \
            .swml_change_step("resolve")
    @AgentBase.tool(name="escalate_to_human")
    def escalate_to_human(self):
        """Hand the call to a live specialist."""
        # connect() is native call control: a real transfer, no extra infra.
        return FunctionResult("Connecting you now.", post_process=True) \
            .connect("+15551234567", final=True)
AI.PY
copy
01
02
03
04
05
06
07
08
09
AI.PY
copy
01
02
03
04
05
06
07
08
09
AI.PY
copy
01
02
03
04
05
06
07
08
09
What you’ll get from the code example
An agent can only do what your code allows, at every step
Native telephony: transfer, conference, and record as built-in call control
One event stream showing what the agent did and why
Real-time translation, with STT, TTS, and voices coordinated inside the platform
Ten languages, one mental model
The same concepts and names across Python, TypeScript, Go, Java, Ruby, and more.
Test before you dial
Run every tool and inspect the exact document a call would get, locally, from the CLI.
Your AI, your webhooks
Tools call your systems with per-call security tokens minted and validated for you.
Composed in code
The developer authors the model’s entire world
What it sees, what exists, where it can go: each step has its own instructions, its own tools, its own exits.
greet
tools: none · next: collect
Instructions only.
collect
tools: check_calendar · next: confirm
Finds real openings.
confirm
tools: book_appointment · next: wrap_up
The software acts; the model only requests.
wrap_up
tools: none · next: none
Structurally complete.
When the model requests a tool, your code reads data the model never sees, acts, and returns a new prompt into its context. One returned result atomically updates the data, moves the step, and controls the call.
The platform behind it
One call, every capability
Build the agent in code, give it tools, and steer the live call as it happens. The control plane owns the call's state so your code decides the outcome, not the model.
Server SDKs
Build AI voice agents in ten languages, same concepts and names: prompts, tools, and multi-step flows, all in code.
Tool Calling
Write SWAIG functions your agent can call. The model invokes them, your code runs and decides the outcome.
SWML
Declarative markup that unifies the model, speech, and telephony in one call flow the platform runs. Write it directly, or generate it from code.
RELAY
A persistent WebSocket for real-time call control: transfer, hold, record, or bridge a live call as events happen. Or, connect your own AI to our voice and telephony.
REST APIs
Provision numbers, manage resources, and control calls, messaging, and AI over HTTP.
Browser SDK
Add voice, video, and chat to your web, mobile, or desktop app as a connected client.
Server SDKs
Tool Calling
SWML
RELAY
REST APIs
Browser SDK
Server SDKs
Tool Calling
SWML
RELAY
REST APIs
Browser SDK
The hard parts
The hard parts and how SignalWire handles them
Dimension
Traditional CPaaS
Call state
Lives in your application
Owned by the platform
Transfers
Context is dropped
Context travels with the call
AI governance
Prompt and hope
Deterministic, inside the call
Vendor stack
Five vendors stitched together
One platform
Voice AI latency
2–4s, compounded
~1200ms typical conversational turn
Dimension
Traditional CPaaS
Call state
Transfers
Context is dropped
AI governance
Prompt and hope
Vendor stack
Voice AI latency
2–4s, compounded
Dimension
Call state
Transfers
AI governance
Vendor stack
One platform
Voice AI latency
In production
Built by teams that ship production voice AI at scale
Trusted by forward-thinking companies
"I don't have any desire to deal with the underlying telephony if it's been solved in a good way. Where the calls are low-latency, I'm willing to pay a price for that. It saves me time and allows me to ship faster."
Avatar
Justin Massey
Founder and CEO at RelayHawk
Avatar
Justin Massey
20 yrs
carrier-grade engineering, from the creators of FreeSWITCH
2,700+
companies run on the platform today
2.7B
minutes and messages a year on the same infrastructure
SOC 2 · HIPAA · PCI · GDPR · ISO 27001. Regulated workloads welcome: healthcare, finance, and payments run here because the controls are structural, not promised.
Your calls inherit twenty years of hardening.
FAQ
The questions we hear most, from how agents hold context to how they route calls.
How does SignalWire's AI Voice Agent API work?
 It integrates speech recognition, LLM orchestration, and text-to-speech natively into the media and signaling layers. Use the server SDKs in 10 different languages, including  Python, to define agent logic, connect to APIs mid-call, and route to humans when needed.
How do SignalWire AI agents handle multi-step workflows without losing context?
Agents progress through explicitly defined Contexts and Steps with completion criteria. At each transition, an updated state is passed into the next step's prompt, so the AI gets a fresh, accurate context window instead of carrying (and drifting on) full conversation history.
What is the SignalWire AI kernel?
The orchestration layer sitting between telecom infrastructure and the language model. Call state, routing logic, and telephony actions stay in the infrastructure layer, with AI used as a tool inside that controlled environment so the LLM can't lose context or corrupt the session.
How does SignalWire handle state management in AI voice agents?
Your agent server can be stateless because the platform carries the call state and presents it to your code at each step. The AI kernel holds all call state (caller data, step progress, variables) and injects it into the prompt dynamically at each step, so the AI always sees exactly what it needs.
Do SignalWire AI agents work with PSTN, SIP, and WebRTC?
Yes. The same logic and workflows work across PSTN phone numbers, SIP endpoints, and WebRTC browser or app sessions.
How do SignalWire AI voice agents handle complex workflows like booking appointments or triggering SMS mid-call?
Agents use SWAIG (SignalWire AI Gateway) to trigger programmable functions mid-conversation, sending an SMS confirmation, querying a CRM, or inserting a calendar appointment, without human intervention or ending the call.
Ready to ship your first AI agent?
Build a working voice agent in one Python file. Every SignalWire Space includes free credit, and voice AI runs $0.16 per minute: transparent usage pricing.
