10 min read
What Is AI Orchestration?
Troubleshooting orchestration problems
Latency & Performance
PUC
AI orchestration coordinates agents, tools, and state so the right actions happen at the right time. Most teams build it on external state and prompt-based control, which works in demos but breaks at scale through race conditions, duplicate actions, and models executing stale decisions. A control plane fixes this by owning state inside the interaction itself and only allowing actions that are still valid at the moment of execution.
Understanding AI orchestration and the control plane
AI orchestration is how software coordinates the moving parts of an AI-powered system: managing which agent handles which task, what context carries forward, when to execute actions, and how to handle everything that goes wrong in between. If you're building anything beyond a simple chatbot (a voice agent, a contact center AI, a multi-step automated workflow), you're doing AI orchestration whether you've named it that or not.
Orchestration is a coordination problem. You have a user with an intent, a language model that interprets it, tools that execute actions, and state that needs to reflect what happened. Orchestration is the layer that keeps all of those synchronized.
In practice, that means managing:
  • Agent routing: which AI agent or step handles which part of the conversation
  • Context and memory: what information persists across turns and channels, and what gets passed when control changes hands
  • Tool invocation: when to call external systems, in what order, with what data
  • State management: maintaining a consistent picture of where the interaction is and what has happened
  • Error handling: what to do when models misbehave, tools fail, or users go off-script
Simple AI applications don't surface orchestration as a distinct problem because there's nothing to coordinate. One agent, one conversation, one call to an LLM. The complexity appears when you add workflows, multiple agents, real-time communications, or any requirement that deterministic outcomes matter.
Signs your AI problem is an orchestration problem
If you’re unsure whether “orchestration” is your real problem, these symptoms are strong indicators:
  • AI systems work in testing but breaks somewhere in production
  • You cannot reproduce failures reliably
  • You keep adding timeouts, retries, and heuristics
  • Your system prompt keeps growing to handle edge cases
  • You maintain a state machine in Redis or a database to track interactions
  • Multi agent workflows duplicate actions or overwrite context
  • Users report dead air, awkward pauses, or broken handoffs
  • Context fails to carry between channels
  • Logs show success while users experience failure
When evaluating how to implement better AI orchestration, or how to evaluate a platform's orchestration capabilities, useful questions are:
Where does state live? If the answer is "in my application's database, synchronized via webhooks," you will solve orchestration yourself at every layer. If state lives in the platform, inside the call or session itself, the hardest synchronization problems are solved at the infrastructure level.
Can the system enforce deterministic control at specific points? Good orchestration gives you the ability to say "at this step, only these actions are possible, and the model cannot go off-script regardless of what the user says." If you can only express this through prompts, it's probabilistic. If you can express it through schema constraints and state machine definitions, it's mechanical.
Can AI and interaction control share the same layer? The deepest orchestration problems require the AI and the call platform to be the same system, not two systems talking via webhooks. If they're separated, you're always working against a race condition.
What happens when the model does the wrong thing? In a well-governed system, the model cannot do the wrong thing because the wrong things aren't available to it. In a prompt-governed system, it can always find a way.
AI orchestration is not a feature you add to a system. It's the architecture that determines whether your system is reliable or fragile, scalable or brittle, correct or usually correct.
The industry is still early in understanding this. Most teams discover orchestration problems only after they've hit scale, by which point they've built their product on a foundation that makes those problems structural rather than fixable. The cost of choosing the wrong architecture is deferred, invisible at 100 calls a day, unavoidable at 10,000 concurrent.
The teams that get this right are the ones who recognize that AI orchestration is a software problem, not a prompting problem. Language models handle language. Software handles state, authority, sequencing, and correctness. The clearer that boundary is in your architecture, the more reliable your AI system will be in production.
The standard orchestration approach and its failure modes
The dominant pattern in AI development today is what's sometimes called "prompt and pray": write a detailed system message, give the model access to a set of tools, and hope it calls the right ones at the right time.
This is treated as orchestration, but it's actually a transfer of authority. You're handing the model control over your system and hoping it exercises that control sensibly.
This works in demos. It breaks in production.
The failure mode isn't catastrophic. Models don't crash. They don't say anything offensive. They confidently do the wrong thing: call the wrong tool at the wrong time, skip a required step, invent data that should have come from a real system, make a promise the backend can't honor. These failures are quiet, they can easily be missed in testing, and they compound at scale. Across hundreds or thousands of calls, this spells disaster.
The root cause is surface area. Give a model ten tools and it will eventually find a plausible reason to call the wrong one. Give it a 500-line system prompt trying to control workflow and the prompt becomes a negotiation. The model mostly follows it, until it doesn't. Orchestration implemented in prompts is inherently probabilistic, and probabilistic systems fail at scale.
Orchestration for voice and real-time communications
AI orchestration is hard in any context. It's dramatically harder in voice and real-time communications because calls are stateful and continuous in ways that standard web applications are not.
Most communications platforms handle orchestration by having the call live in one system and state live in your databases, application servers, external caches. Your system learns what's happening through webhooks.
This creates a fundamental mismatch: the call is happening in real time, but your state management is asynchronous. When that mismatch is small, it's invisible. When you're running thousands of concurrent calls, it becomes the primary source of failures.
Then race conditions appear that weren't there before: two events arrive milliseconds apart, both read the same state, both make decisions, one overwrites the other. Webhooks arrive out of order. A transfer completes from the API's perspective while the caller has already hung up. State says a call is active; the call ended minutes ago. These are the normal failure modes of external state architecture at scale.
The architectural solution is to keep state inside the call rather than synchronizing it externally. When the platform is the system of record for the interaction, not your database, there is no race between what your code thinks is happening and what's actually happening on the call. State updates are atomic within the call's context. When the call ends, the state ends.
This is what separates a communications control plane from a transport layer. Transport moves packets and fires webhooks. A control plane owns the interaction: its state, its lifecycle, and its outcomes. AI operating inside a control plane inherits the platform's constraints and state management. AI bolted onto a transport layer via webhooks has to solve all of those problems externally.
The missing layer: a control plane for orchestration
Without a proper control plane:
  • The model can decide what to do.
  • The system cannot reliably execute it at the right time.
  • The gap between decision and execution is where failures live.
What is a control plane?
A control plane is the layer that owns authoritative state and governs what actions are allowed to execute right now. It exists to answer one question: Given what is true in this moment, what actions are valid?
That’s different from: What action did an agent request?
In orchestration, that distinction is the difference between “requested” and “allowed.”
  • Requested: an agent or application wants to perform an action
  • Allowed: the system validates that the action is still valid against current state and timing, then executes it
When orchestration relies on callbacks and external state, actions often execute because they were requested, not because they are still allowed. That’s how systems produce side effects that no longer match reality.
A control plane prevents that by owning state and serializing execution so conflicting actions cannot both win.
What a control plane does for AI orchestration
A control plane makes orchestration reliable by providing capabilities that are hard to retrofit at the application layer.
Own shared state as the system of record
Instead of reconstructing state from events, the control plane maintains the authoritative view of the interaction and its lifecycle.
Enforce liveness at the moment of action
Actions are not executed simply because they were requested. They execute only if they are still valid right now. This is crucial in real-time systems, where milliseconds matter and users can interrupt or disconnect mid-action.
Serialize control and eliminate conflicting updates
When multiple events or multiple agents attempt to act at once, the control plane applies deterministic ordering and prevents conflicting actions from executing against stale state.
Support cancellation and replacement of in-flight work
Orchestration requires canceling work when reality changes:
  • cancel in-flight responses when the user interrupts
  • discard tool results when they no longer match current context
  • stop audio playback on barge-in
  • restart generation when the conversation turns
Without a control plane, cancellation becomes best effort and increasingly unreliable under load.
Preserve context across workflow boundaries
Orchestration is not only about correctness. It is also about experience. Context needs to persist across steps and handoffs without forcing users to repeat themselves, even as the system enforces deterministic control points.
How SignalWire approaches AI orchestration with a control plane
SignalWire’s approach to orchestration centers on keeping logic attached to the live interaction.
In voice systems, the interaction is not a stateless request. It is a stateful, time-sensitive system with a lifecycle, multiple legs, and actions that must be valid at the moment they execute.
The control plane treats the interaction itself as the system of record, then applies actions within that execution context. That enables a consistent pattern:
  • state is authoritative within the interaction
  • actions validate against liveness at the moment of execution
  • control is serialized so timing and concurrency do not create conflicting outcomes
  • orchestration remains synchronized with the live call, not reconstructed after the fact
This matters because many orchestration failures in voice are not caused by “bad intent detection.” They are caused by timing and state drift. When orchestration logic is outside the live interaction, it becomes possible for decisions to execute after reality has changed.
A control plane like SignalWire is the layer that prevents that.
Governing the model, not just the interaction
A control plane solves the timing and state problems. But there's a third failure mode it doesn't address on its own: the model making a wrong decision within a technically valid state.
The call is live. The state is current. The model still invents a discount that doesn't exist, skips a required verification step, or calls a tool it shouldn't have access to yet.
This is where Programmatically Governed Inference (PGI) comes in. PGI is a design discipline that treats model authority as something to be eliminated structurally, not managed through instructions.
The core rule is simple: don't tell the AI anything it doesn't need to know. At each step of an interaction, the model sees only the tools registered for that step. Not all tools. Not tools from future steps. Only the ones that belong right now. When a step changes, the model's entire available reality changes with it. Mechanically, not through a new prompt.
This is different from guardrails. Guardrails assume the model has authority and try to intercept bad outputs after the fact. PGI removes authority before the model can exercise it. The model doesn't know other tools exist. There's nothing to reason around.
The result is that correctness lives in software, not in prompts. A well-governed step in PGI makes misbehavior structurally impossible. When this runs on top of a control plane that already owns interaction state and enforces liveness, you get a system where the model handles language and the infrastructure handles truth.
That's the boundary that makes AI reliable in production.
Ready to build better AI? Join our developer community on Discord and get started with a free SignalWire account.
Why does multi agent orchestration fail at scale?
Multi agent orchestration fails when agents operate on inconsistent versions of state. Parallel decisions and delayed updates cause drift, duplicate side effects, and unpredictable outcomes.
What is a control plane in AI orchestration?
A control plane is the architectural layer that owns authoritative state and governs which actions are allowed to execute at any given moment, enforcing liveness and preventing stale or conflicting execution.
How does a control plane improve AI orchestration?
It ensures actions execute only when valid, serializes conflicting updates, maintains shared truth, supports cancellation, and separates inference from authority.
What is Programmatically Governed Inference?
PGI is a design discipline where each step of an AI interaction exposes only the tools and context the model needs for that step. The model cannot access capabilities outside its current scope — not because it was told not to, but because they don't exist in its world. Authority lives in deterministic code, not in prompts.
