Latency & Performance
When an agent’s WebRTC connection drops mid-call, the system has to decide whether the agent intentionally ended the call, briefly lost connectivity, or crashed entirely. This article explains why that ambiguity becomes a production-scale failure mode when connection state and call state are managed separately, how event-driven systems are forced to infer intent from incomplete signals, and why preventing “disappearing agents” requires orchestration that manages agent connectivity and call lifecycle together so the platform can recover, reroute, or end the call correctly in real time.
Voice Horror Stories: The Agent Disappears
At small scale, a dropped agent connection looks like a simple disconnect. The call ends, or the agent reconnects, and everyone moves on.
At production scale, the same moment becomes a decision point.
An agent’s WebRTC connection drops mid-call. Is it an intentional hangup, a transient network hiccup, or a hard failure? If the system guesses wrong, the caller gets silence, a premature hangup, or a confusing reroute.
Nothing crashed. The platform just had incomplete information and had to infer intent.
This series examines the failure modes that appear when voice and AI systems scale beyond demo conditions, exploring how asynchronous, externalized state creates subtle but inevitable breakdowns. Solving these issues requires architecture that manages call lifecycle, media, and AI execution inside a single orchestrated control plane.
Welcome to part 5: When the human vanishes, and your system has to guess why.
This is the failure mode that exposes whether your platform understands intent or just reacts to events, appearing when connection state and call state are managed separately.
A human agent is mid-call. Everything is fine… then they’re gone. No goodbye, no handoff, no warning. Just silence.
Act I: A disconnect that looks like any other
From the system’s perspective, all it sees is this:
A WebRTC connection drops
Media stops flowing
An agent is suddenly unreachable
But why? That’s the part your architecture has to decide in real time.
Did the agent:
Intentionally hang up?
Lose Wi-Fi for half a second?
Close their laptop?
Crash their browser?
Lose power entirely?
Each of those demands a different response, and guessing wrong is how you create terrible UX.
Act II: Every guess is a risk
If your system assumes an intentional hangup, the call ends abruptly and the caller is dropped.
If it assumes a transient network issue, the caller waits in silence until the agent never comes back.
If it assumes a crash, the call is rerouted, the original agent reconnects, and two humans answer the same call.
Every option is defensible, but can be catastrophic, because the system doesn’t actually know what happened.
Act III: External state can’t read intent
This failure exists for one reason: connection state and call state live in different systems.
The telephony system knows the call is active.
The WebRTC layer knows a connection dropped.
But intent lives between them.
When those signals are processed asynchronously, an external system is forced to infer meaning from timing, retries, and heuristics.
Was the disconnect:
Immediate or delayed?
Clean or abrupt?
Followed by reconnection?
Inference replaces certainty, and inference breaks down under concurrency and unstable network conditions.
Why the agent disappears
This isn’t a WebRTC problem, a browser problem, or even a network problem.
It’s an architecture problem.
When:
Agent connections are treated as external sessions
Call control operates independently
Reconnection logic lives outside execution
Then the system cannot distinguish intentional disconnect from a transient failure or a hard crash. All three collapse into the same event.
And once that happens, the platform is guessing.
The cost of ambiguous disconnects
Unlike earlier stories in this series that explore failures involving AI agents, this one has humans on both ends.
A caller experiences:
Silence
Confusion
Abrupt rerouting
A human agent experiences:
Lost context
Duplicate calls
Broken trust in the system
Supervisors see:
Inconsistent metrics
“Dropped” calls with no explanation
Issues that only happen in real life
And engineers add timers. 500ms waits. Reconnect windows. Fallback routing rules. And then none of it solves intent.
Orchestration is the difference between disconnect and disappearance
In an orchestrated system, agent connectivity is not an external signal. It’s part of the call’s execution context.
That means the platform knows whether:
The agent explicitly ended the call
The connection dropped unexpectedly
Reconnection is in progress
Failover should occur
Because call state and connectivity are handled inside the same execution model, disconnect handling can be enforced as part of the live call rather than inferred from external events. The system is no longer guessing across disconnected layers. It is acting within a single, authoritative execution context.
The real lesson of the disappearing agent
At scale, every system will experience:
Network instability
Browser crashes
Human unpredictability
The question isn’t whether agents will disappear. It’s whether your platform can tell why.
If your architecture:
Separates connection state from call state
Treats agent presence as external
Relies on timing to infer intent
Then disappearing agents aren’t edge cases. They’re inevitable.
These ghost stories all share one root cause
All the failure modes discussed in this series are different symptoms of the same disease: systems that reconstruct reality after it happens. When call control, media, state, and AI decisions are split across asynchronous components, correctness becomes a best-effort guess. Under real concurrency, those guesses drift.
The most painful failures in voice and AI systems are often the ones that look successful in logs. The call “completed.” The transfer “succeeded.” The response was “generated.” The agent “disconnected.” The system did what it was told to do, but not what the moment required.
Zombie Calls happen when state outlives the call.
Double Updates happen when two correct events overwrite each other.
Phantom Transfers happen when actions outlive the call.
Stale Responses happen when AI output outlives the moment.
Disappearing Agents happen when intent has to be inferred from disconnects.
These problems are not fixed by retries, timeouts, or faster models. They are fixed by eliminating the gap between decision and execution. In production voice systems, the platform must act on what is true now, not what was true milliseconds ago.
If call state, media events, agent connectivity, and AI output are managed as separate asynchronous systems, you do not get a single reliable conversation. You get a set of competing narratives, stitched together after the fact. At low volume, that holds. At production scale, it fails quietly.
The fix is architecture where the platform owns execution: a unified control plane that manages call lifecycle, media, and AI orchestration together.
Solving these failure modes requires an orchestration approach like SignalWire’s control plane because at scale they are inevitable. When the platform manages call state and execution together, it can prevent actions from executing based on outdated information.
Try SignalWire AI today and discover the difference for AI systems that scale.
Why can’t event-driven systems distinguish an agent hangup from a connection failure?
Because connection state and call state are often handled by separate systems. The platform receives events about disconnects, but intent is not directly observable, so it must infer meaning from timing and incomplete signals.
Why is an agent disappearing more common at scale?
At high concurrency, short network drops, renegotiations, and browser instability happen regularly. Systems that rely on external state and asynchronous event handling have more timing ambiguity and more opportunities to misclassify the disconnect.
How can “disappearing agents” be prevented?
By using orchestration that manages agent connectivity and call lifecycle together, allowing the platform to distinguish clean disconnects from failures and choose the correct action, such as waiting briefly for reconnection, failing over to another agent, or ending the call cleanly.
