4 min
How to Build an AI-Powered Voice Assistant in Python
A Python framework for controlling SignalWire’s telephony engine programmatically
The SignalWire Agents SDK for Python is a framework that empowers developers to build and deploy intelligent voice AI agents capable of listening, speaking, and controlling call logic in real time without manually managing webhooks. The SDK provides modular prompting, composable skills, multi-agent orchestration, state management, serverless API integration, prefab agent patterns, and offline search capabilities so teams can scale from single bots to enterprise-grade voice AI systems.
Build an AI-Powered Voice Assistant in Python with the SignalWire Agents SDK
SignalWire was founded on one idea: Programmable Unified Communications (PUC) is the future. It’s not enough to just patch together various APIs for calling, messaging, and AI. We believe every developer should have the ability to build full-scale, intelligent communication workflows that adapt in real time.
That vision is pushed further with the SignalWire Agents SDK, a powerful Python framework that lets you build AI-powered voice assistants and control SignalWire’s telephony engine programmatically. With the Agents SDK, developers can define SIP routing logic, build multi-agent voice systems, run real-time call transfers, preserve context across states, and integrate external APIs, all from Python, no webhooks required.
What is the Agents SDK?
The SignalWire Agents SDK is a Python framework for building AI agents that can talk, listen, understand, and even modify the phone system mid-call in real time. Agents are stateless by default and deploy instantly to any serverless backend, with built-in support for custom state managers when needed.
Each agent includes a modular prompting framework, a declarative skill system, and a CLI testing suite that makes local development as fast as production deployment.
The SDK natively controls the SignalWire Markup Language (SWML) that defines how calls are routed, spoken, recorded, and more.
Agents as microservices
Every agent you build with the SDK is a complete, self-contained microservice. It's simultaneously:
  • A web application with HTTP endpoints
  • An AI persona with defined capabilities
  • A communication endpoint that handles voice, video, and messaging
  • A scalable service ready for production deployment
Stateless by default
All AI agents can persist conversation state across steps, and can even track it across calls if needed. By default, agents do not maintain persistent state, making them highly scalable and suitable for microservice deployments. However, when state management is needed, the platform provides built-in mechanisms through the SignalWire AI Gateway (SWAIG).
Serverless API integration
Define functions that run on SignalWire's infrastructure, not your server. Instead of creating webhook endpoints, describe the API call and response processing using JSON configuration that gets executed serverlessly.
This means you can integrate external APIs without standing up any servers or managing credentials. The SDK handles authentication, retries, error cases, and response processing. You define what you want; we handle how it works.
Building with the Agents SDK
With support for multiple agents on a single server, skills you can plug in with one line of code, and context-driven workflows, the SDK can scale from a single bot to an enterprise-wide AI voice system. Let’s walk through some highlights.
Skills system
Skills are modular, reusable components that can be easily added to any agent and configured with parameters, unlocking transactional and knowledge-base scenarios out-of-the-box. Add capabilities like web search, math, or datetime parsing with one line.
agent.add_skill("web_search",)
agent.add_skill("math")
agent.add_skill("datetime")
Prefab agents
Prebuilt agents are available for use cases like onboarding, support, surveys, and other common scenarios. Custom prefabs can be created directly within your project or packaged as reusable libraries.
Use the custom prefab:
copy
01
02
03
04
05
06
07
08
09
# Create an instance of the custom prefab
support_agent = CustomerSupportAgent(
    product_name="SignalWire Voice API",
    knowledge_base_path="./product_docs",
    support_email="support@example.com",
    escalation_path="tier 2 support",
    name="voice-support",
    route="/voice-support"
# Start the agent
support_agent.serve(host="0.0.0.0", port=8000)
copy
01
02
03
04
05
06
07
08
09
# Start the agent
copy
01
02
03
04
05
06
07
08
09
# Start the agent
copy
01
02
03
04
05
06
07
08
09
# Start the agent
Multi-agent support
The Agents SDK makes true multi-agent orchestration a first-class feature.
You can deploy multiple specialized agents on a single server, define call flows between them, and transfer context seamlessly as users move between roles or tasks. Agents can also maintain chat and call history across sessions.
Alternatively, build a “meta-agent” that dynamically delegates to others. You can even rewrite output before TTS using dynamic config callbacks, enabling silent handoffs and more polished transitions.
Prompt Object Model (POM)
Your prompts are structured objects including sections, goals, instructions, and more. This helps maintain consistent tone and structure across AI interactions.
The SDK provides optional wrapper methods to make this even simpler. These convenience methods call prompt_add_section() internally with the appropriate section titles.
copy
01
02
03
04
05
06
07
08
09
from signalwire_pom import PromptObjectModel
# Create a new POM
pom = PromptObjectModel()
# Create main sections for an LLM prompt
objective = pom.add_section(
    "Objective",
    body="You are an AI assistant built to help users draft professional emails."
objective.add_bullets([
    "Listen carefully to the user's requirements",
    "Draft concise, clear, and professional emails",
    "Provide options when appropriate"
# Add personality section
personality = pom.add_section(
    "Personality",
    body="You should present yourself with these traits:"
personality.add_bullets([
    "Professional but approachable",
    "Clear and concise in communication",
    "Helpful without being overly verbose"
# Add capabilities section with nested subsections
capabilities = pom.add_section(
    "Capabilities",
    body="You can perform the following email-related tasks:"
# Add subsections
drafting = capabilities.add_subsection(
    "Email drafting",
    body="Create email drafts based on user specifications."
drafting.add_bullets([
    "Format emails properly with greeting, body, and signature",
    "Adjust tone based on recipient and purpose",
    "Include necessary information while being concise"
reviewing = capabilities.add_subsection(
    "Email review",
    body="Analyze and improve existing email drafts."
reviewing.add_bullets([
    "Check for grammar and spelling issues",
    "Suggest improvements for clarity and tone",
    "Identify missing information"
# Generate markdown
markdown = pom.render_markdown()
print(markdown)
json = pom.to_json()
print(json)
copy
01
02
03
04
05
06
07
08
09
# Create a new POM
    "Objective",
    "Personality",
    "Capabilities",
# Add subsections
    "Email drafting",
    "Email review",
# Generate markdown
print(markdown)
print(json)
copy
01
02
03
04
05
06
07
08
09
# Create a new POM
    "Objective",
    "Personality",
    "Capabilities",
# Add subsections
    "Email drafting",
    "Email review",
# Generate markdown
print(markdown)
print(json)
copy
01
02
03
04
05
06
07
08
09
# Create a new POM
    "Objective",
    "Personality",
    "Capabilities",
# Add subsections
    "Email drafting",
    "Email review",
# Generate markdown
print(markdown)
print(json)
Search stack
For document search, you can install vector and keyword search layers. For complete search functionalities:
pip install signalwire-agents[search-all]
With this, your agent can query PDFs, docs, and web pages entirely offline, with no third-party APIs required.
Get started with the Agents SDK
SignalWire's platform was built to give developers complete, programmable access to unified communications. Now your logic, routing, tools, and speech behavior live in one place: your Python code.
Ready to see what you can build? Sign up for an account and join our developer community on Discord.
What is the SignalWire Agents SDK for Python?
The SignalWire Agents SDK for Python is a framework that lets developers build real-time ai-powered voice assistants in python capable of handling calls, routing logic, skills, and integrations programmatically without custom webhooks.
How does the SDK help integrate AI into voice applications?
The SDK supports modular prompting, skill systems, and declarative API integrations, enabling agents to respond intelligently during calls, run functions mid-conversation, and preserve context.
What are “skills” in the Agents SDK?
Skills are reusable components that add capabilities like web search, datetime parsing, math evaluation, or custom tools to an agent with simple configuration.
Can multiple agents run together in this SDK?
Yes. The SDK supports multi-agent orchestration on a single server, letting you define dynamic call flows with context hand-offs and shared histories.
Does the SDK handle external APIs without webhooks?
Yes. Using serverless integrations like DataMaps, the SDK can describe and run API calls on SignalWire infrastructure without managing webhooks yourself.
