Developer Tutorials
PUC
The SignalWire Claude Code Skill transforms Claude into an expert SignalWire pair programmer that understands SignalWire APIs, SWML call flows, AI agent design patterns, and production-ready development practices. It helps developers generate working SWML and SDK code, explain implementation patterns like context-aware transfers or SWAIG functions, and follow best practices for real-world applications, reducing the need to search documentation or examples manually.
You're building a SignalWire app. You need to figure out how to structure a SignalWire Markup Language (SWML) call flow, implement context-aware transfers, or set up SignalWire AI Gateway (SWAIG) functions. You could dig through documentation, search GitHub examples, or ask in Discord.
Or you could just ask Claude.
The new SignalWire skill for Claude Code gives you an AI pair programmer that knows SignalWire inside and out. It understands the REST APIs, writes SWML, explains AI agent patterns, and helps you avoid common mistakes.
What is the SignalWire Skill for Claude Code?
Think of it as having a SignalWire expert sitting next to you. Need to implement appointment reminders? It'll write the complete flow. Building an AI agent for customer service? It knows the patterns. Stuck on Subscriber configuration? It explains the concepts and shows you the code.
The skill covers everything you need to build production SignalWire apps:
Voice AI and SWML
Write complete call flows in SWML
Structure AI agent prompts that actually work
Implement SWAIG functions for external integrations
Handle context preservation across transfers
REST APIs and SDKs
Make outbound calls with proper authentication
Send SMS with Campaign Registry compliance
Manage video rooms and tokens
Work with the Relay SDK for real-time communication
Production Patterns
Secure sensitive data with metadata patterns
Implement loop protection in call flows
Set up webhook testing workflows
Add post-prompt analytics
How it works
Install the skill and Claude automatically knows when you're working on SignalWire code. Ask it to generate SWML, explain a concept, or review your implementation.
Once installed, just start coding. Claude recognizes SignalWire context and provides relevant help.
Example prompts that work:
"Create an IVR that routes to sales, support, or billing"
"Write a SWAIG function that checks inventory and returns availability"
"Show me how to implement context-aware transfers"
"Review this AI agent prompt and suggest improvements"
“Make me an AI agent that can call and order me a pizza.”
Why use Claude Code for SignalWire development?
This isn't generic AI help. The skill understands SignalWire's specific patterns and best practices.
It knows to use metadata for sensitive data instead of putting it in AI prompts. It writes SWML with proper loop protection. It implements SWAIG functions that build knowledge progressively. It avoids the over-prompting patterns that make AI agents brittle.
When you ask for a restaurant ordering system, you get working code that follows production patterns—metadata for payment info, progressive knowledge building through SWAIG, context preservation for transfers.
Real examples
Building an AI agent: You ask Claude to create a support agent. It generates a complete implementation with:
Natural, conversational prompts (no programming constructs)
SWAIG functions for ticket creation and lookup
Metadata handling for customer information
Context-aware transfer patterns
Post-prompt analytics configuration
Creating a video conference: Request a video room setup. You get:
Secure token generation (never exposes API credentials to browser)
Room configuration with proper layouts
Browser SDK integration code
WebSocket connection handling
SMS with compliance: Ask about SMS delivery. It explains The Campaign Registry requirements and generates:
Brand and campaign registration steps
Message templates with proper opt-out language
Delivery status tracking
Rate limiting patterns
Getting started
The skill works immediately after installation. No configuration needed. No separate documentation to read.
Start with simple requests. "Create a basic IVR." "Show me how to authenticate." "Explain SWAIG functions." As you work, ask more specific questions about your actual implementation.
The skill includes all the workflow documentation you need—authentication, calling, messaging, video, AI agents, webhooks. When Claude answers your question, it's pulling from comprehensive, tested patterns.
What you get with the Claude Code Skill
Production-ready code. Not pseudocode. Not "here's the general pattern." Complete, working examples with proper error handling, security patterns, and best practices built in.
The code uses modern SignalWire APIs. You get SWML in YAML or JSON. REST API calls with proper authentication. Relay SDK patterns for real-time communication. AI Agents SDK for voice AI.
Every example follows the same production patterns you'll see in SignalWire's own implementations.
Try the SignalWire Claude Code Skill
Install the skill and try these starter prompts:
"Create a simple IVR with loop protection"
"Write an AI agent that collects customer info before transferring"
"Show me how to send SMS with delivery tracking"
"Implement MFA using phone calls"
Watch how Claude not only generates the code but explains the patterns and points out potential issues.
The skill is open source. You can review the documentation, suggest improvements, or adapt it for your team's specific patterns.
Download the SignalWire Claude Code Skill
The SignalWire skill is available now at https://github.com/signalwire/signalwire-claude.
Install it once. Use it every time you build with SignalWire.
What is the SignalWire Claude Code Skill?
The Claude Code Skill is a developer tool that turns Cloud-based Claude Code into a SignalWire-knowledgeable pair programmer, understanding REST APIs, SWML call flows, AI agents, and production patterns.
How does the Claude Code Skill help developers build SignalWire apps?
It generates complete working code, explains patterns like context preservation or SWAIG integrations, and helps avoid common mistakes by writing production-ready examples based on developer prompts.
What kinds of tasks can the Claude Code Skill assist with?
The skill can write SWML for IVRs, structure AI agent prompts, create SWAIG functions, manage REST API operations, handle video tokens, and suggest secure webhook and metadata patterns.
How does the Claude Code Skill work once installed?
Once installed into Claude Code, Claude recognizes SignalWire context automatically and responds with relevant help when you ask it to generate SWML, explain concepts, or review your implementation.
