# Verify SWML request signatures
> Verify the HMAC signature SignalWire sends with every request for a SWML document, so your server can reject forged requests.
When you serve SWML from your own web server, anyone who learns your endpoint URL can POST to it
and read back the SWML document you return. Since a SWML document can contain phone numbers, SIP
credentials, and prompts, that endpoint should not answer to just anyone.
To let you check the caller, SignalWire signs every request for a SWML document with an HMAC
signature derived from your project's signing key. Verifying that signature proves the request came
from SignalWire and that neither the URL nor the body was altered in transit.
#### This step is not optional!
For production applications it is extremely important to verify the signature, so that requests
from a malicious third party are rejected instead of being served a SWML document.
## Which requests are signed
Every POST SignalWire makes to fetch a SWML document from a URL you control is signed. That
includes:
* The initial fetch, when a Resource or phone number is configured with an **External URL** rather
  than a hosted script, and the fetch from your fallback URL when the primary one fails.
* Every subsequent fetch caused by [`execute`](/docs/swml/reference/calling/execute) or
  [`transfer`](/docs/swml/reference/calling/transfer) pointing at an external URL.
* The same fetches on the messaging side, when a number handles inbound SMS and MMS with
  [Messaging SWML](/docs/swml/reference/messaging).
Requests during a call carry two headers. Requests for a messaging document carry the SHA-1 header
alone, so verify that one if your endpoint serves both.
| Header                          | Algorithm                | Sent on              |
| `X-Signalwire-Signature`        | HMAC-SHA1, hex encoded   | Every signed request |
| `X-Signalwire-SHA256-Signature` | HMAC-SHA256, hex encoded | Call requests        |
Both are computed over the same string: the request URL concatenated directly with the raw request
body, with no separator.
```text
signature = hex( HMAC( signing_key, url + raw_body ) )
The `url` is the full URL SignalWire requested, including any query string. A call request signs
that URL without any basic auth credentials you embedded in it; a message request signs it exactly
as you configured it, credentials included. The `raw_body` is the JSON payload exactly as sent —
the object containing `call` (or `message` for a messaging document), `vars`, `envs`, and, when the
document was reached through `execute` or `transfer`, `params`.
Verify against the URL you configured in the Dashboard, not the URL your framework reconstructs
from the incoming request. Proxies, load balancers, and tunnels such as ngrok routinely rewrite the
host or scheme, which changes the string being hashed and makes a valid signature look invalid.
## Which requests are not signed
Signatures cover requests for a SWML document. They do not cover everything a document can send to
your server, so an endpoint that insists on a signature will reject traffic you meant to accept.
The POST to a SWAIG function's `web_hook_url` is unsigned. Protect it with HTTP basic auth: embed
the credentials in the URL as `username:password@url`, or set `web_hook_auth_user` and
`web_hook_auth_password` in [`SWAIG.defaults`](/docs/swml/reference/calling/ai/swaig) or on the
individual [SWAIG function](/docs/swml/reference/calling/ai/swaig/functions). Agents built with the
Server SDKs authenticate differently again — basic auth on every request, plus per-function tokens
for sensitive operations, covered in [Server SDK security](/docs/server-sdks/guides/security).
The conversation summary an agent sends to [`post_prompt_url`](/docs/swml/reference/calling/ai) is
unsigned when you serve your own SWML. Protect that endpoint the same way, with credentials
embedded in the URL.
The [`request`](/docs/swml/reference/calling/request) method is unsigned as well when a call runs
it. Use basic auth in its URL, or send a shared secret in a custom `X-` header through the method's
`headers` parameter. Its [messaging counterpart](/docs/swml/reference/messaging/request) does carry
the SHA-1 header.
## Get your signing key
Your signing key is on the [API Credentials](https://my.signalwire.com?page=credentials) page of
your Dashboard. Click **Show** to reveal it. Each project has its own key, so use the key belonging
to the project that serves the call.
In the Dashboard, open **API Credentials**, find **Signing Key**, and select **Show**. Use the key belonging to the project that serves the call.
You can rotate the key with the reset button on the same page. A new key takes about a minute to
become active, and the page shows it to you before you confirm the reset so you can copy it into
your application first.
Treat the signing key like a password: keep it in an environment variable or a secret manager, not
in the source you deploy.
## Verify the signature in Node
The `validateRequest` helper in `@signalwire/web-api` implements the check for you:
```bash
npm install @signalwire/web-api
`validateRequest` needs the **raw** request body, so capture it before your JSON parser consumes
it. Re-serializing the parsed object is not reliable — key order and whitespace change, and the
hash changes with them.
```javascript title="index.js"
const { validateRequest } = require("@signalwire/web-api");
const app = express();
// Keep the raw body around for signature verification.
app.use(
  express.json({
    verify: (req, _res, buf) => {
      req.rawBody = buf.toString();
// The public-facing URL you configured in the Dashboard.
const WEBHOOK_URL = "https://example.ngrok.io/start";
app.post("/start", (req, res) => {
  const valid = validateRequest(
    process.env.SIGNALWIRE_SIGNING_KEY,
    req.headers["x-signalwire-signature"],
    WEBHOOK_URL,
    req.rawBody
  if (!valid) {
    return res.status(403).send("Invalid signature");
  res.send(`
    sections:
      main:
        - play:
            url: 'say:Hello from SignalWire!'
app.listen(3000);
## Verify the signature in any language
The scheme is a plain hex HMAC, so you can implement it directly wherever a helper is not
available. Compare digests with a constant-time comparison rather than string equality.
#### Python
import hmac
import hashlib
import os
from flask import Flask, request, Response
app = Flask(__name__)
# The public-facing URL you configured in the Dashboard.
def signature_is_valid(url, raw_body, header):
    expected = hmac.new(
        os.environ["SIGNALWIRE_SIGNING_KEY"].encode(),
        (url + raw_body).encode(),
        hashlib.sha1,  # hashlib.sha256 for X-Signalwire-SHA256-Signature
    ).hexdigest()
    return hmac.compare_digest(expected, header or "")
@app.route("/start", methods=["POST"])
def start():
    raw_body = request.get_data(as_text=True)
    header = request.headers.get("X-Signalwire-Signature")
    if not signature_is_valid(WEBHOOK_URL, raw_body, header):
        return Response("Invalid signature", status=403)
    return Response(
        sections:
          main:
            - play:
        mimetype="text/plain",
#### Ruby
```ruby
require "openssl"
require "sinatra"
def signature_is_valid?(url, raw_body, header)
  expected = OpenSSL::HMAC.hexdigest(
    "SHA1", # "SHA256" for X-Signalwire-SHA256-Signature
    ENV.fetch("SIGNALWIRE_SIGNING_KEY"),
    url + raw_body
  OpenSSL.secure_compare(expected, header.to_s)
end
post "/start" do
  raw_body = request.body.read
  unless signature_is_valid?(WEBHOOK_URL, raw_body, env["HTTP_X_SIGNALWIRE_SIGNATURE"])
    halt 403, "Invalid signature"
  end
  <<~SWML
    sections:
      main:
        - play:
  SWML
end
To verify the stronger header on a call request, hash the same `url + raw_body` string with SHA-256
and compare it against `X-Signalwire-SHA256-Signature`.
## Confirm your endpoint rejects forgeries
With the server running and reachable at the URL you configured, POST to it yourself, without a
signature:
```bash
curl -i -X POST https://example.ngrok.io/start \
  -d '{}'
The response is `403 Forbidden`, with `Invalid signature` as the body. Now place a call to the
number pointed at that URL: this request carries a valid signature, passes the check, and the caller
hears the prompt your document plays.
If the real call is rejected too, the `WEBHOOK_URL` in your code doesn't match the URL SignalWire
requested — an ngrok URL that changed when the tunnel restarted is the common cause. The next
section covers the rest.
## Troubleshoot a failing signature
A signature that never validates almost always comes down to one of these:
* **The URL does not match.** Scheme, host, port, path, and query string all feed the hash. Use the
  exact URL configured in the Dashboard, including the query string if you configured one.
* **The body was re-serialized.** Hash the bytes you received, not `JSON.stringify` of the parsed
  object.
* **The wrong project's key.** Signing keys are per project.
* **The key was just rotated.** A new key needs about a minute to become active.
* **Basic auth in the URL.** A call strips embedded credentials before signing, so hash the URL
  without them. A message signs the URL as configured, so hash it with them.
## Next steps
* **[Handle incoming calls from code](/docs/swml/guides/remote-server)** — set up the external SWML
  endpoint this guide protects.
* **[Webhooks](/docs/platform/webhooks)** — how webhooks and status callbacks work across the
  platform.
