*** id: bcdd0209-2f90-46c8-a6d8-e4d99d1a78bc slug: /guides/set-meta-data title: Store data outside LLM context description: >- Learn how to use the `set_meta_data` action to store function metadata without exposing it to the LLM. x-custom: tags: * favorite * 'sdk:swml' * 'product:ai' * 'product:voice' max-toc-depth: 3 *** In this example, we demonstrate how to use `set_meta_data` to store metadata to reference later. The AI agent, will store a user's name and then look up any additional stored information. The benefit of storing information in `meta_data` is that the information it can be referenced from any function with the same `meta_data_token`, while also never being exposing the information to the language model. This allows for the AI agent to store sensitive information without the risk of it being exposed to the AI agent. ## 1. Storing user information The `store_user` function is used to store the user's name. The user's name and a secret associated with them are stored as `meta_data`. ```yaml - function: store_user description: Store the user information parameters: type: object properties: name: type: string description: The name of the user data_map: webhooks: - url: 'https://example.com/name_bank?name=${lc:args.name}' method: GET output: response: The user information was stored. User information can now be looked up with the "get_user_info" function. action: - set_meta_data: '${lc:input.args.name}: ${Records[0].secret}' - toggle_functions: - active: true function: get_user_info - say: Your info was stored. meta_data_token: example_token ``` ```json [ { "function": "store_user", "description": "Store the user information", "parameters": { "type": "object", "properties": { "name": { "type": "string", "description": "The name of the user" } } }, "data_map": { "webhooks": [ { "url": "https://example.com/name_bank?name=${lc:args.name}", "method": "GET", "output": { "response": "The user information was stored. User information can now be looked up with the \"get_user_info\" function.", "action": [ { "set_meta_data": "${lc:input.args.name}: ${Records[0].secret}" }, { "toggle_functions": [ { "active": true, "function": "get_user_info" } ] }, { "say": "Your info was stored." } ] } } ] }, "meta_data_token": "example_token" } ] ``` This will send a request to `data_map.webhooks.url` with the user's name as a query parameter. In this example, we have our server responding with a `Records` array in the response. This will contain information on the user. **Server Response**: ```json { "response": "The user information was stored.", "Records": [{ "secret": ["Info about user here"] }] } ``` Once the response has returned from the webhook, the `meta_data` will be set using `set_meta_data` in the `data_map.webhooks.output.action` of the function, the `get_user_info` function will be toggled on using `toggle_functions`, and the user will be notified that their information was stored. The `meta_data` key is set to the users name and the value is set to the first value in the `Records` array. ```yaml - set_meta_data: '${lc:input.args.name}: ${Records[0].secret}' ``` ```json [ { "set_meta_data": "${lc:input.args.name}: ${Records[0].secret}" } ] ``` ## 2. Looking up user information After storing the user information in `meta_data`, we can now look up the user information with the `get_user_info` function. ```yaml - function: get_user_info description: lookup user information parameters: type: object properties: name: type: string description: The name of the user data_map: expressions: - string: '${lc:args.name}' pattern: /\\w+/i output: response: The meta_data is valid. action: - say: 'Your info is ${meta_data.${lc:args.name}}' - stop: true - string: .* pattern: .* output: response: The meta_data is invalid. User has not been told their information. active: false meta_data_token: example_token ``` ```json [ { "function": "get_user_info", "description": "lookup user information", "parameters": { "type": "object", "properties": { "name": { "type": "string", "description": "The name of the user" } } }, "data_map": { "expressions": [ { "string": "${lc:args.name}", "pattern": "/\\\\w+/i", "output": { "response": "The meta_data is valid.", "action": [ { "say": "Your info is ${meta_data.${lc:args.name}}" }, { "stop": true } ] } }, { "string": ".*", "pattern": ".*", "output": { "response": "The meta_data is invalid. User has not been told their information." } } ] }, "active": false, "meta_data_token": "example_token" } ] ``` This function will check if the `meta_data` is valid by checking if the user's name is a key in the `meta_data` object. If the `meta_data` is valid, the user will be told their information. If the `meta_data` is invalid, the user will be told that their information has not been stored. ## Full example ```yaml sections: main: - ai: prompt: text: >- Your name is Mr. Blabbermouth. You help the user. ## Handling The User - You are asked to store a user's information. - You ask for their name. - You use the 'store_user' function to store the users name. ### Looking up user information - You can only look up a users information after storing it. post_prompt: text: Summarize the call in JSON format. temperature: 0.1 top_p: 0.1 post_prompt_url: https://example.com/post_prompt_url params: swaig_allow_swml: true SWAIG: functions: - function: store_user description: Store the user information parameters: type: object properties: name: type: string description: The name of the user data_map: webhooks: - url: 'https://example/name_bank?name=${lc:args.name}' method: GET output: response: The user information was stored. User information can now be looked up with the "get_user_info" function. action: - set_meta_data: '${lc:input.args.name}: ${Records[0].secret}' - toggle_functions: - active: true function: get_user_info - say: Your info was stored. meta_data_token: example_token - function: get_user_info description: lookup user information parameters: type: object properties: name: type: string description: The name of the user data_map: expressions: - string: '${lc:args.name}' pattern: /\w+/i output: response: The meta_data is valid. User has already been told their information. Do no repeat it. action: - say: 'Your info is ${meta_data.${lc:args.name}}' - stop: true - string: /.*/ pattern: /.*/ output: response: The meta_data is invalid. User has not been told their information. active: "false" meta_data_token: example_token ``` ```json { "sections": { "main": [ { "ai": { "prompt": { "text": "Your name is Mr. Blabbermouth. You help the user. ## Handling The User - You are asked to store a user's information.\n - You ask for their name.\n- You use the 'store_user' function to store the users name. ### Looking up user information - You can only look up a users information after storing it." }, "post_prompt": { "text": "Summarize the call in JSON format.", "temperature": 0.1, "top_p": 0.1 }, "post_prompt_url": "https://example.com/post_prompt_url", "params": { "swaig_allow_swml": true }, "SWAIG": { "functions": [ { "function": "store_user", "description": "Store the user information", "parameters": { "type": "object", "properties": { "name": { "type": "string", "description": "The name of the user" } } }, "data_map": { "webhooks": [ { "url": "https://example/name_bank?name=${lc:args.name}", "method": "GET", "output": { "response": "The user information was stored. User information can now be looked up with the \"get_user_info\" function.", "action": [ { "set_meta_data": "${lc:input.args.name}: ${Records[0].secret}" }, { "toggle_functions": [ { "active": true, "function": "get_user_info" } ] }, { "say": "Your info was stored." } ] } } ] }, "meta_data_token": "example_token" }, { "function": "get_user_info", "description": "lookup user information", "parameters": { "type": "object", "properties": { "name": { "type": "string", "description": "The name of the user" } } }, "data_map": { "expressions": [ { "string": "${lc:args.name}", "pattern": "/\\w+/i", "output": { "response": "The meta_data is valid. User has already been told their information. Do no repeat it.", "action": [ { "say": "Your info is ${meta_data.${lc:args.name}}" }, { "stop": true } ] } }, { "string": "/.*/", "pattern": "/.*/", "output": { "response": "The meta_data is invalid. User has not been told their information." } } ] }, "active": "false", "meta_data_token": "example_token" } ] } } } ] } } ```
