*** id: 96578205-400a-41f1-9199-7500495236e4 title: Control program flow subtitle: 'How are the methods goto, execute and transfer different?' slug: /guides/goto-execute-transfer-disambiguation max-toc-depth: 3 description: 'Learn how to use the goto, execute, and transfer methods in SWML.' -------------------------------------------------------------------------------- SWML offers a lot of flexibility in how you control program flow with its control methods. Of these, [`goto`], [`execute`], and [`transfer`] allow you to unconditionally control program flow. ## goto The [`goto`] method is designed to allow you to jump to particular labels within a section. Use this method to simulate more complex loops like `while` and `for` loops. You cannot jump to sections using `goto`. Use [`execute`] described further below to jump sections. ```yaml version: 1.0.0 sections: main: - play: url: 'say:Entering infinite loop' - label: loop - play: url: 'say:Looping ...' - goto: label: loop ``` ```json { "version": "1.0.0", "sections": { "main": [ { "play": { "url": "say:Entering infinite loop" } }, { "label": "loop" }, { "play": { "url": "say:Looping ..." } }, { "goto": { "label": "loop" } } ] } } ``` ```mermaid graph LR; loop["loop"] main --> loop loop -- goto --> loop ``` ## execute The [`execute`] method allows you to invoke a subsection as a function. You can pass parameters to the function and receive a return value. ```yaml version: 1.0.0 sections: main: - play: url: 'say:Transferring you to another section' - execute: dest: subsection - play: url: 'say: ${return_value}' subsection: - play: url: 'say:inside a subsection' - return: back! ``` ```json { "version": "1.0.0", "sections": { "main": [ { "play": { "url": "say:Transferring you to another section" } }, { "execute": { "dest": "subsection" } }, { "play": { "url": "say: ${return_value}" } } ], "subsection": [ { "play": { "url": "say:inside a subsection" } }, { "return": "back!" } ] } } ``` Output transcript: ``` "Transferring you to another section" "inside a subsection" "back!" ``` ```mermaid graph LR; main --> subsection subsection --"back!"--> main ``` Or in a more complex example: ```yaml version: 1.0.0 sections: main: - play: url: 'say:Transferring you to another section' - execute: dest: subsection params: a: 1 b: 2 - play: url: 'say: ${return_value}' subsection: - return: '${params.a+params.b}' ``` ```json { "version": "1.0.0", "sections": { "main": [ { "play": { "url": "say:Transferring you to another section" } }, { "execute": { "dest": "subsection", "params": { "a": 1, "b": 2 } } }, { "play": { "url": "say: ${return_value}" } } ], "subsection": [ { "return": "${params.a+params.b}" } ] } } ``` ```mermaid graph LR; main -- "a:1, b:2" --> subsection subsection -- "12" --> main ``` ## transfer ```yaml version: 1.0.0 sections: main: - play: url: 'say:Transferring you to another section' - transfer: dest: subsection - play: url: 'say:Back!' subsection: - play: url: 'say:inside a subsection' ``` ```json { "version": "1.0.0", "sections": { "main": [ { "play": { "url": "say:Transferring you to another section" } }, { "transfer": { "dest": "subsection" } }, { "play": { "url": "say:Back!" } } ], "subsection": [ { "play": { "url": "say:inside a subsection" } } ] } } ``` Output transcript: ``` "Transferring you to another section" "inside a subsection" ``` Notice how we aren't going back to the calling section at all. ```mermaid graph LR; main -- "params, vars, etc" --> subsection ``` ## Conclusion | | [`goto`] | [`execute`] | [`transfer`] | | :---- | :----------------------------------- | :--------------------------------------------------- | :--------------------------------------------------- | | Use | Jump between labels within a section | Invoke a subsection with params, then return | Invoke a subsection with params | | Scope | within a section | From one section to another, or to another SWML file | From one section to another, or to another SWML file | [`goto`]: /docs/swml/reference/goto [`transfer`]: /docs/swml/reference/transfer [`execute`]: /docs/swml/reference/execute
