# Forwarding calls
> Use SWML to forward calls
In [Making and receiving phone calls](/docs/swml/guides/make-and-receive-calls) we learned how to use SWML
to define what should happen when a call is received by one of your
SignalWire numbers. In that case, we just played some audio. In this article,
instead, we will use the same technique to forward the call to a different
number.
## SWML for call forwarding
We are going to define the forwarding instructions in a SWML Script hosted on SignalWire.
To create a new SWML Script, navigate to the **Resources** section from your sidebar.
There, create a new Script, and select the **SWML Script** option.
### Creating your call forwarding Script
Once you are in the menu for creating a SWML Script, copy and paste the following Script:
```yaml
version: 1.0.0
sections:
  main:
    - connect:
        to: "+15551234567"
This Script will handle the call by making an outbound dial, setting the `from` address to be the address which created the initial call,
and then forwarding that call to the number specified in the `to` field.
You should replace `+15551234567` with a real phone number, for example your personal one.
We used the [`connect`](/docs/swml/reference/connect) method to call the number you would like the call to be forwarded to.
Notice how we used its `from` parameter to ensure that the number of the original caller
(stored in the [`call.from` variable](/docs/swml/reference/calling#callfrom))
is maintained as caller ID for the forwarded call.
### Assigning the Script to a SignalWire phone number
The final step is to configure one of your SignalWire phone numbers to answer calls using the SWML Script we just created.
You can do that from the **Phone Numbers** section:
![Assign Resource.](https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/f0b50511622e76d7be927bd442190e2e41a88745515f22bc727fa5b480e23409/assets/images/dashboard/phone-numbers/assign-resource-voice.webp)
After clicking on the **Phone Numbers** section, click on the phone number that you'd like to assign, then click **edit settings**.
From there, click **Assign Resource** and assign the newly created SWML Script.
Now any calls that are routed to that number will be forwarded, with the caller ID being the original number that called in.
## Conclusion
You are now ready to test call forwarding.
SWML Scripts offer a quick and easy way to get started with common use cases. If you need more
flexibility and real-time control on your calls, check out the [SDKs](/docs/server-sdks) for programmatic call handling.
