# Execute SWML from a function
> Learn how to execute SWML from a SWAIG function.
`SWAIG` functions allow you to execute `SWML` from within itself.
This allows you to create a function that can be used to execute a specific SWML block, that lives outside the
AI language model. The benefit of this is you can get more granular control over the execution of what happens next after the function
is triggered while also getting the additional benefits of SignalWire's APIs.
For this example, we will create an AI and who will help assist with transferring the call.
The AI will ask the user for a destination to transfer to, and then execute a function to
send an SMS to notify the destination that they have a call coming in, and then transfer the call.
## Enabling SWML execution
The first important step is to make sure our AI is capable of executing SWML in its functions.
In the [`ai.params`](/docs/swml/reference/ai/params), you will need to set the parameter `swaig_allow_swml` to `true`, to allow SWML execution:
```json
  "params": {
    "swaig_allow_swml": true
## Data map example
In this example, we are using the `data_map` to execute SWML in the `data_map.expressions.output.action`.
### Creating the Function
We will create a function that will send an SMS to the destination number, and then transfer the call to the destination number.
```json
  "SWAIG": {
    "functions": [
        "function": "transfer",
        "description": "Get input from user and transfer to a destination department",
        "parameters": {
          "type": "object",
          "properties": {
            "destination": {
              "type": "string",
              "description": "The destination to transfer to"
        "data_map": {
          "expressions": [
              "string": "${args.destination}",
              "pattern": ".*",
              "output": {
                "response": "Transferring call.",
                "action": [
                    "transfer": true,
                    "SWML": {
                      "sections": {
                        "main": [
                            "send_sms": {
                              "to_number": "+1XXXXXXXXXX",
                              "from_number": "+1YYYYYYYYYY",
                              "body": "Call coming from ${caller_id_num}"
                            "connect": {
                              "to": "+1XXXXXXXXXX"
                  { "stop": true }
When passing a SWML object that includes a `connect` (or other method that transfers the call) in `output.action[]`, your script must be JSON, and `"transfer": true,` must be included before the SWML in the same action object. Refer to the example above.
### SWML Execution
We are using the `SWML` action to execute the SWML block that will send the SMS using the
[`send_sms`](/docs/swml/reference/send-sms) method
and then connect the call to the destination number using the
[`connect`](/docs/swml/reference/connect) method.
```json
  "action": [
      "transfer": true,
      "SWML": {
        "sections": {
          "main": [
              "send_sms": {
              "connect": {
### Full Example
```json
  "sections": {
    "main": [
        "ai": {
          "prompt": {
            "text": "Your name is Frank. You help the user with transferring calls.\n## Handling The User\n- You are asked to transfer a call.\n- You ask for the destination.\n- You use the 'transfer' function to transfer the call."
          "post_prompt_url": "https://example.com/post_prompt_url",
          "params": {
          "SWAIG": {
            "functions": [
                "parameters": {
                  "type": "object",
                  "properties": {
                    "destination": {
                      "type": "string",
                "data_map": {
                  "expressions": [
                      "pattern": ".*",
                      "output": {
                        "action": [
                            "transfer": true,
                            "SWML": {
                              "sections": {
                                "main": [
                                    "send_sms": {
                                    "connect": {
                          { "stop": true }
          "hints": ["transfer"]
## Webhook example
In this example, we are using the `function.web_hook_url` to execute SWML.
We will create a function that will take the input from the user as an argument (*destination*) and then make a request
to the `function.web_hook_url`.
```json
  "SWAIG": {
    "functions": [
        "web_hook_url": "https://example.com/transfer",
        "parameters": {
          "type": "object",
          "properties": {
            "destination": {
              "type": "string",
### SWML Execution
When executing `SWML` while utilizing a `function.web_hook_url`, you will need to provide a response
from the `function.web_hook_url` that contains the `action` key. In this `action` key
you will need to provide the `SWML` block that you want to execute.
**Format**:
```json
  "response": "The response to the AI",
  "action": ["The SWML block to execute"]
**Webhook Response Example**:
```json
  "action": [
      "transfer": true,
      "SWML": {
        "sections": {
          "main": [
              "send_sms": {
              "connect": {
### Full Example
```json
  "sections": {
    "main": [
        "ai": {
          "prompt": {
          "params": {
          "SWAIG": {
            "functions": [
                "parameters": {
                  "type": "object",
                  "properties": {
                    "destination": {
                      "type": "string",
