title: State Management
description: Manage data throughout call sessions using global_data for persistent state, metadata for function-scoped data, and post_prompt for call summaries.
slug: /guides/state-management
max-toc-depth: 3
[ref-datamap]: /docs/server-sdks/reference/python/agents/data-map
State management is essential for building agents that remember information throughout a conversation. Without state, every function call would be independent -- your agent wouldn't know the customer's name, what items they've ordered, or what step of a workflow they're on.
The SDK provides several state mechanisms, each designed for different use cases. Understanding when to use each one is key to building effective agents.
### How State Persists
State in the AI Agents SDK is **session-scoped** -- it exists only for the duration of a single call. When the call ends, all state is cleared. This is by design: each call is independent, and there's no built-in mechanism for persisting state between calls.
If you need data to persist across calls (like customer profiles or order history), store it in your own database and retrieve it when needed using SWAIG functions.
**Within a call, state flows like this:**
1. Agent initialization sets initial `global_data`
2. AI uses state in prompts via `${global_data.key}` substitution
3. SWAIG functions can read state from `raw_data` and update it via `FunctionResult`
4. Updated state becomes available to subsequent prompts and function calls
5. When the call ends, `post_prompt` runs to extract structured data
6. All in-memory state is cleared
<Frame caption="State flow within a call session.">
  <img class="diagram" src="https://files.buildwithfern.com/signalwire.docs.buildwithfern.com/docs/b7865608d9808c2bb96276ca74b2f721f069a06cc8a8e2d08c4afea20ef7ffce/assets/images/sdks/diagrams/06_02_state-management_diagram1.webp" alt="Diagram showing how state flows through agent initialization, prompt substitution, SWAIG functions, and post-prompt processing." />
</Frame>
### State Types Overview
| State Type       | Scope           | Key Features        |
| **global\_data** | Entire session  | Persists entire session, available to all functions, accessible in prompts, set at init or runtime                 |
| **metadata**     | Function-scoped | Scoped to function's token, private to specific function, isolated per `meta_data_token`, set via function results |
| **post\_prompt** | After call      | Executes after call ends, generates summaries, extracts structured data, webhook delivery                          |
| **call\_info**   | Read-only       | Read-only call metadata, caller ID, call ID, available in `raw_data`, SignalWire-provided                          |
### Global Data
Global data persists throughout the entire call session and is available to all functions and prompts.
#### Setting Initial Global Data
<Note>
  `set_global_data()` uses **merge** semantics -- it merges the provided dictionary into any existing global data rather than replacing it. This means you can call it multiple times and each call accumulates state.
</Note>
| Language   | Syntax                                                 |
| Python     | `self.set_global_data({"business_name": "Acme Corp"})` |
| TypeScript | `agent.setGlobalData({ business_name: 'Acme Corp' })`  |
class CustomerAgent(AgentBase):
        super().__init__(name="customer-agent")
        # Set initial global data at agent creation
            "business_name": "Acme Corp",
            "support_hours": "9 AM - 5 PM EST",
            "current_promo": "20% off first order"
        self.prompt_add_section(
            "Role",
            "You are a customer service agent for ${global_data.business_name}."
    agent = CustomerAgent()
**Multiple calls accumulate state:**
# First call sets business info
# Second call adds to (does not replace) existing data
    "current_promo": "20% off first order",
    "max_discount": 50
# Result: global_data contains all four keys
#### Updating Global Data at Runtime
| Language   | Syntax                                                  |
| Python     | `self.update_global_data({"customer_tier": "premium"})` |
| TypeScript | `agent.updateGlobalData({ customer_tier: 'premium' })`  |
    "customer_tier": "premium",
    "account_balance": 150.00
#### Updating Global Data from Functions
Updating state from within a SWAIG function handler:
| Language   | Syntax                                                      |
| Python     | `FunctionResult("Done").update_global_data({"key": "val"})` |
| TypeScript | `result.updateGlobalData({ key: 'val' })`                   |
class StateAgent(AgentBase):
        super().__init__(name="state-agent")
        self.define_tool(
            name="set_customer_name",
            description="Store the customer's name",
            parameters={
                "type": "object",
                "properties": {
                    "name": {"type": "string", "description": "Customer name"}
                "required": ["name"]
            handler=self.set_customer_name
    def set_customer_name(self, args, raw_data):
        name = args.get("name", "")
        return (
            FunctionResult(f"Stored name: {name}")
            .update_global_data({"customer_name": name})
    agent = StateAgent()
#### Accessing Global Data in Prompts
Use `${global_data.key}` syntax in prompts:
    "Customer Info",
    Customer Name: ${global_data.customer_name}
    Account Tier: ${global_data.customer_tier}
    Current Balance: ${global_data.account_balance}
### Metadata
Metadata is scoped to a specific function's `meta_data_token`, providing isolated storage per function.
#### Setting Metadata
| Language   | Syntax                                                             |
| Python     | `result.set_metadata({"order_id": order_id, "status": "pending"})` |
| TypeScript | `result.setMetadata({ orderId: orderId, status: 'pending' })`      |
def process_order(self, args, raw_data):
    order_id = create_order()
    return (
        FunctionResult(f"Created order {order_id}")
#### Removing Metadata
| Language   | Syntax                                           |
| Python     | `result.remove_metadata(["order_id", "status"])` |
| TypeScript | `result.removeMetadata(['order_id', 'status'])`  |
def cancel_order(self, args, raw_data):
    return (
        FunctionResult("Order cancelled")
### Post-Prompt Data
The post-prompt runs after the call ends and generates structured data from the conversation.
#### Setting Post-Prompt
class SurveyAgent(AgentBase):
        super().__init__(name="survey-agent")
            "Role",
            "Conduct a customer satisfaction survey."
        # Post-prompt extracts structured data after call
        self.set_post_prompt("""
            Summarize the survey results as JSON:
                "satisfaction_score": <1-10>,
                "main_feedback": "<summary>",
                "would_recommend": <true/false>,
                "issues_mentioned": ["<issue1>", "<issue2>"]
        # Optionally set where to send the data
        self.set_post_prompt_url("https://example.com/survey-results")
    agent = SurveyAgent()
#### Post-Prompt LLM Parameters
Configure a different model for post-prompt processing:
self.set_post_prompt_llm_params(
    model="gpt-4o-mini",
    temperature=0.3  # Lower for consistent extraction
### Accessing Call Information
The `raw_data` parameter contains call metadata:
    # Available call information
    call_id = raw_data.get("call_id")
    caller_id_number = raw_data.get("caller_id_number")
    caller_id_name = raw_data.get("caller_id_name")
    call_direction = raw_data.get("call_direction")  # "inbound" or "outbound"
    # Current AI interaction state
    ai_session_id = raw_data.get("ai_session_id")
    self.log.info(f"Call from {caller_id_number}")
    return FunctionResult("Processing...")
### Complete Example
<Tabs>
  <Tab title="Python">
    #!/usr/bin/env python3
    ## order_agent.py - Order management with state
    class OrderAgent(AgentBase):
            super().__init__(name="order-agent")
            # Initial global state
                "store_name": "Pizza Palace",
                "order_items": [],
                "order_total": 0.0
                "Role",
                "You are an order assistant for ${global_data.store_name}. "
                "Help customers place their order."
                "Current Order",
                "Items: ${global_data.order_items}\n"
                "Total: $${global_data.order_total}"
            # Post-prompt for order summary
                Extract the final order as JSON:
                    "items": [{"name": "", "quantity": 0, "price": 0.00}],
                    "total": 0.00,
                    "customer_name": "",
                    "special_instructions": ""
            self._register_functions()
        def _register_functions(self):
            self.define_tool(
                name="add_item",
                description="Add an item to the order",
                parameters={
                    "type": "object",
                    "properties": {
                        "item": {"type": "string", "description": "Item name"},
                        "price": {"type": "number", "description": "Item price"}
                    "required": ["item", "price"]
                handler=self.add_item
        def add_item(self, args, raw_data):
            item = args.get("item")
            price = args.get("price", 0.0)
            # Note: In real implementation, maintain state server-side
            # This example shows the pattern
            return (
                FunctionResult(f"Added {item} (${price}) to your order")
                    "last_item_added": item,
                    "last_item_price": price
        agent = OrderAgent()
  </Tab>
  <Tab title="TypeScript">
    ```typescript
    import { AgentBase, FunctionResult } from 'signalwire-agents';
    const agent = new AgentBase({ name: 'order-agent' });
    agent.addLanguage('English', 'en-US', 'rime.spore');
      store_name: 'Pizza Palace',
      order_items: [],
      order_total: 0.0,
    agent.promptAddSection('Role',
      'You are an order assistant for ${global_data.store_name}. Help customers place their order.');
    agent.promptAddSection('Current Order',
      'Items: ${global_data.order_items}\nTotal: $${global_data.order_total}');
    agent.setPostPrompt('Extract the final order as JSON: { "items": [], "total": 0.00 }');
    agent.defineTool({
      description: 'Add an item to the order',
      parameters: {
        type: 'object',
        properties: {
          item: { type: 'string', description: 'Item name' },
          price: { type: 'number', description: 'Item price' },
        required: ['item', 'price'],
      handler: (args) => {
        return new FunctionResult(`Added ${args.item} ($${args.price}) to your order`)
          .updateGlobalData({ last_item_added: args.item, last_item_price: args.price });
    agent.run();
  </Tab>
</Tabs>
### [DataMap][ref-datamap] Variable Access
In DataMap functions, use variable substitution:
from signalwire.core.data_map import DataMap
lookup_dm = (
    DataMap("lookup_customer")
    .description("Look up customer by ID")
    .parameter("customer_id", "string", "Customer ID", required=True)
    .webhook(
        "GET",
        "https://api.example.com/customers/${enc:args.customer_id}"
        "?store=${enc:global_data.store_id}"
    .output(FunctionResult(
        "Customer: ${response.name}, Tier: ${response.tier}"
### State Methods Summary
| Method                                | Scope    | Purpose                          |
| `set_global_data()`                   | Agent    | Merge data into global state     |
| `update_global_data()`                | Agent    | Update global state at runtime   |
| `FunctionResult.update_global_data()` | Function | Update state from function       |
| `FunctionResult.set_metadata()`       | Function | Set function-scoped data         |
| `FunctionResult.remove_metadata()`    | Function | Remove function-scoped data      |
| `set_post_prompt()`                   | Agent    | Set post-call data extraction    |
| `set_post_prompt_url()`               | Agent    | Set webhook for post-prompt data |
| `set_post_prompt_llm_params()`        | Agent    | Configure post-prompt model      |
### Timeout and Disconnection Behavior
Understanding what happens when calls end unexpectedly is important for robust state management.
**Normal call end:** When the caller hangs up or the agent ends the call normally, the post-prompt executes and any configured webhooks fire. State is then cleared.
**Timeout:** If the caller is silent for too long, the call may timeout. The post-prompt still executes, but the conversation may be incomplete. Design your post-prompt to handle partial data gracefully.
**Network disconnection:** If the connection drops unexpectedly, the post-prompt may not execute. Don't rely solely on post-prompt for critical data -- consider saving important state via SWAIG function webhooks as the conversation progresses.
**Function timeout:** Individual SWAIG function calls have timeout limits. If a function takes too long, it returns an error. State updates from that function call won't be applied.
### Memory and Size Limits
While the SDK doesn't impose strict limits on state size, keep these practical considerations in mind:
**Global data:** Keep global\_data reasonably small (under a few KB). Large state objects increase latency and memory usage. Don't store base64-encoded files or large datasets.
**Metadata:** Same guidance -- use metadata for small pieces of function-specific data, not large payloads.
**Prompt substitution:** When state is substituted into prompts, the entire value is included. Very large state values can consume your context window quickly.
**Best practice:** If you need to work with large datasets, keep them server-side and retrieve specific pieces as needed rather than loading everything into state.
### Structuring State Effectively
Well-structured state makes your agent easier to debug and maintain.
**Flat structures work well:**
    "customer_email": "",
    "order_total": 0.0,
    "current_step": "greeting"
**Avoid deeply nested structures:**
# Harder to access and update
    "customer": {
        "profile": {
            "personal": {
                "name": ""  # ${global_data.customer.profile.personal.name} is cumbersome
**Use consistent naming conventions:**
# Good: Clear, consistent naming
    "order_id": "",
    "order_items": [],
    "order_total": 0.0,
    "customer_phone": ""
# Avoid: Inconsistent naming
    "orderId": "",
    "items": [],
    "total": 0.0,
    "customerName": "",
    "phone": ""
### Debugging State Issues
When state isn't working as expected:
1. **Log state in handlers:**
    self.log.info(f"Current global_data: {raw_data.get('global_data', {})}")
    # ... rest of handler
2. **Check variable substitution:** Ensure your `${global_data.key}` references match the actual keys in state.
3. **Verify update timing:** State updates from a function result aren't available until the *next* prompt or function call. You can't update state and use the new value in the same function's return message.
4. **Use swaig-test:** The testing tool shows the SWML configuration including initial global\_data.
### Best Practices
**DO:**
* Use global\_data for data needed across functions
* Use metadata for function-specific isolated data
* Set initial state in **init** for predictable behavior
* Use post\_prompt to extract structured call summaries
* Log state changes for debugging
* Keep state structures flat and simple
* Use consistent naming conventions
* Save critical data server-side, not just in session state
**DON'T:**
* Store sensitive data (passwords, API keys) in global\_data where it might be logged
* Rely on global\_data for complex state machines (use server-side)
* Assume metadata persists across function boundaries
* Forget that state resets between calls
* Store large objects or arrays in state
* Use deeply nested state structures
