> This page is for Server SDKs.
# Relay Client
> Use the Relay client to make and receive phone calls with the SignalWire SDK.
[your-first-agent]: /docs/server-sdks/guides/quickstart
[ref-agentbase]: /docs/server-sdks/reference/python/agents/agent-base
[ref-call]: /docs/server-sdks/reference/python/relay/call
[ref-collectaction]: /docs/server-sdks/reference/python/relay/actions/collect-action
[ref-message]: /docs/server-sdks/reference/python/relay/message
[ref-playaction]: /docs/server-sdks/reference/python/relay/actions/play-action
[ref-recordaction]: /docs/server-sdks/reference/python/relay/actions/record-action
[ref-relayclient]: /docs/server-sdks/reference/python/relay/client
### What Is Relay?
Relay is SignalWire's real-time WebSocket protocol for programmatic call control. While the agent-based approach ([AgentBase][ref-agentbase] + SWML) lets SignalWire's AI handle conversations declaratively, Relay gives you **imperative, event-driven control** over every aspect of a call.
#### When to Use Relay vs Agents
| Approach             | Best For        |
| **AgentBase** (SWML) | AI-driven conversations, voice bots, structured workflows                             |
| **Relay Client**     | IVR systems, call routing, call center logic, recording pipelines, custom media flows |
Use Relay when you need fine-grained control over call flow — answering, playing prompts, collecting digits, recording, bridging, conferencing — without an AI agent in the loop.
### Installation
The Relay client is included in the `signalwire-sdk` package:
```bash
pip install signalwire-sdk
It requires the `websockets` library (installed automatically as a dependency).
### Quick Start
#### Python
`relay_hello.py`
#!/usr/bin/env python3
"""Minimal Relay example: answer and play a greeting."""
client = RelayClient(
    project="your-project-id",
    token="your-api-token",
    contexts=["default"],
@client.on_call
async def handle_call(call):
    await call.answer()
    action = await call.play([{"type": "tts", "params": {"text": "Hello from Relay!"}}])
    await action.wait()
    await call.hangup()
client.run()
#### TypeScript
```typescript
import { RelayClient } from '@signalwire/sdk';
  project: 'your-project-id',
  token: 'your-api-token',
  contexts: ['default'],
client.onCall(async (call) => {
  await call.answer();
  const action = await call.play([{ type: 'tts', text: 'Hello from Relay!' }]);
  await action.wait();
  await call.hangup();
client.run();
### Authentication
The Relay client supports two authentication methods:
#### Project + API Token
| Language   | Syntax                                              |
| Python     | `RelayClient(project="...", token="...")`           |
| TypeScript | `new RelayClient({ project: '...', token: '...' })` |
#### JWT Token
    jwt_token="your-jwt-token",
#### Environment Variables
All credentials can be provided via environment variables instead of constructor arguments:
| Variable                | Purpose                                  |
| `SIGNALWIRE_PROJECT_ID` | Project ID                               |
| `SIGNALWIRE_API_TOKEN`  | API token                                |
| `SIGNALWIRE_JWT_TOKEN`  | JWT token (alternative to project+token) |
# With env vars set, no arguments needed
client = RelayClient(contexts=["default"])
### Connection Lifecycle
The Relay client manages a persistent WebSocket connection with automatic reconnection:
1. **Connect** — Establishes WebSocket to `wss://relay.signalwire.com`
2. **Authenticate** — Sends `signalwire.connect` with credentials
3. **Subscribe** — Registers for events on specified contexts
4. **Event Loop** — Processes events until disconnected
5. **Reconnect** — Automatic reconnection with exponential backoff (1s to 30s max)
#### Contexts
Contexts determine which inbound calls your client receives. Pass them in the constructor or subscribe dynamically:
# Subscribe at connection time
client = RelayClient(contexts=["sales", "support"])
# Or subscribe dynamically after connecting
await client.receive(["new-context"])
# Unsubscribe from contexts
await client.unreceive(["old-context"])
#### Async Context Manager
async with RelayClient(contexts=["default"]) as client:
    # Connected and authenticated
    call = await client.dial(...)
    # Automatically disconnects on exit
### Handling Inbound Calls
Register a handler with the `@client.on_call` decorator:
`relay_inbound.py`
"""Handle inbound calls with Relay."""
client = RelayClient(contexts=["ivr"])
@client.on_call
    print(f"Inbound call from {call.device}")
    await call.answer()
    # Play a menu
        {"type": "tts", "params": {"text": "Press 1 for sales, 2 for support."}}
    await action.wait()
    # Collect a digit
    collect = await call.collect(
        digits={"max": 1, "digit_timeout": 5.0},
        initial_timeout=10.0,
    result = await collect.wait()
    digit = result.params.get("result", {}).get("digits", "")
    if digit == "1":
        await call.connect([[{"type": "phone", "params": {"to_number": "+15551001000"}}]])
    elif digit == "2":
        await call.connect([[{"type": "phone", "params": {"to_number": "+15552002000"}}]])
    else:
        play = await call.play([{"type": "tts", "params": {"text": "Invalid selection. Goodbye."}}])
        await play.wait()
        await call.hangup()
client.run()
The [`Call`][ref-call] object provides:
| Property    | Description                     |
| `call_id`   | Unique call identifier          |
| `node_id`   | Relay node handling the call    |
| `context`   | Context the call arrived on     |
| `direction` | `"inbound"` or `"outbound"`     |
| `device`    | Device info dict (type, params) |
| `state`     | Current call state              |
| `tag`       | Client-provided correlation tag |
### Making Outbound Calls
Use `client.dial()` to initiate outbound calls:
`relay_outbound.py`
"""Make an outbound call with Relay."""
import asyncio
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "from_number": "+15551234567",
                    "to_number": "+15559876543",
                    "timeout": 30,
        print(f"Call answered: {call.call_id}")
            {"type": "tts", "params": {"text": "This is an automated message from SignalWire."}}
        await action.wait()
        await call.hangup()
asyncio.run(main())
The `devices` parameter supports serial and parallel dialing:
# Serial dial: try first, then second
devices = [
    [{"type": "phone", "params": {"to_number": "+15551111111", "from_number": "+15550000000"}}],
    [{"type": "phone", "params": {"to_number": "+15552222222", "from_number": "+15550000000"}}],
# Parallel dial: ring both simultaneously
devices = [
        {"type": "phone", "params": {"to_number": "+15551111111", "from_number": "+15550000000"}},
        {"type": "phone", "params": {"to_number": "+15552222222", "from_number": "+15550000000"}},
### Call Control Methods
Key call control methods across languages:
| Method   | Python                                                            |
| Answer   | `await call.answer()`                                             |
| Play TTS | `await call.play([{"type": "tts", "params": {"text": "Hello"}}])` |
| Record   | `await call.record(audio={...})`                                  |
| Hang up  | `await call.hangup()`                                             |
| Connect  | `await call.connect(devices)`                                     |
#### Audio Playback
# Play TTS
action = await call.play([{"type": "tts", "params": {"text": "Hello!"}}])
await action.wait()
# Play audio file
action = await call.play([{"type": "audio", "params": {"url": "https://example.com/audio.mp3"}}])
# Control playback
await action.pause()
await action.resume()
await action.volume(5.0)  # -40.0 to 40.0 dB
await action.stop()
#### Recording
# Start recording
action = await call.record(audio={"direction": "both", "format": "mp3"})
# Pause/resume recording
# Stop and get result
await action.stop()
result = await action.wait()
url = result.params.get("record", {}).get("url", "")
print(f"Recording URL: {url}")
#### Input Collection
# Collect digits with prompt
collect = await call.play_and_collect(
    media=[{"type": "tts", "params": {"text": "Enter your account number."}}],
    collect={
        "digits": {
            "max": 10,
            "digit_timeout": 3.0,
            "terminators": "#",
digits = result.params.get("result", {}).get("digits", "")
# Standalone collect (no prompt)
    digits={"max": 4, "digit_timeout": 5.0},
    speech={"end_silence_timeout": 2.0},
#### Detection (Answering Machine, Fax, DTMF)
# Answering machine detection
detect = await call.detect(
    detect={"type": "machine", "params": {"initial_timeout": 4.5}},
    timeout=30.0,
result = await detect.wait()
machine_result = result.params.get("detect", {})
#### Bridging / Connecting
# Bridge to another number
await call.connect(
    devices=[[{
        "type": "phone",
        "params": {"to_number": "+15559876543", "from_number": "+15551234567"},
    ringback=[{"type": "ringtone", "params": {"name": "us"}}],
# Disconnect (unbridge)
await call.disconnect()
#### Conference
# Join a conference
await call.join_conference("team-standup", muted=False, beep="true")
# Leave a conference
await call.leave_conference("conference-id-here")
#### Hold / Unhold
await call.hold()
# ... do something ...
await call.unhold()
#### Noise Reduction
await call.denoise()
# ... later ...
await call.denoise_stop()
#### AI Agent on a Call
You can start an AI agent session on a Relay-controlled call:
ai = await call.ai(
    prompt={"text": "You are a helpful assistant."},
    languages=[{"name": "English", "code": "en-US", "voice": "rime.spore"}],
await ai.wait()  # Blocks until AI session ends
### The Action Pattern
Most call control methods return an **Action** object — an async handle for the ongoing operation:
action = await call.play([{"type": "tts", "params": {"text": "Hello"}}])
# Fire-and-forget: don't wait for completion
print(f"Play started, control_id={action.control_id}")
# Or wait for completion
result = await action.wait(timeout=30.0)
print(f"Play finished: {result.params.get('state')}")
#### Common Action Methods
| Method          | Available On                                                    | Description               |
| `wait(timeout)` | All actions                                                     | Wait for completion       |
| `stop()`        | Play, Record, Detect, Collect, Fax, Tap, Stream, Transcribe, AI | Stop the operation        |
| `pause()`       | [PlayAction][ref-playaction], [RecordAction][ref-recordaction]  | Pause playback/recording  |
| `resume()`      | PlayAction, RecordAction                                        | Resume playback/recording |
| `volume(db)`    | PlayAction, [CollectAction][ref-collectaction]                  | Adjust volume             |
#### on_completed Callback
Every action-based method accepts an `on_completed` callback:
async def on_play_done(event):
    print(f"Play finished: {event.params.get('state')}")
    [{"type": "tts", "params": {"text": "Processing..."}}],
    on_completed=on_play_done,
# No need to await — callback fires automatically
### SMS/MMS Messaging
The Relay client supports sending and receiving SMS/MMS messages. For a walkthrough that also
assigns a phone number's messages to your client and compares Relay with SWML and REST, see
[Send and receive messages](/docs/platform/messaging/send-and-receive-messages).
| Language   | Send Message        |
| Python     | `await client.send_message(to_number="+155...", from_number="+155...", body="Hello")`     |
| TypeScript | `await client.sendMessage({ toNumber: '+155...', fromNumber: '+155...', body: 'Hello' })` |
#### Sending Messages
message = await client.send_message(
    to_number="+15559876543",
    from_number="+15551234567",
    body="Hello from SignalWire Relay!",
print(f"Message ID: {message.message_id}")
# Wait for delivery confirmation
result = await message.wait(timeout=30.0)
print(f"Final state: {message.state}")  # delivered, failed, etc.
#### Sending MMS (with media)
    body="Check out this image!",
    media=["https://example.com/photo.jpg"],
#### Receiving Messages
@client.on_message
async def handle_message(message):
    print(f"From: {message.from_number}")
    print(f"Body: {message.body}")
    if message.media:
        print(f"Media: {message.media}")
The [`Message`][ref-message] object provides:
| `message_id`  | Unique message identifier                       |
| `from_number` | Sender number                                   |
| `to_number`   | Recipient number                                |
| `body`        | Text content                                    |
| `media`       | List of media URLs                              |
| `state`       | Current state (queued, sent, delivered, failed) |
| `segments`    | Number of SMS segments                          |
| `tags`        | Optional tags                                   |
### Event Listeners
Register per-call event listeners for fine-grained control:
from signalwire.relay import EVENT_CALL_STATE, EVENT_CALL_PLAY
@client.on_call
    def on_state_change(event):
        print(f"Call state: {event.params.get('call_state')}")
    def on_play_event(event):
        print(f"Play state: {event.params.get('state')}")
    call.on(EVENT_CALL_STATE, on_state_change)
    call.on(EVENT_CALL_PLAY, on_play_event)
    await call.answer()
    await call.wait_for_ended()
### Advanced Configuration
#### Max Active Calls
Limit concurrent calls to prevent resource exhaustion:
# Via constructor
client = RelayClient(contexts=["default"], max_active_calls=100)
Or via environment variable:
```bash
export RELAY_MAX_ACTIVE_CALLS=100
Default: 1000.
#### Connection Limits
By default, only one [`RelayClient`][ref-relayclient] connection is allowed per process:
```bash
export RELAY_MAX_CONNECTIONS=3
#### Error Handling
The client handles errors gracefully — server errors from call methods return empty dicts rather than raising exceptions. Connection-level errors trigger automatic reconnection.
For explicit error handling:
from signalwire.relay import RelayClient, RelayError
try:
    call = await client.dial(devices=[[{...}]])
except RelayError as e:
    print(f"Relay error {e.code}: {e.message}")
### Complete Example: IVR System
`relay_ivr.py`
"""Complete IVR system with Relay."""
from signalwire.relay import RelayClient, EVENT_CALL_STATE
client = RelayClient(contexts=["main-ivr"])
@client.on_call
    await call.answer()
    # Start recording
    recording = await call.record(audio={"direction": "both", "format": "mp3"})
    # Play welcome and collect input
        media=[
            {"type": "tts", "params": {"text": "Welcome to Acme Corp."}},
            {"type": "tts", "params": {"text": "Press 1 for sales, 2 for support, or 3 to leave a message."}},
        collect={"digits": {"max": 1, "digit_timeout": 5.0}},
    if digit == "1":
        await call.play([{"type": "tts", "params": {"text": "Connecting you to sales."}}])
            "type": "phone",
            "params": {"to_number": "+15551001000", "from_number": "+15550000000"},
    elif digit == "2":
        await call.play([{"type": "tts", "params": {"text": "Connecting you to support."}}])
            "type": "phone",
            "params": {"to_number": "+15552002000", "from_number": "+15550000000"},
    elif digit == "3":
            {"type": "tts", "params": {"text": "Please leave your message after the beep."}},
            {"type": "audio", "params": {"url": "https://example.com/beep.wav"}},
        await play.wait()
        voicemail = await call.record(audio={
            "direction": "listen",
            "format": "mp3",
            "end_silence_timeout": 3.0,
        await voicemail.wait()
    else:
        play = await call.play([{"type": "tts", "params": {"text": "Invalid option. Goodbye."}}])
        await play.wait()
    # Stop recording and hang up
    await recording.stop()
    await call.hangup()
    client.run()
### See Also
| Topic                | Reference                            |
| Agent-based approach | [Your First Agent][your-first-agent] |
