# AI Parameters
> Tune conversation behavior with parameters for speech detection, timeouts, barge control, and AI model settings.
### Parameter Categories
| Category             | Key Parameters                            | Purpose                         |
| **Speech Detection** | `end_of_speech_timeout`                   | Control when speech ends        |
| **Timeouts**         | `attention_timeout`, `inactivity_timeout` | Handle silence and idle callers |
| **Barge Control**    | `barge_match_string`                      | Manage interruptions            |
| **AI Model**         | `temperature`, `top_p`, `max_tokens`      | Tune response generation        |
### Setting Parameters
The `set_params` method accepts a dictionary/map/object of parameter names and values:
| Language   | Syntax        |
| Python     | `agent.set_params({"end_of_speech_timeout": 600, "temperature": 0.5})` |
| TypeScript | `agent.setParams({ end_of_speech_timeout: 600, temperature: 0.5 })`    |
class MyAgent(AgentBase):
        # Set multiple parameters at once
        self.set_params({
            "attention_timeout": 15000,
            "inactivity_timeout": 45000,
            "temperature": 0.5
### Essential Parameters
#### Speech Detection
| Parameter               | Type | Default | Description                                       |
| `end_of_speech_timeout` | int  | 700     | Milliseconds of silence before speech is complete |
| `energy_level`          | int  | 52      | Minimum audio level in dB (0-100)                 |
## Fast response - shorter silence detection
self.set_params({"end_of_speech_timeout": 400})
## Patient agent - longer silence tolerance
self.set_params({"end_of_speech_timeout": 1000})
#### Timeouts
| `attention_timeout`  | int  | 5000    | Milliseconds before prompting idle caller        |
| `inactivity_timeout` | int  | 600000  | Milliseconds before ending call (10 min default) |
## Quick service - prompt quickly if silent
self.set_params({
    "attention_timeout": 5000,    # "Are you there?" after 5 seconds
    "inactivity_timeout": 30000   # End call after 30 seconds
## Patient service - give caller time to think
self.set_params({
    "attention_timeout": 20000,   # Wait 20 seconds before prompting
    "inactivity_timeout": 60000   # Wait full minute before ending
#### Barge Control
Barge-in allows callers to interrupt the AI while it's speaking.
| `barge_match_string` | str  | -       | Phrase required to trigger barge |
| `transparent_barge`  | bool | true    | Enable transparent barge mode    |
## Require specific phrase to interrupt
self.set_params({
    "barge_match_string": "excuse me"
#### AI Model
| `temperature`       | float | 0.3     | Randomness (0-2, higher = more creative) |
| `top_p`             | float | 1.0     | Nucleus sampling threshold               |
| `max_tokens`        | int   | 256     | Maximum response length                  |
| `frequency_penalty` | float | 0.1     | Reduce repetitive phrases                |
## Consistent responses (FAQ bot)
self.set_params({"temperature": 0.2})
## Creative responses (entertainment)
self.set_params({"temperature": 0.9})
## Balanced for customer service
self.set_params({
    "temperature": 0.5,
    "frequency_penalty": 0.3
### Use Case Presets
#### Customer Service
self.set_params({
    "attention_timeout": 12000,
    "temperature": 0.5
#### Technical Support
self.set_params({
    "end_of_speech_timeout": 800,    # Patient for complex explanations
    "inactivity_timeout": 60000,
    "temperature": 0.3               # Precise responses
#### IVR Menu
self.set_params({
    "end_of_speech_timeout": 400,    # Quick response
    "attention_timeout": 8000,
    "inactivity_timeout": 20000,
    "temperature": 0.2               # Very consistent
### Tuning Guide
#### If callers are...
| Problem                       | Solution                         |
| Being cut off mid-sentence    | Increase `end_of_speech_timeout` |
| Waiting too long for response | Decrease `end_of_speech_timeout` |
| Not hearing "Are you there?"  | Decrease `attention_timeout`     |
| Getting hung up on too fast   | Increase `inactivity_timeout`    |
#### If responses are...
| Too repetitive          | Increase `frequency_penalty` |
| Too random/inconsistent | Decrease `temperature`       |
| Too predictable         | Increase `temperature`       |
| Too long                | Decrease `max_tokens`        |
### Complete Example
#### Python
#!/usr/bin/env python3
## configured_agent.py - Agent with AI parameters configured
class ConfiguredAgent(AgentBase):
        super().__init__(name="configured-agent")
        self.set_params({
            # Speech detection
            # Timeouts
        self.prompt_add_section(
            "Role",
            "You are a helpful customer service agent."
    agent = ConfiguredAgent()
#### TypeScript
```typescript
import { AgentBase } from '@signalwire/sdk';
const agent = new AgentBase({ name: 'configured-agent' });
agent.addLanguage({ name: 'English', code: 'en-US', voice: 'rime.spore' });
agent.setParams({ end_of_speech_timeout: 600, attention_timeout: 15000, inactivity_timeout: 45000 });
agent.promptAddSection('Role', { body: 'You are a helpful customer service agent.' });
agent.run();
### More Parameters
For the complete list of all available parameters including:
* ASR configuration (diarization, smart formatting)
* Audio settings (volume, background music, hold music)
* Video parameters
* Advanced behavior controls
* SWAIG control parameters
See the **AI Parameters Reference** in the Appendix.
