> This page is for Platform.
# Transcribe calls
> Transcribe a live call as it happens with SWML, Relay, or REST and receive each utterance on your webhook, then summarize the conversation with AI, stop transcribing, or transcribe the whole call after it ends.
[prepare-calls]: /docs/platform/voice/make-and-receive-calls#prepare-for-your-first-call
[place-relay]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-websocket-relay
[swml-live-transcribe]: /docs/swml/reference/calling/live-transcribe
[swml-transcribe]: /docs/swml/reference/calling/transcribe
[swml-transcribe-stop]: /docs/swml/reference/calling/transcribe-stop
[swml-execute]: /docs/swml/reference/calling/execute
[swml-ai-sidecar]: /docs/swml/reference/calling/ai-sidecar
[sidecar-callbacks]: /docs/swml/reference/calling/ai-sidecar#callback-types
[sidecar-guide]: /docs/platform/ai/sidecar
[utterance-webhook]: /docs/apis/rest/webhooks/live-transcribe-utterance-webhook
[summary-webhook]: /docs/apis/rest/webhooks/live-transcribe-summary-webhook
[conversation-log-webhook]: /docs/apis/rest/webhooks/live-transcribe-conversation-log-webhook
[transcript-status-callback]: /docs/apis/rest/webhooks/transcribe-status-callback
[transcribe-state-callback]: /docs/apis/rest/webhooks/transcribe-state-callback
[verify-signature]: /docs/platform/webhooks#verify-webhook-signature
[call-streaming]: /docs/platform/voice/call-streaming
[record-calls]: /docs/platform/voice/record-calls
Live transcription turns each side of a call into text while the call happens, and posts every
utterance to a webhook you run, so your app can show a transcript, search it, or act on what the
caller says. Start by transcribing a call between your phone and your number into a small server that prints each
utterance, then read the events in full, tune the options, summarize the conversation with AI, stop
transcribing, and transcribe a whole call after it ends.
## Prepare for call transcription
This guide places and answers calls the way [Make and receive calls][make-and-receive-calls] does.
Have these values ready:
* Your Space URL, such as `<YOUR_SPACE>.signalwire.com`.
* Your Project ID and an API token with the **Voice** permission.
* A phone number in your Space, and a phone you can call it from and answer.
* A machine that can run a small server, and a tunnel such as [ngrok](https://ngrok.com/) that
  gives it a public HTTPS URL.
> **Trial projects only call and receive calls from verified numbers**
> A [trial project][trial-mode] only places calls to and receives calls from numbers you've
> purchased or verified, and can't call internationally. [Prepare for your first call][prepare-calls]
> shows how to verify the phone you'll test with.
> **Transcribing a call can require consent**
> Transcription captures what people say on the call, and many jurisdictions require you to tell
> callers before you record or transcribe them. Check the rules that apply to your callers before you
> transcribe a real conversation.
| Value                           | Replace with        |
| `<YOUR_SPACE>`                  | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                                                         |
| `<YOUR_PROJECT_ID>`             | Your Project ID        |
| `<YOUR_API_TOKEN>`              | Your API token with the Voice permission, used only in server code                                              |
| `<YOUR_PUBLIC_HOST>`            | The public hostname of your server's tunnel        |
| `<YOUR_BASIC_AUTH_PASSWORD>`    | A password you choose for the SWML your server serves                                                           |
| `<YOUR_TRANSCRIPT_WEBHOOK_URL>` | Your server's transcript webhook, `https://<YOUR_PUBLIC_HOST>/transcripts`                                      |
| `<YOUR_TRANSCRIPT_STATUS_URL>`  | Your server's post-call transcript webhook, `https://<YOUR_PUBLIC_HOST>/transcript-status`                      |
| `<YOUR_CALLER_ID>`              | Your SignalWire phone number, or a [verified caller ID][caller-id], in E.164 format, when Relay places the call |
| `<YOUR_DESTINATION>`            | The phone you'll answer, in E.164 format, when Relay places the call                                            |
| `<YOUR_CALL_ID>`                | The ID of a live call, when you send a command over REST                                                        |
## How live transcription works
The SWML [`live_transcribe`][swml-live-transcribe] method and the `calling.live_transcribe`
command, sent over Relay or REST, all take the same `action`: `start` a session, `summarize`
it, or `stop` it. Once a session starts, SignalWire recognizes speech on each side of the call you
list in `direction` and sends HTTP `POST` requests to the `webhook` URL you set on `start`:
* With `live_events` set to `true`, one request for each utterance as soon as it's transcribed.
* When you send `summarize`, one request with an AI summary of the conversation so far.
* When the session ends, because you stopped it or the call ended, one request with the whole
  conversation, totals for the session, and an AI summary if you asked for one.
All three requests arrive at the same URL, so your server tells them apart by
`channel_data.content_disposition`, as [Read transcript events on your webhook](#read-transcript-events-on-your-webhook)
shows.
SignalWire has a second, simpler method, [`transcribe`][swml-transcribe]. It produces no text
during the call. When the call ends, it posts the whole call's text to a `status_url` as a single
block. Choose by when you need the text:
| You need                                                   | Use               |
| Text while the call is happening, one utterance at a time  | `live_transcribe` |
| Who said what, as `remote-caller` and `local-caller` turns | `live_transcribe` |
| An AI summary of the conversation                          | `live_transcribe` |
| Text in any language other than U.S. English               | `live_transcribe` |
| The call's text after it ends, and nothing during it       | `transcribe`      |
The rest of this guide uses `live_transcribe` until
[Transcribe the whole call after it ends](#transcribe-the-whole-call-after-it-ends).
## Transcribe a call in real time
Every sample in this guide sends transcript events to one small server that prints them. Run it
first, then start transcription from the product your app uses.
### Transcribe a call in real time via SWML
When someone calls your number, SignalWire fetches the call's SWML from your server and runs it.
The server below serves that document and receives the transcript events, so one tunnel covers
both.
#### Run the transcription server
This server answers calls with a SWML document that starts live transcription on both sides of the
call, asks the caller where they're headed, and keeps the call open for twenty seconds while they
talk. It prints each utterance that arrives at `/transcripts`, and the transcript that arrives at
`/transcript-status`, which the post-call section uses later. The document is served only to
requests that carry the username `signalwire` and the password you set.
#### Python — SWML builder
# Install: python -m pip install signalwire-sdk==3.4.1 fastapi "uvicorn[standard]"
# Save as transcribe_app.py and run: python transcribe_app.py
import uvicorn
from fastapi import FastAPI, Request
service = SWMLService(
    name="transcribe-call",
swml = SWMLBuilder(service)
swml.answer().live_transcribe(action={
    "start": {
        "lang": "en-US",
        "direction": ["remote-caller", "local-caller"],
        "webhook": "<YOUR_TRANSCRIPT_WEBHOOK_URL>",
        "live_events": True,
swml.say("Thanks for calling Bayview Taxi. Where would you like to go?").sleep(20000).say(
    "Thanks. A driver is on the way. Goodbye."
app = FastAPI()
# SignalWire fetches the call's SWML from the server's root URL.
app.include_router(service.as_router())
# Live transcription events arrive at /transcripts.
@app.post("/transcripts")
async def transcripts(request: Request):
    event = await request.json()
    kind = event["channel_data"]["content_disposition"]
    if kind == "transcribe.utterance":
        utterance = event["utterance"]
        print(f"{utterance['role']}: {utterance['content']}")
    elif kind == "transcribe.live_summarize":
        print(f"Summary so far: {event['conversation_summary']}")
    elif kind == "transcribe.conversation_log":
        print(f"Transcription ended after {len(event['conversation_log'])} utterances")
        if "conversation_summary" in event:
            print(f"Summary: {event['conversation_summary']}")
    return {}
# Post-call transcripts arrive at /transcript-status.
@app.post("/transcript-status")
async def transcript_status(request: Request):
    # Skip the calling.call.transcribe state events.
    if event["event_type"].startswith("calling.transcript."):
        print(f"{event['event_type']}: {event['params'].get('text', '')}")
    return {}
uvicorn.run(app, host="0.0.0.0", port=8080)
#### TypeScript — SWML builder
```typescript
// Install: npm install @signalwire/sdk@2.0.5 @hono/node-server hono
// This sample also runs as JavaScript: save as transcribe-app.mjs,
// then run: node transcribe-app.mjs
import { serve } from "@hono/node-server";
import { Hono } from "hono";
const swml = service.getBuilder();
swml.answer().live_transcribe({
  action: {
    start: {
      lang: "en-US",
      direction: ["remote-caller", "local-caller"],
      webhook: "<YOUR_TRANSCRIPT_WEBHOOK_URL>",
      live_events: true,
swml
  .sleep(20000)
  .say("Thanks. A driver is on the way. Goodbye.");
const app = new Hono();
// Live transcription events arrive at /transcripts.
app.post("/transcripts", async (c) => {
  const event = await c.req.json();
  const kind = event.channel_data.content_disposition;
  if (kind === "transcribe.utterance") {
    console.log(`${event.utterance.role}: ${event.utterance.content}`);
  } else if (kind === "transcribe.live_summarize") {
    console.log(`Summary so far: ${event.conversation_summary}`);
  } else if (kind === "transcribe.conversation_log") {
    console.log(`Transcription ended after ${event.conversation_log.length} utterances`);
    if (event.conversation_summary) console.log(`Summary: ${event.conversation_summary}`);
  return c.json({});
// Post-call transcripts arrive at /transcript-status.
app.post("/transcript-status", async (c) => {
  // Skip the calling.call.transcribe state events.
  if (event.event_type.startsWith("calling.transcript.")) {
    console.log(`${event.event_type}: ${event.params.text ?? ""}`);
  return c.json({});
// SignalWire fetches the call's SWML from the server's root URL.
app.route("/", service.getApp());
serve({ fetch: app.fetch, port: 8080 });
console.log("Listening on port 8080");
Start a tunnel to port `8080`, such as `ngrok http 8080`, and use its hostname as
`<YOUR_PUBLIC_HOST>` in the webhook URL before you start the server. Check that the document is
reachable through the tunnel:
```bash
curl -u "signalwire:<YOUR_BASIC_AUTH_PASSWORD>" "https://<YOUR_PUBLIC_HOST>/"
The response is the SWML document, starting with `{"version": "1.0.0"`. A `401` means the password
doesn't match the one in your server.
#### Point your phone number at the server
Create a SWML Script that fetches the document from your server:
1. Open **My Resources**, select **+ Add**, then **Script**, then **SWML Script**.
2. Name it **Transcribe call** and leave **Used For** set to **Calling**.
3. Under **Handle Calls Using**, choose **External URL** and enter
   `https://signalwire:<YOUR_BASIC_AUTH_PASSWORD>@<YOUR_PUBLIC_HOST>/` in **Primary Script URL**.
4. Select **Create**.
Then assign the script to your phone number:
Open **Phone Numbers**, select the number, and select **Edit Settings**. Under **Inbound Call
Settings**, select **Assign Resource**, choose the Resource, and save. To assign from the Resource
instead, open its **Addresses & Phone Numbers** tab, select **+ Add**, then **Phone Number**, and
pick a number you own.
To do both in code, see [Answer a call via SWML][answer-swml].
#### Call your number and speak
Call your SignalWire number from your phone and answer the question. The server prints each
utterance as it's transcribed, with the side of the call that spoke:
```text
local-caller: Thanks for calling Bayview Taxi. Where would you like to go?
remote-caller: To the airport, please.
`remote-caller` is you, and `local-caller` is the prompt SignalWire played. After twenty seconds
you hear the goodbye, the call ends, and the server prints
`Transcription ended after 3 utterances` with your own count. If it doesn't work, see
[Troubleshoot call transcription](#troubleshoot-call-transcription).
The same document in YAML and JSON, to paste into a hosted SWML Script instead:
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - answer: {}
    - live_transcribe:
        action:
          start:
            lang: en-US
            direction:
              - remote-caller
              - local-caller
            webhook: <YOUR_TRANSCRIPT_WEBHOOK_URL>
            live_events: true
    - play:
        url: say:Thanks for calling Bayview Taxi. Where would you like to go?
    - sleep: 20000
    - play:
        url: say:Thanks. A driver is on the way. Goodbye.
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "answer": {} },
        "live_transcribe": {
          "action": {
            "start": {
              "lang": "en-US",
              "live_events": true
      { "play": { "url": "say:Thanks for calling Bayview Taxi. Where would you like to go?" } },
      { "sleep": 20000 },
      { "play": { "url": "say:Thanks. A driver is on the way. Goodbye." } }
### Transcribe a call in real time via WebSocket (Relay)
Send the live transcribe command to an answered call, passing the same `action` the SWML method
takes. Transcript events still go to your webhook, so keep the
[transcription server](#run-the-transcription-server) and its tunnel running. Call setup follows
[Place a call via WebSocket (Relay)][place-relay].
#### Run the call program
This program dials your phone, starts transcription, asks where you're headed, and hangs up after
twenty seconds.
#### Python — Relay client
# Save as transcribe_call_relay.py and run: python transcribe_call_relay.py
import asyncio
client = RelayClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
    contexts=["default"],
async def main():
    async with client:
        call = await client.dial(
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        await call.live_transcribe({
            "start": {
                "lang": "en-US",
        await call.play([{
            "type": "tts",
            "params": {"text": "Hi, this is Bayview Taxi. Where would you like to go?"},
        await asyncio.sleep(20)
            if call.state != "ended":
                await call.hangup()
        await call.play(
            [{"type": "tts", "params": {"text": "Thanks. A driver is on the way. Goodbye."}}],
        await call.wait_for_ended()
asyncio.run(main())
```typescript
// This sample also runs as JavaScript: save as transcribe-call-relay.mjs,
// then run: node transcribe-call-relay.mjs
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
  contexts: ["default"],
await client.connect();
    type: "phone",
    params: {
      timeout: 30,
  await call.liveTranscribe({
    start: {
      lang: "en-US",
      live_events: true,
  await call.play([
    { type: "tts", text: "Hi, this is Bayview Taxi. Where would you like to go?" },
  await new Promise((resolve) => setTimeout(resolve, 20_000));
  await call.play([{ type: "tts", text: "Thanks. A driver is on the way. Goodbye." }], {
    onCompleted: async () => {
  await call.waitForEnded();
} finally {
  await client.disconnect();
The Server SDKs send the `action` keys as written, so they stay in snake_case in every language.
#### Answer and speak
Answer your phone and say where you're headed. The transcription server prints a `local-caller`
line for the prompt and a `remote-caller` line for your answer. After twenty seconds you hear the
goodbye, the call ends, and the server prints `Transcription ended after` with the number of
utterances. If it doesn't work, see [Troubleshoot call transcription](#troubleshoot-call-transcription).
### Start live transcription on a call in progress via REST
When a process that doesn't hold the call needs to transcribe it, send the `calling.live_transcribe`
command with the answered call's ID and a `start` action. The call ID is the `id` from the `dial`
response, or the `call_id` delivered to your SWML endpoint or webhook. The
[Server SDKs][server-sdks] wrap the command:
#### Python — REST client
# Save as transcribe_rest.py and run: python transcribe_rest.py
client = RestClient(
client.calling.live_transcribe(
    "<YOUR_CALL_ID>",
    action={
        "start": {
            "lang": "en-US",
print("Transcription started")
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as transcribe-rest.mjs,
// then run: node transcribe-rest.mjs
await client.calling.liveTranscribe("<YOUR_CALL_ID>", {
  action: {
    start: {
      lang: "en-US",
      live_events: true,
console.log("Transcription started");
#### cURL — Calling API
```bash
curl -X POST "https://<YOUR_SPACE>.signalwire.com/api/calling/calls" \
  -u "<YOUR_PROJECT_ID>:<YOUR_API_TOKEN>" \
  -d '{
    "command": "calling.live_transcribe",
    "id": "<YOUR_CALL_ID>",
    "params": {
      "action": {
        "start": {
          "lang": "en-US",
          "live_events": true
The cURL request sends the same command to [Call commands][call-commands]. To try it, run the
program while a call that isn't already being transcribed is up, such as one from
[Make and receive calls][make-and-receive-calls]. The transcription server starts printing
utterances as soon as the command succeeds.
## Read transcript events on your webhook
Each request is a JSON `POST`. Read `channel_data.content_disposition` first, then the fields for
that event:
| `content_disposition`         | Sent                                             | Fields to read        |
| `transcribe.utterance`        | Once per utterance, when `live_events` is `true` | `utterance.role`, `utterance.content`, `confidence`                                   |
| `transcribe.live_summarize`   | When you send `summarize`                        | `conversation_summary`, `conversation_log`                                            |
| `transcribe.conversation_log` | Once, when the session ends                      | `conversation_log`, `metrics`, and `conversation_summary` when `ai_summary` is `true` |
`utterance.role` and each `conversation_log` entry's `role` say which side of the call spoke, using
the values you passed in `direction`. Every event also carries `channel_data.call_id`, so one server
can follow several calls at once. Timestamps such as `utterance.timestamp` are Unix times in
microseconds. The top-level `confidence` is the speech engine's confidence in the utterance, from
`0` to `1`, or `null` when the engine didn't report one.
An utterance event looks like this. The [Live transcription utterance webhook][utterance-webhook]
reference lists every field:
The event sent when the session ends carries the whole conversation in order, with totals for each
side in `metrics`. Its fields are in the [Live transcription conversation log webhook][conversation-log-webhook]
reference:
The summary you request mid-call has the same `conversation_log` and `conversation_summary` fields,
without `metrics`. See the [Live transcription summary webhook][summary-webhook] reference.
Answer each request with a `2xx` status within 10 seconds, and do slow work after you respond.
SignalWire retries a request that fails to connect, times out, or gets a `5xx` status, so a slow
handler can receive the same utterance more than once. Use `utterance.utterance_id` to ignore
repeats. A `4xx` status isn't retried, and redirects aren't followed, so that event is lost.
> **Protect your webhooks**
> Requests carry an `X-SignalWire-Signature` header, so your server can confirm they came from
> SignalWire, as [Verify webhook signature][verify-signature] shows. You can also put a username and
> password in the webhook URL, as in `https://<USERNAME>:<PASSWORD>@<YOUR_PUBLIC_HOST>/transcripts`,
> and SignalWire sends them as HTTP Basic authentication. Both work for the post-call `status_url`
> too. If you reject unsigned requests, keep `live_events` set to `true`: with it off, the
> end-of-session event can arrive without a signature.
## Live transcription options: language, direction, and speech engine
`start` takes two required values. `lang` is the language to transcribe, such as `en-US` or
`es-ES`. `direction` lists the sides of the call to transcribe:
* `remote-caller` is the audio SignalWire receives from the call: the person who called your
  number, or the person your app dialed.
* `local-caller` is the audio SignalWire sends into the call, such as prompts it plays or the other
  party of a `connect`.
List both to get the whole conversation, or one side to transcribe only that party. Each side
you list sends its own utterance events.
`speech_engine` picks the speech recognizer: `deepgram`, the default, or `google`. When the
recognizer splits utterances too early or too late for your callers, tune `vad_silence_ms`, the
silence in milliseconds that ends an utterance, and `vad_thresh`, how loud audio must be to count as
speech. The [`live_transcribe` reference][swml-live-transcribe] lists every option with its default.
The same options work in Relay and REST.
## Summarize a call with AI
Live transcription can hand the conversation to an AI model and send you a summary, either once
when the session ends or whenever you ask while the call is up.
### Summarize the call when transcription ends
Add `ai_summary: true` to `start`, and optionally `ai_summary_prompt` to say what the summary should
contain. The event sent when the session ends then includes `conversation_summary`. Make this change
to the [first run's](#transcribe-a-call-in-real-time-via-swml) `start` action. The same keys work
in a `start` action sent over Relay or REST:
```python {7-8}
    "start": {
        "lang": "en-US",
        "ai_summary": True,
        "ai_summary_prompt": "List the pickup address, the destination, and the pickup time.",
```typescript {8-9}
  action: {
    start: {
      lang: "en-US",
      live_events: true,
      ai_summary: true,
      ai_summary_prompt: "List the pickup address, the destination, and the pickup time.",
#### YAML
```yaml {10-11}
- live_transcribe:
    action:
      start:
        lang: en-US
        direction:
          - remote-caller
          - local-caller
        live_events: true
        ai_summary: true
        ai_summary_prompt: List the pickup address, the destination, and the pickup time.
#### JSON
```json {9-10}
    "action": {
      "start": {
        "lang": "en-US",
        "live_events": true,
        "ai_summary": true,
The transcription server prints the summary on a `Summary:` line after the call ends. If
`conversation_summary` is missing from the event, no summary could be produced for the call.
### Summarize a call in progress via SWML
Send the `summarize` action while transcription is running to get a summary of the conversation so
far, and keep transcribing. Its `prompt` and `webhook` are optional. An empty `summarize`
object sends the summary to the webhook from `start` and uses the default summary prompt, since
`ai_summary_prompt` applies only to the summary sent when the session ends. In the first run's document, add it after the
`sleep`, so the summary arrives before the goodbye:
swml.live_transcribe(action={"summarize": {"prompt": "Summarize the ride request in one sentence."}})
swml.say("Thanks. A driver is on the way. Goodbye.")
```typescript
swml.say("Thanks for calling Bayview Taxi. Where would you like to go?").sleep(20000);
swml.live_transcribe({
  action: { summarize: { prompt: "Summarize the ride request in one sentence." } },
swml.say("Thanks. A driver is on the way. Goodbye.");
#### YAML
```yaml
- sleep: 20000
- live_transcribe:
    action:
      summarize:
        prompt: Summarize the ride request in one sentence.
- play:
#### JSON
```json
  { "sleep": 20000 },
      "action": {
        "summarize": { "prompt": "Summarize the ride request in one sentence." }
The server prints a `Summary so far:` line when the summary arrives. If no summary could be
produced, the event still arrives, with `conversation_summary` set to `Error creating summary`. To summarize at a moment the
document doesn't know in advance, run a section with the action through
[`execute`][swml-execute], or send it from Relay or REST.
### Summarize a call in progress via WebSocket (Relay)
In the [Relay call program](#transcribe-a-call-in-real-time-via-websocket-relay), send `summarize`
after the twenty-second wait. The REST client sends the same action to a call by ID:
```typescript
  summarize: { prompt: "Summarize the ride request in one sentence." },
    "<YOUR_CALL_ID>",
    action={"summarize": {"prompt": "Summarize the ride request in one sentence."}},
```typescript
```bash
  -d '{
    "params": {
      "action": {
The cURL request goes to [Call commands][call-commands].
## Stop live transcription
A session stops by itself when the call ends. Stop it earlier, for example before the caller reads
out a card number, with the `stop` action. SignalWire then sends the
[event for the end of the session](#read-transcript-events-on-your-webhook), with everything
transcribed until that point.
### Stop live transcription via SWML
Set `action` to the string `stop`:
swml.live_transcribe(action="stop")
```typescript
swml.live_transcribe({ action: "stop" });
#### YAML
```yaml
- live_transcribe:
    action: stop
#### JSON
```json
{ "live_transcribe": { "action": "stop" } }
### Stop live transcription via WebSocket (Relay)
Send the `stop` action. SignalWire accepts it either as the string `stop` or as a `stop` key with
an empty object. The Relay clients take the object form, and the REST clients take the string:
await call.live_transcribe({"stop": {}})
```typescript
await call.liveTranscribe({ stop: {} });
client.calling.live_transcribe("<YOUR_CALL_ID>", action="stop")
```typescript
await client.calling.liveTranscribe("<YOUR_CALL_ID>", { action: "stop" });
```bash
  -d '{
    "params": { "action": "stop" }
To start transcribing again, send a new `start` action. A `start` sent while a session is running
stops that session, which sends its end-of-session event, and starts a new one.
## Transcribe the whole call after it ends
When you only need the call's text once it's over, [`transcribe`][swml-transcribe] is simpler:
there are no options to set and no events during the call. It transcribes only U.S. English
(`en-US`), so use `live_transcribe` for any other language. SignalWire captures the call in the
background and, after the call ends, posts the text to your `status_url` as a
`calling.transcript.completed` event. Only one `transcribe` can run on a call at a time.
### Transcribe the whole call via SWML
Add `transcribe` with a `status_url` where the transcription should start. The Server SDKs' SWML
builder has no `transcribe` method, and its schema has no `transcribe` verb, so the builder samples
add the verb by name and turn schema validation off where the SDK would reject it:
```python {6-8,12}
    name="transcribe-whole-call",
    # The schema has no transcribe verb yet, and validation can only be
    # turned off for the whole service, not for one verb.
    schema_validation=False,
swml.answer()
service.add_verb("transcribe", {"status_url": "<YOUR_TRANSCRIPT_STATUS_URL>"})
```typescript {9-10}
swml.answer();
// The builder has no transcribe method yet, so add the verb by name.
swml.addVerb("transcribe", { status_url: "<YOUR_TRANSCRIPT_STATUS_URL>" });
swml
  .sleep(20000)
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - answer: {}
    - transcribe:
        status_url: <YOUR_TRANSCRIPT_STATUS_URL>
    - play:
    - sleep: 20000
    - play:
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "answer": {} },
      { "transcribe": { "status_url": "<YOUR_TRANSCRIPT_STATUS_URL>" } },
      { "sleep": 20000 },
To try it, swap these lines into the [transcription server](#run-the-transcription-server) in place
of its service and `live_transcribe` document, and call your number again. After you hang up, the server prints
`calling.transcript.completed:` followed by the call's text.
`transcribe` sets `transcribe_result` to `success` or `failed`. To end it before the call does,
add [`transcribe_stop`][swml-transcribe-stop]. It takes no options and stops the transcription
running on the call:
```yaml
- transcribe_stop: {}
### Transcribe the whole call via WebSocket (Relay)
Send the transcribe command to start the transcription. It returns an action you can stop to end
the transcription early. In the [Relay call program](#transcribe-a-call-in-real-time-via-websocket-relay),
replace the live transcription lines with these:
transcription = await call.transcribe(status_url="<YOUR_TRANSCRIPT_STATUS_URL>")
# ... later, to end it before the call does:
await transcription.stop()
```typescript
const transcription = await call.transcribe({ statusUrl: "<YOUR_TRANSCRIPT_STATUS_URL>" });
// ... later, to end it before the call does:
await transcription.stop();
The action completes when SignalWire finishes capturing the call's audio. The text itself arrives
at your `status_url` afterward.
Over REST, send `calling.transcribe` with a `control_id` you choose, and `calling.transcribe.stop`
with the same `control_id` to end it. The REST client in the [Server SDKs][server-sdks] wraps both
commands:
client.calling.transcribe(
    "<YOUR_CALL_ID>",
    control_id="whole-call",
    status_url="<YOUR_TRANSCRIPT_STATUS_URL>",
client.calling.transcribe_stop("<YOUR_CALL_ID>", control_id="whole-call")
```typescript
await client.calling.transcribe("<YOUR_CALL_ID>", {
  control_id: "whole-call",
  status_url: "<YOUR_TRANSCRIPT_STATUS_URL>",
await client.calling.transcribeStop("<YOUR_CALL_ID>", { control_id: "whole-call" });
`client` is the REST client from [Start live transcription on a call in progress via REST](#start-live-transcription-on-a-call-in-progress-via-rest).
To call the REST API directly, send these requests to [Call commands][call-commands]:
### Request
POST https\://%7BYour_Space_Name%7D.signalwire.com/api/calling/calls
**`calling.transcribe`**
```curl calling.transcribe
     -d '{
  "command": "calling.transcribe",
  "id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "params": {
    "control_id": "transcribe-control-1",
    "status_url": "https://example.com/transcribe-status"
```python calling.transcribe
import requests
url = "https://{your_space_name}.signalwire.com/api/calling/calls"
payload = {
    "params": {
headers = {
response = requests.post(url, json=payload, headers=headers, auth=("<project_id>", "<api_token>"))
print(response.json())
```javascript calling.transcribe
const url = 'https://{your_space_name}.signalwire.com/api/calling/calls';
const credentials = btoa("<project_id>:<api_token>");
const options = {
  method: 'POST',
  headers: {
    Authorization: `Basic ${credentials}`,
    'Content-Type': 'application/json'
  body: '{"command":"calling.transcribe","id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","params":{"control_id":"transcribe-control-1","status_url":"https://example.com/transcribe-status"}}'
  const response = await fetch(url, options);
  const data = await response.json();
  console.log(data);
} catch (error) {
  console.error(error);
```go calling.transcribe
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/calling/calls"
	payload := strings.NewReader("{\n  \"command\": \"calling.transcribe\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\",\n    \"status_url\": \"https://example.com/transcribe-status\"\n  }\n}")
	req, _ := http.NewRequest("POST", url, payload)
	req.SetBasicAuth("<project_id>", "<api_token>")
	req.Header.Add("Content-Type", "application/json")
	res, _ := http.DefaultClient.Do(req)
	defer res.Body.Close()
	body, _ := io.ReadAll(res.Body)
	fmt.Println(res)
	fmt.Println(string(body))
```ruby calling.transcribe
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/calling/calls")
http = Net::HTTP.new(url.host, url.port)
http.use_ssl = true
request = Net::HTTP::Post.new(url)
request.basic_auth("<project_id>", "<api_token>")
request["Content-Type"] = 'application/json'
request.body = "{\n  \"command\": \"calling.transcribe\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\",\n    \"status_url\": \"https://example.com/transcribe-status\"\n  }\n}"
response = http.request(request)
puts response.read_body
```java calling.transcribe
HttpResponse<String> response = Unirest.post("https://{your_space_name}.signalwire.com/api/calling/calls")
  .basicAuth("<project_id>", "<api_token>")
  .header("Content-Type", "application/json")
  .body("{\n  \"command\": \"calling.transcribe\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\",\n    \"status_url\": \"https://example.com/transcribe-status\"\n  }\n}")
  .asString();
```php calling.transcribe
<?php
require_once('vendor/autoload.php');
$client = new \GuzzleHttp\Client();
$response = $client->request('POST', 'https://{your_space_name}.signalwire.com/api/calling/calls', [
  'body' => '{
  "params": {
  'headers' => [
    'Content-Type' => 'application/json',
    'auth' => ['<project_id>', '<api_token>'],
echo $response->getBody();
```csharp calling.transcribe
using RestSharp;
using RestSharp.Authenticators;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/calling/calls");
client.Authenticator = new HttpBasicAuthenticator("<project_id>", "<api_token>");
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/json");
request.AddParameter("application/json", "{\n  \"command\": \"calling.transcribe\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\",\n    \"status_url\": \"https://example.com/transcribe-status\"\n  }\n}", ParameterType.RequestBody);
IRestResponse response = client.Execute(request);
```swift calling.transcribe
import Foundation
let credentials = Data("<project_id>:<api_token>".utf8).base64EncodedString()
let headers = [
  "Authorization": "Basic \(credentials)",
let parameters = [
  "params": [
] as [String : Any]
let postData = JSONSerialization.data(withJSONObject: parameters, options: [])
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/calling/calls")! as URL,
                                        cachePolicy: .useProtocolCachePolicy,
                                    timeoutInterval: 10.0)
request.httpMethod = "POST"
request.allHTTPHeaderFields = headers
request.httpBody = postData as Data
let session = URLSession.shared
let dataTask = session.dataTask(with: request as URLRequest, completionHandler: { (data, response, error) -> Void in
  if (error != nil) {
    print(error as Any)
  } else {
    let httpResponse = response as? HTTPURLResponse
    print(httpResponse)
dataTask.resume()
### Request
**`calling.transcribe.stop`**
```curl calling.transcribe.stop
     -d '{
  "command": "calling.transcribe.stop",
  "params": {
```python calling.transcribe.stop
import requests
payload = {
    "params": { "control_id": "transcribe-control-1" }
headers = {
```javascript calling.transcribe.stop
const options = {
  method: 'POST',
  headers: {
  body: '{"command":"calling.transcribe.stop","id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","params":{"control_id":"transcribe-control-1"}}'
  console.log(data);
} catch (error) {
```go calling.transcribe.stop
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	payload := strings.NewReader("{\n  \"command\": \"calling.transcribe.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\"\n  }\n}")
	fmt.Println(res)
```ruby calling.transcribe.stop
require 'uri'
require 'net/http'
http.use_ssl = true
request.body = "{\n  \"command\": \"calling.transcribe.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\"\n  }\n}"
```java calling.transcribe.stop
  .body("{\n  \"command\": \"calling.transcribe.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\"\n  }\n}")
  .asString();
```php calling.transcribe.stop
<?php
  'body' => '{
  "params": {
  'headers' => [
```csharp calling.transcribe.stop
using RestSharp;
request.AddParameter("application/json", "{\n  \"command\": \"calling.transcribe.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"transcribe-control-1\"\n  }\n}", ParameterType.RequestBody);
```swift calling.transcribe.stop
import Foundation
let headers = [
let parameters = [
  "params": ["control_id": "transcribe-control-1"]
] as [String : Any]
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
### Receive the call's transcript
SignalWire posts the transcript to your `status_url` after the call ends. `event_type` is
`calling.transcript.completed` with the text in `params.text`, or `calling.transcript.failed` when
the call couldn't be transcribed. `params.text` is omitted when nobody spoke. The
[Transcript status callback][transcript-status-callback] reference lists every field:
Answer with a `2xx` status within 5 seconds. SignalWire retries the request when your server
doesn't, so the same transcript can arrive more than once. Use `params.id` to ignore repeats. The
request is signed like the live events, as
[Protect your webhooks](#read-transcript-events-on-your-webhook) describes.
The same `status_url` also receives a `calling.call.transcribe` event when transcription starts,
with `params.state` set to `transcribing`, and another with `finished` when it ends. The
[Transcribe state callback][transcribe-state-callback] reference lists their fields. The sample
servers print only the `calling.transcript.*` events.
## Watch the live transcript with an AI sidecar
To have an AI model follow the conversation as it's transcribed and act on it, use
[`ai_sidecar`][swml-ai-sidecar], with or without `live_transcribe`. The sidecar transcribes the call
the same way, then after each turn from the customer it sends the transcript to a model with your
prompt and tools. It never speaks on the call. It posts advice, transcript updates, and tool
results to your webhook, so it suits coaching a human agent, flagging compliance issues, or pulling
data out of the call while it happens. Its [callback types][sidecar-callbacks] include the running
transcript. To build one step by step, see [Coach live calls with an AI sidecar][sidecar-guide].
## Alternatives: run your own speech-to-text
To use a speech recognizer of your own choice, or to process the raw audio yourself,
[stream the call's audio][call-streaming] to a WebSocket server and send it on from there. To keep
the audio itself, [record the call][record-calls]. A stereo recording keeps each side on its own
channel for later processing.
## Troubleshoot call transcription
Find the symptom you see:
* **The call plays normally, but your server prints nothing.** SignalWire couldn't reach your
  webhook. Check that the URL begins with `https://` and ends with `/transcripts`, and that the
  tunnel is running and points at port `8080`.
* **The server prints the end of the session, but no utterances.** `live_events` isn't `true` on
  `start`. Without it, the transcript arrives only when the session ends.
* **You see utterances from only one side.** `direction` lists one side. Add `remote-caller` and
  `local-caller` to transcribe both.
* **You hear an error or silence when you call your number.** SignalWire couldn't fetch your SWML.
  Rerun the `curl` check with the exact URL in the SWML Script, and confirm that the server and the
  tunnel are still running. A `401` means the password in the URL doesn't match the server's.
* **You hear your number's old behavior.** The number still points at another Resource. Open it
  under **Phone Numbers** and check **Inbound Call Settings**.
* **A Relay or REST `start` command is rejected.** Check that `start` has both `lang` and
  `direction`.
* **No `calling.transcript.completed` event arrives.** The event comes after the call ends, not
  during it. Check that `status_url` ends with `/transcript-status`, and that no other `transcribe`
  was already running on the call.
## Next steps
#### [live_transcribe reference](/docs/swml/reference/calling/live-transcribe)
Every option for starting, summarizing, and stopping live transcription
#### [Live transcription webhooks](/docs/apis/rest/webhooks/live-transcribe-utterance-webhook)
Every field in the events your webhook receives
#### [AI sidecar](/docs/platform/ai/sidecar)
Have an AI model watch the live transcript and coach your agents
#### [Stream call audio](/docs/platform/voice/call-streaming)
Send the call's raw audio to your own speech-to-text service
