> This page is for Platform.
# Speak text on a call
> Speak text on a call with SWML, Relay, or REST. Learn the SWML say URL, hear a message on your own phone, and control the speech while it plays.
[prepare-calls]: /docs/platform/voice/make-and-receive-calls#prepare-for-your-first-call
[place-swml]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-swml
[place-relay]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-websocket-relay
[answer-relay]: /docs/platform/voice/make-and-receive-calls#answer-a-call-via-websocket-relay
[tcpa]: /docs/platform/compliance/tcpa
[tts-voices]: /docs/platform/voice/tts
[tts-custom]: /docs/platform/voice/tts#custom-and-cloned-voices
[sdk-voice-language]: /docs/server-sdks/guides/voice-language
[swml-play]: /docs/swml/reference/calling/play
[swml-prompt]: /docs/swml/reference/calling/prompt
[swml-pay]: /docs/swml/reference/calling/pay
[swml-set]: /docs/swml/reference/calling/set
[swml-ai-languages]: /docs/swml/reference/calling/ai/languages#use-voice-strings
Text-to-speech (TTS) reads text aloud on a live call, such as a booking confirmation or a menu.
You give SignalWire the text and a voice from the [TTS voice catalog][tts-voices], and it speaks
the text into the call. Start with the SWML `say:` URL, then speak a message to your own phone
## Speak text with a SWML say URL
In SWML's `play` and `prompt` methods, a `say:` URL takes the place of an audio file URL.
SignalWire speaks whatever follows `say:` instead of fetching a file:
```yaml
- play:
    url: "say:Your ride is confirmed for 8 AM tomorrow."
    say_voice: elevenlabs.rachel
`say_voice` picks the voice, as an `engine.voice` string from the catalog. `say_language` and
`say_gender` are also available. Set them on one verb, or once for the whole document with
[`set`][swml-set]; a value on a verb overrides the document-wide one.
> **Always set the voice**
> Default voices and engines can change. Set a full `engine.voice` string so the call keeps
> sounding the same.
These SWML methods speak text:
* [`play`][swml-play] speaks a `say:` URL in `url`. To mix speech with audio files and pauses,
  list several URLs in `urls`.
* [`prompt`][swml-prompt] speaks a `say:` URL in `play`, then collects key presses or speech.
* [`pay`][swml-pay] speaks custom payment prompts written as `Say` actions, with the text in
  `phrase`.
* [`ai`][swml-ai-languages] agents speak in the voice set in `languages`. See
  [Voice and language][sdk-voice-language] in the Server SDKs.
Relay clients and the REST Calling API speak a `tts` media item instead of a `say:` URL. Its
`text`, `voice`, `language`, and `gender` fields match the SWML settings above.
## Prepare to speak text on a call
Start from working call setup in [Make and receive calls][make-and-receive-calls], and test with a
phone you can answer.
> **Trial projects only call verified numbers**
> A [trial project][trial-mode] only calls and receives calls from numbers you've purchased or
> verified. [Prepare for your first call][prepare-calls] shows how to verify your phone.
> **Calls that use an artificial voice are regulated**
> TTS counts as an artificial voice under consent, do-not-call, and calling-hour rules. Read the
> [TCPA guide][tcpa] before you call anyone but yourself.
Replace these values in the samples:
| Value                       | Replace with        |
| `<YOUR_SPACE>`              | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                             |
| `<YOUR_PROJECT_ID>`         | Your Project ID        |
| `<YOUR_API_TOKEN>`          | Your API token, used only in server code                                            |
| `<YOUR_CALLER_ID>`          | Your SignalWire phone number, or a [verified caller ID][caller-id], in E.164 format |
| `<YOUR_DESTINATION>`        | The phone number you'll call, in E.164 format                                       |
| `<YOUR_CALL_ID>`            | The ID of an answered call, for the REST commands                                   |
| `<YOUR_STATUS_WEBHOOK_URL>` | An HTTPS endpoint you control that receives playback progress                       |
## Speak text on a call via SWML
The Server SDKs' SWML builder writes the `play` for you: `say()` takes the text and the voice.
This program builds the document and places a call with it, as in
[Place a call via SWML][place-swml].
#### Python — REST client
# Save as speak_message.py and run: python speak_message.py
client = RestClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
swml = (
    SWMLBuilder(SWMLService(name="speak-message"))
    .say(
        "Hello from Bayview Taxi. Your ride is confirmed for 8 AM tomorrow.",
        voice="elevenlabs.rachel",
    .hangup()
    .build()
call = client.calling.dial(
    from_="<YOUR_CALLER_ID>",
    to="<YOUR_DESTINATION>",
    swml=swml,
print(call["id"])
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as speak-message.mjs,
// then run: node speak-message.mjs
import { RestClient, SwmlBuilder } from "@signalwire/sdk";
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
const swml = new SwmlBuilder()
  .say("Hello from Bayview Taxi. Your ride is confirmed for 8 AM tomorrow.", {
    voice: "elevenlabs.rachel",
  .hangup()
  .build();
const call = await client.calling.dial({
  to: "<YOUR_DESTINATION>",
  swml,
console.log(call.id);
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - play:
        url: "say:Hello from Bayview Taxi. Your ride is confirmed for 8 AM tomorrow."
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
        "play": {
          "url": "say:Hello from Bayview Taxi. Your ride is confirmed for 8 AM tomorrow.",
          "say_voice": "elevenlabs.rachel"
      { "hangup": {} }
> **\`dial()\` signature depends on the SDK version**
> `@signalwire/sdk@2.0.5` takes a single options object. Newer releases take the positional
> `dial(from, to, options)` form.
Run the program and answer your phone. You hear the confirmation in the Rachel voice, then the
call ends. If the phone never rings, check that `<YOUR_CALLER_ID>` is a number in your Space or a
verified caller ID. If you hear a different voice, the voice string isn't in SignalWire's
catalog: voices from your own provider account fall back to a default
([Custom and cloned voices][tts-custom]).
To speak to people who call your number, serve the same document as in
[Answer a call via SWML][answer-swml].
## Speak text on a call via WebSocket (Relay)
A Relay client speaks with `play()` and a `tts` media item. Use it when your code needs to react
as the speech plays or ends, such as hanging up or asking the next question. This program dials
your phone as in [Place a call via WebSocket (Relay)][place-relay], speaks the confirmation, and
hangs up when the speech finishes.
#### Python — Relay client
# Save as speak_message_relay.py and run: python speak_message_relay.py
import asyncio
client = RelayClient(
    contexts=["default"],
async def main():
    async with client:
        call = await client.dial(
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
            if call.state != "ended":
                await call.hangup()
        await call.play([{
            "type": "tts",
            "params": {
                "text": "Hello from Bayview Taxi. Your ride is confirmed for 8 AM tomorrow.",
                "voice": "elevenlabs.rachel",
        }], on_completed=hang_up_after_playback)
        await call.wait_for_ended()
asyncio.run(main())
```typescript
// This sample also runs as JavaScript: save as speak-message-relay.mjs,
// then run: node speak-message-relay.mjs
  contexts: ["default"],
await client.connect();
    type: "phone",
    params: {
      timeout: 30,
  await call.play([{
    type: "tts",
    params: {
      text: "Hello from Bayview Taxi. Your ride is confirmed for 8 AM tomorrow.",
    onCompleted: async () => {
  await call.waitForEnded();
} finally {
  await client.disconnect();
Run the program and answer your phone. You hear the confirmation, then the call ends. To speak on
calls to your number instead, see [Answer a call via WebSocket (Relay)][answer-relay].
`play()` takes a list of media items and plays them in order, so `tts` items can mix with
`audio`, `silence`, and `ringtone` items. It returns an action once SignalWire accepts the
command: `stop()`, `pause()`, `resume()`, and `volume()` control the speech while it plays, and
`volume()` takes decibels from -40 to 40. To speak a menu and collect the caller's input, use the
Relay client's play-and-collect method, which takes the same media items.
## Speak text on a call in progress via REST
When a different process needs to speak on a call that's already up, such as a backend job
announcing an update, send [`calling.play`][call-commands] with the call's ID. It takes the same
`tts` media items as Relay. `control_id` names the playback so later commands can address it.
# Save as speak_rest.py and run: python speak_rest.py
client.calling.play(
    "<YOUR_CALL_ID>",
    control_id="driver-update",
    play=[{
        "type": "tts",
        "params": {
            "text": "Your Bayview Taxi driver is five minutes away.",
```typescript
// This sample also runs as JavaScript: save as speak-rest.mjs,
// then run: node speak-rest.mjs
await client.calling.play("<YOUR_CALL_ID>", {
  control_id: "driver-update",
  play: [{
    type: "tts",
    params: {
      text: "Your Bayview Taxi driver is five minutes away.",
  status_url: "<YOUR_STATUS_WEBHOOK_URL>",
#### cURL — Calling API
```bash
curl -X POST "https://<YOUR_SPACE>.signalwire.com/api/calling/calls" \
  -u "<YOUR_PROJECT_ID>:<YOUR_API_TOKEN>" \
  -d '{
    "command": "calling.play",
    "id": "<YOUR_CALL_ID>",
    "params": {
      "control_id": "driver-update",
      "play": [
          "type": "tts",
          "params": {
      "status_url": "<YOUR_STATUS_WEBHOOK_URL>"
> **\`play()\` signature depends on the SDK version**
> `@signalwire/sdk@2.0.5` takes the call ID and a single options object. Newer releases take the
> positional `play(callId, play, options)` form.
The command returns once SignalWire accepts it. Your `status_url` then receives the playback's
`control_id` and `state`: `playing` when the speech starts, then `finished`, or `error` if it
failed. See the [webhooks guide][webhooks] to set up the endpoint.
`direction` sets who hears the speech: `listen` (the default) plays it to the caller, `speak` to
the called party, and `both` to both. `loop` repeats the list, and `0` repeats it until you stop
it. To control the speech, send `calling.play.stop`, `calling.play.pause`, `calling.play.resume`,
or `calling.play.volume` with the same `control_id`.
The REST Calling API can't speak and collect input in one step. To speak a menu, start the call
with a SWML [`prompt`][swml-prompt] or control it from a Relay client.
