# Outbound calling
> Place your first outbound phone call, track its progress, and add AI or browser calling to your application.
[international]: /docs/platform/how-to-enable-international-services
[api-credentials]: /docs/platform/your-signalwire-api-space
[phone-numbers]: /docs/platform/phone-numbers
[swml-ai]: /docs/swml/reference/calling/ai
[ai-best-practices]: /docs/platform/ai/best-practices
[tcpa]: /docs/platform/compliance/tcpa
[swml-detect-machine]: /docs/swml/reference/calling/detect-machine
[swml-record-call]: /docs/swml/reference/calling/record-call
[swml-stream]: /docs/swml/reference/calling/stream
[call-whisper]: /docs/swml/guides/call-whisper
[subscriber-token]: /docs/apis/rest/subscribers/tokens/create-subscriber-token
[guest-token]: /docs/apis/rest/subscribers/tokens/create-subscriber-guest-token
[resources]: /docs/platform/resources
[sip-credentials]: /docs/platform/voice/sip/sip-credentials
[subscribers]: /docs/platform/subscribers
[dial-options]: /docs/browser-sdk/v4/reference/interfaces/dial-options
[device-management]: /docs/browser-sdk/v4/guides/device-management
[call-create-error]: /docs/browser-sdk/v4/reference/errors/call-create-error
[browser-inbound]: /docs/browser-sdk/v4/guides/inbound-calls
[browser-call-controls]: /docs/browser-sdk/v4/guides/call-controls
[ts-dial]: /docs/server-sdks/reference/typescript/rest/calling/dial
[address-default-channel]: /docs/browser-sdk/v4/reference/address/default-channel
[browser-transfer]: /docs/browser-sdk/v4/reference/webrtc-call/transfer
Place an outbound phone call with SignalWire and choose what happens when the destination answers.
Start by calling your own phone and playing a short announcement, then track the call's progress,
run an AI agent, or let users call from your web app.
## Prepare for your first call
Have these values ready:
* Your Space URL, such as `<YOUR_SPACE>.signalwire.com`.
* Your Project ID and API token from the Dashboard's [API credentials][api-credentials] page.
  Enable the token's **Voice** permission for the Calling API.
* If calling a phone number, a voice-capable [phone number purchased in your Space][phone-numbers]
  or a [verified caller ID][caller-id].
* If calling from the browser, you need a [Subscriber token][subscriber-token] or
  [guest token][guest-token] to provide to the Browser SDK client.
* A destination device you can answer.
#### Trial projects and international calls are restricted
A [trial project][trial-mode] can dial only numbers it has purchased or verified, and cannot call
internationally at all. Any other project can dial any number, but needs
[international dialing enabled][international] before it reaches another country.
## Make your first call
Call a phone you can answer and play a short announcement.
### Choose how to place your call
Choose the approach that fits how you want to control the call.
| What you want to do        | Where to start                                                  |
| Give SignalWire call instructions over HTTP, supplied inline or returned by your webhook                                   | [REST Calling API](#place-the-call), using cURL or a Server SDK |
| Control the call in real time, asynchronously receiving events and sending commands over a persistent WebSocket connection | [WebSocket (Relay)](#place-the-call), using a Server SDK        |
| Let someone place and speak on a call from your web app        | [Browser SDK](#place-the-call)                                  |
Each approach places the same call, but they differ in how you follow and control it afterward.
| Function                                                              | REST | WebSocket (Relay) | Browser SDK |
| Place the call without holding a connection open                      |      |                   |             |
| Place the call from a web page, with the user speaking on it          |      |                   |             |
| Command a call already in progress from any process, by its call ID   |      |                   |             |
| Follow the call's events in your own code, with no public webhook URL |      |                   |             |
| Receive call progress as HTTP callbacks to a URL you host             |      |                   |             |
SWML doesn't place calls. It's the script the call runs once it connects, so you place the call
with REST or Relay and pass SWML in the `swml` field.
### Set your credentials and caller ID
Replace these values in the code sample you choose:
| Value                            | Replace with        |
| `<YOUR_SPACE>`                   | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                                      |
| `<YOUR_PROJECT_ID>`              | Your Project ID        |
| `<YOUR_API_TOKEN>`               | Your API token        |
| `<YOUR_CALLER_ID>`               | Your caller ID number        |
| `<YOUR_SUBSCRIBER_ACCESS_TOKEN>` | A [Subscriber token][subscriber-token] created by your backend, for the Browser SDK examples |
### Choose a destination
A call can reach a phone, a [SIP destination][sip-credentials], a [Subscriber][subscribers], or
another [Resource][resources] in your SignalWire Space.
| Destination     | Dial                                                      | Example                   |
| Phone           | Its number in [E.164 format](/docs/platform/what-is-e164) | `+12025550123`            |
| SIP destination | Its SIP URI                                               | `sip:support@example.com` |
| Subscriber      | Its resource address                                      | `/private/support-rep`    |
| Application     | Its resource address                                      | `/public/support-agent`   |
| Conference      | Its resource address                                      | `/public/team-standup`    |
For this walkthrough, choose a device you can answer and replace
`<YOUR_DESTINATION>` with its address.
### Place the call
Use the REST Calling API with any server-side HTTP client or a SignalWire Server SDK. For
WebSocket calling, use a Server SDK or the Browser SDK.
#### REST
The request includes a SignalWire Markup Language (SWML) document in `swml`. SignalWire runs
it when the destination answers, playing the announcement below.
#### cURL — Calling API
```bash
curl -X POST "https://<YOUR_SPACE>.signalwire.com/api/calling/calls" \
  -u "<YOUR_PROJECT_ID>:<YOUR_API_TOKEN>" \
  -d '{
    "command": "dial",
    "params": {
      "from": "<YOUR_CALLER_ID>",
      "to": "<YOUR_DESTINATION>",
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
            { "play": {"url": "say:Hello, welcome to SignalWire!"} }
#### Python — REST client
# Save as outbound_call.py and run: python outbound_call.py
client = RestClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
swml = (
    SWMLBuilder(SWMLService(name="outbound-call"))
    .say("Hello, welcome to SignalWire!")
    .build()
call = client.calling.dial(
    from_="<YOUR_CALLER_ID>",
    to="<YOUR_DESTINATION>",
    swml=swml,
print(call["id"])
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as outbound-call.mjs,
// then run: node outbound-call.mjs
import { RestClient, SwmlBuilder } from "@signalwire/sdk";
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
const swml = new SwmlBuilder()
  .build();
const call = await client.calling.dial({
  to: "<YOUR_DESTINATION>",
  swml,
console.log(call.id);
#### TypeScript \`dial()\` signature depends on the SDK version
The TypeScript samples on this page pin `@signalwire/sdk@2.0.5`, whose `dial()` takes a single
options object. The [TypeScript `dial` reference][ts-dial] documents the positional
`dial(from, to, options)` form of a newer release. Match the form to the version you install.
The REST API returns a call `id` and status `queued`. This confirms that SignalWire accepted the
request; the call hasn't necessarily rung or been answered yet. Save the `id` to identify this call.
### Response (200)
```json
  "billing_ms": null,
  "charge": 0,
  "charge_details": [
      "charge": 0.004,
      "description": "Outbound Voice"
  "created_at": "2024-05-06T12:20:00Z",
  "direction": "outbound-api",
  "duration": null,
  "duration_ms": null,
  "from": "+12069708643",
  "id": "0e9c80d7-a149-4917-892d-420043709f45",
  "parent_id": null,
  "source": "realtime_api",
  "status": "queued",
  "to": "+15550198765",
  "type": "relay_pstn_call",
  "url": null
#### WebSocket (Relay)
Use a Server SDK when controlling a call flow from the server, or the Browser SDK when placing a
call from a web app.
#### Python — Relay client
import asyncio
client = RelayClient(
    contexts=["default"],
async def main():
    async with client:
        call = await client.dial(
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
            if call.state != "ended":
                await call.hangup()
        await call.play([{
            "type": "tts",
            "params": {"text": "Hello, welcome to SignalWire!"},
        }], on_completed=hang_up_after_playback)
        await call.wait_for_ended()
asyncio.run(main())
```typescript
  contexts: ["default"],
await client.connect();
    type: "phone",
    params: {
      timeout: 30,
  await call.play([
    { type: "tts", text: "Hello, welcome to SignalWire!" },
    onCompleted: async () => {
  await call.waitForEnded();
} finally {
  await client.disconnect();
#### JavaScript — Browser SDK
```javascript
// Install: npm install @signalwire/js@latest rxjs
// Run on HTTPS or localhost with these elements in your page:
// <audio id="remote-audio" autoplay></audio>
// <button id="call" type="button">Call</button>
// <button id="hangup" type="button" disabled>Hang up</button>
// Use a Subscriber Access Token issued by your backend.
const client = new SignalWire(new StaticCredentialProvider({
  token: "<YOUR_SUBSCRIBER_ACCESS_TOKEN>",
const remoteAudio = document.querySelector("#remote-audio");
const callButton = document.querySelector("#call");
const hangupButton = document.querySelector("#hangup");
callButton.onclick = async () => {
  callButton.disabled = true;
    const call = await client.dial("<YOUR_DESTINATION>", { audio: true, video: false });
    call.remoteStream$.subscribe((stream) => (remoteAudio.srcObject = stream));
    hangupButton.disabled = false;
    hangupButton.onclick = () => {
      void call.hangup().catch(console.error);
    call.status$.subscribe((status) => {
      if (status === "disconnected" || status === "failed" || status === "destroyed") {
        remoteAudio.srcObject = null;
        hangupButton.disabled = true;
        callButton.disabled = false;
  } catch (error) {
    console.error(error);
### Answer the call
Answer the destination phone. With a server example, you should hear "Hello, welcome to
SignalWire!", then the call ends. With the browser example, allow
microphone access to speak on the call and select **Hang up** when you finish.
## Track the call's progress
Use callbacks with REST or event handlers with Relay to follow what happens after you dial.
Follow the section for the approach you used for your first call.
### Track call progress via REST
Add `status_url` and `status_events` to your first request to receive call progress callbacks.
Keep the inline `swml` announcement. The examples below place another call with notifications
for `ringing`, `answered`, and `ended`.
Before running the request, replace `<YOUR_STATUS_WEBHOOK_URL>` with a webhook endpoint
you control that SignalWire can reach. Your endpoint receives HTTP POST requests as the call
reaches the selected states. See the [webhooks guide][webhooks] for endpoint setup and local testing.
`status_events` accepts `created`, `ringing`, `answered`, and `ended`; if omitted, it defaults
to `ended`.
```bash
  -d '{
    "command": "dial",
    "params": {
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
      "status_url": "<YOUR_STATUS_WEBHOOK_URL>",
      "status_events": ["ringing", "answered", "ended"]
swml = (
    .build()
    swml=swml,
    status_events=["ringing", "answered", "ended"],
```typescript
  .build();
  swml,
  status_url: "<YOUR_STATUS_WEBHOOK_URL>",
  status_events: ["ringing", "answered", "ended"],
This flow shows a call with `ringing`, `answered`, and `ended` status events enabled:
```mermaid
sequenceDiagram
    participant App as Your code
    participant SW as SignalWire
    participant Dest as Destination
    App->>SW: dial: from, to, SWML
    SW-->>App: call id, status queued
    SW->>Dest: rings
    SW-->>App: status ringing
    Dest->>SW: answers
    SW-->>App: status answered
    Note over SW,Dest: Your SWML runs
    Note over SW,Dest: Call finishes
    SW-->>App: status ended
### Track call progress via WebSocket
Relay exposes call state events through `call.on()`. Because `dial()` returns after the destination
answers, the handler observes later states such as `ending` and `ended`.
The Browser SDK returns a WebRTC `Call` while it is `ringing`. Subscribe to `call.status$` to follow
it through `connecting`, `connected`, and the final states.
import asyncio
from signalwire.relay.event import CallStateEvent
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        def handle_state(event: CallStateEvent):
            print(f"State: {event.call_state}, reason: {event.end_reason}")
        call.on("calling.call.state", handle_state)
                await call.hangup()
        await call.play([{
            "type": "tts",
asyncio.run(main())
```typescript
    type: "phone",
    params: {
      timeout: 30,
  call.on("calling.call.state", (event) => {
    console.log(`State: ${event.params.call_state}, reason: ${event.params.end_reason ?? ""}`);
  await call.play([
} finally {
```javascript
// <p id="status">Idle</p>
const statusLine = document.querySelector("#status");
const finalStatuses = new Set(["disconnected", "failed", "destroyed"]);
      statusLine.textContent = `Call: ${status}`;
      console.log(`Call: ${status}`);
      if (finalStatuses.has(status)) {
  } catch (error) {
    statusLine.textContent = "Call failed";
For more Relay event handlers, see
[Event listeners in the Relay client guide](/docs/server-sdks/guides/relay-client#event-listeners).
For Relay, this flow shows the commands your code sends and the events SignalWire returns over the
same persistent connection:
```mermaid
sequenceDiagram
    Note over App,SW: One persistent WebSocket, both directions
    App->>SW: calling.dial
    SW-->>App: calling.call.state: created, ringing, answered
    App->>SW: calling.play
    SW-->>App: calling.call.play: playing, then finished
    App->>SW: calling.end
    SW-->>App: calling.call.state: ending, then ended
## Examples
### Run an AI agent
Start an AI agent that welcomes the person and answers basic questions about SignalWire.
#### Outbound AI calls are regulated
Before dialing, follow consent, do-not-call, and calling-hour requirements for artificial voices.
See the [TCPA guide][tcpa] and [AI best practices][ai-best-practices].
#### Run an AI agent via REST
Send a `dial` request with an inline SWML [`ai` instruction][swml-ai] that starts when the call is answered.
```bash
  -d '{
    "command": "dial",
    "params": {
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
              "ai": {
                "params": {
                  "static_greeting": "Hello, welcome to SignalWire! This call uses an artificial voice.",
                  "static_greeting_no_barge": true
                "prompt": {
                  "text": "Welcome the caller to SignalWire. Briefly explain that SignalWire provides APIs and SDKs for voice, messaging, video, and AI. Answer basic follow-up questions. If you are unsure, direct the caller to signalwire.com."
swml = (
    SWMLBuilder(SWMLService(name="outbound-ai-call"))
    .ai(
        prompt_text="Welcome the caller to SignalWire. Briefly explain that SignalWire provides APIs and SDKs for voice, messaging, video, and AI. Answer basic follow-up questions. If you are unsure, direct the caller to signalwire.com.",
        params={
            "static_greeting_no_barge": True,
    .build()
    swml=swml,
print(call["id"])
```typescript
  .ai({
    prompt: "Welcome the caller to SignalWire. Briefly explain that SignalWire provides APIs and SDKs for voice, messaging, video, and AI. Answer basic follow-up questions. If you are unsure, direct the caller to signalwire.com.",
    params: {
      static_greeting: "Hello, welcome to SignalWire! This call uses an artificial voice.",
      static_greeting_no_barge: true,
  .build();
  swml,
#### Run an AI agent via WebSocket (Relay)
Dial with Relay, start the agent with `call.ai()`, and keep the connection open until the call ends.
import asyncio
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        await call.ai(
            ai_params={
            prompt={
                "text": """Welcome the caller to SignalWire. Briefly explain that SignalWire
follow-up questions. If you are unsure, direct the caller to signalwire.com."""
        # Keep the connection open until the destination hangs up.
asyncio.run(main())
```typescript
    type: "phone",
    params: {
      timeout: 30,
  await call.ai({
    aiParams: {
    prompt: {
      text: `Welcome the caller to SignalWire. Briefly explain that SignalWire
  follow-up questions. If you are unsure, direct the caller to signalwire.com.`,
  // Keep the connection open until the destination hangs up.
} finally {
### Leave a voicemail
Use answering machine detection (AMD) to speak to a person immediately or leave a message after a
voicemail greeting and beep.
Follow the consent and calling-hour requirements in the [TCPA guide][tcpa].
#### Leave a voicemail via REST
Use [`detect_machine`][swml-detect-machine] and `switch` to choose the live or voicemail message.
```bash
  -d '{
    "command": "dial",
    "params": {
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
              "detect_machine": {
                "detectors": "amd",
                "detect_message_end": true,
                "timeout": 30
              "switch": {
                "variable": "detect_result",
                "case": {
                  "machine": [
                    { "play": {"url": "say:Hello, welcome to SignalWire! Visit signalwire.com to learn more."} }
                  "human": [
                "default": [
            { "hangup": {} }
voicemail = "say:Hello, welcome to SignalWire! Visit signalwire.com to learn more."
live = "say:Hello, welcome to SignalWire!"
swml = (
    SWMLBuilder(SWMLService(name="outbound-voicemail"))
    .detect_machine(
        detectors="amd",
        detect_message_end=True,
        timeout=30,
    .switch(
        variable="detect_result",
        case={
            "machine": [{"play": {"url": voicemail}}],
            "human": [{"play": {"url": live}}],
        default=[{
            "play": {
    .hangup()
    .build()
    swml=swml,
print(call["id"])
```typescript
const voicemail = "say:Hello, welcome to SignalWire! Visit signalwire.com to learn more.";
const live = "say:Hello, welcome to SignalWire!";
  .detect_machine({
    detectors: "amd",
    detect_message_end: true,
    timeout: 30,
  .switch({
    variable: "detect_result",
    case: {
      machine: [{ play: { url: voicemail } }],
      human: [{ play: { url: live } }],
    default: [{
      play: {
        url: "say:Hello, welcome to SignalWire!",
  .hangup()
  .build();
  swml,
#### Leave a voicemail via WebSocket (Relay)
Use `call.detect()` to play the live message after `HUMAN` or `UNKNOWN`, or wait for `READY` after a
machine greeting.
import asyncio
from signalwire.relay.event import DetectEvent
VOICEMAIL = "Hello, welcome to SignalWire! Visit signalwire.com to learn more."
LIVE = "Hello, welcome to SignalWire!"
def outcome(event: DetectEvent) -> str:
    return event.detect.get("params", {}).get("event", "")
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
                await call.hangup()
        announced = False
        async def announce(event: DetectEvent):
            nonlocal announced
            if announced or call.state == "ended":
                return
            result = outcome(event)
            if result == "READY":
                # The voicemail greeting and its beep have finished.
                announced = True
                await call.play(
                    [{"type": "tts", "params": {"text": VOICEMAIL}}],
            elif result in ("HUMAN", "UNKNOWN"):
                announced = True
                await call.play(
                    [{"type": "tts", "params": {"text": LIVE}}],
            elif result == "finished":
                await call.hangup()
        call.on("calling.call.detect", announce)
        await call.detect({"type": "machine", "params": {"detect_message_end": True}}, timeout=30)
asyncio.run(main())
```typescript
// Save as outbound-call.mts and run: npx tsx outbound-call.mts
import { RelayClient, DetectEvent, RelayEvent } from "@signalwire/sdk";
const VOICEMAIL = "Hello, welcome to SignalWire! Visit signalwire.com to learn more.";
const LIVE = "Hello, welcome to SignalWire!";
function outcome(event: RelayEvent): string {
  const detect = (event as DetectEvent).detect?.params as { event?: string } | undefined;
  return detect?.event ?? "";
    type: "phone",
    params: {
      timeout: 30,
  const hangUpAfterPlayback = async () => {
  let announced = false;
  call.on("calling.call.detect", async (event) => {
    if (announced || call.state === "ended") return;
    const result = outcome(event);
    if (result === "READY") {
      // The voicemail greeting and its beep have finished.
      announced = true;
      await call.play([{ type: "tts", text: VOICEMAIL }], { onCompleted: hangUpAfterPlayback });
    } else if (result === "HUMAN" || result === "UNKNOWN") {
      announced = true;
      await call.play([{ type: "tts", text: LIVE }], { onCompleted: hangUpAfterPlayback });
    } else if (result === "finished") {
  await call.detect({ type: "machine", params: { detect_message_end: true } }, { timeout: 30 });
} finally {
### Whisper before connecting two people
Play a private message to `<YOUR_AGENT_DESTINATION>`, then connect that call to
`<YOUR_DESTINATION>`.
#### Play a whisper via REST
Use `connect.confirm` to play the [whisper][call-whisper] to the agent before bridging the calls.
```bash
  -d '{
    "command": "dial",
    "params": {
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
            { "play": {"url": "say:Hello, welcome to SignalWire!"} },
              "connect": {
                "to": "<YOUR_AGENT_DESTINATION>",
                "confirm": [
                  { "play": {"url": "say:You are about to be connected to the caller."} }
                "confirm_timeout": 20
whisper = "say:You are about to be connected to the caller."
swml = (
    SWMLBuilder(SWMLService(name="outbound-whisper"))
    .connect(**{
        "confirm": [{"play": {"url": whisper}}],
        "confirm_timeout": 20,
    .build()
    swml=swml,
print(call["id"])
```typescript
const whisper = "say:You are about to be connected to the caller.";
  .connect({
    to: "<YOUR_AGENT_DESTINATION>",
    confirm: [{ play: { url: whisper } }],
    confirm_timeout: 20,
  .build();
  swml,
#### Play a whisper via WebSocket (Relay)
Dial the agent first, play the whisper, then connect the caller after playback finishes.
import asyncio
async def main():
    async with client:
        # Call the agent first: only this leg hears the whisper.
            devices=[[{
                "type": "phone",
                "params": {
                    "to_number": "<YOUR_AGENT_DESTINATION>",
                    "timeout": 30,
        async def connect_the_caller(_event):
                await call.connect([[{
                    "type": "phone",
                    "params": {
                        "timeout": 30,
        await call.play(
            [{"type": "tts", "params": {"text": "You are about to be connected to the caller."}}],
            on_completed=connect_the_caller,
asyncio.run(main())
```typescript
  // Call the agent first: only this leg hears the whisper.
    type: "phone",
    params: {
      to_number: "<YOUR_AGENT_DESTINATION>",
      timeout: 30,
  await call.play(
    [{ type: "tts", text: "You are about to be connected to the caller." }],
        if (call.state === "ended") return;
          type: "phone",
          params: {
            timeout: 30,
} finally {
### Record the call
Record both sides of an outbound call and retrieve the finished recording URL.
#### Recording consent is your responsibility
Confirm which parties must consent and announce the recording when required.
#### Record the call via REST
Start [`record_call`][swml-record-call] in the background and receive the result at `status_url`.
```bash
  -d '{
    "command": "dial",
    "params": {
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
              "record_call": {
                "format": "mp3",
                "direction": "both",
                "stereo": true,
                "beep": true,
                "status_url": "<YOUR_RECORDING_STATUS_URL>"
swml = (
    SWMLBuilder(SWMLService(name="outbound-recording"))
    .record_call(
        format="mp3",
        direction="both",
        stereo=True,
        beep=True,
        status_url="<YOUR_RECORDING_STATUS_URL>",
    .build()
    swml=swml,
print(call["id"])
```typescript
  .record_call({
    format: "mp3",
    direction: "both",
    stereo: true,
    beep: true,
    status_url: "<YOUR_RECORDING_STATUS_URL>",
  .build();
  swml,
#### Record the call via WebSocket (Relay)
Start `call.record()` and read the recording URL from its `finished` event.
import asyncio
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        recording = await call.record(
            audio={
                "format": "mp3",
                "stereo": True,
                "beep": True,
                "initial_timeout": 0,
                "end_silence_timeout": 0,
                await call.hangup()
        await call.play(
            [{"type": "tts", "params": {"text": "Hello, welcome to SignalWire!"}}],
        finished = await recording.wait()
        print(f"Recording: {finished.url}")
asyncio.run(main())
```typescript
import { RelayClient, RecordEvent } from "@signalwire/sdk";
    type: "phone",
    params: {
      timeout: 30,
  const recording = await call.record({
    format: "mp3",
    direction: "both",
    stereo: true,
    beep: true,
    initial_timeout: 0,
    end_silence_timeout: 0,
  await call.play(
    [{ type: "tts", text: "Hello, welcome to SignalWire!" }],
  const finished = await recording.wait();
  console.log(`Recording: ${(finished as RecordEvent).url}`);
} finally {
### Stream the call audio
Stream both sides of a live call to your secure WebSocket endpoint for real-time processing.
#### Stream call audio via REST
Start [`stream`][swml-stream] in the background and send status events to your webhook.
```bash
  -d '{
    "command": "dial",
    "params": {
      "swml": {
        "version": "1.0.0",
        "sections": {
          "main": [
              "stream": {
                "url": "<YOUR_AUDIO_STREAM_URL>",
                "track": "both_tracks",
                "codec": "PCMU",
                "status_url": "<YOUR_STREAM_STATUS_URL>"
# `stream` is not yet in the builder's bundled schema, so add it as raw SWML.
swml_builder = SWMLBuilder(
    SWMLService(name="outbound-stream", schema_validation=False)
swml_builder.service.add_verb("stream", {
    "codec": "PCMU",
    "status_url": "<YOUR_STREAM_STATUS_URL>",
swml = (
    swml_builder
    .build()
    swml=swml,
print(call["id"])
```typescript
// `stream` is not yet in the builder's bundled schema, so add it as raw SWML.
const swmlBuilder = new SwmlBuilder();
swmlBuilder.setValidation(false);
swmlBuilder.addVerb("stream", {
  url: "<YOUR_AUDIO_STREAM_URL>",
  track: "both_tracks",
  codec: "PCMU",
  status_url: "<YOUR_STREAM_STATUS_URL>",
swmlBuilder.setValidation(true);
const swml = swmlBuilder
  .build();
  swml,
#### Stream call audio via WebSocket (Relay)
Start `call.stream()` over the Relay connection and keep it running until the call ends.
import asyncio
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        stream = await call.stream(
            url="<YOUR_AUDIO_STREAM_URL>",
            track="both_tracks",
            codec="PCMU",
            custom_parameters={"session_id": "<YOUR_SESSION_ID>"},
        print(f"Streaming audio, control ID {stream.control_id}")
                await call.hangup()
        await call.play(
asyncio.run(main())
```typescript
    type: "phone",
    params: {
      timeout: 30,
  const stream = await call.stream("<YOUR_AUDIO_STREAM_URL>", {
    codec: "PCMU",
    customParameters: { session_id: "<YOUR_SESSION_ID>" },
  console.log(`Streaming audio, control ID ${stream.controlId}`);
  await call.play(
} finally {
### Call from the browser
Place a WebRTC call from a web page using a restricted [guest token][guest-token] from your backend.
Serve the page over HTTPS or `localhost` so the browser can access the microphone.
#### index.html
```html
<!doctype html>
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <title>Call with SignalWire</title>
  </head>
  <body>
    <script type="module" src="./call.js"></script>
  </body>
</html>
#### call.js
```javascript
// Save as call.js next to the page above.
// GET /api/guest-token is your own endpoint: it creates a guest SAT with your
// Project API token and returns it as {"token": "..."}.
let clientPromise;
function getClient() {
  clientPromise ??= (async () => {
    const response = await fetch("/api/guest-token");
    if (!response.ok) throw new Error(`Token request failed: ${response.status}`);
    const { token } = await response.json();
    if (!token) throw new Error("Token response did not include a token");
    return new SignalWire(new StaticCredentialProvider({ token }));
  })().catch((error) => {
    clientPromise = undefined;
    throw error;
  return clientPromise;
function reset() {
  statusLine.textContent = "Connecting";
    const client = await getClient();
      statusLine.textContent = status;
        reset();
  } catch (error) {
    reset();
#### Choose audio, video, or both
`client.dial()` takes a [`DialOptions`][dial-options] object whose `audio` and `video` keys set what
the browser captures and sends. Omit them and the call sends audio only.
#### Audio + video
```javascript
const call = await client.dial("<YOUR_DESTINATION>", { audio: true, video: true });
A standard video call. Both tracks come from the selected microphone and camera.
#### Audio only
```javascript
A phone-style call, with no camera permission prompt.
#### Video, microphone off
```javascript
const call = await client.dial("<YOUR_DESTINATION>", { audio: false, video: true });
Joins on camera with the microphone muted — a kiosk, or a viewer who watches without speaking.
#### Receive only
```javascript
  audio: false,
  video: false,
  receiveAudio: true,
  receiveVideo: true,
Joins without sending any media. The remote tracks still arrive on `remoteStream$`.
A destination address can carry a `?channel=audio` or `?channel=video` hint that sets the matching
defaults, but options passed to `dial()` always win. If you're picking destinations from the
directory, an `Address` exposes [`defaultChannel`][address-default-channel], a ready-to-dial URI, so
you don't assemble the string yourself. To pin the microphone, camera, or speaker across
every call instead of constraining each `dial()`, use the [device management APIs][device-management].
#### Attach the media to the page
The call exposes `localStream$` (what the user sends) and `remoteStream$` (what the user receives).
Bind each to a media element's `srcObject`. The sample above binds `remoteStream$` to an `<audio>`
element; a video call binds both streams to `<video>` elements:
```html
<video id="local-video" autoplay muted playsinline></video>
<video id="remote-video" autoplay playsinline></video>
```javascript
call.localStream$.subscribe((stream) => (localVideo.srcObject = stream));
call.remoteStream$.subscribe((stream) => (remoteVideo.srcObject = stream));
Give the local element `muted` so the user doesn't hear their own voice back, leave the remote
element unmuted, and give both `playsinline` for mobile Safari. An audio-only call uses
`remoteStream$` the same way.
Watch the browser console as you dial: the call moves through `connecting` to `connected`, and
through `disconnecting`, `disconnected`, and `destroyed` once it ends. If `dial()` rejects with
[`CallCreateError`][call-create-error], the token's scope doesn't reach the destination — re-check the
token's `allowed_addresses` and its project.
`call.hangup()` ends the call for everyone. To leave the page but keep the call alive on the platform,
use [`transfer()`][browser-transfer] instead.
For receiving calls in the browser, see the [inbound calls guide][browser-inbound]; for mute, hold,
and other in-call controls, see [call controls][browser-call-controls].
