# Detect machines
> Detect people, voicemail, and fax machines, then act on the result with SWML, Relay, or REST.
[prepare-calls]: /docs/platform/voice/make-and-receive-calls#prepare-for-your-first-call
[place-swml]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-swml
[place-relay]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-websocket-relay
[answer-relay]: /docs/platform/voice/make-and-receive-calls#answer-a-call-via-websocket-relay
[tcpa]: /docs/platform/compliance/tcpa
[swml-detect-machine]: /docs/swml/reference/calling/detect-machine
[swml-switch]: /docs/swml/reference/calling/switch
[swml-ai]: /docs/swml/reference/calling/ai
[swml-receive-fax]: /docs/swml/reference/calling/receive-fax
Machine detection lets SignalWire identify whether a person, voicemail, or a fax machine is on
the call so your app can choose what happens next. This guide shows two flows: greet a person
or leave a voicemail, and send a document when a fax machine answers.
## How detection works
SignalWire listens to audio on an answered call. A short greeting followed by silence suggests a
person; longer speech suggests voicemail or an IVR menu. Fax detection listens for a fax tone.
If there isn't enough audio to decide, your app needs a fallback for the uncertain result.
Voicemail detection can also wait for the greeting to end before you leave a message. The
sections below explain how to handle these results in each approach.
## Choose an approach
Follow the section for your app's approach:
* [SWML](#detect-machines-via-swml): add `detect_machine` to your call document and branch on
  the result. Optionally send events to a webhook.
* [WebSocket (Relay)](#detect-machines-via-websocket-relay): start detection on an answered call
  and handle events in your code. No public URL is needed.
* [REST](#detect-on-a-call-already-in-progress-via-rest): start detection by call ID from any
  process and receive results at a webhook.
## Prepare for detection
Start with working call setup from [Make and receive calls][make-and-receive-calls]. Test AMD
(answering machine detection) with a phone you can answer or send to voicemail. To test fax
detection, use a fax destination and a publicly accessible PDF.
> **Trial projects only call and receive calls from verified numbers**
> A [trial project][trial-mode] only places calls to and receives calls from numbers you've
> purchased or verified. [Prepare for your first call][prepare-calls] shows how to verify the phone
> you'll test with.
> **Messages left by artificial voices are regulated**
> Prerecorded and synthesized voicemail messages fall under consent, do-not-call, and calling-hour
> rules. Read the [TCPA guide][tcpa] before you dial anyone but yourself.
| Value                     | Replace with        |
| `<YOUR_SPACE>`            | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                             |
| `<YOUR_PROJECT_ID>`       | Your Project ID        |
| `<YOUR_API_TOKEN>`        | Your API token, used only in server code                                            |
| `<YOUR_CALLER_ID>`        | Your SignalWire phone number, or a [verified caller ID][caller-id], in E.164 format |
| `<YOUR_DESTINATION>`      | The phone or fax number you'll call, in E.164 format                                |
| `<YOUR_FAX_DOCUMENT_URL>` | The public URL of a PDF that SignalWire can fetch and fax                           |
## Detect machines via SWML
[`detect_machine`][swml-detect-machine] pauses the document by default, then sets `detect_result`.
Use [`switch`][swml-switch] to choose the next action.
| `detect_result` | Meaning        | Typical action                                                           |
| `human`         | A short greeting followed by silence                                                    | Play a message or connect an agent                                       |
| `machine`       | Speech exceeds the voice or word threshold, or a beep is heard                          | Leave voicemail if you waited for the greeting to end; otherwise hang up |
| `fax`           | The configured fax tone was detected                                                    | Send or receive a fax                                                    |
| `unknown`       | No decision before `timeout`                                                            | Greet the caller or use another fallback                                 |
| `failed`        | Invalid settings, missing `status_url` with `wait: false`, or detection already running | Log the failure and use a fallback                                       |
| `detecting`     | Background detection is running with `wait: false`                                      | Handle events at `status_url`                                            |
`detect_machine_beep` is `true` when the machine detector heard a beep; otherwise it is `false`.
With `detectors: amd,fax`, a fax tone can register as a beep, so a `fax` result can also report
`true`. `detect_ms` holds the elapsed milliseconds, or `-1` with `wait: false`.
### Detect voicemail via SWML
Use AMD to distinguish a person from voicemail, then branch on the result.
`detect_message_end: true` waits for a beep or a pause of `machine_ready_timeout` before the
`machine` branch plays. The `default` branch also greets `unknown` and `failed` results.
The SDK programs place the call as in [Place a call via SWML][place-swml]. Each branch is built
with the SDK's SWML builder. The YAML and JSON tabs contain the equivalent complete document.
#### Python — REST client
# Save as leave_message.py and run: python leave_message.py
client = RestClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
live = (
    SWMLBuilder(SWMLService(name="live-message"))
    .say("Hello! Your Bayview Taxi ride is confirmed for 8 AM tomorrow.")
    .build()["sections"]["main"]
voicemail = (
    SWMLBuilder(SWMLService(name="voicemail-message"))
    .say(
        "This is Bayview Taxi. Your ride is confirmed for 8 AM tomorrow. "
        "Reply to our text message if you need to change it."
swml = (
    SWMLBuilder(SWMLService(name="leave-a-message"))
    .detect_machine(detectors="amd", detect_message_end=True, timeout=45)
    .switch(
        variable="detect_result",
        case={
            "human": live,
            "machine": voicemail,
        default=live,
    .hangup()
    .build()
call = client.calling.dial(
    from_="<YOUR_CALLER_ID>",
    to="<YOUR_DESTINATION>",
    swml=swml,
print(call["id"])
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as leave-message.mjs,
// then run: node leave-message.mjs
import { RestClient, SwmlBuilder } from "@signalwire/sdk";
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
const live = new SwmlBuilder()
  .document.sections.main;
const voicemail = new SwmlBuilder()
  .say(
    "This is Bayview Taxi. Your ride is confirmed for 8 AM tomorrow. " +
      "Reply to our text message if you need to change it.",
const swml = new SwmlBuilder()
  .detect_machine({ detectors: "amd", detect_message_end: true, timeout: 45 })
  .switch({
    variable: "detect_result",
    case: {
      human: live,
      machine: voicemail,
    default: live,
  .hangup()
  .build();
const call = await client.calling.dial({
  to: "<YOUR_DESTINATION>",
  swml,
console.log(call.id);
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - detect_machine:
        detectors: amd
        timeout: 45
    - switch:
        variable: detect_result
        case:
          human:
            - play:
                url: say:Hello! Your Bayview Taxi ride is confirmed for 8 AM tomorrow.
          machine:
            - play:
                url: say:This is Bayview Taxi. Your ride is confirmed for 8 AM tomorrow. Reply to our text message if you need to change it.
        default:
          - play:
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
        "detect_machine": {
          "detectors": "amd",
          "detect_message_end": true,
          "timeout": 45
        "switch": {
          "variable": "detect_result",
          "case": {
            "human": [
              { "play": { "url": "say:Hello! Your Bayview Taxi ride is confirmed for 8 AM tomorrow." } }
            "machine": [
              { "play": { "url": "say:This is Bayview Taxi. Your ride is confirmed for 8 AM tomorrow. Reply to our text message if you need to change it." } }
          "default": [
      { "hangup": {} }
Run the example and answer with "Hello?" to hear the live confirmation. Run it again and send the
call to voicemail to test the message after the greeting. The 45-second timeout allows time for
the greeting; tune the silence threshold below if playback starts before the beep.
To reject voicemail instead, set `detect_message_end: false` and use `hangup` in the `machine`
branch. An AI handoff can use [`ai`][swml-ai] in the `human` branch.
### Detect a fax machine via SWML
Detect whether a fax machine or a person answers with `detectors: "amd,fax"`.
The `fax` branch sends a PDF, the `human` branch plays a spoken message, and the default
branch hangs up.
`CED` is the default tone, sent by an answering fax machine. A fax tone can resemble a voicemail
beep, so if `amd` decides first, SignalWire briefly waits for the fax detector. A detected fax
tone takes priority.
# Save as detect_fax.py and run: python detect_fax.py
send_receipt = (
    SWMLBuilder(SWMLService(name="send-receipt"))
    .send_fax(document="<YOUR_FAX_DOCUMENT_URL>", header_info="Bayview Taxi receipt")
not_a_fax = (
    SWMLBuilder(SWMLService(name="not-a-fax"))
    .say("Hello, this is Bayview Taxi. We tried to fax your receipt. We will email it instead.")
hang_up = (
    SWMLBuilder(SWMLService(name="hang-up"))
    .hangup()
swml = (
    SWMLBuilder(SWMLService(name="detect-fax"))
    .detect_machine(detectors="amd,fax", timeout=30)
    .switch(
        case={
            "fax": send_receipt,
            "human": not_a_fax,
        default=hang_up,
    .hangup()
    .build()
    swml=swml,
print(call["id"])
```typescript
// This sample also runs as JavaScript: save as detect-fax.mjs,
// then run: node detect-fax.mjs
const sendReceipt = new SwmlBuilder()
  .send_fax({ document: "<YOUR_FAX_DOCUMENT_URL>", header_info: "Bayview Taxi receipt" })
const notAFax = new SwmlBuilder()
const hangUp = new SwmlBuilder()
  .hangup()
  .detect_machine({ detectors: "amd,fax", timeout: 30 })
  .switch({
    case: {
      fax: sendReceipt,
      human: notAFax,
    default: hangUp,
  .hangup()
  .build();
  swml,
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - detect_machine:
        detectors: amd,fax
        timeout: 30
    - switch:
        case:
          fax:
            - send_fax:
                document: <YOUR_FAX_DOCUMENT_URL>
                header_info: Bayview Taxi receipt
          human:
            - play:
                url: say:Hello, this is Bayview Taxi. We tried to fax your receipt. We will email it instead.
        default:
          - hangup: {}
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
        "detect_machine": {
          "detectors": "amd,fax",
          "timeout": 30
        "switch": {
          "case": {
            "fax": [
                "send_fax": {
                  "document": "<YOUR_FAX_DOCUMENT_URL>",
                  "header_info": "Bayview Taxi receipt"
            "human": [
              { "play": { "url": "say:Hello, this is Bayview Taxi. We tried to fax your receipt. We will email it instead." } }
          "default": [
            { "hangup": {} }
      { "hangup": {} }
Test with a fax number to confirm document delivery, then with a phone to hear the spoken
fallback. For a fax machine calling you, use `tone: "CNG"` and
[`receive_fax`][swml-receive-fax] instead; its `status_url` receives the document details.
Inbound call setup is covered in [Answer a call via SWML][answer-swml].
### Track detection results via SWML
Add `status_url` to `detect_machine` to receive JSON webhooks. These report intermediate detector
events; the document still branches on `detect_result`.
| Webhook field                | Value                                                     |
| `event_type`                 | `calling.call.detect`                                     |
| `params.call_id`             | The call ID                                               |
| `params.control_id`          | The detection operation's ID                              |
| `params.detect.type`         | `machine` or `fax`                                        |
| `params.detect.params.event` | The detector event listed below                           |
| `params.detect.params.beep`  | `true` once a beep has been heard; absent from fax events |
| Outcome                                     | Callbacks, in order                                                            |
| A person answers                            | `HUMAN`, `finished`                                                            |
| A machine answers, `detect_message_end` off | `MACHINE`, `finished`, with `READY` between them if the line is already silent |
| A machine answers, `detect_message_end` on  | `MACHINE`, `READY` when the greeting ends, `finished`                          |
| A beep is heard before `MACHINE`            | `MACHINE`, then `READY`, then `finished`, regardless of `detect_message_end`   |
| No decision                                 | `UNKNOWN` at `initial_timeout`, then `finished` at `timeout`                   |
| A fax tone is heard                         | `CED` or `CNG`, then `finished`                                                |
`UNKNOWN` doesn't stop detection or resume the document. A silent call waits until `timeout`
before `detect_result` becomes `unknown`. If the call hangs up during machine detection, no
final `finished` callback is sent; fax detection still sends `finished`. Once set, `beep: true`
remains on later machine events.
For background detection, set `wait: false` and supply `status_url`. The document continues
immediately with `detect_result: detecting`; act on the webhook events instead. See the
[webhooks guide][webhooks] for endpoint setup and testing.
### Tune SWML detection
Set these properties on `detect_machine`. Change one at a time and test with the destinations
you expect to call.
| Setting                   | Default                       | When to change it                                                          |
| `initial_timeout`         | 4.5 s                         | Raise it for greetings that start with silence                             |
| `machine_voice_threshold` | 1.25 s                        | Raise it if longer human greetings are classified as machines              |
| `machine_words_threshold` | 6 words                       | Lower it if short recorded greetings are classified as people              |
| `end_silence_timeout`     | 1.0 s                         | Lower it if a person's pause after "Hello?" isn't recognized               |
| `machine_ready_timeout`   | Same as `end_silence_timeout` | Raise it for voicemail greetings that pause before the beep                |
| `timeout`                 | 30 s                          | Raise it for long greetings; lower it for inbound callers waiting silently |
| `detect_message_end`      | `false`                       | Set to `true` to wait through a voicemail greeting                         |
For inbound screening, greet `unknown` callers and keep `timeout` short: they may be waiting
for you to speak. `detect_interruptions` is unsupported in SWML and makes detection fail.
The [`detect_machine` reference][swml-detect-machine] lists all properties, including the
`detectors` selector, which defaults to both `amd` and `fax`.
## Detect machines via WebSocket (Relay)
Start detection on an answered call with `detect()` and a `machine` or `fax` detector. Each
operation runs one detector, and a call can run only one detector of each type at a time.
Register a `calling.call.detect` handler before starting detection. Read `event.detect.type`
for the detector and `event.detect.params.event` for its result:
| Event          | Meaning                                                           | Typical action                                  |
| `HUMAN`        | A short greeting followed by silence                              | Play a message or connect an agent              |
| `MACHINE`      | A recorded greeting or beep was detected                          | Wait for `READY` to leave voicemail, or hang up |
| `READY`        | A beep or the end of the greeting                                 | Play the voicemail message                      |
| `NOT_READY`    | Speech resumed after `READY`, with `detect_interruptions` enabled | Wait for the next `READY`                       |
| `UNKNOWN`      | Nothing heard before `initial_timeout`                            | Greet the caller or keep waiting                |
| `CED` or `CNG` | The configured fax tone                                           | Send or receive a fax                           |
| `finished`     | Detection ended                                                   | Clean up if no action has been taken            |
An action's `wait()` returns on the first result. To leave voicemail, follow events through
`MACHINE` to `READY` instead. `detect_message_end` defaults to `true`; setting it to `false`
stops on `MACHINE`. A beep heard before `MACHINE` triggers `MACHINE` and then `READY` with
either setting; with `false`, detection has already stopped by the time a later beep plays, so
it's usually missed.
`UNKNOWN` doesn't stop the detector: it keeps listening until it decides or `timeout` expires.
`finished` follows the final result, including when the call hangs up during detection. Once a
beep is heard, `event.detect.params.beep` is `true` on that and later machine events; fax events
don't carry it. Call the action's `stop()` to stop detection early.
### Detect voicemail via WebSocket (Relay)
Use AMD events to distinguish a person from voicemail and detect when the greeting ends.
The handler plays a live confirmation on `HUMAN` or `UNKNOWN`, leaves voicemail on `READY`,
and hangs up if detection finishes without a usable result. The `announced` flag prevents
later events from starting a second message.
Call setup follows [Place a call via WebSocket (Relay)][place-relay].
#### Python — Relay client
# Save as leave_message_relay.py and run: python leave_message_relay.py
import asyncio
from signalwire.relay.event import DetectEvent
LIVE = "Hello! Your Bayview Taxi ride is confirmed for 8 AM tomorrow."
VOICEMAIL = (
client = RelayClient(
    contexts=["default"],
async def main():
    async with client:
        call = await client.dial(
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        announced = False
            if call.state != "ended":
                await call.hangup()
        async def speak(text: str):
            nonlocal announced
            announced = True
            await call.play(
                [{"type": "tts", "params": {"text": text}}],
        async def on_detect(event: DetectEvent):
            if announced or call.state == "ended":
                return
            result = event.detect.get("params", {}).get("event", "")
            if result == "READY":
                # The greeting and its beep have finished.
                await speak(VOICEMAIL)
            elif result in ("HUMAN", "UNKNOWN"):
                await speak(LIVE)
            elif result == "finished":
                # Detection timed out without a usable result.
                await call.hangup()
        call.on("calling.call.detect", on_detect)
        await call.detect(
            {"type": "machine", "params": {"detect_message_end": True}}, timeout=45
        await call.wait_for_ended()
asyncio.run(main())
```typescript
// Save as leave-message-relay.mts and run: npx tsx leave-message-relay.mts
import { RelayClient, DetectEvent } from "@signalwire/sdk";
const LIVE = "Hello! Your Bayview Taxi ride is confirmed for 8 AM tomorrow.";
const VOICEMAIL =
  "Reply to our text message if you need to change it.";
  contexts: ["default"],
await client.connect();
    type: "phone",
    params: {
      timeout: 30,
  let announced = false;
  const speak = async (text: string) => {
    announced = true;
    await call.play([{ type: "tts", text }], {
      onCompleted: async () => {
  call.on("calling.call.detect", async (event) => {
    if (announced || call.state === "ended") return;
    const detect = (event as DetectEvent).detect as { params?: { event?: string } };
    const result = detect.params?.event ?? "";
    if (result === "READY") {
      // The greeting and its beep have finished.
      await speak(VOICEMAIL);
    } else if (result === "HUMAN" || result === "UNKNOWN") {
      await speak(LIVE);
    } else if (result === "finished") {
      // Detection timed out without a usable result.
  await call.detect({ type: "machine", params: { detect_message_end: true } }, { timeout: 45 });
  await call.waitForEnded();
} finally {
  await client.disconnect();
Test once by answering with "Hello?" and once by sending the call to voicemail. To observe the
sequence, log `event.detect` in the handler. To reject machines, hang up on `MACHINE` instead;
to hand a person to an AI agent, call `call.ai()` on `HUMAN`.
### Detect a fax machine via WebSocket (Relay)
Detect a fax machine by listening for `CED`, the default tone from an answering fax machine.
On detection, send the PDF; otherwise, play a spoken fallback. Unlike AMD, this detector
only decides whether it heard the fax tone; the fallback isn't a human classification.
Listen for `calling.call.fax` with `fax.type: finished` to read `fax.params.success` and
`fax.params.pages`. These SDK versions don't complete `fax.wait()` for that payload, so the
example handles the event directly.
# Save as detect_fax_relay.py and run: python detect_fax_relay.py
import asyncio
from signalwire.relay.event import FaxEvent
NOT_A_FAX = "Hello, this is Bayview Taxi. We tried to fax your receipt. We will email it instead."
def is_fax(event) -> bool:
    detect = event.params.get("detect", {})
    return detect.get("params", {}).get("event") in ("CED", "CNG")
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        action = await call.detect({"type": "fax", "params": {"tone": "CED"}}, timeout=8)
        event = await action.wait()
        if is_fax(event):
            async def on_fax(fax_event: FaxEvent):
                if fax_event.fax.get("type") != "finished":
                    return
                result = fax_event.fax.get("params", {})
                print(f"Fax sent: {result.get('success')}, {result.get('pages', 0)} pages")
                    await call.hangup()
            call.on("calling.call.fax", on_fax)
            await call.send_fax(
                header_info="Bayview Taxi receipt",
            return
                await call.hangup()
        await call.play(
            [{"type": "tts", "params": {"text": NOT_A_FAX}}],
asyncio.run(main())
```typescript
// Save as detect-fax-relay.mts and run: npx tsx detect-fax-relay.mts
import { RelayClient, RelayEvent, FaxEvent } from "@signalwire/sdk";
const NOT_A_FAX = "Hello, this is Bayview Taxi. We tried to fax your receipt. We will email it instead.";
function isFax(event: RelayEvent): boolean {
  const detect = event.params.detect as { params?: { event?: string } } | undefined;
  return ["CED", "CNG"].includes(detect?.params?.event ?? "");
    type: "phone",
    params: {
      timeout: 30,
  const action = await call.detect({ type: "fax", params: { tone: "CED" } }, { timeout: 8 });
  const event = await action.wait();
  if (isFax(event)) {
    call.on("calling.call.fax", async (faxEvent) => {
      const fax = (faxEvent as FaxEvent).fax as {
        type?: string;
        params?: { success?: boolean; pages?: number };
      if (fax.type !== "finished") return;
      console.log(`Fax sent: ${fax.params?.success}, ${fax.params?.pages ?? 0} pages`);
    await call.sendFax("<YOUR_FAX_DOCUMENT_URL>", {
      headerInfo: "Bayview Taxi receipt",
  } else {
    await call.play([{ type: "tts", text: NOT_A_FAX }], {
} finally {
Test with a fax destination, then with a phone to check the fallback. For incoming faxes,
listen for `CNG` and use `receive_fax()` in Python or `receiveFax()` in TypeScript. The finished
fax event also includes the stored document URL in `fax.params.document`. For inbound call
setup, see [Answer a call via WebSocket (Relay)][answer-relay].
### Tune Relay detection
Pass `timeout` separately to `detect()`; put the other settings in the detector's `params`.
| `initial_timeout`         | 4.5 s                         | Raise it for delayed greetings; lower it to greet silent inbound callers sooner |
| `timeout`                 | 30 s                          | Raise it for long greetings; keep fax checks short for voice callers            |
| `detect_message_end`      | `true`                        | Set explicitly; use `false` when you only need the initial classification       |
| `detect_interruptions`    | `false`                       | Enable it to receive `NOT_READY` if speech resumes after `READY`                |
Change one setting at a time. For inbound screening, greet `UNKNOWN` callers: they may be
waiting silently for you to speak. If you enable interruptions, handle `NOT_READY` and wait
for the next `READY` before resuming your message.
## Detect on a call already in progress via REST
If another process needs to start detection, send [`calling.detect`][call-commands] with the
answered call's ID, a required `control_id`, a `detect` object, and `status_url`. Use
`detect.type: machine` for AMD or `detect.type: fax` for fax tones; pass settings in
`detect.params` and `timeout` separately. `detect_message_end` defaults to `true`, and fax
`tone` defaults to `CED` (use `CNG` for incoming faxes).
### Request
POST https\://%7BYour\_Space\_Name%7D.signalwire.com/api/calling/calls
**`calling.detect`**
```curl calling.detect
     -d '{
  "command": "calling.detect",
  "id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "params": {
    "control_id": "detect-control-1",
    "detect": {
      "params": {
        "end_silence_timeout": 1,
        "initial_timeout": 4.5
      "type": "machine"
    "timeout": 30,
    "status_url": "https://example.com/webhooks/detection"
```python calling.detect
import requests
url = "https://{your_space_name}.signalwire.com/api/calling/calls"
payload = {
    "params": {
        "detect": {
            "params": {
            "type": "machine"
        "timeout": 30,
headers = {
response = requests.post(url, json=payload, headers=headers, auth=("<project_id>", "<api_token>"))
print(response.json())
```javascript calling.detect
const url = 'https://{your_space_name}.signalwire.com/api/calling/calls';
const credentials = btoa("<project_id>:<api_token>");
const options = {
  method: 'POST',
  headers: {
    Authorization: `Basic ${credentials}`,
    'Content-Type': 'application/json'
  body: '{"command":"calling.detect","id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","params":{"control_id":"detect-control-1","detect":{"params":{"end_silence_timeout":1,"initial_timeout":4.5},"type":"machine"},"timeout":30,"status_url":"https://example.com/webhooks/detection"}}'
  const response = await fetch(url, options);
  const data = await response.json();
  console.log(data);
} catch (error) {
  console.error(error);
```go calling.detect
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/calling/calls"
	payload := strings.NewReader("{\n  \"command\": \"calling.detect\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"detect-control-1\",\n    \"detect\": {\n      \"params\": {\n        \"end_silence_timeout\": 1,\n        \"initial_timeout\": 4.5\n      },\n      \"type\": \"machine\"\n    },\n    \"timeout\": 30,\n    \"status_url\": \"https://example.com/webhooks/detection\"\n  }\n}")
	req, _ := http.NewRequest("POST", url, payload)
	req.SetBasicAuth("<project_id>", "<api_token>")
	req.Header.Add("Content-Type", "application/json")
	res, _ := http.DefaultClient.Do(req)
	defer res.Body.Close()
	body, _ := io.ReadAll(res.Body)
	fmt.Println(res)
	fmt.Println(string(body))
```ruby calling.detect
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/calling/calls")
http = Net::HTTP.new(url.host, url.port)
http.use_ssl = true
request = Net::HTTP::Post.new(url)
request.basic_auth("<project_id>", "<api_token>")
request["Content-Type"] = 'application/json'
request.body = "{\n  \"command\": \"calling.detect\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"detect-control-1\",\n    \"detect\": {\n      \"params\": {\n        \"end_silence_timeout\": 1,\n        \"initial_timeout\": 4.5\n      },\n      \"type\": \"machine\"\n    },\n    \"timeout\": 30,\n    \"status_url\": \"https://example.com/webhooks/detection\"\n  }\n}"
response = http.request(request)
puts response.read_body
```java calling.detect
HttpResponse<String> response = Unirest.post("https://{your_space_name}.signalwire.com/api/calling/calls")
  .basicAuth("<project_id>", "<api_token>")
  .header("Content-Type", "application/json")
  .body("{\n  \"command\": \"calling.detect\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"detect-control-1\",\n    \"detect\": {\n      \"params\": {\n        \"end_silence_timeout\": 1,\n        \"initial_timeout\": 4.5\n      },\n      \"type\": \"machine\"\n    },\n    \"timeout\": 30,\n    \"status_url\": \"https://example.com/webhooks/detection\"\n  }\n}")
  .asString();
```php calling.detect
<?php
require_once('vendor/autoload.php');
$client = new \GuzzleHttp\Client();
$response = $client->request('POST', 'https://{your_space_name}.signalwire.com/api/calling/calls', [
  'body' => '{
  "params": {
    "detect": {
      "params": {
      "type": "machine"
    "timeout": 30,
  'headers' => [
    'Content-Type' => 'application/json',
    'auth' => ['<project_id>', '<api_token>'],
echo $response->getBody();
```csharp calling.detect
using RestSharp;
using RestSharp.Authenticators;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/calling/calls");
client.Authenticator = new HttpBasicAuthenticator("<project_id>", "<api_token>");
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/json");
request.AddParameter("application/json", "{\n  \"command\": \"calling.detect\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"detect-control-1\",\n    \"detect\": {\n      \"params\": {\n        \"end_silence_timeout\": 1,\n        \"initial_timeout\": 4.5\n      },\n      \"type\": \"machine\"\n    },\n    \"timeout\": 30,\n    \"status_url\": \"https://example.com/webhooks/detection\"\n  }\n}", ParameterType.RequestBody);
IRestResponse response = client.Execute(request);
```swift calling.detect
import Foundation
let credentials = Data("<project_id>:<api_token>".utf8).base64EncodedString()
let headers = [
  "Authorization": "Basic \(credentials)",
let parameters = [
  "params": [
    "detect": [
      "params": [
      "type": "machine"
    "timeout": 30,
] as [String : Any]
let postData = JSONSerialization.data(withJSONObject: parameters, options: [])
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/calling/calls")! as URL,
                                        cachePolicy: .useProtocolCachePolicy,
                                    timeoutInterval: 10.0)
request.httpMethod = "POST"
request.allHTTPHeaderFields = headers
request.httpBody = postData as Data
let session = URLSession.shared
let dataTask = session.dataTask(with: request as URLRequest, completionHandler: { (data, response, error) -> Void in
  if (error != nil) {
    print(error as Any)
  } else {
    let httpResponse = response as? HTTPURLResponse
    print(httpResponse)
dataTask.resume()
The command returns immediately. Your webhook receives `calling.call.detect` events with the
result in `params.detect.params.event`. Have the handler send the next call command, such as
`calling.play` on `READY` for voicemail. Use `calling.detect.stop` with the same `control_id`
to stop early. Only one detector of each type can run on a call at a time.
