> This page is for Platform.
# Forward calls
> Forward calls to your SignalWire number to another phone with SWML or Relay, play a message when nobody answers, and forward a call already in progress over REST.
[prepare-calls]: /docs/platform/voice/make-and-receive-calls#prepare-for-your-first-call
[answer-relay]: /docs/platform/voice/make-and-receive-calls#answer-a-call-via-websocket-relay
[swml-intro]: /docs/swml
[swml-connect]: /docs/swml/reference/calling/connect
[cfb-forward]: /docs/call-flow-builder/reference/forward-to-phone
[addresses]: /docs/platform/addresses
[sip-refer]: /docs/platform/voice/sip-refer
Call forwarding sends calls to your SignalWire number on to another phone, so a caller reaches a
person wherever they are. Each section below forwards a call to your number to a second phone, and
plays a message to the caller when nobody answers.
## Choose an approach
SWML and Relay each forward calls to your number with their own code and their own kind of Resource
on the number, so pick one and follow only its section. REST works on any live call, however it was
answered. All three dial the destination and connect it to the caller the same way, so the timeout
and caller ID rules on this page apply to each.
* [SWML][swml-intro]: answer calls to your number with a document that SignalWire runs, served from
  your server or hosted in SignalWire. `connect` forwards the call, and the next instructions in the
  document run if nobody answers.
* WebSocket (Relay): answer calls with the [Server SDKs][server-sdks] in code that holds a
  connection to SignalWire, and forward them with a connect command. Forwarding events arrive in your
  code, so no webhook is needed.
* [REST](#forward-a-call-already-in-progress-via-rest): forward a call that's already in progress,
  such as one an AI agent is handling, by call ID from any process.
To forward calls without code, use the [Forward to Phone][cfb-forward] node in Call Flow Builder.
## Prepare for call forwarding
Start with working call setup from [Make and receive calls][make-and-receive-calls]. Have these
values ready:
* Your Space URL, such as `<YOUR_SPACE>.signalwire.com`.
* Your Project ID and an API token with the **Voice** permission.
* A phone number in your Space.
* Two phones you can answer: one to call your number from, and one that receives the forwarded
  call.
> **Trial projects only call and receive calls from verified numbers**
> A [trial project][trial-mode] only places calls to and receives calls from numbers you've purchased
> or verified, and can't call internationally. Verify both phones you'll test with, as
> [Prepare for your first call][prepare-calls] shows.
| Value                        | Replace with        |
| `<YOUR_SPACE>`               | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`        |
| `<YOUR_PROJECT_ID>`          | Your Project ID        |
| `<YOUR_API_TOKEN>`           | Your API token with the Voice permission, used only in server code        |
| `<YOUR_DESTINATION>`         | The phone that receives forwarded calls, in E.164 format, such as `+12025550123`        |
| `<YOUR_CALLER_ID>`           | Your SignalWire phone number, or a [verified caller ID][caller-id], in E.164 format, when the forwarded call shows it instead of the caller's number |
| `<YOUR_BASIC_AUTH_PASSWORD>` | A password you choose for the SWML your server serves        |
| `<YOUR_PUBLIC_HOST>`         | The public hostname of your SWML server or tunnel        |
| `<YOUR_CALL_ID>`             | The ID of a live call, when you forward it over REST        |
## How call forwarding works
A forwarded call is two calls joined together. The caller's call to your number is the first.
SignalWire then places a second call to the destination, and when the destination answers, bridges
the two so the caller and the destination hear each other. The forward ends when either side hangs
up. If the destination doesn't answer, is busy, or declines, the forward fails, and your code decides
what the caller hears next.
Two settings shape every forward:
* **Timeout.** How long the destination rings before the forward fails. A voicemail system that
  answers counts as an answer, so keep the timeout shorter than the time the destination's phone
  takes to send calls to its own voicemail if you want your own message to play instead.
* **Caller ID.** The number the destination's phone shows. Show the caller's number so the person
  answering knows who's calling, or show your SignalWire number so they know the call came through
  your business line.
A destination can be a phone number or a SIP URI such as `sip:ada@example.com`. SWML, and so REST,
can also forward to a [Resource Address][addresses] such as `/public/support`. The samples on this
page forward to a phone number.
Forwarding keeps SignalWire in the call for as long as it lasts. To hand a SIP call back to your PBX
or SIP device instead, see [Transfer calls with SIP REFER][sip-refer].
## Forward calls via SWML
[`connect`][swml-connect] places the call to the destination and bridges it to the caller. The
document waits at `connect` until the forward ends, then moves on to the next instruction.
### Forward an incoming call via SWML
Bayview Taxi forwards calls to its business number to Ada, its dispatcher. This walkthrough forwards
a call to your number to your second phone.
#### Build the forwarding document
The document rings the destination for up to twenty seconds with `connect`. It sets `from` to
`${call.from}`, the number of the person calling you, so the forwarded call shows who's calling. If
nobody answers, the document continues and plays a message.
#### Python — SWML builder
# Save as forward_calls.py and run: python forward_calls.py
service = SWMLService(
    name="forward-calls",
    route="/swml",
    port=3000,
    SWMLBuilder(service)
    # from is a Python keyword, so unpack the connect settings from a dict.
    .connect(**{"to": "<YOUR_DESTINATION>", "from": "${call.from}", "timeout": 20})
    .say("Sorry, nobody at Bayview Taxi can take your call right now. Please call back later.")
# Serves the document at /swml. Put the credentials in the URL you give
# SignalWire: https://signalwire:<YOUR_BASIC_AUTH_PASSWORD>@<YOUR_PUBLIC_HOST>/swml
service.serve()
#### TypeScript — SWML builder
```typescript
// This sample also runs as JavaScript: save as forward-calls.mjs,
// then run: node forward-calls.mjs
  route: "/swml",
  port: 3000,
service.getBuilder()
  .connect({ to: "<YOUR_DESTINATION>", from: "${call.from}", timeout: 20 })
  .say("Sorry, nobody at Bayview Taxi can take your call right now. Please call back later.");
// Serves the document at /swml. Put the credentials in the URL you give
// SignalWire: https://signalwire:<YOUR_BASIC_AUTH_PASSWORD>@<YOUR_PUBLIC_HOST>/swml
await service.serve();
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - connect:
        to: <YOUR_DESTINATION>
        timeout: 20
    - play:
        url: say:Sorry, nobody at Bayview Taxi can take your call right now. Please call back later.
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
        "connect": {
          "timeout": 20
      { "play": { "url": "say:Sorry, nobody at Bayview Taxi can take your call right now. Please call back later." } }
The [Server SDKs][server-sdks] build the document and serve it from your server. Run the server,
give it a public URL, and create a SWML Script with
**External URL** set to `https://signalwire:<YOUR_BASIC_AUTH_PASSWORD>@<YOUR_PUBLIC_HOST>/swml`, as
[Answer a call via SWML][answer-swml] shows. To skip the server, create a SWML Script with
**Hosted Script** and paste the YAML or JSON into **Primary Script** instead.
To show your SignalWire number instead of the caller's, set `from` to `<YOUR_CALLER_ID>`. The message also plays if the destination hangs up before the caller does; to play it
only when nobody answers, branch on the `connect_result` variable, which `connect` sets to
`connected` or `failed`.
#### Assign the script to your phone number
Open **Phone Numbers**, select the number, and select **Edit Settings**. Under **Inbound Call
Settings**, select **Assign Resource**, choose the Resource, and save. To assign from the Resource
instead, open its **Addresses & Phone Numbers** tab, select **+ Add**, then **Phone Number**, and
pick a number you own.
To assign it in code, see [Answer a call via SWML][answer-swml].
#### Call your number
Call your SignalWire number from your first phone. You hear ringing while your second phone rings,
and the second phone shows your first phone's number. Answer it and talk: each phone hears the
other. Hang up either phone to end the call.
Call again and let the second phone ring without answering. After twenty seconds you hear the
message, then the call ends.
If it doesn't work, check the symptom:
* **The call ends right away, or you hear an error.** SignalWire couldn't run the document. If your
  server serves it, check that the server and tunnel are running and that the URL's password
  matches the server's.
* **You hear your number's old behavior.** The number still points at another Resource. Open it
  under **Phone Numbers** and check **Inbound Call Settings**.
* **The second phone never rings, and the call ends after the timeout.** Check that
  `<YOUR_DESTINATION>` is in E.164 format, and in a trial project, that it's a verified number.
## Forward calls via WebSocket (Relay)
Answer the call, then send a connect command with the destination to dial. The command returns as
soon as SignalWire accepts it, so the program follows the forward through
`calling.call.connect` events: `connecting`, then `connected` while the two phones talk and
`disconnected` when one hangs up, or `failed` if nobody answers.
### Forward an incoming call via WebSocket (Relay)
This walkthrough forwards a call to your number to your second phone, showing the caller's number.
#### Run the forwarding handler
Run the handler and leave it running while you test. It subscribes to the `forward-calls`
topic. When a call arrives, it answers, plays a ringtone to the caller, and rings your second phone
for up to twenty seconds. If nobody answers, it plays a message, then hangs up; when the forward
ends, it hangs up.
#### Python — Relay client
# Save as forward_relay.py and run: python forward_relay.py
from signalwire.relay import ConnectEvent, RelayClient
client = RelayClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
    contexts=["forward-calls"],
@client.on_call
async def handle_call(call):
    caller = call.device.get("params", {}).get("from_number")
        if call.state != "ended":
            await call.hangup()
        print(f"Forward: {event.connect_state}")
        if call.state == "ended":
            return
        if event.connect_state == "failed":
            # Nobody answered, the line was busy, or the call was declined.
            await call.play_tts(
                "Sorry, nobody at Bayview Taxi can take your call right now. Please call back later.",
        elif event.connect_state == "disconnected":
            await call.hangup()
    await call.answer()
    await call.connect(
        devices=[[{
            "type": "phone",
            "params": {
                "from_number": caller,
                "timeout": 20,
        ringback=[{"type": "ringtone", "params": {"name": "us"}}],
    await call.wait_for_ended()
client.run()
```typescript
// This sample also runs as JavaScript: save as forward-relay.mjs,
// then run: node forward-relay.mjs
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
  contexts: ["forward-calls"],
client.onCall(async (call) => {
  const caller = call.device.params?.from_number;
  call.on("calling.call.connect", async (event) => {
    const state = event.params.connect_state;
    console.log(`Forward: ${state}`);
    if (call.state === "ended") return;
    if (state === "failed") {
      // Nobody answered, the line was busy, or the call was declined.
      await call.play([{ type: "tts", text: "Sorry, nobody at Bayview Taxi can take your call right now. Please call back later." }], {
        onCompleted: async () => {
    } else if (state === "disconnected") {
  await call.answer();
  await call.connect(
      type: "phone",
      params: {
        from_number: caller,
        timeout: 20,
    { ringback: [{ type: "ringtone", name: "us" }] },
  await call.waitForEnded();
await client.run();
The handler sets the forwarded call's caller ID to the caller's number, read from the incoming call.
To show your SignalWire number instead, use `<YOUR_CALLER_ID>`. The [Server SDKs][server-sdks]
document every connect option.
#### Assign the topic to your phone number
Create a Relay Application for the topic:
1. Open **My Resources**, select **+ Add**, then **Relay Application**.
2. Name it **Forward calls** and enter `forward-calls` as the **Topic**. It must match the
   `contexts` value in your code.
3. Select **Create**.
To assign it in code, see [Answer a call via WebSocket (Relay)][answer-relay].
Call your SignalWire number from your first phone. You hear a ringtone while your second phone
rings, and the handler prints `Forward: connecting`. Answer the second phone: it shows your first
phone's number, the handler prints `Forward: connected`, and each phone hears the other. Hang up
either phone; the handler prints `Forward: disconnected` and ends the call.
Call again and let the second phone ring without answering. After twenty seconds the handler prints
`Forward: failed`, you hear the message, and the call ends.
* **The call never reaches your handler.** Check that the handler is still running, that its
  `contexts` value matches the Relay Application's **Topic** exactly, and that the number's
  **Inbound Call Settings** point at that Relay Application.
* **The handler prints `Forward: failed` right away, and the second phone never rings.** Check that
## Forward a call already in progress via REST
When a process that doesn't hold the call needs to forward it, such as a dashboard where a
dispatcher reroutes a caller, send the `calling.transfer` command with the call's ID and a SWML
document that uses `connect`. Whatever the call is doing stops, and the document takes over: the
destination rings, and when it answers, the caller is connected to it. If nobody answers, the
caller hears the message. The call ID is the `id` from
a `dial` response, or the `call_id` that SignalWire sends your SWML server or status webhook.
The [Server SDKs][server-sdks] wrap the command:
#### Python — REST client
# Save as forward_rest.py and run: python forward_rest.py
client = RestClient(
swml = (
    SWMLBuilder(SWMLService(name="forward-in-progress"))
    .build()
client.calling.transfer("<YOUR_CALL_ID>", dest=swml)
print("Forwarding")
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as forward-rest.mjs,
// then run: node forward-rest.mjs
import { RestClient, SwmlBuilder } from "@signalwire/sdk";
const swml = new SwmlBuilder()
  .build();
await client.calling.transfer("<YOUR_CALL_ID>", { dest: swml });
console.log("Forwarding");
#### cURL — Calling API
```bash
curl -X POST "https://<YOUR_SPACE>.signalwire.com/api/calling/calls" \
  -u "<YOUR_PROJECT_ID>:<YOUR_API_TOKEN>" \
  -d '{
    "command": "calling.transfer",
    "id": "<YOUR_CALL_ID>",
    "params": {
      "dest": {
        "version": "1.0.0",
        "sections": {
          "main": [
            { "connect": { "to": "<YOUR_DESTINATION>", "from": "${call.from}", "timeout": 20 } },
The cURL example calls [Call commands][call-commands]. The command returns as soon as SignalWire
accepts it, and the call keeps the same ID. `dest` also takes the URL of a SWML document your server
serves.
