> This page is for Platform.
# Collect caller input
> Ask the caller a question with SWML, Relay, or Call Flow Builder, collect speech or key presses, branch on the answer, handle silence and unmatched replies, and read the result in the call log or your own code.
[answer-relay]: /docs/platform/voice/make-and-receive-calls#answer-a-call-via-websocket-relay
[api-credentials]: /docs/platform/your-signalwire-api-space
[cfb]: /docs/call-flow-builder
[cfb-answer]: /docs/call-flow-builder/reference/answer-call
[cfb-conditions]: /docs/call-flow-builder/reference/conditions
[cfb-forward]: /docs/call-flow-builder/reference/forward-to-phone
[cfb-gather]: /docs/call-flow-builder/reference/gather-input
[cfb-gather-loop]: /docs/call-flow-builder/reference/gather-input#input-with-infinite-loop-prevention
[cfb-hangup]: /docs/call-flow-builder/reference/hangup-call
[cfb-play]: /docs/call-flow-builder/reference/play-audio-or-tts
[cfb-set-variables]: /docs/call-flow-builder/reference/set-variables
[cfb-version]: /docs/call-flow-builder/guides/version
[collect-webhook]: /docs/apis/rest/webhooks/collect-status-callback
[control-flow]: /docs/swml/guides/goto-execute-transfer-disambiguation
[create-swml-script]: /docs/platform/voice/make-and-receive-calls#create-the-swml-script
[forward-relay]: /docs/platform/voice/forward-calls#forward-an-incoming-call-via-websocket-relay
[forward-swml]: /docs/platform/voice/forward-calls#forward-an-incoming-call-via-swml
[how-incoming]: /docs/platform/voice/make-and-receive-calls#how-an-incoming-call-reaches-your-code
[make-receive]: /docs/platform/voice/make-and-receive-calls
[rest-calling]: /docs/apis/rest/calls/call-commands
[speak-rest]: /docs/platform/voice/speak-text#speak-text-on-a-call-in-progress-via-rest
[speak-text]: /docs/platform/voice/speak-text
[swml]: /docs/swml
[swml-goto]: /docs/swml/reference/calling/goto
[swml-prompt]: /docs/swml/reference/calling/prompt
[swml-switch]: /docs/swml/reference/calling/switch
[swml-transfer]: /docs/swml/reference/calling/transfer
Ask the caller a question, collect what they say or press, and send the call down a branch based
on the answer. That one pattern is a department menu, a yes-or-no confirmation, or a request for
an account number, and it works the same whether the call reached your flow from a phone number, a
SIP address, or a browser. Start by asking one question and branching on the reply, then handle
silence and unmatched replies, track what the flow heard, and extend the prompt to keypad digits
and a retry.
## Pick the right product for collecting caller input
| Function                                                         | SWML | WebSocket (Relay) | REST | Call Flow Builder |
| Ask a question and branch on the answer without running a server |      |                   |      |                   |
| Collect speech, keypad digits, or both on one prompt             |      |                   |      |                   |
| Play the question and collect the reply in one command           |      |                   |      |                   |
| Tell silence apart from speech the recognizer could not make out |      |                   |      |                   |
| Receive the reply in your own process without hosting a webhook  |      |                   |      |                   |
| Collect input on a call another process answered, by its call ID |      |                   |      |                   |
| Build the menu visually, with no code                            |      |                   |      |                   |
* [SWML][swml] is a JSON or YAML document that SignalWire runs step by step. Generate it with the
  [Server SDKs][server-sdks] or write it by hand, then host it in your Space or serve it from your
  own server. Its `prompt` method asks and collects in one step. To compare the reply on your own
  server instead, `transfer` or `execute` to a URL: SignalWire posts the document's variables,
  `prompt_value` among them, and runs the SWML you return.
* [Relay][server-sdks] is the WebSocket client in the Server SDKs. Your process receives the call,
  plays the question, and gets the reply back as a value it can compare.
* The [REST Calling API][rest-calling] sends the same collect command over HTTP to a call you
  already hold the ID for. The reply arrives as a webhook.
* [Call Flow Builder][cfb] is a visual editor in the Dashboard. Its Gather Input node asks,
  collects, and branches without code.
The Browser SDK places and receives calls from a web page. It is the caller or the callee, never
the flow, so it has no column here.
## Prepare to collect caller input
Start from working inbound call setup in [Make and receive calls][make-receive]: a SWML Script,
Relay Application, or Call Flow that a call can reach. This guide picks up once a call reaches your
flow. [How an incoming call reaches your code][how-incoming] explains why the same flow answers a
phone number, a SIP address, a browser call, or the Dashboard's **Click-to-Test** button. To pick a
voice for the questions, see [Speak text on a call][speak-text].
Have these values ready:
* Your Space URL, such as `<YOUR_SPACE>.signalwire.com`.
* For the Relay and REST paths, your Project ID and an API token from the Dashboard's
  [API credentials][api-credentials] page, with the **Voice** permission enabled. A hosted SWML
  script or a Call Flow needs no credentials.
* Python 3 or Node.js for the served SWML and Relay samples. A served document also needs the
  tunnel and basic auth password set up in [Answer a call via SWML][answer-swml].
Replace these placeholders in the samples. The hosted SWML and Call Flow Builder paths use none of
them.
| Value                        | Replace with        |
| `<YOUR_SPACE>`               | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                              |
| `<YOUR_PROJECT_ID>`          | Your Project ID        |
| `<YOUR_API_TOKEN>`           | Your API token, used only in server code                                             |
| `<YOUR_BASIC_AUTH_PASSWORD>` | A password you choose; SignalWire presents it when it fetches a served SWML document |
| `<YOUR_CALL_ID>`             | The ID of a call in progress, for the REST samples                                   |
| `<YOUR_STATUS_WEBHOOK_URL>`  | A public HTTPS URL on your server that accepts POST requests                         |
## Ask a question and branch on the answer
In every surface the pattern is the same: play a question, wait for input, compare the result, and
continue down one path. Bayview Taxi asks callers to say "booking" or "dispatch". Speech hints tell
the recognizer which words to expect, which makes short single-word replies reliable.
### Ask a question and branch via SWML
Three methods do the work. [`prompt`][swml-prompt] plays the question and waits. Setting any
speech parameter, such as `speech_hints`, switches it from keypad digits to speech; the recognized
text lands in the `prompt_value` variable and the outcome in `prompt_result`.
[`switch`][swml-switch] compares a variable against case keys and runs the matching list, or
`default` when nothing matches. [`transfer`][swml-transfer] jumps to another section and does not
return.
The `booking` and `dispatch` sections each speak a different line, and `no_match` catches
everything else. The [Server SDKs][server-sdks] build the document with the SWML builder and serve
it over HTTP; the YAML and JSON forms are what you paste into a hosted script. The builder's
methods append to `main`; the named sections go through the service.
#### Python — SWML builder
# Install: python -m pip install signalwire-sdk
# Save as collect_input.py and run: python collect_input.py
service = SWMLService(
    name="collect-input",
    route="/swml",
    port=3000,
    SWMLBuilder(service)
    .answer()
    .prompt(
        play=["say:Thanks for calling Bayview Taxi. Say booking or dispatch."],
        speech_hints=["booking", "dispatch"],
    .switch(
        variable="prompt_value",
        case={
            "booking": [{"transfer": {"dest": "booking"}}],
            "dispatch": [{"transfer": {"dest": "dispatch"}}],
        default=[{"transfer": {"dest": "no_match"}}],
# The builder appends to the main section. Named sections go through the service.
service.add_verb_to_section("booking", "play", {"url": "say:You said booking."})
service.add_verb_to_section("booking", "hangup", {})
service.add_verb_to_section("dispatch", "play", {"url": "say:You said dispatch."})
service.add_verb_to_section("dispatch", "hangup", {})
service.add_verb_to_section("no_match", "play", {"url": "say:Sorry, I didn't catch that. Goodbye."})
service.add_verb_to_section("no_match", "hangup", {})
service.serve()
#### TypeScript — SWML builder
```typescript
// Install: npm install @signalwire/sdk
// This sample also runs as JavaScript: save as collect-input.mjs,
// then run: node collect-input.mjs
  route: "/swml",
  port: 3000,
const swml = service.getBuilder();
swml
  .answer()
  .prompt({
    play: ["say:Thanks for calling Bayview Taxi. Say booking or dispatch."],
    speech_hints: ["booking", "dispatch"],
  .switch({
    variable: "prompt_value",
    case: {
      booking: [{ transfer: { dest: "booking" } }],
      dispatch: [{ transfer: { dest: "dispatch" } }],
    default: [{ transfer: { dest: "no_match" } }],
// The builder's verb methods append to the main section. Named sections use addVerbToSection.
swml.addVerbToSection("booking", "play", { url: "say:You said booking." });
swml.addVerbToSection("booking", "hangup", {});
swml.addVerbToSection("dispatch", "play", { url: "say:You said dispatch." });
swml.addVerbToSection("dispatch", "hangup", {});
swml.addVerbToSection("no_match", "play", { url: "say:Sorry, I didn't catch that. Goodbye." });
swml.addVerbToSection("no_match", "hangup", {});
await service.serve();
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - answer: {}
    - prompt:
        play:
          - "say:Thanks for calling Bayview Taxi. Say booking or dispatch."
        speech_hints:
          - booking
          - dispatch
    - switch:
        variable: prompt_value
        case:
          booking:
            - transfer:
                dest: booking
          dispatch:
            - transfer:
                dest: dispatch
        default:
          - transfer:
              dest: no_match
  booking:
    - play:
    - hangup: {}
  dispatch:
    - play:
    - hangup: {}
  no_match:
    - play:
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "answer": {} },
        "prompt": {
          "play": ["say:Thanks for calling Bayview Taxi. Say booking or dispatch."],
          "speech_hints": ["booking", "dispatch"]
        "switch": {
          "variable": "prompt_value",
          "case": {
            "booking": [{ "transfer": { "dest": "booking" } }],
            "dispatch": [{ "transfer": { "dest": "dispatch" } }]
          "default": [{ "transfer": { "dest": "no_match" } }]
    "booking": [
      { "play": { "url": "say:You said booking." } },
      { "hangup": {} }
    "dispatch": [
      { "play": { "url": "say:You said dispatch." } },
      { "hangup": {} }
    "no_match": [
      { "play": { "url": "say:Sorry, I didn't catch that. Goodbye." } },
      { "hangup": {} }
`switch` compares the whole value exactly. SignalWire lowercases recognized speech and strips its
punctuation before storing it in `prompt_value`, so "Booking." still matches the `booking` case,
but "booking please" does not.
Run the program and point an External URL SWML Script at it through your tunnel, or paste the YAML
or JSON into a Hosted Script, as in [Create the SWML Script][create-swml-script]. To put dispatch
callers through to a person instead of playing a line, the `dispatch` section can
[connect the call to a phone][forward-swml].
Then open the Resource under **My Resources** and select **Click-to-Test**, under the Resource's
name. A new tab opens, shows "Connecting", and places a browser call to the Resource. Allow
microphone access if the browser asks. Call three times: say "booking", say "dispatch", and say
nothing. You hear a different line each time.
If you don't, match the symptom:
* **The call connects but stays silent.** The flow never ran. [Answer a call via SWML][answer-swml]
  shows how to confirm that SignalWire can fetch a served document and that the Resource points at
  it.
* **Every call ends in the `no_match` line.** The recognized text did not equal a case key.
  [Track what the flow heard](#track-what-the-flow-heard) shows the text SignalWire stored.
* **Click-to-Test is disabled.** It appears only on Resources that handle calls and have an
  address. Open the Resource's **Addresses & Phone Numbers** tab and add an alias.
### Ask a question and branch via WebSocket (Relay)
The [Server SDKs][server-sdks] expose the prompt as `play_and_collect` on the call. It plays the
question and resolves when input arrives, times out, or fails. The result carries a `type` of
`speech`, `digit`, `no_input`, `no_match`, or `error`, and for speech the recognized `text` with a
`confidence` score. Your code compares the text and continues.
#### Python — Relay client
# Save as collect_input_relay.py and run: python collect_input_relay.py
client = RelayClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
    contexts=["default"],
@client.on_call
async def handle_call(call):
    await call.answer()
    action = await call.play_and_collect(
        media=[{"type": "tts", "params": {"text": "Thanks for calling Bayview Taxi. Say booking or dispatch."}}],
        collect={"speech": {"hints": ["booking", "dispatch"], "language": "en-US"}},
    event = await action.wait()
    result = event.params.get("result", {})
    heard = ""
    if result.get("type") == "speech":
        heard = result.get("params", {}).get("text", "").lower()
    if "booking" in heard:
        reply = "You said booking."
    elif "dispatch" in heard:
        reply = "You said dispatch."
    else:
        reply = "Sorry, I didn't catch that. Goodbye."
        if call.state != "ended":
            await call.hangup()
    await call.play(
        [{"type": "tts", "params": {"text": reply}}],
    await call.wait_for_ended()
client.run()
```typescript
// Save as collect-input-relay.mts and run: npx tsx collect-input-relay.mts
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
  contexts: ["default"],
client.onCall(async (call) => {
  await call.answer();
  const action = await call.playAndCollect(
    [{ type: "tts", text: "Thanks for calling Bayview Taxi. Say booking or dispatch." }],
    { speech: { hints: ["booking", "dispatch"], language: "en-US" } },
  const event = await action.wait();
  const result = (event.params.result ?? {}) as {
    type?: string;
    params?: { text?: string };
  const heard = result.type === "speech" ? (result.params?.text ?? "").toLowerCase() : "";
  let reply = "Sorry, I didn't catch that. Goodbye.";
  if (heard.includes("booking")) reply = "You said booking.";
  else if (heard.includes("dispatch")) reply = "You said dispatch.";
  await call.play([{ type: "tts", text: reply }], {
    onCompleted: async () => {
  await call.waitForEnded();
await client.run();
Because the comparison runs in your code, you can match loosely: `"booking" in heard` accepts
"booking please" as well as "booking". To put dispatch callers through to a person,
[connect the call to a phone][forward-relay] instead of playing the reply.
Run the client and create a Relay Application Resource whose **Topic** is `default`, the value in
the client's `contexts`, as in [Answer a call via WebSocket (Relay)][answer-relay]. Then open the
Resource under **My Resources**, select **Click-to-Test**, and call three times to hear the three
outcomes. If the client logs an authentication error at startup, the project, token, and Space do
not belong together. If the call connects but stays silent, check that the client process is still
running and that the Resource's **Topic** matches its `contexts`.
Over REST, the same collect runs as the `calling.collect` command on a call you already hold the
ID for, such as one a hosted script answered. REST can't play the question and collect in one
command, so [speak the question with `calling.play`][speak-rest] first, and send the collect once
playback finishes with `start_input_timers` set to `true`. Without it, the wait for input doesn't
start until you send `calling.collect.start_input_timers`. The reply arrives at `status_url` as a
`calling.call.collect` event instead of a return value, and `control_id` names the collect so you
can match the event to it.
#### Python — REST client
# Save as collect_rest.py and run: python collect_rest.py
client = RestClient(
# collect() has no status_url or start_input_timers argument; extras adds them to the command's params.
client.calling.collect(
    "<YOUR_CALL_ID>",
    control_id="collect-1",
    speech={"hints": ["booking", "dispatch"], "language": "en-US"},
    extras={"status_url": "<YOUR_STATUS_WEBHOOK_URL>", "start_input_timers": True},
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as collect-rest.mjs,
// then run: node collect-rest.mjs
// collect() has no status_url or start_input_timers option; extras adds them to the command's params.
await client.calling.collect("<YOUR_CALL_ID>", {
  control_id: "collect-1",
  speech: { hints: ["booking", "dispatch"], language: "en-US" },
  extras: { status_url: "<YOUR_STATUS_WEBHOOK_URL>", start_input_timers: true },
#### cURL — Calling API
```bash
# Runs against a call that is already answered; play the question first with calling.play.
curl --request POST "https://<YOUR_SPACE>.signalwire.com/api/calling/calls" \
  --user "<YOUR_PROJECT_ID>:<YOUR_API_TOKEN>" \
  --header "Content-Type: application/json" \
  --data '{
    "id": "<YOUR_CALL_ID>",
    "command": "calling.collect",
    "params": {
      "control_id": "collect-1",
      "speech": { "hints": ["booking", "dispatch"], "language": "en-US" },
      "start_input_timers": true,
The [Calling API reference][rest-calling] documents every `calling.collect` field, and the
[collect status callback reference][collect-webhook] the event that reaches `status_url`.
### Ask a question and branch via Call Flow Builder
Open **Tools** > **Call Flow Builder** in the Dashboard, select **Add New**, name the flow, and
select **Save**. Open the flow's **More Options** menu and select **Edit** to reach the canvas.
Every flow starts from the **Handle Call** node. Connect these nodes in order:
1. [**Answer Call**][cfb-answer].
2. [**Gather Input**][cfb-gather], with "Thanks for calling Bayview Taxi. Say booking or dispatch."
   as its Text to Speech. Every input option pairs a key with a word: add one option with
   **Caller presses** `1` and **Or says** `booking`, and a second with `2` and `dispatch`. The node
   grows one output connector per option, plus **Unknown** and **No Input**.
3. A [**Play Audio or TTS**][cfb-play] node on each option's connector, with the matching line,
   and a [**Hangup Call**][cfb-hangup] node after each. To put dispatch callers through to a
   person, use a [**Forward to Phone**][cfb-forward] node instead.
Leave **Unknown** and **No Input** for the next task. Select **Deploy** to make this version the
live one; the [versioning guide][cfb-version] explains how deployed and draft versions relate. A
deployed Call Flow is a Resource under **My Resources**, so **Click-to-Test** works here too: call
three times and hear the three outcomes.
## Handle silence and unmatched speech
A caller who says nothing, or whose words the recognizer could not make out, must still get an
answer. Each surface reports the two cases separately, so the flow can say something different for
each. A reply the recognizer did understand comes back as text whether or not it is one of your
words, so an off-menu reply is caught by your comparison, not by these cases.
### Handle silence and unmatched speech via SWML
After `prompt`, `prompt_result` is `match_speech`, `no_input`, `no_match`, or `failed`, and
`match_digits` once keypad input is enabled. `match_speech` means the recognizer returned text, not
that the text is one of your cases. The `default` case already routes everything but a
match to `no_match`; this change makes that section say which one happened, using a JavaScript
expression inside the spoken text. Only the `no_match` section changes.
```python {1-6}
    "no_match",
    "play",
    {"url": "say:${prompt_result == 'no_input' ? \"I didn't hear anything.\" : \"I didn't understand that.\"} Goodbye."},
```typescript {1-4}
  url: "say:${prompt_result == 'no_input' ? \"I didn't hear anything.\" : \"I didn't understand that.\"} Goodbye.",
#### YAML
```yaml {3}
  no_match:
    - play:
    - hangup: {}
#### JSON
```json {2}
    "no_match": [
      { "play": { "url": "say:${prompt_result == 'no_input' ? \"I didn't hear anything.\" : \"I didn't understand that.\"} Goodbye." } },
      { "hangup": {} }
The wait for input before `no_input` is five seconds by default; `prompt.initial_timeout` changes
it.
### Handle silence and unmatched speech via WebSocket (Relay)
The collect result's `type` is `no_input` when the caller stayed silent. Anything the recognizer
transcribes comes back as `speech`, whether or not it's one of your words, so your comparison
catches an off-menu reply. `no_match` means the recognizer returned no text at all. Replace the
reply selection in the Relay sample:
```python {1-8}
    elif result.get("type") == "no_input":
        reply = "I didn't hear anything. Goodbye."
    else:
        reply = "I didn't understand that. Goodbye."
```typescript {1-4}
  let reply = "I didn't understand that. Goodbye.";
  else if (result.type === "no_input") reply = "I didn't hear anything. Goodbye.";
### Handle silence and unmatched speech via Call Flow Builder
Connect the **Gather Input** node's **No Input** connector to a **Play Audio or TTS** node that
says "I didn't hear anything. Goodbye.", and its **Unknown** connector to one that says "I didn't
understand that. Goodbye." Connect both to a **Hangup Call** node and select **Deploy**.
## Track what the flow heard
Three places show what happened on the call: the Dashboard's call log, a webhook you host, and the
Relay client's own event stream.
### See the flow's steps in the Dashboard
Open **Logs** > **Voice** in the Dashboard and select the most recent call. The call's timeline
lists each step the flow ran in order: the call state changes, a **Play** entry for each spoken
line, and a **Collect** entry for the prompt. Select an entry to see its details. A document that
fails to load or contains an invalid method shows a **Script Warning** or **Error** entry with the
reason, so a broken flow is visible here without a support ticket.
The timeline records that input was collected, not what the caller said. For the recognized text
itself, use one of the two paths below.
### Receive the result via SWML
Add a `status_url` to the `prompt` method. SignalWire sends a `calling.call.collect` event to that
URL when input arrives, and `calling.call.play` events to the same URL as the question plays, so
check `event_type` before reading `params.result`. The same collect event reaches the `status_url`
on a REST `calling.collect` command.
```python {4}
    .prompt(
```typescript {4}
  .prompt({
#### YAML
```yaml {5}
    - prompt:
        play:
        speech_hints: [booking, dispatch]
#### JSON
```json {5}
        "prompt": {
          "speech_hints": ["booking", "dispatch"],
The POST body for a recognized reply looks like this. `params.result.type` is `no_input` or
`no_match` for the failure cases, with no `params.result.params`.
```json
  "event_type": "calling.call.collect",
  "event_channel": "swml:...",
  "timestamp": 1757971200.123,
  "project_id": "<YOUR_PROJECT_ID>",
  "space_id": "...",
  "params": {
    "call_id": "<YOUR_CALL_ID>",
    "node_id": "...",
    "control_id": "...",
    "result": {
      "type": "speech",
      "params": {
        "text": "dispatch",
        "confidence": 0.94
The [collect status callback reference][collect-webhook] documents every field of the event, and
the [`prompt` reference][swml-prompt] the play events that reach the same URL.
```mermaid
sequenceDiagram
    participant Caller
    participant SW as SignalWire
    participant Srv as Your server
    SW->>Caller: prompt plays: say booking or dispatch
    Caller->>SW: says "dispatch"
    Note over SW: prompt_value is dispatch, switch runs the dispatch branch
    par The flow does not wait for the webhook
        SW->>Srv: POST status_url: calling.call.collect, type speech, text, confidence
        Srv-->>SW: 200 OK
    and
        SW->>Caller: dispatch branch plays
    end
### Receive the result via WebSocket (Relay)
The Relay client already holds the result: it is the event that `action.wait()` returned. To log
every collect event as it happens, register a handler on the call before starting the prompt. The
[Server SDKs][server-sdks] document the fields of every call event.
```python {1-4}
    def log_collect(event):
        print("collect:", event.params.get("result"))
    call.on("calling.call.collect", log_collect)
```typescript {1-3}
  call.on("calling.call.collect", (event) => {
    console.log("collect:", event.params.result);
```mermaid
sequenceDiagram
    participant Caller
    participant App as Your Relay client
    Caller->>SW: calls the Resource address
    SW->>App: call arrives on topic default
    App->>SW: answer, play_and_collect
    SW-->>App: calling.call.collect: type speech, text
    Note over App: wait() returns, your code branches
    App->>SW: play reply, then hangup
### Compare the surfaces
| Surface           | Where the recognized text shows up                                    | How silence and unrecognized speech are reported |
| SWML              | `prompt_value` inside the document; the `status_url` webhook          | `prompt_result` is `no_input` or `no_match`      |
| WebSocket (Relay) | The `result` on the event `action.wait()` returns; `call.on` handlers | `result.type` is `no_input` or `no_match`        |
| REST              | The `status_url` webhook only                                         | `params.result.type` is `no_input` or `no_match` |
| Call Flow Builder | The `%{prompt_value}` variable in any later node                      | The **No Input** and **Unknown** connectors      |
The Dashboard's call log shows that a Collect step ran, for every surface, but not its outcome and
never the text.
## Examples
### Accept a keypad digit as well as speech
Some callers are in a noisy place or on a handset that makes speaking awkward. Offer keys and
words at once, and treat "press 1" and "say booking" as the same answer.
#### Accept a keypad digit as well as speech via SWML
Setting one digit parameter alongside the speech parameters enables both inputs. `max_digits`
joins the prompt, and the digit keys join the switch.
    route="/swml",
    port=3000,
    .answer()
    .prompt(
        play=["say:Thanks for calling Bayview Taxi. Say booking or press 1. Say dispatch or press 2."],
        max_digits=1,
    .switch(
        case={
            "1": [{"transfer": {"dest": "booking"}}],
            "2": [{"transfer": {"dest": "dispatch"}}],
service.serve()
```typescript
  route: "/swml",
  port: 3000,
swml
  .answer()
  .prompt({
    play: ["say:Thanks for calling Bayview Taxi. Say booking or press 1. Say dispatch or press 2."],
    max_digits: 1,
  .switch({
    case: {
      "1": [{ transfer: { dest: "booking" } }],
      "2": [{ transfer: { dest: "dispatch" } }],
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - answer: {}
    - prompt:
        play:
          - "say:Thanks for calling Bayview Taxi. Say booking or press 1. Say dispatch or press 2."
        max_digits: 1
        speech_hints:
          - booking
          - dispatch
    - switch:
        case:
          booking:
            - transfer:
                dest: booking
          "1":
            - transfer:
                dest: booking
          dispatch:
            - transfer:
                dest: dispatch
          "2":
            - transfer:
                dest: dispatch
        default:
          - transfer:
              dest: no_match
  booking:
    - play:
    - hangup: {}
  dispatch:
    - play:
    - hangup: {}
  no_match:
    - play:
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "answer": {} },
        "prompt": {
          "play": ["say:Thanks for calling Bayview Taxi. Say booking or press 1. Say dispatch or press 2."],
          "max_digits": 1,
        "switch": {
          "case": {
            "1": [{ "transfer": { "dest": "booking" } }],
            "dispatch": [{ "transfer": { "dest": "dispatch" } }],
            "2": [{ "transfer": { "dest": "dispatch" } }]
    "booking": [
      { "hangup": {} }
    "dispatch": [
      { "hangup": {} }
    "no_match": [
      { "hangup": {} }
#### Accept a keypad digit as well as speech via WebSocket (Relay)
Pass both `digits` and `speech` in the collect config. A keypad reply comes back with type
`digit` and the pressed key in `params.digits`, so the code maps keys to the same words.
BY_KEY = {"1": "booking", "2": "dispatch"}
@client.on_call
    await call.answer()
        media=[{"type": "tts", "params": {"text": "Thanks for calling Bayview Taxi. Say booking or press 1. Say dispatch or press 2."}}],
        collect={"digits": {"max": 1}, "speech": {"hints": ["booking", "dispatch"], "language": "en-US"}},
    heard = ""
    if result.get("type") == "digit":
        heard = BY_KEY.get(result.get("params", {}).get("digits", ""), "")
    elif result.get("type") == "speech":
    else:
            await call.hangup()
    await call.play(
client.run()
```typescript
const byKey: Record<string, string> = { "1": "booking", "2": "dispatch" };
    [{ type: "tts", text: "Thanks for calling Bayview Taxi. Say booking or press 1. Say dispatch or press 2." }],
    { digits: { max: 1 }, speech: { hints: ["booking", "dispatch"], language: "en-US" } },
    type?: string;
    params?: { text?: string; digits?: string };
  let heard = "";
  if (result.type === "digit") heard = byKey[result.params?.digits ?? ""] ?? "";
  else if (result.type === "speech") heard = (result.params?.text ?? "").toLowerCase();
await client.run();
#### Accept a keypad digit as well as speech via Call Flow Builder
The flow you built already accepts both, because every **Gather Input** option carries a
**Caller presses** key as well as an **Or says** word. Change the prompt text to mention the keys
### Ask again when the caller says nothing
One retry turns a dead end into a second chance. Ask the question again after silence, then give
up.
#### Ask again when the caller says nothing via SWML
[`goto`][swml-goto] jumps to a label within the same section, and its `when` condition and `max`
count keep the loop bounded. A `label` before the prompt and a conditional `goto` after it repeat
the question once. The [control flow guide][control-flow] compares `goto` with `execute` and
`transfer`.
```typescript
  route: "/swml",
  port: 3000,
swml
  .answer()
  // The Python SDK's builder can't emit label, whose value is a bare string rather than an object;
  // from Python, paste the YAML or JSON tab into a hosted script.
  .label("ask")
  .prompt({
  .goto({ label: "ask", when: "prompt_result == 'no_input'", max: 1 })
  .switch({
    case: {
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - answer: {}
    - label: ask
    - prompt:
        play:
        speech_hints:
          - booking
          - dispatch
    - goto:
        label: ask
        max: 1
    - switch:
        case:
          booking:
            - transfer:
                dest: booking
          dispatch:
            - transfer:
                dest: dispatch
        default:
          - transfer:
              dest: no_match
  booking:
    - play:
    - hangup: {}
  dispatch:
    - play:
    - hangup: {}
  no_match:
    - play:
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "answer": {} },
      { "label": "ask" },
        "prompt": {
        "goto": {
          "label": "ask",
          "when": "prompt_result == 'no_input'",
          "max": 1
        "switch": {
          "case": {
    "booking": [
      { "hangup": {} }
    "dispatch": [
      { "hangup": {} }
    "no_match": [
      { "hangup": {} }
#### Ask again when the caller says nothing via WebSocket (Relay)
A loop around the prompt exits on the first reply of any kind and gives up after two silent
attempts.
@client.on_call
    await call.answer()
    result = {}
    for _attempt in range(2):
        if result.get("type") != "no_input":
            break
    heard = ""
    else:
            await call.hangup()
    await call.play(
client.run()
```typescript
type CollectResult = { type?: string; params?: { text?: string } };
  let result: CollectResult = {};
  for (let attempt = 0; attempt < 2; attempt++) {
    result = (event.params.result ?? {}) as CollectResult;
    if (result.type !== "no_input") break;
await client.run();
#### Ask again when the caller says nothing via Call Flow Builder
A counter bounds the loop. Route the **Gather Input** node's **No Input** connector to a
[**Set Variables**][cfb-set-variables] node that sets `count` to `%{count} + 1`, then to a
[**Conditions**][cfb-conditions] node with the condition `%{count} > 1`. Connect the condition's
connector to a **Hangup Call** node, and **Else** to a **Play Audio or TTS** node that says "I
didn't hear anything." and leads back to **Gather Input**. The Gather Input reference builds the
same flow in [Input with infinite loop prevention][cfb-gather-loop].
## Next steps
#### [Speak text on a call](/docs/platform/voice/speak-text)
Pick a voice for the questions, and speak on a call in progress over REST.
#### [Forward calls](/docs/platform/voice/forward-calls)
Connect the branch the caller chose to a phone, and play a message when nobody answers.
#### [Make and receive calls](/docs/platform/voice/make-and-receive-calls)
Point a phone number at this flow, or place the call yourself and run the flow once the
destination answers.
#### [Call Flow Builder](/docs/call-flow-builder)
Every node the visual editor offers, including request, recording, and AI agent nodes.
