> This page is for Platform.
# Stream call audio
> Stream a live call to your own WebSocket server with SWML, Relay, or REST, then save or process the audio as it arrives, and play audio back into the call on a bidirectional stream.
[prepare-calls]: /docs/platform/voice/make-and-receive-calls#prepare-for-your-first-call
[place-relay]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-websocket-relay
[relay-guide]: /docs/server-sdks/guides/relay-client
[swml-intro]: /docs/swml
[stream-status-callback]: /docs/apis/rest/webhooks/stream-status-callback
[swml-stream]: /docs/swml/reference/calling/stream
[swml-stop-stream]: /docs/swml/reference/calling/stop-stream
[swml-connect]: /docs/swml/reference/calling/connect
[swml-answer]: /docs/swml/reference/calling/answer
[sip-addresses]: /docs/platform/addresses#sip-addresses
[swml-join-conference]: /docs/swml/reference/calling/join-conference
Call streaming sends the audio of a live call to a WebSocket server you run, so your app can
transcribe, analyze, record, or answer it in near real time. Start by streaming a call to your own
phone into a small server that prints what arrives, then save or process the audio, and talk back to
the caller on a bidirectional stream.
## Choose an approach
Each approach starts and stops streams in its own way. All of them stream to the same kind of
WebSocket server, so the server code on this page works with every approach. Follow the section for
your app's approach:
* [SWML][swml-intro]: answer calls to your number with a document your server serves. Add `stream`
  for a one-way stream, or `connect` the call to your server for a bidirectional stream. Optionally
  send stream events to a webhook.
* [WebSocket (Relay)][relay-guide]: start and stop a stream from code that holds a connection to
  the call. Stream events arrive in your code, so no webhook is needed.
* [REST](#stream-a-call-already-in-progress-via-rest): start and stop a one-way stream by call ID
  from any process.
## Prepare for streaming
Start with working call setup from [Make and receive calls][make-and-receive-calls]. Have these
values ready:
* Your Space URL, such as `<YOUR_SPACE>.signalwire.com`.
* Your Project ID and an API token with the **Voice** permission.
* A phone number in your Space, and a phone you can call it from and answer.
* A machine that can run a small server, and a tunnel such as [ngrok](https://ngrok.com/) that
  gives it a public URL.
> **Stream URLs must use wss\://**
> SignalWire connects to your server over a secure WebSocket only, and rejects a plain `ws://` URL.
> During development, run the server locally and put a TLS tunnel in front of it, as
> [Run a WebSocket server](#run-a-websocket-server) shows.
> **Trial projects only call and receive calls from verified numbers**
> A [trial project][trial-mode] only places calls to and receives calls from numbers you've
> purchased or verified, and can't call internationally. [Prepare for your first call][prepare-calls]
> shows how to verify the phone you'll test with.
| Value                        | Replace with        |
| `<YOUR_SPACE>`               | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                                                         |
| `<YOUR_PROJECT_ID>`          | Your Project ID        |
| `<YOUR_API_TOKEN>`           | Your API token with the Voice permission, used only in server code                                              |
| `<YOUR_PUBLIC_HOST>`         | The public hostname of your server's tunnel        |
| `<YOUR_AUDIO_STREAM_URL>`    | Your server's stream URL, `wss://<YOUR_PUBLIC_HOST>/stream`                                                     |
| `<YOUR_BASIC_AUTH_PASSWORD>` | A password you choose for the SWML your server serves                                                           |
| `<YOUR_CALLER_ID>`           | Your SignalWire phone number, or a [verified caller ID][caller-id], in E.164 format, when Relay places the call |
| `<YOUR_DESTINATION>`         | The phone you'll answer, in E.164 format, when Relay places the call                                            |
| `<YOUR_CALL_ID>`             | The ID of a live call, when you start a stream over REST                                                        |
## How call streaming works
When a stream starts, SignalWire opens a WebSocket connection to your server and sends it the
call's audio as the call happens, in 20 ms frames. What happens to the audio next is up to your
server. It can:
* [Save it to a file](#save-call-audio-to-a-file), as a recording you control.
* [Forward it to another service](#buffer-audio-for-processing), such as a speech-to-text or
  sentiment API, and act on what comes back.
* [Send audio back into the call](#send-audio-back-on-a-bidirectional-stream), such as a recorded
  prompt or the output of a voice agent.
Sending audio back needs a bidirectional stream. A one-way stream gives your server a copy of the
call's audio while the call carries on as normal, and anything your server sends is ignored. A
bidirectional stream connects the call to your server as if the server were the other party: the
caller hears what your server sends, and the call stays connected to your server until your server
closes the connection or the call ends.
SignalWire sends the same messages whichever approach starts the stream, so one server works with
all of them. A call can run several one-way streams at once, each with its
own `control_id`.
## Run a WebSocket server
Every stream in this guide connects to a server you run, at the `/stream` path. Start with one that
prints what arrives, so you can see a stream working before you write any processing code.
#### Run the stream server
This server prints the call's ID and the stream's format when the stream starts, then a line for
each second of audio it receives on each track.
#### Python — FastAPI
# Install: python -m pip install fastapi "uvicorn[standard]"
# Save as stream_server.py and run: python stream_server.py
import json
import uvicorn
from fastapi import FastAPI, WebSocket
app = FastAPI()
FRAMES_PER_SECOND = 50  # each media message carries 20 ms of audio
@app.websocket("/stream")
async def stream(websocket: WebSocket):
    await websocket.accept()
    frames = {}
    async for message in websocket.iter_text():
        event = json.loads(message)
        if event["event"] == "start":
            start = event["start"]
            media_format = start["mediaFormat"]
            print(f"Stream started for call {start['callSid']}: tracks {start['tracks']}, "
                  f"{media_format['encoding']} at {media_format['sampleRate']} Hz")
        elif event["event"] == "media":
            track = event["media"]["track"]
            frames[track] = frames.get(track, 0) + 1
            if frames[track] % FRAMES_PER_SECOND == 0:
                print(f"{track}: {frames[track] // FRAMES_PER_SECOND} s of audio")
        elif event["event"] == "stop":
            print("Stream stopped")
uvicorn.run(app, host="0.0.0.0", port=8080)
#### JavaScript — ws
```javascript
// Install: npm install ws
// Save as stream-server.mjs and run: node stream-server.mjs
import { WebSocketServer } from "ws";
const FRAMES_PER_SECOND = 50; // each media message carries 20 ms of audio
const streams = new WebSocketServer({ port: 8080, path: "/stream" });
console.log("Listening on port 8080");
streams.on("connection", (socket) => {
  const frames = new Map();
  socket.on("message", (data) => {
    const event = JSON.parse(data.toString());
    if (event.event === "start") {
      const { callSid, tracks, mediaFormat } = event.start;
      console.log(`Stream started for call ${callSid}: tracks ${tracks}, ` +
        `${mediaFormat.encoding} at ${mediaFormat.sampleRate} Hz`);
    } else if (event.event === "media") {
      const track = event.media.track;
      const count = (frames.get(track) ?? 0) + 1;
      frames.set(track, count);
      if (count % FRAMES_PER_SECOND === 0) {
        console.log(`${track}: ${count / FRAMES_PER_SECOND} s of audio`);
    } else if (event.event === "stop") {
      console.log("Stream stopped");
#### Give the server a public URL
In a second terminal, put a tunnel in front of port `8080`:
```bash
ngrok http 8080
ngrok prints an `https://` **Forwarding** URL. Its hostname is your `<YOUR_PUBLIC_HOST>`, and your
`<YOUR_AUDIO_STREAM_URL>` is `wss://<YOUR_PUBLIC_HOST>/stream`. Keep the server and the tunnel
running while you test; a new tunnel usually means a new hostname.
### Run an echo server for bidirectional streams
A bidirectional stream needs a server that sends audio back. This one returns each `media` payload
unchanged, so the caller hears their own voice a moment later. It confirms that audio flows in both
directions before you plug in a real speech pipeline. Run it in place of the stream server, on the
same port and tunnel, when you reach a "Talk back" section.
# Save as echo_server.py and run: python echo_server.py
import json
import uvicorn
app = FastAPI()
    stream_sid = None
            stream_sid = event["start"]["streamSid"]
            print(f"Echoing stream {stream_sid}")
            await websocket.send_text(json.dumps({
                "event": "media",
                "streamSid": stream_sid,
                "media": {"payload": event["media"]["payload"]},
```javascript
// Save as echo-server.mjs and run: node echo-server.mjs
  let streamSid;
      streamSid = event.start.streamSid;
      console.log(`Echoing stream ${streamSid}`);
      socket.send(JSON.stringify({
        event: "media",
        streamSid,
        media: { payload: event.media.payload },
## Stream call audio via SWML
SWML has two ways to stream a call, one for each type of stream:
* To record, transcribe, or analyze a call while it carries on as normal, use
  [`stream`][swml-stream]. It starts a one-way stream and moves on to the next method at once, so
  the rest of the document runs while audio streams.
* To put your own voice agent or speech pipeline on the call, use [`connect`][swml-connect] with
  `to` set to `stream:<URL>`. It bridges the call to your server for a bidirectional stream, and
  the document waits there until the stream ends.
### Stream a call via SWML
When someone calls your number, SignalWire fetches the call's SWML from your server and runs it.
Your server can serve that document and accept the stream on the same port, so the one tunnel from
[Run a WebSocket server](#run-a-websocket-server) covers both.
#### Serve the SWML from your server
Stop the stream server and run this one in its place. It's the same stream server, plus a SWML
document at its root URL that streams the call, keeps it open for twenty seconds while you talk,
and says goodbye. The document is served only to requests that carry the username `signalwire`
and the password you set.
#### Python — SWML builder
# Save as stream_app.py and run: python stream_app.py
import json
import uvicorn
service = SWMLService(
    name="stream-call",
    schema_validation=False,
swml = SWMLBuilder(service)
service.add_verb("stream", {"url": "<YOUR_AUDIO_STREAM_URL>"})
swml.say("Your call is being streamed. Say a few words.").sleep(20000).say("Goodbye.")
app = FastAPI()
# SignalWire fetches the call's SWML from the server's root URL.
app.include_router(service.as_router())
# SignalWire streams the call's audio to /stream.
    frames = {}
#### JavaScript — SWML builder
```javascript
// Install: npm install @signalwire/sdk@2.0.5 @hono/node-server ws
// Save as stream-app.mjs and run: node stream-app.mjs
import { serve } from "@hono/node-server";
const swml = service.getBuilder();
swml.addVerb("stream", { url: "<YOUR_AUDIO_STREAM_URL>" });
swml.say("Your call is being streamed. Say a few words.").sleep(20000).say("Goodbye.");
// SignalWire fetches the call's SWML from the server's root URL.
const server = serve({ fetch: service.getApp().fetch, port: 8080 });
// SignalWire streams the call's audio to /stream.
const streams = new WebSocketServer({ server, path: "/stream" });
The [Server SDKs][server-sdks] build the document with the SWML builder and serve it through
`SWMLService`, which your app mounts next to its `/stream` route. Check that the document is
reachable through the tunnel:
```bash
curl -u "signalwire:<YOUR_BASIC_AUTH_PASSWORD>" "https://<YOUR_PUBLIC_HOST>/"
The response is the SWML document, starting with `{"version": "1.0.0"`. A `401` means the password
doesn't match the one in your server.
#### Point your phone number at the server
Create a SWML Script that fetches the document from your server:
1. Open **My Resources**, select **+ Add**, then **Script**, then **SWML Script**.
2. Name it **Stream call** and leave **Used For** set to **Calling**.
3. Under **Handle Calls Using**, choose **External URL** and enter
   `https://signalwire:<YOUR_BASIC_AUTH_PASSWORD>@<YOUR_PUBLIC_HOST>/` in **Primary Script URL**.
4. Select **Create**.
Then assign the script to your phone number:
Open **Phone Numbers**, select the number, and select **Edit Settings**. Under **Inbound Call
Settings**, select **Assign Resource**, choose the Resource, and save. To assign from the Resource
instead, open its **Addresses & Phone Numbers** tab, select **+ Add**, then **Phone Number**, and
pick a number you own.
To do both in code, see [Answer a call via SWML][answer-swml].
#### Call your number and speak
Call your SignalWire number from your phone and say a few words. The server prints a `started`
line as the call connects, then a line for each second of audio:
```text
Stream started for call 76ac3c36-56da-4a3e-a0d6-b5f8df6da9ad: tracks ['inbound'], audio/x-mulaw at 8000 Hz
inbound: 1 s of audio
inbound: 2 s of audio
After twenty seconds you hear "Goodbye.", the call ends, and the server prints `Stream stopped`.
The stream carries only the `inbound` track, your voice, until you
[choose other tracks](#stream-options-track-and-custom-parameters). If it doesn't work, see
[Troubleshoot call streaming](#troubleshoot-call-streaming).
The same document in YAML, to paste into a hosted SWML Script instead:
```yaml
version: 1.0.0
sections:
  main:
    - stream:
        url: <YOUR_AUDIO_STREAM_URL>
    - play:
        url: say:Your call is being streamed. Say a few words.
    - sleep: 20000
    - play:
        url: say:Goodbye.
### Talk back on a bidirectional stream via SWML
This document plays an announcement, connects the call to your server's `/stream` route, and hangs
up once your server closes the connection. In your SWML server, replace the document with this one,
and the `/stream` handler with the [echo server's](#run-an-echo-server-for-bidirectional-streams).
Set `to` to your stream URL with a `stream:` prefix. The stream's settings, such as `codec`,
`realtime`, and `name`, sit alongside `to`.
**`Python — SWML builder`**
```python title="Python — SWML builder"
    swml.say("You are connected to the echo server. Speak, and you will hear yourself.")
    .connect(to="stream:<YOUR_AUDIO_STREAM_URL>", codec="PCMU", realtime=True, name="echo")
    .hangup()
**`JavaScript — SWML builder`**
```javascript title="JavaScript — SWML builder"
swml
  .connect({ to: "stream:<YOUR_AUDIO_STREAM_URL>", codec: "PCMU", realtime: true, name: "echo" })
  .hangup();
**`YAML`**
```yaml title="YAML"
version: 1.0.0
sections:
  main:
    - play:
        url: say:You are connected to the echo server. Speak, and you will hear yourself.
    - connect:
        to: stream:<YOUR_AUDIO_STREAM_URL>
        codec: PCMU
        realtime: true
    - hangup: {}
**`JSON`**
```json title="JSON"
  "version": "1.0.0",
  "sections": {
    "main": [
      { "play": { "url": "say:You are connected to the echo server. Speak, and you will hear yourself." } },
        "connect": {
          "to": "stream:<YOUR_AUDIO_STREAM_URL>",
          "codec": "PCMU",
          "realtime": true,
          "name": "echo"
      { "hangup": {} }
Call your number and speak. You hear the announcement, then your own voice echoed back a moment
after you say each word. Hang up to end the call; the server prints `Stream stopped`.
When your server closes the connection, `connect` finishes and the document continues with the
next method, here `hangup`. Put a `play` or any other method there to keep the call going instead.
To stream a whole conference in both directions, give [`join_conference`][swml-join-conference] a
`stream` object; its reference lists the settings it accepts.
### Stop a stream via SWML
A one-way stream runs until the call ends unless you stop it. Give `stream` a `control_id`, and
run [`stop_stream`][swml-stop-stream] with the same value when your server has what it needs. In
your SWML server, replace the document lines with these to stop the stream after twenty seconds and
keep the call open:
```python title="Python — SWML builder" {1,3}
service.add_verb("stream", {"url": "<YOUR_AUDIO_STREAM_URL>", "control_id": "my-stream"})
service.add_verb("stop_stream", {"control_id": "my-stream"})
swml.say("The stream has stopped. Goodbye.")
```javascript title="JavaScript — SWML builder" {1,3}
swml.addVerb("stream", { url: "<YOUR_AUDIO_STREAM_URL>", control_id: "my-stream" });
swml.say("Your call is being streamed. Say a few words.").sleep(20000);
swml.addVerb("stop_stream", { control_id: "my-stream" });
swml.say("The stream has stopped. Goodbye.");
**`YAML`**
```yaml title="YAML" {6,10-11}
version: 1.0.0
sections:
  main:
    - stream:
        control_id: my-stream
    - play:
    - sleep: 20000
    - stop_stream:
    - play:
        url: say:The stream has stopped. Goodbye.
**`JSON`**
```json title="JSON" {8,13}
  "version": "1.0.0",
  "sections": {
    "main": [
        "stream": {
      { "play": { "url": "say:Your call is being streamed. Say a few words." } },
      { "sleep": 20000 },
      { "stop_stream": { "control_id": "my-stream" } },
      { "play": { "url": "say:The stream has stopped. Goodbye." } }
The server prints `Stream stopped` before you hear "The stream has stopped." Omit `control_id` in
both places to stop the most recently started stream. A bidirectional stream has no `stop_stream`;
your server ends it by closing the connection.
### Track a stream via SWML
Add `status_url` to `stream` to receive a JSON webhook when the stream starts and another when it
finishes. On a `stream:` `connect`, `status_url` must be an `https://` URL; it is notified only if
the stream connects. See the [webhooks guide][webhooks] for endpoint setup and testing.
| Webhook field       | Value                                               |
| `event_type`        | `calling.call.stream`                               |
| `params.call_id`    | The call ID                                         |
| `params.control_id` | The stream's `control_id`                           |
| `params.state`      | `streaming` when the stream starts, then `finished` |
| `params.url`        | The stream's WebSocket URL                          |
```json
  "event_type": "calling.call.stream",
  "params": {
    "call_id": "2e1e66e5-5d07-413d-9668-55542992eec0",
    "control_id": "my-stream",
    "state": "streaming",
    "url": "wss://example.com/audio-stream"
On a one-way stream, `streaming` means SignalWire started the stream, not that your server accepted
the connection, so confirm the connection from your server's output. The
[stream status callback reference][stream-status-callback] lists every field.
## Stream call audio via WebSocket (Relay)
Start a one-way stream on an answered call with `call.stream()`. It returns a stream action that
keeps the `control_id` for you; call its `stop()` method to end the stream. For a bidirectional
stream, pass a device of type `stream` to `call.connect()`. It must be the only device in the
list.
### Stream a call via WebSocket (Relay)
Dial your phone, start a stream, and keep the call open for twenty seconds while you talk. Call
setup follows [Place a call via WebSocket (Relay)][place-relay].
#### Run the call program
#### Python — Relay client
# Save as stream_call_relay.py and run: python stream_call_relay.py
import asyncio
client = RelayClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
    contexts=["default"],
async def main():
    async with client:
        call = await client.dial(
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
        await call.stream(url="<YOUR_AUDIO_STREAM_URL>")
        await call.play([{
            "type": "tts",
            "params": {"text": "Your call is being streamed. Say a few words."},
        await asyncio.sleep(20)
            if call.state != "ended":
                await call.hangup()
        await call.play(
            [{"type": "tts", "params": {"text": "Goodbye."}}],
        await call.wait_for_ended()
asyncio.run(main())
```typescript
// This sample also runs as JavaScript: save as stream-call-relay.mjs,
// then run: node stream-call-relay.mjs
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
  contexts: ["default"],
await client.connect();
    type: "phone",
    params: {
      timeout: 30,
  await call.stream("<YOUR_AUDIO_STREAM_URL>");
  await call.play([
    { type: "tts", text: "Your call is being streamed. Say a few words." },
  await new Promise((resolve) => setTimeout(resolve, 20_000));
  await call.play([{ type: "tts", text: "Goodbye." }], {
    onCompleted: async () => {
  await call.waitForEnded();
} finally {
  await client.disconnect();
#### Answer and speak
Answer your phone and say a few words. The stream server prints a `started` line, then a line for
each second of `inbound` audio. After twenty seconds you hear "Goodbye.", the call ends, and the
server prints `Stream stopped`. If it doesn't work, see
### Talk back on a bidirectional stream via WebSocket (Relay)
Run the [echo server](#run-an-echo-server-for-bidirectional-streams) instead of the stream server.
This program dials, plays an announcement, then connects the call to your server through a `stream`
device. `connect()` returns as soon as SignalWire accepts the request, so the program follows the
bridge through `calling.call.connect` events and hangs up when the bridge ends.
# Save as echo_call_relay.py and run: python echo_call_relay.py
import asyncio
from signalwire.relay import ConnectEvent, RelayClient
async def main():
    async with client:
            devices=[[{
                "type": "phone",
                "params": {
                    "timeout": 30,
            print(f"Stream bridge: {event.connect_state}")
            # The bridge ends when your server closes the connection.
            if event.connect_state in ("disconnected", "failed") and call.state != "ended":
                await call.hangup()
        announcement = await call.play([{
            "type": "tts",
            "params": {"text": "You are connected to the echo server. Speak, and you will hear yourself."},
        await announcement.wait()
        await call.connect(
            devices=[[{
                "type": "stream",
                "params": {
                    "codec": "PCMU",
                    "realtime": True,
                    "name": "echo",
asyncio.run(main())
```typescript
// This sample also runs as JavaScript: save as echo-call-relay.mjs,
// then run: node echo-call-relay.mjs
    type: "phone",
    params: {
      timeout: 30,
  call.on("calling.call.connect", async (event) => {
    const state = event.params.connect_state;
    console.log(`Stream bridge: ${state}`);
    // The bridge ends when your server closes the connection.
    if ((state === "disconnected" || state === "failed") && call.state !== "ended") {
  const announcement = await call.play([
    { type: "tts", text: "You are connected to the echo server. Speak, and you will hear yourself." },
  await announcement.wait();
  await call.connect([[{
    type: "stream",
    params: {
      codec: "PCMU",
      realtime: true,
} finally {
Answer and speak to hear your voice echoed back. The program prints `connected` while audio flows,
then `disconnected` when you hang up, or `failed` if SignalWire couldn't reach your URL.
The call stays bridged to your server until your server closes the connection or the call ends.
This program hangs up when the bridge ends; to keep the call going instead, play audio or connect
it elsewhere.
### Stop a stream via WebSocket (Relay)
Keep the action that `call.stream()` returns, and call its `stop()` method when your server has
what it needs. In the [Stream a call via WebSocket (Relay)](#stream-a-call-via-websocket-relay)
program, replace the stream and sleep lines with these:
**`Python — Relay client`**
```python title="Python — Relay client" {1,7}
stream = await call.stream(url="<YOUR_AUDIO_STREAM_URL>")
await call.play([{
    "type": "tts",
await stream.stop()
**`TypeScript — Relay client`**
```typescript title="TypeScript — Relay client" {1,6}
const stream = await call.stream("<YOUR_AUDIO_STREAM_URL>");
await call.play([
await stream.stop();
To stop a stream from a process that doesn't hold the call, use the REST
[`calling.stream.stop`](#stream-a-call-already-in-progress-via-rest) command with the stream's
`control_id`, which the action exposes as `control_id` in Python and `controlId` in TypeScript.
### Track a stream via WebSocket (Relay)
Stream events arrive in your code over the same connection:
| Event                  | What to read        | Typical action                               |
| `calling.call.stream`  | `state` is `streaming` when the stream starts, then `finished`; `control_id` identifies the stream                                               | Log it, or clean up when the stream finishes |
| `calling.call.connect` | `connect_state` moves from `connecting` to `connected` while audio flows, then `disconnected`, or `failed` if SignalWire couldn't reach your URL | Retry or hang up on `failed`                 |
To log one-way stream events, register a handler before you call `call.stream()`:
from signalwire.relay import StreamEvent
def on_stream(event: StreamEvent):
    print(f"Stream {event.control_id} is {event.state}")
call.on("calling.call.stream", on_stream)
call.on("calling.call.stream", (event) => {
  console.log(`Stream ${event.params.control_id} is ${event.params.state}`);
As with the SWML webhook, `streaming` means SignalWire started the stream, not that your server
accepted the connection.
## Stream a call already in progress via REST
When a process that doesn't hold the call needs to stream it, send the `calling.stream` command
with the answered call's ID, a `control_id`, and the stream's `url`. The call ID is the `id` from
the `dial` response, or the `call_id` delivered to your SWML endpoint or status webhook. To try it,
make a call from the [first run](#stream-a-call-via-swml), and while it's up, run this program with
the call ID your stream server printed. The [Server SDKs][server-sdks] wrap both commands; this program
streams the call for ten seconds, then sends `calling.stream.stop` with the same `control_id`:
#### Python — REST client
# Save as stream_rest.py and run: python stream_rest.py
import time
client = RestClient(
client.calling.stream(
    "<YOUR_CALL_ID>",
    url="<YOUR_AUDIO_STREAM_URL>",
    control_id="rest-stream",
time.sleep(10)
client.calling.stream_stop("<YOUR_CALL_ID>", control_id="rest-stream")
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as stream-rest.mjs,
// then run: node stream-rest.mjs
await client.calling.stream("<YOUR_CALL_ID>", {
  control_id: "rest-stream",
await new Promise((resolve) => setTimeout(resolve, 10_000));
await client.calling.streamStop("<YOUR_CALL_ID>", { control_id: "rest-stream" });
The server prints a second `started` line for the REST stream, and `Stream stopped` ten seconds
later while the call carries on. The other stream settings, such as `track`, `codec`, and
`status_url`, sit alongside `url`. In Python, pass `status_url` through `extras`.
The command doesn't echo the `control_id`, so keep the value you sent. To call the REST API
directly, send these requests to [Call commands][call-commands]:
### Request
POST https\://%7BYour\_Space\_Name%7D.signalwire.com/api/calling/calls
**`calling.stream`**
```curl calling.stream
     -d '{
  "command": "calling.stream",
  "id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "params": {
    "control_id": "stream-control-1",
    "url": "wss://example.com/stream",
    "track": "inbound_track"
```python calling.stream
import requests
url = "https://{your_space_name}.signalwire.com/api/calling/calls"
payload = {
    "params": {
headers = {
response = requests.post(url, json=payload, headers=headers, auth=("<project_id>", "<api_token>"))
print(response.json())
```javascript calling.stream
const url = 'https://{your_space_name}.signalwire.com/api/calling/calls';
const credentials = btoa("<project_id>:<api_token>");
const options = {
  method: 'POST',
  headers: {
    Authorization: `Basic ${credentials}`,
    'Content-Type': 'application/json'
  body: '{"command":"calling.stream","id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","params":{"control_id":"stream-control-1","url":"wss://example.com/stream","track":"inbound_track"}}'
  const response = await fetch(url, options);
  const data = await response.json();
  console.log(data);
} catch (error) {
  console.error(error);
```go calling.stream
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/calling/calls"
	payload := strings.NewReader("{\n  \"command\": \"calling.stream\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\",\n    \"url\": \"wss://example.com/stream\",\n    \"track\": \"inbound_track\"\n  }\n}")
	req, _ := http.NewRequest("POST", url, payload)
	req.SetBasicAuth("<project_id>", "<api_token>")
	req.Header.Add("Content-Type", "application/json")
	res, _ := http.DefaultClient.Do(req)
	defer res.Body.Close()
	body, _ := io.ReadAll(res.Body)
	fmt.Println(res)
	fmt.Println(string(body))
```ruby calling.stream
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/calling/calls")
http = Net::HTTP.new(url.host, url.port)
http.use_ssl = true
request = Net::HTTP::Post.new(url)
request.basic_auth("<project_id>", "<api_token>")
request["Content-Type"] = 'application/json'
request.body = "{\n  \"command\": \"calling.stream\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\",\n    \"url\": \"wss://example.com/stream\",\n    \"track\": \"inbound_track\"\n  }\n}"
response = http.request(request)
puts response.read_body
```java calling.stream
HttpResponse<String> response = Unirest.post("https://{your_space_name}.signalwire.com/api/calling/calls")
  .basicAuth("<project_id>", "<api_token>")
  .header("Content-Type", "application/json")
  .body("{\n  \"command\": \"calling.stream\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\",\n    \"url\": \"wss://example.com/stream\",\n    \"track\": \"inbound_track\"\n  }\n}")
  .asString();
```php calling.stream
<?php
require_once('vendor/autoload.php');
$client = new \GuzzleHttp\Client();
$response = $client->request('POST', 'https://{your_space_name}.signalwire.com/api/calling/calls', [
  'body' => '{
  "params": {
  'headers' => [
    'Content-Type' => 'application/json',
    'auth' => ['<project_id>', '<api_token>'],
echo $response->getBody();
```csharp calling.stream
using RestSharp;
using RestSharp.Authenticators;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/calling/calls");
client.Authenticator = new HttpBasicAuthenticator("<project_id>", "<api_token>");
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/json");
request.AddParameter("application/json", "{\n  \"command\": \"calling.stream\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\",\n    \"url\": \"wss://example.com/stream\",\n    \"track\": \"inbound_track\"\n  }\n}", ParameterType.RequestBody);
IRestResponse response = client.Execute(request);
```swift calling.stream
import Foundation
let credentials = Data("<project_id>:<api_token>".utf8).base64EncodedString()
let headers = [
  "Authorization": "Basic \(credentials)",
let parameters = [
  "params": [
] as [String : Any]
let postData = JSONSerialization.data(withJSONObject: parameters, options: [])
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/calling/calls")! as URL,
                                        cachePolicy: .useProtocolCachePolicy,
                                    timeoutInterval: 10.0)
request.httpMethod = "POST"
request.allHTTPHeaderFields = headers
request.httpBody = postData as Data
let session = URLSession.shared
let dataTask = session.dataTask(with: request as URLRequest, completionHandler: { (data, response, error) -> Void in
  if (error != nil) {
    print(error as Any)
  } else {
    let httpResponse = response as? HTTPURLResponse
    print(httpResponse)
dataTask.resume()
### Request
**`calling.stream.stop`**
```curl calling.stream.stop
     -d '{
  "command": "calling.stream.stop",
  "params": {
```python calling.stream.stop
import requests
payload = {
    "params": { "control_id": "stream-control-1" }
headers = {
```javascript calling.stream.stop
const options = {
  method: 'POST',
  headers: {
  body: '{"command":"calling.stream.stop","id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","params":{"control_id":"stream-control-1"}}'
  console.log(data);
} catch (error) {
```go calling.stream.stop
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	payload := strings.NewReader("{\n  \"command\": \"calling.stream.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\"\n  }\n}")
	fmt.Println(res)
```ruby calling.stream.stop
require 'uri'
require 'net/http'
http.use_ssl = true
request.body = "{\n  \"command\": \"calling.stream.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\"\n  }\n}"
```java calling.stream.stop
  .body("{\n  \"command\": \"calling.stream.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\"\n  }\n}")
  .asString();
```php calling.stream.stop
<?php
  'body' => '{
  "params": {
  'headers' => [
```csharp calling.stream.stop
using RestSharp;
request.AddParameter("application/json", "{\n  \"command\": \"calling.stream.stop\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"control_id\": \"stream-control-1\"\n  }\n}", ParameterType.RequestBody);
```swift calling.stream.stop
import Foundation
let headers = [
let parameters = [
  "params": ["control_id": "stream-control-1"]
] as [String : Any]
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
`calling.stream.stop` stops one-way streams only. A bidirectional stream ends when your server
closes the WebSocket.
## Handle stream audio on your server
The stream server prints what arrives; a real app decodes it. This section covers the messages in
full, the stream settings that shape the audio, and two servers you can swap in for the stream
server: one saves the audio and one processes it as it arrives. Both work with the calls above
unchanged. If your server also serves your SWML, keep its SWML lines and replace only the `/stream`
handler.
### Messages your server receives
SignalWire sends each message as JSON text. Every message has an `event` field that names its type,
so your server parses each message and branches on `event`. Every message after `connected` also
carries a `sequenceNumber`, a string counter that starts at `"1"` and increments with each message
on the connection.
| `event`     | When it arrives                                                   | Fields you use        |
| `connected` | Once, when the WebSocket opens                                    | None; wait for `start`        |
| `start`     | Once, before any audio                                            | `start.streamSid`, `start.callSid`, `start.tracks`, `start.mediaFormat`, `start.customParameters` |
| `media`     | For each frame of audio on each track                             | `media.track`, `media.chunk`, `media.timestamp`, `media.payload`                                  |
| `dtmf`      | When a key is pressed on the call                                 | `dtmf.digit`, one of `0` to `9`, `*`, `#`, or `A` to `D`; `dtmf.duration`                         |
| `mark`      | Bidirectional streams only, in reply to a `mark` your server sent | `mark.name`        |
| `stop`      | Once, when the stream stops or the call ends                      | None; finish your per-stream work        |
Set up your per-stream state on `start`:
```json
  "event": "start",
  "sequenceNumber": "1",
  "start": {
    "streamSid": "7d56cc11-536d-4a45-b4fb-ed3d55be843b",
    "callSid": "76ac3c36-56da-4a3e-a0d6-b5f8df6da9ad",
    "tracks": ["inbound", "outbound"],
    "customParameters": {"session_id": "abc123"},
    "mediaFormat": {"encoding": "audio/x-mulaw", "sampleRate": 8000, "channels": 2}
* `streamSid` identifies the stream. Each stream gets its own connection, so a server handling many
  calls tells them apart by it. Send it back on every message to a bidirectional stream.
* `callSid` is the ID of the call being streamed.
* `tracks` lists the tracks that will arrive: `inbound`, `outbound`, or both.
* `mediaFormat` describes the audio. `encoding` names the codec and `sampleRate` is in hertz.
  `channels` is the number of tracks; each `media` message still carries a single track.
* `customParameters` holds the custom parameters you set when you started the stream, if any.
Each `media` message carries one frame of one track:
```json
  "event": "media",
  "sequenceNumber": "42",
  "media": {
    "track": "inbound",
    "chunk": "41",
    "timestamp": "820",
    "payload": "<BASE64_AUDIO>"
* `track` is `inbound`, what the person on the call says, or `outbound`, what they hear.
* `chunk` counts frames on that track, starting at `"1"`.
* `timestamp` is in milliseconds and advances one frame per message. Both tracks share it, so use
  it rather than arrival order to align or mix them.
* `payload` is the base64-encoded audio.
### Choose a stream codec for the call
The stream has its own codec, separate from the codec the call uses. SignalWire converts the call's
audio to the stream's `codec` before sending it to your server, and on a bidirectional stream
converts the audio your server sends back into the call's codec. When you don't set `codec`, every
stream uses `PCMU`, 8 kHz G.711 µ-law, whatever the call type.
A stream can't carry more detail than the call does. Streaming a call that uses an 8 kHz codec at
16 kHz only resamples the same audio. Choose the stream codec from the call's own codec:
| The call's codec          | Audio the call carries | Stream `codec` to request                                       |
| `PCMU`, `PCMA`, or `G729` | 8 kHz narrowband       | `PCMU`, the default                                             |
| `G722` or `AMR-WB`        | 16 kHz wideband        | `L16@16000h`                                                    |
| `OPUS`                    | Up to 48 kHz           | `L16@16000h`, or `L16@24000h` when your speech model accepts it |
Where the call's codec comes from depends on the call type:
* Calls to and from phone numbers use a codec SignalWire sets, and the `codecs` settings in SWML
  have no effect on them. Stream them with the default `PCMU`.
* SIP calls use a codec from the list your SIP endpoint or [SIP Address][sip-addresses] allows. In
  SWML, `codecs` on [`answer`][swml-answer] or [`connect`][swml-connect] sets the codecs offered,
  for example `G722` when you want wideband audio to stream.
* Browser SDK calls use WebRTC, and browsers support `OPUS`, so these calls can carry wideband
  audio.
Request `L16` when your speech model expects linear PCM, at the sample rate the model wants, even
on an 8 kHz call. Other codecs and packet-time modifiers are listed in the
[`connect` reference][swml-connect]. SignalWire doesn't start a stream whose codec it doesn't accept.
| Stream `codec`   | `mediaFormat.encoding` | `mediaFormat.sampleRate` |
| `PCMU` (default) | `audio/x-mulaw`        | 8000                     |
| `L16@16000h`     | `audio/x-L16`          | 16000                    |
| `L16@24000h`     | `audio/x-L16`          | 24000                    |
A decoded `payload` is raw audio with no file header. Each frame is 20 ms by default: 160 bytes of
`PCMU`, or 640 bytes of `L16` at 16 kHz. `L16` audio is 16-bit signed samples in little-endian byte
order.
### Stream options: track and custom parameters
`track` selects which side of the conversation a one-way stream sends. `inbound_track`, the default,
is what the person on the call says; `outbound_track` is what they hear; `both_tracks` sends both,
with each `media` message labeled by track. A bidirectional stream sends only the `inbound` track.
Two more settings connect a WebSocket to the rest of your application:
* `custom_parameters` is an object you set when you start the stream. Its keys arrive as
  `start.customParameters`, so pass your own session or customer IDs here rather than in the URL.
* `authorization_bearer_token` is sent as `Authorization: Bearer <token>` on the WebSocket
  handshake. Reject connections that don't carry the token you expect.
### Save call audio to a file
This server writes each track to its own file as audio arrives, so memory use stays flat on a long
call. It closes the files when the stream stops or the connection drops. Run it in place of the
stream server, then make the call from your first run again. Add `track: both_tracks` to the stream to get
a second file with what the caller hears.
# Save as save_audio.py and run: python save_audio.py
import base64
import json
import uvicorn
app = FastAPI()
    files = {}
    try:
                for track in event["start"]["tracks"]:
                    files[track] = open(f"{stream_sid}-{track}.ulaw", "wb")
                print(f"Recording stream {stream_sid}")
                audio = base64.b64decode(event["media"]["payload"])
                files[event["media"]["track"]].write(audio)
                break
    finally:
        # Runs when the stream stops or the connection drops.
        for file in files.values():
            file.close()
            print(f"Saved {file.name}")
```javascript
// Save as save-audio.mjs and run: node save-audio.mjs
import { createWriteStream } from "node:fs";
const server = new WebSocketServer({ port: 8080, path: "/stream" });
server.on("connection", (socket) => {
  const files = new Map();
      const { streamSid, tracks } = event.start;
      for (const track of tracks) {
        files.set(track, createWriteStream(`${streamSid}-${track}.ulaw`));
      console.log(`Recording stream ${streamSid}`);
      files.get(event.media.track).write(Buffer.from(event.media.payload, "base64"));
  // Runs when the stream stops or the connection drops.
  socket.on("close", () => {
    for (const file of files.values()) {
      file.end();
      console.log(`Saved ${file.path}`);
When the call ends, the server prints `Saved` with each file's name. The files hold raw `PCMU`
audio with no header. Convert one to WAV with [ffmpeg](https://ffmpeg.org/) to play it:
```bash
ffmpeg -f mulaw -ar 8000 -ac 1 -i <STREAM_SID>-inbound.ulaw inbound.wav
For an `L16` stream, use `-f s16le` and the stream's sample rate, such as `-ar 16000`. Audio from
the moment before your server accepts the connection isn't streamed, so a file can start a fraction
of a second into the call.
### Buffer audio for processing
Speech-to-text services, voice agents, and analytics usually want audio in fixed-size pieces rather
than one `media` message at a time. Buffer each track by bytes, and hand a window to your processing
whenever the buffer holds enough audio. With `PCMU`, one byte is one sample, so a one-second window
is `sampleRate` bytes.
This server cuts one-second windows and measures each one's loudness. Replace `analyze` with your
processing, such as a request to a speech-to-text API.
# Save as process_audio.py and run: python process_audio.py
import base64
import json
import math
import uvicorn
app = FastAPI()
def mulaw_to_linear(value):
    # Decode one G.711 µ-law byte to a 16-bit sample.
    value = ~value & 0xFF
    exponent = (value >> 4) & 0x07
    sample = ((((value & 0x0F) << 3) + 0x84) << exponent) - 0x84
    return -sample if value & 0x80 else sample
def analyze(track, window):
    samples = [mulaw_to_linear(value) for value in window]
    rms = math.sqrt(sum(sample * sample for sample in samples) / len(samples))
    level = 20 * math.log10(max(rms, 1) / 32768)
    print(f"{track}: {level:.0f} dBFS")
    buffers = {}
    window_bytes = 8000
            window_bytes = event["start"]["mediaFormat"]["sampleRate"]
            buffers = {track: bytearray() for track in event["start"]["tracks"]}
            buffer = buffers[track]
            buffer += base64.b64decode(event["media"]["payload"])
            if len(buffer) >= window_bytes:
                analyze(track, bytes(buffer[:window_bytes]))
                del buffer[:window_bytes]
```javascript
// Save as process-audio.mjs and run: node process-audio.mjs
function mulawToLinear(byte) {
  // Decode one G.711 µ-law byte to a 16-bit sample.
  const value = ~byte & 0xff;
  const exponent = (value >> 4) & 0x07;
  const sample = ((((value & 0x0f) << 3) + 0x84) << exponent) - 0x84;
  return value & 0x80 ? -sample : sample;
function analyze(track, window) {
  let sum = 0;
  for (const byte of window) sum += mulawToLinear(byte) ** 2;
  const rms = Math.sqrt(sum / window.length);
  const level = 20 * Math.log10(Math.max(rms, 1) / 32768);
  console.log(`${track}: ${level.toFixed(0)} dBFS`);
  const buffers = new Map();
  let windowBytes = 8000;
      windowBytes = event.start.mediaFormat.sampleRate;
      for (const track of event.start.tracks) buffers.set(track, Buffer.alloc(0));
      let buffer = Buffer.concat([buffers.get(track), Buffer.from(event.media.payload, "base64")]);
      if (buffer.length >= windowBytes) {
        analyze(track, buffer.subarray(0, windowBytes));
        buffer = buffer.subarray(windowBytes);
      buffers.set(track, buffer);
Run it in place of the stream server, make the call from your first run again, and speak. The server prints
a line per second for each track, in dBFS, and the number rises toward zero while that side talks.
`analyze` runs inside the receive loop, which suits quick work like this. For slow work such as a
network request, hand each window to a background task, so the server keeps reading audio while it
waits. The decoder assumes the default `PCMU` codec. `L16` audio is already linear 16-bit PCM, so
skip the decoding and read two bytes per sample; a one-second window then holds `sampleRate * 2`
bytes.
## Send audio back on a bidirectional stream
On a bidirectional stream, SignalWire plays the audio your server sends into the call. The stream's
`realtime` setting decides what happens to audio your server sends faster than it plays:
* `realtime: false` (the default): SignalWire queues the audio and plays it in order. The queue is
  bounded; once it fills, new audio and marks are dropped.
* `realtime: true`: SignalWire keeps the queue short and drops new audio while it backs up, so
  playback stays close to live.
In either mode, send audio in small chunks at about the rate it plays. Sending an entire file at
once fills the queue, and a very large backlog ends the stream.
### Messages your server sends back
Your server sends JSON messages to SignalWire on the same connection. Include the `streamSid` from
the `start` message on each one, as the samples do.
#### media
Plays `media.payload`, base64-encoded raw audio in the stream's codec, into the call. SignalWire
queues these messages and plays them in order. Send raw audio only: a payload that includes a file
header, such as a WAV header, plays as noise.
```json
  "event": "media",
  "streamSid": "<STREAM_SID_FROM_START>",
  "media": { "payload": "<BASE64_AUDIO>" }
#### mark
Asks SignalWire to send a `mark` message with the same `mark.name` back once everything queued
before it has played, or right away if nothing is queued. Use it to learn when a prompt has
finished.
```json
  "event": "mark",
  "mark": { "name": "prompt-done" }
#### clear
Stops playback and empties the queue, including key presses your server queued, so you can
interrupt what the caller hears, for example when they start talking or press a key. Marks still
waiting in the queue come back at once, so after a `clear`, treat returned marks as acknowledgments
of cleared audio, not proof that the caller heard it.
```json
  "event": "clear",
#### dtmf
Sends `dtmf.digit`, one of `0` to `9`, `*`, `#`, or `A` to `D`, into the call as a key press. Add
`dtmf.duration` to set how long the key is held.
```json
  "event": "dtmf",
  "dtmf": { "digit": "1" }
### Play your own audio into the call
To play audio your server produces, such as a recorded prompt or text-to-speech output, convert it
to the stream's codec, split it into frames, and send each frame as a `media` message. This server
plays a prompt when the stream starts, lets the caller skip it with any key, and closes the
connection once the prompt has finished or been skipped.
The server sends 160-byte frames of 8 kHz µ-law audio about every 20 ms. After the final frame,
it sends a `mark` and waits for the acknowledgment before closing. On a key press, it stops
sending, sends `clear`, and closes. Receiving continues while audio plays.
Convert your prompt to raw 8 kHz µ-law with no header first, for example with
`ffmpeg -i prompt.mp3 -ar 8000 -ac 1 -f mulaw prompt.ulaw`, and save `prompt.ulaw` next to the server.
# Save as play_audio.py next to prompt.ulaw and run: python play_audio.py
import asyncio
import base64
import json
import uvicorn
app = FastAPI()
FRAME_BYTES = 160  # 20 ms of 8 kHz µ-law audio
with open("prompt.ulaw", "rb") as prompt_file:
    PROMPT = prompt_file.read()
async def play(websocket, stream_sid, audio):
    for offset in range(0, len(audio), FRAME_BYTES):
        frame = audio[offset:offset + FRAME_BYTES]
            "event": "media",
            "media": {"payload": base64.b64encode(frame).decode()},
        # Send one frame every 20 ms, the rate it plays.
        await asyncio.sleep(0.02)
    # SignalWire sends this mark back once everything before it has played.
        "event": "mark",
        "mark": {"name": "prompt-done"},
    stream_sid = None
    player = None
    try:
                player = asyncio.create_task(play(websocket, stream_sid, PROMPT))
            elif event["event"] == "dtmf" and player:
                # Any key skips the prompt: stop sending, then drop what is queued.
                player.cancel()
                await websocket.send_text(json.dumps({"event": "clear", "streamSid": stream_sid}))
                print(f"Prompt skipped with {event['dtmf']['digit']}")
                break
            elif event["event"] == "mark" and event["mark"]["name"] == "prompt-done":
                print("Prompt finished")
                break
    finally:
        if player:
            player.cancel()
    await websocket.close()
```javascript
// Save as play-audio.mjs next to prompt.ulaw and run: node play-audio.mjs
import { readFileSync } from "node:fs";
const FRAME_BYTES = 160; // 20 ms of 8 kHz µ-law audio
const FRAME_MS = 20;
const PROMPT = readFileSync("prompt.ulaw");
  let streamSid;
  let timer;
  function play(audio) {
    let offset = 0;
    // Send one frame every 20 ms, the rate it plays.
    timer = setInterval(() => {
      if (offset >= audio.length) {
        clearInterval(timer);
        // SignalWire sends this mark back once everything before it has played.
        socket.send(JSON.stringify({ event: "mark", streamSid, mark: { name: "prompt-done" } }));
        return;
      const frame = audio.subarray(offset, offset + FRAME_BYTES);
      socket.send(JSON.stringify({ event: "media", streamSid, media: { payload: frame.toString("base64") } }));
      offset += FRAME_BYTES;
    }, FRAME_MS);
      play(PROMPT);
    } else if (event.event === "dtmf") {
      // Any key skips the prompt: stop sending, then drop what is queued.
      socket.send(JSON.stringify({ event: "clear", streamSid }));
      console.log(`Prompt skipped with ${event.dtmf.digit}`);
      socket.close();
    } else if (event.event === "mark" && event.mark.name === "prompt-done") {
      console.log("Prompt finished");
      socket.close();
  socket.on("close", () => clearInterval(timer));
Run it in place of the echo server, then make your Talk back call again. You hear the announcement,
then your prompt. Let it finish, or press a key to cut it short; either way the server prints the
outcome and closes the connection, and the call hangs up.
## Troubleshoot call streaming
Find the symptom you see:
* **The call plays normally, but your server prints nothing.** SignalWire couldn't reach your stream
  URL, and the call carried on without a stream. Check that the URL begins with `wss://` and ends
  with `/stream`, and that the tunnel is running and points at port `8080`. A Relay program reports
  the same problem on a bidirectional stream as the `failed` connect state.
* **You hear an error or silence when you call your number.** SignalWire couldn't fetch your SWML.
  Rerun the `curl` check with the exact URL in the SWML Script, and confirm that the server and the
  tunnel are still running. A `401` means the password in the URL doesn't match the server's.
* **You hear your number's old behavior.** The number still points at another Resource. Open it
  under **Phone Numbers** and check **Inbound Call Settings**.
* **The phone never rings, or the call doesn't connect.** Check that `<YOUR_CALLER_ID>` is a number
  in your Space or a verified caller ID. A trial project only calls and receives calls from verified
  numbers.
* **You hear silence on a bidirectional stream.** Check that the call uses `connect`, or a `stream`
  device in Relay, rather than a one-way `stream`, which ignores anything your server sends.
* **Your prompt plays as loud static.** The audio has a file header, or isn't in the stream's codec.
  Convert it to raw 8 kHz µ-law, as [Play your own audio into the call](#play-your-own-audio-into-the-call)
  shows.
