> This page is for Platform.
# Queue calls
> Hold callers in a queue and connect each one to the next free agent with SWML or Relay, then track, remove, and manage waiting callers.
[prepare-calls]: /docs/platform/voice/make-and-receive-calls#prepare-for-your-first-call
[place-swml]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-swml
[place-relay]: /docs/platform/voice/make-and-receive-calls#place-a-call-via-websocket-relay
[answer-relay]: /docs/platform/voice/make-and-receive-calls#answer-a-call-via-websocket-relay
[swml-intro]: /docs/swml
[relay-guide]: /docs/server-sdks/guides/relay-client
[swml-enter-queue]: /docs/swml/reference/calling/enter-queue
[swml-connect]: /docs/swml/reference/calling/connect
[swml-switch]: /docs/swml/reference/calling/switch
[paging]: /docs/apis/paging
[rest-create-queue]: /docs/apis/rest/queues/create-queue
[rest-list-queues]: /docs/apis/rest/queues/list-queues
[rest-get-queue]: /docs/apis/rest/queues/get-queue
[rest-update-queue]: /docs/apis/rest/queues/update-queue
[rest-delete-queue]: /docs/apis/rest/queues/delete-queue
[rest-list-members]: /docs/apis/rest/queue-members/list-queue-members
[rest-get-member]: /docs/apis/rest/queue-members/retrieve-queue-member
A call queue holds callers until someone is free to talk to them. Callers hear hold music while
they wait, and each time an agent becomes available, SignalWire connects the agent to the caller
who has waited longest. This guide builds a dispatch line for Bayview Taxi: callers wait in a
`dispatch` queue, and the dispatcher, Ada, takes them one at a time.
## Choose an approach
Follow the section for your app's approach. Each is a complete way to build the queue, and the
sections don't build on each other:
* [SWML](#run-a-call-queue-via-swml): a document puts the caller in the queue with
  `enter_queue`, and a document on the agent's call takes the next caller with `connect`.
  SignalWire plays the hold music and enforces the wait limit.
* [WebSocket (Relay)](#run-a-call-queue-via-websocket-relay): your code puts an answered call in
  the queue and connects an agent's call to it, and handles queue events as they happen. Your
  code plays the hold music and decides when a caller has waited too long. No public URL is
  needed.
Both approaches use the same queues, which you can [create, inspect, and delete over REST](#monitor-and-manage-queues-via-rest) whichever one you choose.
## Prepare for call queues
Start with working call setup from [Make and receive calls][make-and-receive-calls]. To test a
queue you need two phones: one to call in and wait as the caller, and one to answer as the agent.
> **Trial projects only call and receive calls from verified numbers**
> A [trial project][trial-mode] only places calls to and receives calls from numbers you've
> purchased or verified. [Prepare for your first call][prepare-calls] shows how to verify the
> phones you'll test with.
| Value                        | Replace with        |
| `<YOUR_SPACE>`               | Your Space's subdomain in `<YOUR_SPACE>.signalwire.com`                                 |
| `<YOUR_PROJECT_ID>`          | Your Project ID        |
| `<YOUR_API_TOKEN>`           | Your API token with the **Voice** permission, used only in server code                  |
| `<YOUR_CALLER_ID>`           | Your SignalWire phone number, or a [verified caller ID][caller-id], in E.164 format     |
| `<YOUR_AGENT_NUMBER>`        | The phone the agent answers, in E.164 format                                            |
| `<YOUR_BASIC_AUTH_PASSWORD>` | A password you choose for your SWML server                                              |
| `<YOUR_HOLD_MUSIC_URL>`      | The public URL of an audio file to play while callers wait (Relay only)                 |
| `<YOUR_STATUS_WEBHOOK_URL>`  | An HTTPS endpoint you control that receives queue events                                |
| `<YOUR_QUEUE_ID>`            | A queue's ID, from [Create a queue](#create-a-queue) or [List queues][rest-list-queues] |
| `<YOUR_CALL_ID>`             | The call ID of a waiting caller, from a [queue event](#track-a-queue-via-swml)          |
## How call queues work
A queue is a named waiting line in your project. Two calls take part in every connection:
1. **The caller's call enters the queue.** SignalWire records the caller's position. With SWML,
   SignalWire also plays hold audio while the caller waits; with Relay, your code plays it. A
   caller can wait in only one queue at a time.
2. **The agent's call connects to the queue.** This is a separate call: an agent dialing in, or a
   call you place to the agent. When it connects to the queue, SignalWire takes the caller who
   has waited longest and bridges the two calls.
3. **The bridge ends.** When either side hangs up, the other side hangs up too, unless you gave it
   SWML to run next with `execute_after_queue`.
A caller can also leave without reaching an agent: they hang up, their wait limit runs out, or
your code removes them.
## Create a queue
> **Queues are created on first use**
> You don't have to create a queue first. When a call enters or connects to a queue name your
> project hasn't used, SignalWire creates that queue. Names are case-sensitive, so a misspelled name
> creates a separate, empty queue.
Create a queue ahead of time when you want to set it up before any call arrives, or to look up its
ID for the REST examples in this guide. The [Server SDKs][server-sdks] create one with a `name`
that's unique among your project's queues:
#### Python — REST client
# Save as create_queue.py and run: python create_queue.py
client = RestClient(
    project="<YOUR_PROJECT_ID>",
    token="<YOUR_API_TOKEN>",
queue = client.queues.create(name="dispatch")
print(queue["id"])
#### TypeScript — REST client
```typescript
// This sample also runs as JavaScript: save as create-queue.mjs,
// then run: node create-queue.mjs
  project: "<YOUR_PROJECT_ID>",
  token: "<YOUR_API_TOKEN>",
const queue = await client.queues.create({ name: "dispatch" });
console.log(queue.id);
To call the REST API directly, use [Create queue][rest-create-queue]:
### Request
POST https\://%7BYour\_Space\_Name%7D.signalwire.com/api/relay/rest/queues
```curl
curl -X POST https://{your_space_name}.signalwire.com/api/relay/rest/queues \
     -d '{}'
import requests
url = "https://{your_space_name}.signalwire.com/api/relay/rest/queues"
payload = {}
headers = {
response = requests.post(url, json=payload, headers=headers, auth=("<project_id>", "<api_token>"))
print(response.json())
```javascript
const url = 'https://{your_space_name}.signalwire.com/api/relay/rest/queues';
const credentials = btoa("<project_id>:<api_token>");
const options = {
  method: 'POST',
  headers: {
    Authorization: `Basic ${credentials}`,
    'Content-Type': 'application/json'
  body: '{}'
  const response = await fetch(url, options);
  const data = await response.json();
  console.log(data);
} catch (error) {
  console.error(error);
```go
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/relay/rest/queues"
	payload := strings.NewReader("{}")
	req, _ := http.NewRequest("POST", url, payload)
	req.SetBasicAuth("<project_id>", "<api_token>")
	req.Header.Add("Content-Type", "application/json")
	res, _ := http.DefaultClient.Do(req)
	defer res.Body.Close()
	body, _ := io.ReadAll(res.Body)
	fmt.Println(res)
	fmt.Println(string(body))
```ruby
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/relay/rest/queues")
http = Net::HTTP.new(url.host, url.port)
http.use_ssl = true
request = Net::HTTP::Post.new(url)
request.basic_auth("<project_id>", "<api_token>")
request["Content-Type"] = 'application/json'
request.body = "{}"
response = http.request(request)
puts response.read_body
```java
HttpResponse<String> response = Unirest.post("https://{your_space_name}.signalwire.com/api/relay/rest/queues")
  .basicAuth("<project_id>", "<api_token>")
  .header("Content-Type", "application/json")
  .body("{}")
  .asString();
```php
<?php
require_once('vendor/autoload.php');
$client = new \GuzzleHttp\Client();
$response = $client->request('POST', 'https://{your_space_name}.signalwire.com/api/relay/rest/queues', [
  'body' => '{}',
  'headers' => [
    'Content-Type' => 'application/json',
    'auth' => ['<project_id>', '<api_token>'],
echo $response->getBody();
```csharp
using RestSharp;
using RestSharp.Authenticators;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/relay/rest/queues");
client.Authenticator = new HttpBasicAuthenticator("<project_id>", "<api_token>");
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/json");
request.AddParameter("application/json", "{}", ParameterType.RequestBody);
IRestResponse response = client.Execute(request);
```swift
import Foundation
let credentials = Data("<project_id>:<api_token>".utf8).base64EncodedString()
let headers = [
  "Authorization": "Basic \(credentials)",
let parameters = [] as [String : Any]
let postData = JSONSerialization.data(withJSONObject: parameters, options: [])
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/relay/rest/queues")! as URL,
                                        cachePolicy: .useProtocolCachePolicy,
                                    timeoutInterval: 10.0)
request.httpMethod = "POST"
request.allHTTPHeaderFields = headers
request.httpBody = postData as Data
let session = URLSession.shared
let dataTask = session.dataTask(with: request as URLRequest, completionHandler: { (data, response, error) -> Void in
  if (error != nil) {
    print(error as Any)
  } else {
    let httpResponse = response as? HTTPURLResponse
    print(httpResponse)
dataTask.resume()
The response's `id` is the queue's ID, and `friendly_name` is the name that calls use to reach it.
A request with a name that's already in use fails with a validation error.
## Run a call queue via SWML
[`enter_queue`][swml-enter-queue] places the caller in a queue, and [`connect`][swml-connect]
with `to: "queue:<name>"` connects the agent's call to the caller at the front.
### Put a caller in a queue via SWML
Callers to your number hear a greeting, then wait in the `dispatch` queue for up to two minutes.
`wait_time` defaults to 180 seconds. SignalWire plays hold music until an agent connects; set
`wait_url` to an audio file to play your own.
The server below answers calls the way [Answer a call via SWML][answer-swml] does. Run it in place
of that server, with the same public URL and SWML Script.
#### Python — SWML builder
# Save as dispatch_queue.py and run: python dispatch_queue.py
service = SWMLService(
    name="dispatch-queue",
    route="/swml",
    port=3000,
    # signalwire-sdk 3.4.1 validates enter_queue against an outdated schema
    # that rejects every valid document, so validation is off for this service.
    # https://github.com/signalwire/signalwire-python/issues/112
    schema_validation=False,
    SWMLBuilder(service)
    .say("Thanks for calling Bayview Taxi. A dispatcher will be with you shortly.")
    .enter_queue(queue_name="dispatch", wait_time=120)
    # Runs only if the caller leaves the queue without reaching an agent.
    .say("All our dispatchers are busy. Please call back in a few minutes.")
    .hangup()
service.serve()
#### TypeScript — SWML builder
```typescript
// This sample also runs as JavaScript: save as dispatch-queue.mjs,
// then run: node dispatch-queue.mjs
  route: "/swml",
  port: 3000,
service
  .getBuilder()
  .enter_queue({ queue_name: "dispatch", wait_time: 120 })
  // Runs only if the caller leaves the queue without reaching an agent.
  .hangup();
await service.serve();
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - play:
        url: say:Thanks for calling Bayview Taxi. A dispatcher will be with you shortly.
    - enter_queue:
        queue_name: dispatch
        wait_time: 120
    - play:
        url: say:All our dispatchers are busy. Please call back in a few minutes.
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "play": { "url": "say:Thanks for calling Bayview Taxi. A dispatcher will be with you shortly." } },
      { "enter_queue": { "queue_name": "dispatch", "wait_time": 120 } },
      { "play": { "url": "say:All our dispatchers are busy. Please call back in a few minutes." } },
      { "hangup": {} }
From the phone you're using as the caller, call your SignalWire number. You hear the greeting,
then hold music. Stay on the line
for the next section, or wait two minutes to hear the busy message.
If you hear the busy message right after the greeting, the caller couldn't enter the queue. When
you set `wait_url`, check that it points at a public audio file in WAV, MP3, AIFF, GSM, or μ-law
format: a file that can't be played ends the wait.
### Connect an agent to a waiting caller via SWML
Call the agent with a document that connects to the queue. When Ada answers, she hears a short
announcement, then the caller who has waited longest. The call is placed as in
[Place a call via SWML][place-swml].
# Save as call_agent.py and run: python call_agent.py
swml = (
    SWMLBuilder(SWMLService(name="call-agent"))
    .say("Connecting you to the next caller in the dispatch queue.")
    .connect(to="queue:dispatch")
    # Runs only if no caller is waiting.
    .say("No callers are waiting.")
    .hangup()
    .build()
call = client.calling.dial(
    from_="<YOUR_CALLER_ID>",
    to="<YOUR_AGENT_NUMBER>",
    swml=swml,
print(call["id"])
```typescript
// This sample also runs as JavaScript: save as call-agent.mjs,
// then run: node call-agent.mjs
import { RestClient, SwmlBuilder } from "@signalwire/sdk";
const swml = new SwmlBuilder()
  .connect({ to: "queue:dispatch" })
  // Runs only if no caller is waiting.
  .hangup()
  .build();
const call = await client.calling.dial({
  to: "<YOUR_AGENT_NUMBER>",
  swml,
console.log(call.id);
#### YAML
```yaml
version: 1.0.0
sections:
  main:
    - play:
        url: say:Connecting you to the next caller in the dispatch queue.
    - connect:
        to: queue:dispatch
    - play:
        url: say:No callers are waiting.
    - hangup: {}
#### JSON
```json
  "version": "1.0.0",
  "sections": {
    "main": [
      { "play": { "url": "say:Connecting you to the next caller in the dispatch queue." } },
      { "connect": { "to": "queue:dispatch" } },
      { "play": { "url": "say:No callers are waiting." } },
      { "hangup": {} }
With the caller phone still on hold, run the program and answer the agent phone. After the
announcement, the hold music stops on the caller phone and the two phones can talk. Hang up either
phone to end both calls.
If the agent hears "No callers are waiting.", the queue was empty: `connect` doesn't wait for a
caller to arrive. It sets `connect_result` to `failed` and the document continues. Check that the
caller is still on hold and that both documents use the same queue name, including case.
A `queue:` connect takes exactly one destination and doesn't accept `call_state_url` or
`call_state_events`; track the queue with `status_url` on `enter_queue` instead. To run more SWML
on either call after the bridge ends, such as a short survey for the caller, set
`execute_after_queue` on `enter_queue` or on `connect` to a URL or an inline SWML document.
### Take a caller out of a queue via SWML
SWML has no instruction that removes a caller from a queue. A waiting caller leaves the queue in
one of three ways:
| How the caller leaves          | `queue_result` | What happens next                                                 |
| An agent connects to the queue | `connected`    | The calls are bridged, and the caller's document doesn't continue |
| `wait_time` runs out           | `timeout`      | The document continues with the next instruction                  |
| The caller hangs up            | `hangup`       | The call has ended                                                |
In the caller's document from
[Put a caller in a queue via SWML](#put-a-caller-in-a-queue-via-swml), the busy message plays for
any caller who leaves without reaching an agent. To give a different message per reason, put a
[`switch`][swml-switch] on `queue_result` after `enter_queue`.
To remove a caller before their wait runs out, end their call with the `calling.end`
[call command][call-commands], from any process. Get the caller's call ID from a
[queue event](#track-a-queue-via-swml). The [Server SDKs][server-sdks] send the command with
`end`:
# Save as remove_caller.py and run: python remove_caller.py
client.calling.end("<YOUR_CALL_ID>")
```typescript
// This sample also runs as JavaScript: save as remove-caller.mjs,
// then run: node remove-caller.mjs
await client.calling.end("<YOUR_CALL_ID>");
To call the REST API directly, send `calling.end` to [Call commands][call-commands]:
### Request
POST https\://%7BYour\_Space\_Name%7D.signalwire.com/api/calling/calls
**`calling.end`**
```curl calling.end
     -d '{
  "command": "calling.end",
  "id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "params": {
    "reason": "hangup"
**`calling.end`**
```python calling.end
import requests
url = "https://{your_space_name}.signalwire.com/api/calling/calls"
payload = {
    "params": { "reason": "hangup" }
headers = {
**`calling.end`**
```javascript calling.end
const url = 'https://{your_space_name}.signalwire.com/api/calling/calls';
const options = {
  method: 'POST',
  headers: {
  body: '{"command":"calling.end","id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","params":{"reason":"hangup"}}'
  console.log(data);
} catch (error) {
**`calling.end`**
```go calling.end
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/calling/calls"
	payload := strings.NewReader("{\n  \"command\": \"calling.end\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"reason\": \"hangup\"\n  }\n}")
	fmt.Println(res)
**`calling.end`**
```ruby calling.end
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/calling/calls")
http.use_ssl = true
request.body = "{\n  \"command\": \"calling.end\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"reason\": \"hangup\"\n  }\n}"
**`calling.end`**
```java calling.end
HttpResponse<String> response = Unirest.post("https://{your_space_name}.signalwire.com/api/calling/calls")
  .body("{\n  \"command\": \"calling.end\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"reason\": \"hangup\"\n  }\n}")
  .asString();
**`calling.end`**
```php calling.end
<?php
$response = $client->request('POST', 'https://{your_space_name}.signalwire.com/api/calling/calls', [
  'body' => '{
  "params": {
    "reason": "hangup"
  'headers' => [
**`calling.end`**
```csharp calling.end
using RestSharp;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/calling/calls");
request.AddParameter("application/json", "{\n  \"command\": \"calling.end\",\n  \"id\": \"3fa85f64-5717-4562-b3fc-2c963f66afa6\",\n  \"params\": {\n    \"reason\": \"hangup\"\n  }\n}", ParameterType.RequestBody);
**`calling.end`**
```swift calling.end
import Foundation
let headers = [
let parameters = [
  "params": ["reason": "hangup"]
] as [String : Any]
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/calling/calls")! as URL,
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
The caller's queue reports `leave`, and their call ends.
### Track a queue via SWML
Add `status_url` to the `enter_queue` instruction in
[Put a caller in a queue via SWML](#put-a-caller-in-a-queue-via-swml) to receive a JSON webhook
each time the caller enters or leaves the queue. The [webhooks guide][webhooks] covers endpoint
setup and local testing.
    .enter_queue(queue_name="dispatch", wait_time=120, status_url="<YOUR_STATUS_WEBHOOK_URL>")
```typescript
  .enter_queue({ queue_name: "dispatch", wait_time: 120, status_url: "<YOUR_STATUS_WEBHOOK_URL>" })
#### YAML
```yaml {4}
    - enter_queue:
        wait_time: 120
        status_url: <YOUR_STATUS_WEBHOOK_URL>
#### JSON
```json
  "enter_queue": {
    "wait_time": 120,
    "status_url": "<YOUR_STATUS_WEBHOOK_URL>"
Each webhook has `event_type: calling.call.queue` and reports what happened in `params.status`:
| `params.status` | Sent when        |
| `enqueue`       | The caller enters the queue        |
| `dequeue`       | An agent connects to the queue and takes this caller                                                         |
| `leave`         | The caller leaves without reaching an agent: `wait_time` runs out, the caller hangs up, or the call is ended |
A caller receives either `dequeue` or `leave`, never both. SignalWire doesn't send updates while
the caller waits, so to watch positions change, read the
[member list](#monitor-and-manage-queues-via-rest).
| Webhook field                                               | Value        |
| `params.call_id`                                            | The caller's call ID        |
| `params.id`                                                 | The queue's ID        |
| `params.name`                                               | The queue's name        |
| `params.position`                                           | The caller's position in the queue; `0` in `dequeue`                                       |
| `params.size`                                               | The number of callers in the queue; `0` in `dequeue`                                       |
| `params.avg_time`                                           | The average wait in the queue, in seconds                                                  |
| `params.enqueue_ts`, `params.dequeue_ts`, `params.leave_ts` | When the caller entered, was taken, or left, in Unix microseconds; `0` when not applicable |
The [`enter_queue` reference][swml-enter-queue] has a complete payload for each event. After
`enter_queue`, the caller's document can also read `entry_position` and `entry_size`, the
caller's position and the queue's size when they entered, and `wait_time`, how many seconds a
caller who left without reaching an agent waited.
## Run a call queue via WebSocket (Relay)
With Relay, your code places an answered call in a queue, then connects an agent's call to the
queue with a `queue` device. Your server code must play the hold music and decide when the
caller has waited too long: in Relay, SignalWire plays no hold audio and doesn't apply a wait
limit.
### Put a caller in a queue via WebSocket (Relay)
This handler answers each call, plays a greeting, places the caller in the `dispatch` queue, and
loops hold music. It waits for the caller to leave the queue: a `dequeue` event means an agent took
them, and `leave` means they hung up. If neither happens within two minutes, the handler removes
the caller from the queue, plays a busy message, and hangs up.
The handler receives calls the way [Answer a call via WebSocket (Relay)][answer-relay] does. Run it
in place of that handler, with the same topic and Relay Application.
#### Python — Relay client
# Save as dispatch_queue_relay.py and run: python dispatch_queue_relay.py
import asyncio
from signalwire.relay.event import QueueEvent
GREETING = "Thanks for calling Bayview Taxi. A dispatcher will be with you shortly."
BUSY = "All our dispatchers are busy. Please call back in a few minutes."
client = RelayClient(
    contexts=["inbound-calling"],
@client.on_call
async def handle_call(call):
    left_queue = asyncio.get_running_loop().create_future()
    def on_queue(event: QueueEvent):
        print(f"Queue: {event.status}, position {event.position}")
        if event.status in ("dequeue", "leave") and not left_queue.done():
            left_queue.set_result(event.status)
    call.on("calling.call.queue", on_queue)
    await call.answer()
    greeting = await call.play([{"type": "tts", "params": {"text": GREETING}}])
    await greeting.wait()
    await call.queue_enter(queue_name="dispatch")
    hold_music = await call.play(
        [{"type": "audio", "params": {"url": "<YOUR_HOLD_MUSIC_URL>"}}], loop=0
    try:
        await asyncio.wait_for(left_queue, timeout=120)
        await hold_music.stop()
    except asyncio.TimeoutError:
        # No agent took the caller within two minutes.
        await call.queue_leave(queue_name="dispatch")
        busy = await call.play([{"type": "tts", "params": {"text": BUSY}}])
        await busy.wait()
        await call.hangup()
    await call.wait_for_ended()
client.run()
```typescript
// Save as dispatch-queue-relay.mts and run: npx tsx dispatch-queue-relay.mts
import { RelayClient, QueueEvent } from "@signalwire/sdk";
const GREETING = "Thanks for calling Bayview Taxi. A dispatcher will be with you shortly.";
const BUSY = "All our dispatchers are busy. Please call back in a few minutes.";
  contexts: ["inbound-calling"],
client.onCall(async (call) => {
  const leftQueue = new Promise<string>((resolve) => {
    call.on("calling.call.queue", (event) => {
      const { status, position } = event as QueueEvent;
      console.log(`Queue: ${status}, position ${position}`);
      if (status === "dequeue" || status === "leave") resolve(status);
  await call.answer();
  const greeting = await call.play([{ type: "tts", text: GREETING }]);
  await greeting.wait();
  await call.queueEnter("dispatch");
  const holdMusic = await call.play([{ type: "audio", url: "<YOUR_HOLD_MUSIC_URL>" }], { loop: 0 });
  const timeout = new Promise<string>((resolve) => setTimeout(() => resolve("timeout"), 120_000));
  const outcome = await Promise.race([leftQueue, timeout]);
  await holdMusic.stop();
  if (outcome === "timeout") {
    // No agent took the caller within two minutes.
    await call.queueLeave("dispatch");
    const busy = await call.play([{ type: "tts", text: BUSY }]);
    await busy.wait();
    await call.hangup();
  await call.waitForEnded();
await client.run();
then your hold music, and the handler logs `Queue: enqueue, position 1`. Stay on the line for the next section.
If you hear silence instead of music, check that `<YOUR_HOLD_MUSIC_URL>` is a public audio file.
If no `Queue:` line appears, check that the handler registers its `calling.call.queue` listener
before the call enters the queue.
### Connect an agent to a waiting caller via WebSocket (Relay)
Dial the agent, then connect the agent's call with a `queue` device that names the queue. SignalWire takes
the caller who has waited longest and bridges the two calls. Watch `calling.call.connect` events on
the agent's call to learn the outcome. The call is placed as in
[Place a call via WebSocket (Relay)][place-relay].
# Save as call_agent_relay.py and run: python call_agent_relay.py
import asyncio
from signalwire.relay.event import ConnectEvent
    contexts=["default"],
async def main():
    async with client:
        call = await client.dial(
            devices=[[{
                "type": "phone",
                "params": {
                    "to_number": "<YOUR_AGENT_NUMBER>",
                    "timeout": 30,
            if call.state != "ended":
                await call.hangup()
            print(f"Connect: {event.connect_state}")
            if event.connect_state == "failed":
                # The queue was empty.
                await call.play(
                    [{"type": "tts", "params": {"text": "No callers are waiting."}}],
        intro = await call.play([{
            "type": "tts",
            "params": {"text": "Connecting you to the next caller in the dispatch queue."},
        await intro.wait()
        await call.connect(
            devices=[[{"type": "queue", "params": {"queue_name": "dispatch"}}]],
asyncio.run(main())
```typescript
// Save as call-agent-relay.mts and run: npx tsx call-agent-relay.mts
import { RelayClient, ConnectEvent } from "@signalwire/sdk";
  contexts: ["default"],
await client.connect();
    type: "phone",
    params: {
      to_number: "<YOUR_AGENT_NUMBER>",
      timeout: 30,
  call.on("calling.call.connect", async (event) => {
    const state = (event as ConnectEvent).connectState;
    console.log(`Connect: ${state}`);
    if (state === "failed") {
      // The queue was empty.
      await call.play([{ type: "tts", text: "No callers are waiting." }], {
        onCompleted: async () => {
  const intro = await call.play([
    { type: "tts", text: "Connecting you to the next caller in the dispatch queue." },
  await intro.wait();
  await call.connect([[{ type: "queue", params: { queue_name: "dispatch" } }]]);
} finally {
  await client.disconnect();
announcement, the program logs `Connect: connecting`, then `Connect: connected`. The caller's
handler logs `Queue: dequeue`, stops the hold music, and the two phones can talk. Hang up either phone to end both calls.
If the agent hears "No callers are waiting." and the program logs `Connect: failed`, the queue was empty:
connecting doesn't wait for a caller to arrive. Check that the caller is still on hold and that
both programs use the same queue name, including case.
### Take a caller out of a queue via WebSocket (Relay)
Leaving the queue removes the caller and sends a `leave` event. The call stays up, so your code
decides what the caller hears next. In
[Put a caller in a queue via WebSocket (Relay)](#put-a-caller-in-a-queue-via-websocket-relay), the
handler leaves the queue when the caller's two minutes run out, then plays the busy message. Leave
the queue the same way to offer a callback, send the caller to voicemail, or move them to another
queue.
A caller who hangs up leaves the queue on their own, and also sends a `leave` event. To remove a
caller from a process that doesn't hold their call, end the call with the REST `calling.end`
command, as in [Take a caller out of a queue via SWML](#take-a-caller-out-of-a-queue-via-swml).
### Track a queue via WebSocket (Relay)
Register a `calling.call.queue` handler on the caller's call before the call enters the queue, as
the caller's handler does. The event carries the same fields as the
[SWML webhooks](#track-a-queue-via-swml): its `status` is `enqueue`, `dequeue`, or `leave`, and it
reports the queue's ID and name, the caller's position, and the queue's size. To receive the same
events at a webhook instead, pass a status URL when the call enters the queue. The
[Relay client guide][relay-guide] covers event listeners in depth.
## Monitor and manage queues via REST
The REST API reads and changes the same queues that SWML and Relay calls use. Calls reach a queue
by name, and the REST API addresses it by ID. Use it to build a wallboard, decide which caller to
handle next, or rename and clean up queues. The [Server SDKs][server-sdks] cover each operation:
| Task                                | REST API                                |
| Create a queue                      | [Create queue][rest-create-queue]       |
| List queues                         | [List queues][rest-list-queues]         |
| Get one queue                       | [Get queue][rest-get-queue]             |
| List the callers waiting in a queue | [List queue members][rest-list-members] |
| Get one waiting caller              | [Get queue member][rest-get-member]     |
| Rename a queue                      | [Update queue][rest-update-queue]       |
| Delete an empty queue               | [Delete queue][rest-delete-queue]       |
### Get a queue's size and wait time via REST
This program lists your project's queues with their IDs, how many callers each holds, and how
long those callers have waited on average. Use it to find the ID of a queue that a call created by
name:
# Save as list_queues.py and run: python list_queues.py
for queue in client.queues.list()["data"]:
    print(
        f"{queue['friendly_name']} ({queue['id']}): {queue['current_size']} waiting, "
        f"average wait {queue['average_wait_time']} s"
```typescript
// This sample also runs as JavaScript: save as list-queues.mjs,
// then run: node list-queues.mjs
const queues = await client.queues.list();
for (const queue of queues.data) {
  console.log(
    `${queue.friendly_name} (${queue.id}): ${queue.current_size} waiting, ` +
      `average wait ${queue.average_wait_time} s`,
To read one queue whose ID you know, use `get` or [Get queue][rest-get-queue]:
### Request
GET https\://%7BYour\_Space\_Name%7D.signalwire.com/api/relay/rest/queues/\{id}
```curl
curl https://{your_space_name}.signalwire.com/api/relay/rest/queues/id \
import requests
url = "https://{your_space_name}.signalwire.com/api/relay/rest/queues/id"
response = requests.get(url, auth=("<project_id>", "<api_token>"))
```javascript
const url = 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/id';
const options = {method: 'GET', headers: {Authorization: `Basic ${credentials}`}};
  console.log(data);
} catch (error) {
```go
package main
import (
	"fmt"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/relay/rest/queues/id"
	req, _ := http.NewRequest("GET", url, nil)
	fmt.Println(res)
```ruby
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/relay/rest/queues/id")
http.use_ssl = true
request = Net::HTTP::Get.new(url)
```java
HttpResponse<String> response = Unirest.get("https://{your_space_name}.signalwire.com/api/relay/rest/queues/id")
  .asString();
```php
<?php
$response = $client->request('GET', 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/id', [
  'headers' => [
```csharp
using RestSharp;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/relay/rest/queues/id");
var request = new RestRequest(Method.GET);
```swift
import Foundation
let headers = ["Authorization": "Basic \(credentials)"]
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/relay/rest/queues/id")! as URL,
request.httpMethod = "GET"
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
### Response (200)
```json
  "id": "aae131db-214c-46f5-88b6-92004f8467cf",
  "project_id": "c6c4679b-716a-456a-9e41-a03821005005",
  "friendly_name": "test",
  "max_size": 5,
  "current_size": 0,
  "average_wait_time": 0,
  "uri": "/api/relay/rest/queues/aae131db-214c-46f5-88b6-92004f8467cf",
  "date_created": "2024-01-15T09:30:00Z",
  "date_updated": "2024-01-15T09:30:00Z"
`friendly_name` is the name that calls use to reach the queue, and `id` is what every REST request
about it uses. `current_size` counts the callers waiting now, and `average_wait_time` is how long,
in seconds, those callers have waited on average: `0` when the queue is empty.
List queues returns your newest queues first, 50 to a page. Follow `links.next` in the response for
the next page, as [Paging][paging] describes.
### List the callers waiting in a queue via REST
This program prints every caller waiting in a queue, next caller first, with their position and
how long they've waited. The list returns the most recent callers first, 50 to a page, so the
program follows `links.next` through every page, as [Paging][paging] describes, then sorts by
position:
# Save as list_waiting.py and run: python list_waiting.py
from urllib.parse import parse_qsl, urlsplit
members = []
params = {}
while True:
    page = client.queues.list_members("<YOUR_QUEUE_ID>", **params)
    members.extend(page["data"])
    next_url = page.get("links", {}).get("next")
    if not next_url:
        break
    params = dict(parse_qsl(urlsplit(next_url).query))
for member in sorted(members, key=lambda m: m["position"]):
    print(f"{member['position']}: waiting {member['wait_time']} s")
```typescript
// This sample also runs as JavaScript: save as list-waiting.mjs,
// then run: node list-waiting.mjs
const members = [];
let params = {};
while (true) {
  const page = await client.queues.listMembers("<YOUR_QUEUE_ID>", params);
  members.push(...page.data);
  const nextUrl = page.links?.next;
  if (!nextUrl) break;
  params = Object.fromEntries(new URLSearchParams(nextUrl.split("?")[1]));
members.sort((a, b) => a.position - b.position);
for (const member of members) {
  console.log(`${member.position}: waiting ${member.wait_time} s`);
### Request
GET https\://%7BYour\_Space\_Name%7D.signalwire.com/api/relay/rest/queues/\{queue\_id}/members
```curl
curl https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members \
import requests
url = "https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members"
```javascript
const url = 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members';
  console.log(data);
} catch (error) {
```go
package main
import (
	"fmt"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members"
	fmt.Println(res)
```ruby
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members")
http.use_ssl = true
```java
HttpResponse<String> response = Unirest.get("https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members")
  .asString();
```php
<?php
$response = $client->request('GET', 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members', [
  'headers' => [
```csharp
using RestSharp;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members");
```swift
import Foundation
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members")! as URL,
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
### Response (200)
```json
  "links": {
    "self": "string",
    "first": "string",
    "next": "string",
    "prev": "string"
  "data": [
      "call_id": "596e2dea-a269-4765-a0b4-01b82d11c120",
      "project_id": "d421473b-d696-449a-a1a1-4ddd83d2d0e5",
      "queue_id": "596e2dea-a269-4765-a0b4-01b82d11c120",
      "position": 2,
      "uri": "/api/relay/rest/queues/596e2dea-a269-4765-a0b4-01b82d11c120/members/596e2dea-a269-4765-a0b4-01b82d11c120",
      "wait_time": 172975,
      "date_enqueued": "2024-01-15T09:30:00Z"
A caller at `position` `1` has waited longest and is the next caller an agent's call connects to.
`wait_time` is how long the caller has waited, in seconds.
A member's `call_id` identifies them in this API only: it isn't the call ID that queue events
report or that `calling.end` takes. To check one member again later, pass the `call_id` from the
list to [Get queue member][rest-get-member]:
### Request
GET https\://%7BYour\_Space\_Name%7D.signalwire.com/api/relay/rest/queues/\{queue\_id}/members/\{id}
```curl
curl https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id \
import requests
url = "https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id"
```javascript
const url = 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id';
  console.log(data);
} catch (error) {
```go
package main
import (
	"fmt"
	"net/http"
	"io"
func main() {
	url := "https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id"
	fmt.Println(res)
```ruby
require 'uri'
require 'net/http'
url = URI("https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id")
http.use_ssl = true
```java
HttpResponse<String> response = Unirest.get("https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id")
  .asString();
```php
<?php
$response = $client->request('GET', 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id', [
  'headers' => [
```csharp
using RestSharp;
var client = new RestClient("https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id");
```swift
import Foundation
let request = NSMutableURLRequest(url: NSURL(string: "https://{your_space_name}.signalwire.com/api/relay/rest/queues/queue_id/members/id")! as URL,
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
### Update or delete a queue via REST
Update a queue to rename it:
# Save as update_queue.py and run: python update_queue.py
queue = client.queues.update("<YOUR_QUEUE_ID>", name="airport-dispatch")
print(queue["friendly_name"])
```typescript
// This sample also runs as JavaScript: save as update-queue.mjs,
// then run: node update-queue.mjs
const queue = await client.queues.update("<YOUR_QUEUE_ID>", { name: "airport-dispatch" });
console.log(queue.friendly_name);
### Request
PUT https\://%7BYour\_Space\_Name%7D.signalwire.com/api/relay/rest/queues/\{id}
```curl
curl -X PUT https://{your_space_name}.signalwire.com/api/relay/rest/queues/id \
     -d '{}'
import requests
payload = {}
headers = {
response = requests.put(url, json=payload, headers=headers, auth=("<project_id>", "<api_token>"))
```javascript
const options = {
  method: 'PUT',
  headers: {
  body: '{}'
  console.log(data);
} catch (error) {
```go
package main
import (
	"fmt"
	"strings"
	"net/http"
	"io"
func main() {
	req, _ := http.NewRequest("PUT", url, payload)
	fmt.Println(res)
```ruby
require 'uri'
require 'net/http'
http.use_ssl = true
request = Net::HTTP::Put.new(url)
request.body = "{}"
```java
HttpResponse<String> response = Unirest.put("https://{your_space_name}.signalwire.com/api/relay/rest/queues/id")
  .body("{}")
  .asString();
```php
<?php
$response = $client->request('PUT', 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/id', [
  'body' => '{}',
  'headers' => [
```csharp
using RestSharp;
var request = new RestRequest(Method.PUT);
```swift
import Foundation
let headers = [
request.httpMethod = "PUT"
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
A new name must be unique among your project's queues. Renaming doesn't change the documents and
programs that use the old name: the next call that enters or connects to the old name creates a new
queue with it.
To delete a queue, replace the last two lines of that program with the line below, or use
[Delete queue][rest-delete-queue]. The queue must be empty: a queue with callers waiting returns
`400 Bad Request` and stays in place.
client.queues.delete("<YOUR_QUEUE_ID>")
```typescript
await client.queues.delete("<YOUR_QUEUE_ID>");
### Request
DELETE https\://%7BYour\_Space\_Name%7D.signalwire.com/api/relay/rest/queues/\{id}
```curl
curl -X DELETE https://{your_space_name}.signalwire.com/api/relay/rest/queues/id \
import requests
response = requests.delete(url, auth=("<project_id>", "<api_token>"))
```javascript
const options = {method: 'DELETE', headers: {Authorization: `Basic ${credentials}`}};
  console.log(data);
} catch (error) {
```go
package main
import (
	"fmt"
	"net/http"
	"io"
func main() {
	req, _ := http.NewRequest("DELETE", url, nil)
	fmt.Println(res)
```ruby
require 'uri'
require 'net/http'
http.use_ssl = true
request = Net::HTTP::Delete.new(url)
```java
HttpResponse<String> response = Unirest.delete("https://{your_space_name}.signalwire.com/api/relay/rest/queues/id")
  .asString();
```php
<?php
$response = $client->request('DELETE', 'https://{your_space_name}.signalwire.com/api/relay/rest/queues/id', [
  'headers' => [
```csharp
using RestSharp;
var request = new RestRequest(Method.DELETE);
```swift
import Foundation
request.httpMethod = "DELETE"
  if (error != nil) {
    print(error as Any)
  } else {
    print(httpResponse)
dataTask.resume()
