> This page is for Platform.
# Auto Top-Up
> How Auto Top-Up funds your SignalWire balance and when your card is charged.
Adding a payment method to your Space turns on Auto Top-Up.
When your balance falls below a threshold you set, SignalWire charges the card you chose and adds the funds to your balance.
This keeps calls and messages running, and keeps recurring charges such as phone numbers paid.
> **Auto Top-Up is required**
> Auto Top-Up is required for any account with active SignalWire resources.
> You can change the amount, the threshold, and the card that funds it.
## When you are charged
| Setting       | Default | Limits                             |
| Threshold     | `$5`    | Minimum `$5`, maximum `$1,000,000` |
| Top-up amount | `$10`   | Minimum `$10`                      |
The charge is normally the top-up amount.
If topping up by that amount would still leave your balance at or below the threshold, SignalWire charges enough to clear the threshold and add the top-up amount on top.
The amount charged can therefore be larger than the amount you configured.
With a threshold of `$50` and a top-up amount of `$10`, a balance that falls to `$5` is charged `$55`.
Auto Top-Up charges at most once every six hours.
A Space that spends faster than that can reach a zero balance between charges and lose service until the next one, so set a top-up amount that covers six hours of your own traffic.
Some features require Auto Top-Up to be active before you can use them.
Registering a campaign with [The Campaign Registry](/docs/platform/messaging/campaign-registry) is one of them, and returns the `auto_top_up_deactivated` error while Auto Top-Up is off.
## Change your settings
Open **Billing → Low Balance Settings** in the Dashboard to change the top-up amount, the threshold, and which card funds Auto Top-Up.
## Remove the card that funds Auto Top-Up
A card cannot be removed while it is your Auto Top-Up payment method. To remove it:
### Add another card
Add the replacement payment method to your Space.
### Point Auto Top-Up at the new card
In Low Balance Settings, select the new card as your Auto Top-Up payment method and save.
### Remove the original card
The original card can now be removed from the Payment Methods page.
## If a charge fails
If the charge is declined, or no valid card is on file to charge, SignalWire turns Auto Top-Up off and emails your Space administrators.
Adding a payment method or topping up your balance manually turns it back on.
