# Voicemail Recording
> Call Flow Builder node to record voicemail messages.
This node uses the asynchronous recording method to record a voicemail.
Reference the recording URL in other nodes in the Flow using the variable `%{record_url}`.
You can also access the recording URL from the call log details in your [Relay Space](https://my.signalwire.com?page=relay).
## **Node Settings**
**`Stereo`** `boolean`
Record in stereo. Toggle this on to separate the two legs of the call recording into left and right channels.\
**Default Value:** `Toggled Off`
**`Beep`** `boolean`
Play a beep before recording starts. \
**`Terminators`** `string`
DTMF digits that will stop the recording. Multiple DTMF tones can be added by being seperated by a comma.\
**Default Value:** `None`\
**Possible Values:** Digits `0-9`, `*`, `#`
**`Maximum Recording Length`** `integer`
The maximum length of the recording in seconds.\
&#x20;**Possible Values:** `1-3600` seconds
**`Initial Timeout`** `integer`
The time in seconds to wait for the first DTMF digit before starting the recording.\
**Possible Values:** `1-99` seconds
**`End Silence Timeout`** `integer`
The time in seconds to wait for the end of the call before ending the recording.\
**`Format`** `string`
The format of the recording.\
**Possible Values:** `wav`, `mp3`
## **Examples**
### Simple voicemail with goodbye message
For a traditional voicemail experience, we recommend pairing the Voicemail Recording node with a
[Play Audio or TTS](/docs/call-flow-builder/reference/play-audio-or-tts) node and including a beep before recording.
Including a terminator (in this case, a `#` sign) will allow nodes to run after the caller is finished leaving their voicemail.
Route **Forward to Phone**'s **No Answer**, **Busy**, **Decline**, and **Error** outputs to an unavailable-message **Play Audio or TTS** node → **Voicemail Recording** → a thank-you **Play Audio or TTS** node. Enable the recording beep, use `#` as the terminator, and save WAV format.
### Record voicemail and send recording URL as a POST request
You can pair this node with a [Request](/docs/call-flow-builder/reference/request) node to send the recording URL to the webhook of your choice.
Please note that any later recordings in the Flow will overwrite the `%{record_url}` variable,
so the Request node should immediately follow this Voicemail Recording node or use
[Set Variables](/docs/call-flow-builder/reference/set-variables) to save this URL for a later request.
Use the same failed-forward branches for **Play Audio or TTS** → **Voicemail Recording** → **Request**. Configure the Request as POST with a body containing `New voicemail from %{call.from} calling into %{call.to}. Recording URL: %{record_url}`.
### Record voicemail and send recording URL as SMS
You may want to be notified about a new voicemail with an SMS.
You can follow the Voicemail Recording node with a Send SMS node and again access call data and the recording URL with
the `{call.}` and `{record_url}` variables.
Use the same failed-forward branches for **Play Audio or TTS** → **Voicemail Recording** → **Send SMS**. Include `%{call.to}`, `%{call.from}`, and `%{record_url}` in the notification text.
