title: Unset Variables
description: Call Flow Builder node to unset variables in the call flow.
slug: /reference/unset-variables
max-toc-depth: 3
The Unset Variables is used to clear any variable that was set using [Set Variables](/docs/call-flow-builder/reference/set-variables).
All currently set variables are populated in the dropdown menu.
You can unset multiple variables in one node by selecting multiple variables from the dropdown menu.
## Node Settings
The variables that you want to unset. Variables will show in the drop-down menu if they are set in the call flow. Variables are set by [Set Variables](/docs/call-flow-builder/reference/set-variables) node.
## Example
In the example below, we answer the call and set a variable `from_number` with the value
of the caller's number. We then play a message to the caller and unset the `from_number` variable.
